Staro 09.04.2012., 18:36   #3061
tiki66
tiki
tiki66's Avatar
Postovi: 2,762
Odi na XFX Core Edition od 450w, više nego dovoljno.
Staro 11.04.2012., 16:59   #3062
Facelessone
Facelessone's Avatar
Postovi: 4,205
Komp iz mojkomp. Mijenjao bi napanje uskoro.
Gledam SEASONIC 620W, SS-620GM, SEASONIC 620W, SS-620GB i CORSAIR TX 650W v2.31.
Vjerojatno i jesu mali overkill, ali mi je bitno da se u max loadu s clockanim procem ventilator u napajanju ne dere, znači tišina. Također, garancija, Corsair je pretpostavljam 5 godina, a Seasonic? Ovaj Seasonic je polu modularan, ajde, to mu je jedna prednost. Može i preporuka za neko drugo u tom cjenovnom rangu.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 11.04.2012., 17:10   #3063
lolofuxy
lolofuxy's Avatar
Datum registracije: Jun 2010
Postovi: 3,319
@im43768
I tu P67-icu za ovu Z68-icu
@Facelessone
OCZ s 5 godina garancije
lolofuxy je offline   Reply With Quote
Staro 11.04.2012., 18:32   #3064
Facelessone
Postovi: 4,205
Vidim da je isto modularno. OCZ vs Seasonic M12 II?
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 11.04.2012., 18:39   #3065
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
Ja bi na OCZ-a moj je 400w verzija i prezadovoljan sam sa njim, bila mi je tjedan dana GTX 560 Ti nutra i nikakvog štucanja i slabosti nije pokazao, a ovih 5 godina garancije je velki + kod mene i to što je modularan pa nema prevelke muke oko kablovinja, o tišini mogu samo reči da opravdava naziv Silencer
edit: @1v@n ti ima 600W verziju pa se posavjetuj i s njim
Staro 11.04.2012., 19:13   #3066
Postovi: 34,075
Ako se dobro sjećam, taj OCZ bi mogao biti rebrandani Sisa. Pretraži malo zadnjih par stranica ove teme.
Staro 11.04.2012., 23:09   #3067
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Ne da bi mogao biti Seasonic, nego je.
Staro 30.04.2012., 19:42   #3068
Analord
Analord's Avatar
Postovi: 161
poštovani kolege, da li je HX520W od Corsaira dovoljan za guranje Core i7 860, 3 diska i HD6970?
hvala!!!
Analord je offline   Reply With Quote
Staro 30.04.2012., 20:01   #3069
mislav_os
freak
Postovi: 2,688
Bez po' muke.
Staro 03.05.2012., 10:49   #3070
antispin
Datum registracije: Jan 2012
Postovi: 17
Koe mi napajanje preporučujete za ovu konfu?
Intel i5 2500k
Sapphire Radeon 7850
ssd 660 gb
hdd 750 gb
Cijena do 550 kuna, portio ili links. Hvala.
antispin je offline   Reply With Quote
Staro 03.05.2012., 10:52   #3071
Postovi: 34,075
XFX 450W
Staro 03.05.2012., 10:53   #3072
antispin
Postovi: 17
Koje mi napajanje preporučujete za ovu konfiguraciju?
Intel i5 2500 k
Sapphire radeon 7850
ssd 60 gb
hdd 750 gb wd green
Cijena do 55o kuna i to iz linksa ili portia . Hvala.
Staro 03.05.2012., 11:03   #3073
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Staro 03.05.2012., 11:27   #3074
Wolverine
Wolverine's Avatar
Postovi: 12,433
Autor antispin Pregled postova
Intel i5 2500 k
ssd 60 gb
hdd 750 gb wd green
Za tu konfu dušu dalo
http://www.portio.hr/index.php?page=artikl&id=052768001
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 04.05.2012., 12:58   #3075
antispin
Postovi: 17
Da li bi bilo dobro da kupim xfx 550 w zbog eventualne nadogradnje?
Staro 04.05.2012., 13:10   #3076
Wolverine
Wolverine's Avatar
Postovi: 12,433
Ako želiš slobodno uzmi.
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 04.05.2012., 17:55   #3077
suedamA obmaR
Game, PC ,motobikes, bike
suedamA obmaR's Avatar
Datum registracije: Jan 2010
Lokacija: Sibenik
Postovi: 779
Moja preporuka je svima koji imaju u planu xfx 450 da odma doplate 100 kuna i uzmu model od 550W jer xfx 450 ima samo jedan kabel za grafu spojit i 3 molexa.
suedamA obmaR je offline   Reply With Quote
Staro 11.05.2012., 01:06   #3078
Goranbm
Goranbm's Avatar
Postovi: 1,238
Zanimaju me mišljenja o Scythe Kamariki 4 750w napajanju. Trenutno sam na HX620 starom otprilike 4 i pol godine. Kolika je razlika u kvaliteti između navedenim napajanja ? I da li bi se isplatila nadogradnja (kao ulog za neku budućnost) i koja bi bila recimo fer nadoplata u navedenoj zamjeni?? Kamariki je nov i zapakiran.
Goranbm je offline   Reply With Quote
Staro 11.05.2012., 07:04   #3079
Postovi: 34,075
Po meni, nadogradnja nije isplativa. HX620 ima dovoljno snage za pokretanje 90% konfi na forumu i još je modularan. Kikiriki jest dobro napajanje, ali ti je stvarno nepotrebno uz HX-a.
Staro 11.05.2012., 08:32   #3080
Dottore
Dottore's Avatar
Postovi: 7,703
@Gorane
Ne isplati se, ima jos dovoljno snage. Ako jos imas garancije i strpi se. Ako je istekla, mozes ocistiti od nakupljene prasine i a promjeni odgovarajuci vent.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 11.05.2012., 11:54   #3081
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
@Goranbm
Ja dajem glas da ostaneš na Hx-u grafe su najveći potrošaći, al počinju se raditi što jače, a da što manje troše tako da taj Hx može gurat svašta još dugo dugo vremena.
I da pokucam u drvo da ti još duže potraje jer je to odlično napajanje
Staro 11.05.2012., 12:56   #3082
Goranbm
Goranbm's Avatar
Postovi: 1,238
Ok, puno vam hvala svima
Staro 25.05.2012., 15:53   #3083
GT-R
Datum registracije: May 2012
Postovi: 21
Do 100 kn trebam neko napajanje, 350-400W Fortron ili Chieftek, polovno.
Nađoh za 100 kn Chieftec GPS-400AA-101 A, 400W
Trenutno imam MS ATX P4 400W, znači treba mi nešto bolje od toga..
Preporuke i savjeti dobrodošli, zahvaljujem unaprijed.
GT-R je offline   Reply With Quote
Staro 25.05.2012., 16:09   #3084
ShanTech
Postovi: 3,784
Taj Chieftec je OK, naravno, ako je ispravan i ako mu nije prolupao ventilator (Yate Loon D12SH-12). To možeš naznačiti kod pregovaranja, pa možda dobiješ i jeftinije.
Od Fortrona gledaj PNF seriju (ATX-350PNF, ATX-400PNF). Na forumskoj tržnici nedavno se je prodavao ATX-400PNF za 80 kn.
Ostala napajanja se obično prodaju za veće novce, tako da ih je bezveze spominjati.
Staro 25.05.2012., 23:47   #3085
GT-R
Postovi: 21
Evo nešto sam pronašao u oglasima, pa vi kažite koji je best buy za moje komponente:
Matična: Gigabyte GA-N650SLI-DS4
Procesor: Intel(R) Pentium(R) D CPU 2.66GHz,
Grafička: Nvidia GeForce 9600 GT
Hard: Hitachi HDP725025GLA (230 GB SATA)
1. Fortron napajanje 350W PNF. 50 kn
2. spire atx 420wtb-pfc1 (u kutiji, šarafi) 150 kn
3. Chieftec GPS-400AA-101 A 400W 100 kn
4. Codegen 480X 100 kn
(cijene su stavljene samo radi usporedbe)
Staro 25.05.2012., 23:52   #3086
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Za tu konfu Fortron ti se najviše isplati uzeti od ovih navedenih, pogotovo po toj cijeni.
C L O W N I N G A R O U N D
Staro 25.05.2012., 23:55   #3087
GT-R
Postovi: 21
Ja sam mislio da će mi netko reć "uzmi spire, malo je skuplji al je puno bolji" al izgleda da sam se prevario
Ako ti tako kažeš onda uzimam fortrona
Staro 25.05.2012., 23:56   #3088
Doink the Clown
Postovi: 6,214
Autor GT-R Pregled postova
Pričekaj još par mišljenja ali po meni ti je PNF najpametnije uzeti, jer se radi o dosta dobrom napajanju.
Staro 26.05.2012., 00:29   #3089
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Doink dobro kaze, uzmi Fortron-a
Staro 26.05.2012., 00:59   #3090
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Steta sto nema vise onih MS FSP napajanja za oko 200 kn, to su bila solidna nova napajanja, tiha i s dosta konektora..
Za 100 kn nadji fortrona PNF ili chiefteca GPS, samo pazi da vent nije otisao, proslo mi ih je kroz ruke dosta i nije bilo bas rijetko da ventovi nisu u najboljem stanju, ipak je to pomalo staro...
Imas jos i coolermaster elite i xilence red, al oni su malo rjedji...
Za 150 kn se vec nadje chieftec GPS od 550W..
Za 150 kn od novih stvari imas ovo [link] (verzija sa 12 cm ventom(u linksu je 159)), nije prelose, al je bolje od spirea...
Campeonato je offline   Reply With Quote
