Staro 19.06.2012., 10:29   #2881
imik
imik's Avatar
Postovi: 626
Evo danas stiže patch 1.0.3
We will be performing scheduled maintenance for Diablo III starting tomorrow at 3:00 a.m. PDT in order to deploy patch 1.0.3. We anticipate that maintenance will conclude and that all services will be available by approximately 1:00 p.m. PDT.
Important: Please note that you will not be prompted to download patch 1.0.3 until the patch is live in your home region. If you are logging in from a European or Asian client, you will need to wait for this patch to release in that region before it can be installed. Additionally, if your home region is the Americas, you will be unable to log into Europe or Asia using Global Play after patch 1.0.3 is live until those regions have also patched.
For reference, here are the scheduled maintenance times for each region:
The Americas: 3:00 a.m. PDT (6/19) to 1:00 p.m. PDT (6/19)
Europe: 6:00 p.m. PDT (6/19) to 4:00 a.m. PDT (6/20)
Asia: 1:00 p.m. PDT (6/20) to 11:00 p.m. PDT (6/20)
Zadnje izmijenjeno od: imik. 19.06.2012. u 10:37.
imik je offline   Reply With Quote
Staro 19.06.2012., 10:35   #2882
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,503
Autor imik Pregled postova
Evo danas stiže patch 1.3
1.0.3, 1.3 će za par godina :>>
užas od patcha što se barbariana tiče, dizao sam taj attack speed da mogu imat koristi od life on hita, al asd će i to nerfat, mogu slobodno deletat charactera.
Staro 19.06.2012., 10:46   #2883
Snowrider
Snowrider's Avatar
Lokacija: Lika
Postovi: 864
Jaooo čekam taj patch radi gemova samo...ostalo nista. I da ako zelite farmat inferno act 2. Neka vas netko chechpointa na quest blackstone . i tamo farmajte goblina.
evo i link : http://www.youtube.com/watch?v=HGThGT1in5k
Snowrider je offline   Reply With Quote
Staro 19.06.2012., 11:11   #2884
mahoona
mahoona's Avatar
Postovi: 284
Na Infernu Actu 2 goblini farmaju mene, ako me taknu, mrtav sam. Strava
mahoona je offline   Reply With Quote
Staro 19.06.2012., 11:33   #2885
TheProfiler
Gamer 2 the Bone
TheProfiler's Avatar
Lokacija: Zagreb, oko centra...
Postovi: 1,640
Kak je lijepo čitat os svim tim farmanjima na infernu, i AH i opermanju....a ja siroče još na nigtmatreu, lvl 51 hehehe
Dok ja udarim 60 pola igre će se izmijenit.
Zasad nisam ni prismrdio AH, imam malo vremena za igru pa onda to koristim za šajbanje, nemrem si priuštit sat vremena browsat po AH. To možda kad udarim 60, zasad nosim ono što mi dropa.
Čak nemam ni strpljenja gold iteme stavljat na prodaju, procjenjivat jel vrijede ili ne vrijede, ovo - ono. Il ih dam pratiocima, ili salvagiram ili mercham.
- Nothing in this world is certain.
That's the only certain thing I know. -
TheProfiler je offline   Reply With Quote
Staro 19.06.2012., 11:39   #2886
Interpol
Interpol's Avatar
Postovi: 917
Figures, nakon cca 65 sati igre, prvi legendary mi padne dan prije patcha kojim ih buffaju
Interpol je offline   Reply With Quote
Staro 19.06.2012., 11:40   #2887
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
1.0.3. ce nerfat IAS. Ne prvi pogled pusiona (imam life on hit monka).
Ipak, ako su smanjili dmg koji radi monsteri, trebat cu manje heala pa ce se to izjednaciti.
Vidjet cemo.
Staro 19.06.2012., 11:43   #2888
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,503
Autor mahoona Pregled postova
goblini ne udaraju
Staro 19.06.2012., 11:46   #2889
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,503
pao je i HC inferno diablo upravo, gg Kripparrian
Staro 19.06.2012., 11:54   #2890
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 432
Sva sreca da sam preksinoc izgubio biddanje na neke attack speed rukavice.
Bile su vec dosta visoko otisle, sad bi si izgrizao ja.. kad bi vidio na sta sam ulupao novce nakon nerfa
If you are not paranoid you don't have enough information
Tumor je offline   Reply With Quote
Staro 19.06.2012., 12:23   #2891
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Lokacija: Svuda okolo / EU
Postovi: 1,404
Autor gaggo Pregled postova
samo su rijeci na cirilici a igra na eng ili je sve rus? ak je to eng na cirilici, mogu naucit
sve je na ruskom i cirilici,naravno, kad ukucas ruski kljuc dobijes opciju za ruski klijent da skines (ili ako imas EU verziju skine ti ruski patch od 2.7GB te updejta na ruski, ali nestanu svi jezici u opcijama osim ruskog)
imam osobno obje verzije, vise igram EU (neznam zasto)
JozicA je offline   Reply With Quote
Staro 19.06.2012., 12:25   #2892
gaggo
Datum registracije: Aug 2009
Postovi: 528
Hvala na infu, steta sto nikad nisam ucio ruski...
Nista, budem si kupio onda diablo za koji 2 tjedna
gaggo je online   Reply With Quote
Staro 19.06.2012., 12:40   #2893
ehohr
ehohr's Avatar
Postovi: 348
To je isti onaj koji kad je umro je boostao HC charactera? Da bas bravo za njega.
ehohr je offline   Reply With Quote
Staro 19.06.2012., 14:26   #2894
Goranbm
Goranbm's Avatar
Postovi: 1,238
Ako sam dobro skužio između nas i PDT vremena je 9 sati razlike... Znaći da će to biti sutra od 3 ujutro do 1 popodne ?? ili ??
Goranbm je offline   Reply With Quote
Staro 19.06.2012., 15:30   #2895
Interpol
Interpol's Avatar
Postovi: 917
Šta nije malo čudno da su požurili s patchom, s obzirom da je bio najavljen za kraj mjeseca? Sigurno nema nikakve veze s RMAH
Staro 19.06.2012., 15:33   #2896
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,503
pa nije baš početak mjeseca a i sredina mjeseca je prošla
Staro 19.06.2012., 15:53   #2897
imik
imik's Avatar
Postovi: 626
Izgleda da imamo dva update-a. Sad sam pokrenu i nešto se skinulo.
Staro 19.06.2012., 16:08   #2898
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,503
launcher update, nebitna sitnica
noćas ide 1.0.3 nakon maintenancea
Staro 19.06.2012., 16:32   #2899
Sanogo
Sanogo's Avatar
Datum registracije: Dec 2011
Postovi: 188
Autor Goranbm Pregled postova
Mislim da po našem vremenu patch ide od 3 ujutro do 1 popodne.
Sanogo je offline   Reply With Quote
Staro 19.06.2012., 17:48   #2900
Red_Dragon
Lost soul still wondering
Red_Dragon's Avatar
Lokacija: Aiur
Postovi: 474
Autor TheProfiler Pregled postova
Kaj se ti žališ, neki nisu još ni nabavili igru za sad sam samo probao "demo" igrivost je dobra ali bih volio da imamo više kontole nad samim likom (stat pointsi) i malo mi je bezveze kaj se mogu itemi kupovati i prodavati za prave pare, da znam, ko voli nek izvoli ali meh
Da nije nas bile za grabu bi spal
Red_Dragon je offline   Reply With Quote
Staro 19.06.2012., 18:29   #2901
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,503
Staro 19.06.2012., 18:56   #2902
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Jedna stvar koja me ubola u oko.
Nema više smisla svaki kamen pomaknut...
Magic Find will no longer be considered when looting objects in the environment such as chests, barrels, vases, pots, and corpses
žmnpp
Staro 19.06.2012., 20:37   #2903
CatKiller
CatKiller's Avatar
Postovi: 3,312
Ma ima smisla, treba se oznojiti za item. To je zapravo mjera protiv botova.
Staro 19.06.2012., 20:38   #2904
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Ima netko s jakim receptima za crafting? Posebno me zanima helm of command.
d4rk_ch1ld je offline   Reply With Quote
Staro 19.06.2012., 22:09   #2905
potemkin.hr
Akutna lijenčina
potemkin.hr's Avatar
Lokacija: Fiume
Postovi: 1,834
Danas će biti dobra berba bottom itema
Lijepo biddati na ultrajeftine (i dobre) iteme par minuta prije nego serveri idu offline, a čije trajanje ističe prije nego serveri idu natrag online. Recept za profit
potemkin.hr je offline   Reply With Quote
Staro 19.06.2012., 22:15   #2906
Sanogo
Sanogo's Avatar
Postovi: 188
Autor potemkin.hr Pregled postova
Ma da, znači kad serveri odu offline aukcije i dalje teku, ja sam mislio da se pauziraju i nastave kad serveri dođu online?
Staro 19.06.2012., 22:18   #2907
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Autor Sanogo Pregled postova
Ja se nadam mojem slučaju, ali trebamo isprobati u svakom slučaju, možemo samo dobiti super gear za bagatelu (bar ja tako planiram, a uspio si gearati likove za nestvarno nisku lovu, da kažem tu na forumu bi mi se smijali )
Zadnje izmijenjeno od: potemkin.hr. 19.06.2012. u 22:27.
Staro 19.06.2012., 22:30   #2908
Sanogo
Sanogo's Avatar
Postovi: 188
I ja se nadam. A što se tiče gearanja likova, da, sve je moguće sa malo strpljivosti u AH-u, ja sam kupio kacigu za 120k koju sam prodao za 115 eura, tako da, stvarno je sve moguće.
Staro 19.06.2012., 23:04   #2909
Postovi: 17,123
Dajte vi meni recite, nisam baš čitao o tome, skinem patch, i opet mi piše da je novi patch aktualni, i izađem van i piše mi diablo III allready running... wtf? Zadnji patch normalno.
Zadnje izmijenjeno od: Mommistake. 19.06.2012. u 23:18.
Staro 19.06.2012., 23:29   #2910
b1tterman
Takozvani influenser
b1tterman's Avatar
Lokacija: Dublin
Postovi: 650
meni je danas dropao najbolji blackthornes threads na europskom serveru pa se sad dvoumim da li da prodam ili da cuvam
b1tterman je offline   Reply With Quote
