Staro 19.03.2013., 08:36   #1981
Dottore
Dottore's Avatar
Postovi: 7,660
Samsung Android mobiteli - root,custom romovi,fleshanje,original romovi etc.
Ispravljeno. Sjedi dolje, jedinica vruća. S3 je i9300
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 21.03.2013., 12:26   #1982
mujica
črna jetra
mujica's Avatar
Postovi: 453
trebal bi malu pomoc sa samsungom galaxy ace, nesto se sprtljalo i sad nema tipkovnice, naravno nemrem se ni ulogirat na googleplay da skinem novu tipkovnicu... moze se to kak prek kompa nakalemit gore? btw verzija je 4.0.4
Avoid hangovers: stay drunk.
mujica je offline   Reply With Quote
Staro 21.03.2013., 15:17   #1983
zgmmax
zgmmax's Avatar
Postovi: 1,673
pa na kompu odes na google play i nadjes tipkovnicu i on ti to automatski skine i instalira na tvoj mob
Staro 21.03.2013., 15:26   #1984
trpi
kako vratiti note 2 sve na stock unrooted sa 0 binary counterom? popizdit cu od silnog flashanja romova i kernela, a kad pogledam nista korisno nisam dobio samo se opterecujem pizdarijama
trenutno sam na omega romu, perseus kernel, twrp recovery, binary counter na 5
mislio sam,
-backup u twrp, spremiti na microsd
-reset trianglom
-u twrp recoveryu wipe cache, wipe dalvik cache, factory reset i zbrisati sve zivo
-skinuti firmware sa sammobile i flashati odinom
jel to ok i hoce li nakon tog postupka biti 0 binary, citao sam nesto da cim se upali mobitel sa custom recoveryem binary ode na 1
pitanje br2, sta je CSC kod firmwarea,
mogu skinuti CROATIA TRA sa CSCom N7100OXFDMA1 ili CROATIA TMOBILE(tmobile mreza sam)sa CSCom N7100CRODMA2, mobitel je kupljen u tele2 i tamo ima garanciju. jel ima kakve veze to, koji skinuti
Zadnje izmijenjeno od: trpi. 21.03.2013. u 15:44.
Staro 22.03.2013., 00:52   #1985
spawn
spawn's Avatar
Postovi: 8,426
Re: Samsung Android mobiteli - root,custom romovi,fleshanje,original romovi etc.
Kad resetiras binary odmah u download mode i stavi TWO firmware ako nadjes. TRA je HR fw za slobodnu prodaju
CSC je dio fw-a u kojem su podesenja providera i bitan je za vracanje stock fw. Inace ovi fajlovi sa sammobile-a imaju sve u jednom ali znaju ponekad preskocit vracanje product code-a, pa moras sam rucno sa csc selectorom
Staro 22.03.2013., 03:46   #1986
tutix
tutix's Avatar
Postovi: 4,069
Autor mujica Pregled postova
Odakle si skinuo ROM, po kojim si uputama radio?
Staro 23.03.2013., 17:22   #1987
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Autor trpi Pregled postova
mislio sam,
-reset trianglom
http://samsung-updates.com/device/?id=GT-N7100
Imaš TWO verziju za Tele2 croatia.
Dakle digni sa twrp-om stock rootani. MORA biti stock kernel i rom.
resetiraj sa triangle away.
odi u download mode i flešaj sa odinom stock TWO rom.
TA - DA.
Staro 23.03.2013., 21:11   #1988
trpi
ok budem,
jos jedno pitanje, sestra je uzela polovni prvi galaxy i9000, moze preporuka nekog roma i kernela da joj flasham odmah, poboljsam mobitel sto je vise moguce
Staro 23.03.2013., 22:28   #1989
Mar
Suit up!
Mar's Avatar
Postovi: 5,968
Hahaha
Skužija si da to nema smisla. Meni baš prije koji dan doša official 4.1.2 (Tele2), sve funkcionira vrlo fluidno i bez greške tako da ne vidim smisla u minjanju romova, ti custom made romovi uvik imaju neke probleme, a N2 je više nego dovoljno jak da se nosi sa Samsung bloatwareom
- Barney Stinson
Staro 23.03.2013., 22:58   #1990
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
CM10.0.0 - http://get.cm/get/jenkins/12608/cm-1...galaxysmtd.zip
Njega sam zadnjeg imao prije nego sam prodao, odličan rom
ili Slim Bean zadnji. Meni je 4.2.1 radio odlično. Koristi Semafor kernel
http://slimroms.net/index.php/downlo...egory/84-i9000
Sve upute i custom recovery imaš na prvoj strani ove teme. Flešaš CWM sa Odinom. Prije stavljanja bilo kojeg Slim Beana obavezno prvo zadnji CM10.1. Definitivno preporuka za CM10.0. stable
@Mar
Slažem se
Zadnje izmijenjeno od: Mihael. 23.03.2013. u 23:05.
Staro 23.03.2013., 23:33   #1991
Dottore
Dottore's Avatar
Postovi: 7,660
Autor Mihael Pregled postova
@Mar
Slažem se
Semaphore kernel, ujedno najbolji i najstabilniji kernel
Bilo koji ROM + Semaphore kernel i dobije stroj i pol
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 24.03.2013., 10:24   #1992
Postovi: 10,109
Za SGS2!
Kao sto sam nedavno preporucio SlimBean 4.2.1, danas cu dati preporuku kernela za 4.2.2 romove s Mali v2 driverima (samo AOKP/CM JB romovi). Ovo vrijedi i za SlimBean 4.2.2 b2.x.
Oduvijek koristim Siyah i Siyah MCM kernele i pokazali su mi se najboljim omjerom performansi i potrosnje baterije. Nazalost MCM je prestao razvijati odlicnu varijantu Siyahovog kernela prilagodjenu za Mali v1 GPU drivere (JB 4.2.1 AOKP/CM romovi). Tu je svijet malo stao i zaplakao
Ali odnedavno postoji rjesenje - updejtani MCM kernel s Mali v1 driverima za 4.2.2 romove. Procitajte sto dobivate i gubite downgradeom v2 drivera na v1 u temi:
http://forum.xda-developers.com/show....php?t=2201017
Reci cu samo da se zadnjih 10 verzija Dorimanxa po performansama ne moze usporediti s ovim kernelom i iza toga odgovorno stojim. Pauziram od fleshanja do daljnjeg
Staro 24.03.2013., 10:47   #1993
fishkal
fishkal's Avatar
Datum registracije: Dec 2009
Postovi: 1,116
I ja sam na Slim beanu, odličan je rom.
Ako sam dobro shvatio, skinem ovaj kernel, u aroma instaleru instaliram Siyah kernel s mali v1 driverima i to je to. Ako se vraćam na cm ili dorimanx kernel, ili neki drugi moram u aroma instaleru vratiti na dorimanx kernel s mali v2 driverima, i nakon toga flasaham bilo koji kernel
Gledam, čitam, kad ne znam pitam!
fishkal je offline   Reply With Quote
Staro 24.03.2013., 10:55   #1994
Postovi: 10,109
Tako je. Siyah v4 ili v5 fleshas (razlika je u dualbootu) a za povratak na staro trebas fleshati iz arome kernel s mali v2 i onda bilo sto drugo... Puno fajlova se mijenja fleshanjem v1 drivera na rom s v2 i onda ako bez ovog koraka flesas treci kernel moglo bi biti svega. U najgorem slucaju flesas Slimbean preko svega i to ti vrati sve na staro+stock kernel.
Staro 24.03.2013., 20:54   #1995
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
Update slucaja sa Samsung GT I5500 http://www.gsmarena.com/samsung_i5500b-3371.php
Dakle mob je bio hard brickan ili kako se vec kaze,preko jig nije islo,hvala xlr jos jednom,kad dodjem doma saljem.
Mob je stari odnio u Bosnu preko kod nekog servisera sto se valjda razumije,mobitel je proradio i radi sve ( wifi,igre,appovi,browser itd. ) osim sto nece primiti karticu.
Sad ja ne znam sta je taj lik radio i koji je rom/kernel stavljao,vjerujem da je preko jtag uspio ozivjeti i staviti prvi ROM koji stigne,a vjerojatno je bio zakljucan na neku mrezu.
Posto mobitel radi,stavio bi neki clean Gingerbread gore i mirna Bosna za sestru,zanima me hoce li to ici,jel moguce da ga opet zeznem ako stavljam Gingerbread gore,tj.hoce li prihvatiti i sta sa zakljucanim mobitelom,opet cu imati muke po editorima,vadjenju .img datoteka i trazenju kljuca :/
Staro 24.03.2013., 21:16   #1996
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Ako nije skurio IMEI... Imaš li backup EFS particije?
Staro 24.03.2013., 21:20   #1997
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
EFS particija ? prvi put cujem za to tako da cisto sumnjam da imam to
sta sada raditi kad dodjem doma,s cime flashati uopce,gdje krenuti ?
hoce li se to uopce dati otkljucati kao sto sam prije ( otkljucao sam dok je bio stock rom od Telstre )
Staro 24.03.2013., 21:23   #1998
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Onda my bad. Otključat ćeš ga kako si ga otključao i prvi put.
Staro 25.03.2013., 14:28   #1999
fishkal
fishkal's Avatar
Postovi: 1,116
Autor xlr Pregled postova
Za SGS2!
Nikako ne mogu instalirati siyah MCM kernel po ovoj metodi. Pokušao sam više puta, jednostavno nakon restarta moba mi ne boota rom nego mi se samo prikaže bijeli ekran i tako stoji. Za sad sam natrag na stock SlimBean kernel
Staro 25.03.2013., 17:25   #2000
Postovi: 10,109
Autor fishkal Pregled postova
A koji Slimbean je u pitanji? Ovo bi moralo raditi za build 1, 2.1 i 2.5 koji imaju mali v2 (4.2.2). Slimbean stable 1 (4.1.2) je druga prica i nije ovo za njega.
Ne znam gdje moze zapeti, aroma instalacija je u pitanju, odaberes Siyah v5 i next next :/
Staro 25.03.2013., 22:34   #2001
fishkal
fishkal's Avatar
Postovi: 1,116
4.2.2 verzija s mali v2 driverima (2.5 verzija roma). Odradim ja instalacijalu bez problema, nakon restarta mi dođe standarda "animacija" siyahova kernela i nakon toga samo mi ekran zabijeli i tako stoji dok ne izvadim bateriju.
Staro 26.03.2013., 12:08   #2002
Postovi: 10,109
Zanimljivo. U temi na xda o tom kernelu vidio sam da je netko spominjao bijeli ekran, ali na cm 10.1 romu.
Staro 26.03.2013., 20:47   #2003
6Finger
Lokacija: Zagreb, trešnjevka
Postovi: 1,166
Probao sam nekoliko dana s oficijelnim JB (talijanska verzija) na sgs2, radi jako fino no ima problem s br brzim izbornikom ili kako se vec zove (onaj sto povuces s vrha ekrana) malo malo se zblesi taj izbornik i nemozes mu pristupiti nikako bez restarta . Dali je netko imao slicnih iskustava s oficijelnim JB, dali vama radi, ako da koja verzija?
Ajde spasite da se maknem sa ICS jer je bruka los nakon JBa
6Finger je offline   Reply With Quote
Staro 27.03.2013., 00:53   #2004
trpi
jel moguce iskljuciti cetvrtu automatsku rotaciju ekrana koju sam dobio s omega romom? dakle onu kad je telefon naopako,
stock rom ima samo 3-normalno, lijevi landscape, desni landscape
ta cetvrta me ubija, kad legnem na bok ne mogu surfati u landscapeu jer se slika okrene naopako, moram lezati na trbuhu i drzati mob u zraku
mozda editirati neki sistemski file i to je to?
pomagajte, pitao sam na xda forumu omega rom temi, pa posebno otvorio topic, pa poslao email developeru ali nitko me ne jebe ni 5%, vi ste mi posljednja nada
rotation lockeri na jednu stranu sa marketa nije rjesenje
(da, jos se nisam vratio na stock)
Staro 27.03.2013., 07:29   #2005
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Imas Note2 ako se ne varam? Zar ne postoji opcija smart rotation upravo za takve slucajeve, iako bas i nije nesto pouzdana u mraku.. Druga solucija je instalirati jedan od popularnih launchera koji mogu podesiti okretanje ekrana u bilo kojoj kombinaciji, poput Nova ili Apex launchera...
Staro 27.03.2013., 08:28   #2006
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Mislim da je to u framework.apk tako da...
Drugi launcher bi pomogao samo u slučaju launchera, ostale aplikacije bi se i dalje rotirale.
Staro 27.03.2013., 12:19   #2007
hrki
Lokacija: ZG - VŽ - KR
Postovi: 279
Pomoć, kada sam imao S2 dosta mi je blokirao sam od sebe na Neatrom-u lite (free ram je padao sa 300 na 100) s programima koje sam imao instalirane, jel ce se to dogadati i na S3?
hrki je offline   Reply With Quote
Staro 27.03.2013., 13:39   #2008
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
@ Mihael
Da, framework je u pitanju, no i to se moze srediti, jkay, 3minit te
ostali framework-ovi koji se mogu flashati daju kontrolu nad svim i svacim...
Staro 29.03.2013., 14:14   #2009
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
Evo dodjoh kuci i idem vidjeti sta je sa GT i5500,sve radi,wifi i ostale funkcije,trazi mrezu normalno,ali izbaci neki error kad se pokusam spojiti na ili t-mobile ili vip ili bilokoju,nesto kartica nije odgovarajuca
tomato je kartica,tele2 i vip uredno radi,nadje mrezu,kao i kod tomato,samo nece spojiti,stalno nesto izbacuje...
sto da radim,flasham neki drugi rom ili ?
sad sam ga ugasio i vise nece upaliti,samo stoji bijeli posvijetljeni ekran,nece preko jig-a uci u download,ne reagira na usb wtf?
a mob prije 10 min radio,surfao netom i skidao appove
Zadnje izmijenjeno od: blava. 29.03.2013. u 17:34.
Staro 04.04.2013., 23:33   #2010
fishkal
fishkal's Avatar
Postovi: 1,116
Pitanje za ekipu na slim bean romu za s2.
Imam najnoviju verziju roma, originalni kernel, 240 dpi.
Imam problema s holo launcherom. Ponekad mi u meniju kod aplikacija I widgeta bude jako štekavo. Ponekad se kompletno zbrejka (stoped working). Mogu li ga nekako u postavkama "popraviti" ili bez milosti da idem na apex /nova?
