Staro 24.02.2012., 08:10   #181
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
Meni adsl ledica trepti kad imam prometa prema van
Freak Show Inc.
Friday je offline   Reply With Quote
Staro 25.02.2012., 19:15   #182
mskvorc
Datum registracije: Jan 2012
Postovi: 14
Uspio sam zbrikati uređaj i sad imam problem s ponovnim osposobljavanjem. Složio sam serijski interface i kod uključivanja dobijem samo ovo
ROM VER: 1.0.3
CFG 01
Read EEPROMX
X
Zatim sam krenuo sa stavljanjem bootloadera preko uputa na wikiju, ali sam zapeo kod tftpboot
ROM VER: 1.0.3
CFG 04
Read EEPROMX
X
UART
U-Boot 2010.03 (Feb 23 2012 - 10:58:26)
Board: Danube/Twinpass/Vinax-VE V1.5, DDR Speed 111 MHz, CPU Speed 111 MHz
DRAM: 32 MB
Flash: 8 MB
*** Warning - bad CRC, using default environment
Net: lq_cpe_eth
Hit any key to stop autoboot: 0
DANUBE =>
DANUBE => setenv ipaddr 192.168.1.1
DANUBE => setenv serverip 192.168.1.10
DANUBE => protect off all
Un-Protect Flash Bank # 1
DANUBE => era 0xb0010000 0xb001ffff
. done
Erased 1 sectors
DANUBE => cp.b 0xb000e000 0xb0010000 0x2000
Copy to Flash... 9....8....7....6....5....4....3....2....1....done
DANUBE => tftpboot 0x816e0000 u-boot-bootstrap.bin
Using lq_cpe_eth device
TFTP from server 192.168.1.10; our IP address is 192.168.1.1
Filename 'u-boot-bootstrap.bin'.
Load address: 0x816e0000
Loading: T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T
Imam Windows 7 i koristio sam tftpd64 server, ali ga siemens očito ne vidi. IP adresa računala je 192.168.1.10
Pogledao sam i promet preko wiresharka i dobivam
3com_03:04:05 Broadcast ARP Who has 192.168.1.10? Tell 192.168.1.1
AsustekC_30:68:7b 3com_03:04:05 ARP 192.168.1.10 is at 00:23:54:30:68:7b
i nema daljnje komunikacije? U čemu griješim?
Hvala na pomoći
mskvorc je offline   Reply With Quote
Staro 25.02.2012., 20:25   #183
Postovi: 23,504
U izboru os - a, nađi / stavi stari dobri XP ili Linux ako snalaziš u njemu i tada takve tftp / flash radnje.
Vista i W7 su (namjerno) problematični, da bi radili ok treba klikat po njima . . .
Staro 26.02.2012., 16:49   #184
mskvorc
Postovi: 14
Uspio. Koristio sam pogrešan u-boot, ali je Delboy pomogao i sad je sve ok.
Staro 27.02.2012., 16:23   #185
spile
Datum registracije: Feb 2012
Lokacija: osijek
Postovi: 5
nakon skoro tjedan dana flesanja i rasturanja Siemens Sx763 (uz delboyevu pomoc oko flashanja nakon avanture sa gubitkom napajanja), moram reci da sam skoro odusevljen mogucnostima, naveo bih prvo zapazanja, a poslije nesto sto nisam bas uspio -- kao poziv za pomoc
OpenWRT stvarno otvara puuuno mogucnosti, najvise sa MultiWanom. Vlan, L2, L3 solidno. Firewall korektan, nema klasicni QOS -- ili nisam nasao. Sve se dodaju paketici putem konzole, fora je. Generalno -- SPOR. Multipraktik.
DD-WRT je solidno obrijan, ali radi perfektno brzo. Ima QOS, nema Vlan. Linksysasto izgleda, ali i asketski pristup te dobro funkcionira. Zgodnije GUI odredjivanje Annex A/B. Vise orijentiran na DSL modem / router / switch.
Sto nisam uspio, i na DDWRT i na OPENWRT.
1. modem 3g Huawei 1752 i ZTE MF100 - padnem na driverima
2. RFC 1483, MER bridge 40/0 ili 37/0, Annex A i B, dignem link interneta, dodijelim ga
VLAN 0 - portovi 3-4-5, pokusam dici link PPPOA dodijeliti ga u bridgu na VLAN 1 - port 2,
(tagged procesori, untagged portovi u Vlanu - jer radi preko L1)
3. torrent server na routeru i snimak na usb hard ili stick
4. sto je port1 na switchu OPENWRT
5. podici QOS na openWRT
Zadnje izmijenjeno od: spile. 27.02.2012. u 20:15.
spile je offline   Reply With Quote
Staro 27.02.2012., 22:03   #186
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Ovo za gui, valjda ce nest biti uskoro da se vidi status i odabir annexa, mada se i sad moze preko konzole(trunk verzija) namjestati annex, moze se i dal da bude adsl, adsl2 ili 2+.
Ovo za qos, ima tamo za prioritet, znaci dal da se useru x da prioritet nad netom, za brzine i to ima neke skripte preko tc.
1. nemam pojma, mozda je do drivera, ako radi na ubuntu/fedora/... onda je nesto do openwrt
2. http://pastebin.com/H3y9h2bm , network config za iskon.
3. neko je govorio gore da je proc preslab za puno peerova
4. to je kao port 4 ili 5 jer je obrnuto, ali to nepostoji na sx jer neki ruteri imaju lan1,2,3,4 i wan port, a sx ima samo 4 lana.
Staro 28.02.2012., 23:39   #187
grga11
grga11's Avatar
Postovi: 89
Autor spile Pregled postova
Kako nema Vlan? Setup>Networking>Vlan Tagging
grga11 je offline   Reply With Quote
Staro 29.02.2012., 08:09   #188
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
Autor grga11 Pregled postova
I ja sam baš gledao istu stvar. Jel bi se tu nekako mogao iskemijati vlan za IPTV?
Freak Show Inc.
Staro 29.02.2012., 14:23   #189
grga11
grga11's Avatar
Postovi: 89
Autor Friday Pregled postova
Hm, teško kad ddwrt nema podršku za multiple VC's, bar ne iz web gui-ja.
Staro 01.03.2012., 09:47   #190
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
OK, sad sam već u opasnoj zoni - žena samo što me nije ubila! Nemam maxtv već 3 tjedna. Planiram uzeti još jedan SX763 i njega staviti "ispred" ovog sa ddwrt-om. On bi služio samo za maxtv i imao bi pppoe pass through (tako da ovaj sa ddwrt-om "zove" van). Jel to izvedivo?
Freak Show Inc.
Staro 01.03.2012., 10:58   #191
Postovi: 23,504
Da, izvedivo je, ni ne mora biti baš SX ako nemaš T-Koma telefoniju (VoIp tj. IMS),
igraju D-Link DSL-G684T, ZyXEL P-660, možda još neki,
fino podesiš dupli Bridge mode, wireless ugasiš, postaviš mu drugačiji ip u odnosu na 2. uređaj, ugasiš DHCP Server, . . .
Staro 01.03.2012., 12:53   #192
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
OK, znači router sa originalnim FW će samo opsluživati STB a ovaj će mi raditi sve što se tiče interneta kao da je sam, ne? To sam već imao sa posebnim firewallom i pass through je radio OK ali nisam to nikada radio sa ddwrt-om. U koji port na ddwrt routeru treba ubosti kabel iz prvog routera?
Freak Show Inc.
Staro 01.03.2012., 13:24   #193
Postovi: 23,504
2. router u toj kombinaciji konfiguriraš kao WAN (Ethernet) router, prevrti po temi koji je port tada WAN, ne zaboravi da su spominjali obrnutu numeraciju Lan portova u odnosu na origigi fw.
Provjeri jel trenutni DD-WRT za SX podržava WAN (Ethernet) konfig, nisam siguro, ako ne pređi na OpenWRT.
Ako nađeš navedeni DSL-G684T vidi: http://forum.pcekspert.com/showthread.php?t=82992
opisano kako staviti origigi D-Link fw jer je tada uređaj stabilniji a nakon toga podesiš Bridge Internet pa potom drugi PVC za MaxTv + mapiranje jednog Lan porta za tu MaxTv konekciju.
Zadnje izmijenjeno od: Nikky. 01.03.2012. u 13:30.
Staro 01.03.2012., 15:19   #194
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
@friday, gore sam postao link za network config za iskon za openwrt, http://pastebin.com/H3y9h2bm
samo ubaci openwrt, izmjeni u ovom vpi/vci i ubaci ga umjesto /etc/config/network fajla u openwrt sa npr win scp programom.
Staro 01.03.2012., 15:43   #195
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
Ma već sam naručio drugog siemensa tu na forumu od jednog dečka. Imat ću ih 2, pa kad je bal nek je maskembal .
Stavit ću ovog sa originalnim FW samo da radi maxtv pa ću sa ovim drugim kemijati (probat ću i openwrt i taj tvoj config...)
EDIT:
Mogu na postojeći dd wrt normalno ubaciti openwrt preko web gui?
Freak Show Inc.
Zadnje izmijenjeno od: Friday. 01.03.2012. u 15:55.
Staro 01.03.2012., 19:19   #196
uncut
Datum registracije: Apr 2011
Postovi: 58
EDIT:
Ne, nego držati reset botun prilikom paljenja usmjerivača i onda iz loader webui flashati openwrt...
uncut je offline   Reply With Quote
Staro 01.03.2012., 19:32   #197
uncut
Postovi: 58
nedavno je ovjezena definicija drivera u dd-wrt
http://svn.dd-wrt.com/changeset/18548#
ali jos nema nove javne verzije fw
Staro 02.03.2012., 09:46   #198
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
Jel vama wlan radi normalno sa ddwrt-om? Meni je u totalnom raspadu. Errora milijun i nitko se ne može spojiti...
Freak Show Inc.
Staro 02.03.2012., 11:43   #199
uncut
Postovi: 58
Meni radi najnormalnije...
Staro 02.03.2012., 13:24   #200
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
Vidi kod mene:
Sinoć je restartan. Kad se netko pokuša zakačiti onda sve brojke odu u nebo...
Freak Show Inc.
Staro 03.03.2012., 20:28   #201
uncut
Postovi: 58
evo nova verzija dd-wrt fw - ide samo preko postojece instalacije dd-wrt
http://rghost.net/36825729
Staro 03.03.2012., 21:30   #202
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
Jel ima negdje breaking changes lista ili nešto?
Freak Show Inc.
Staro 03.03.2012., 21:45   #203
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
Upravo flashao. Wireless Packet Info i dalje samo broji errore. VLAN tab nije dodan u setup grupu.
Freak Show Inc.
Staro 03.03.2012., 21:47   #204
uncut
Postovi: 58
Pa bar je to jednostavno; stara verzija http://svn.dd-wrt.com/changeset/18313 a nova http://svn.dd-wrt.com/changeset/18613 i listas promjene na 'next changeset' na desnoj strani...
Zadnje izmijenjeno od: uncut. 03.03.2012. u 21:48. Razlog: nadopuna
Staro 03.03.2012., 21:50   #205
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
updejtan dd-wrt img na tutorialu.
http://svn.dd-wrt.com/log/
pa proucavaj, ovaj je na rev 18613
Staro 03.03.2012., 21:57   #206
uncut
Postovi: 58
Zadnje izmijenjeno od: uncut. 03.03.2012. u 22:48.
Staro 03.03.2012., 22:05   #207
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
Autor uncut Pregled postova
Po nekom tutorialu koji sam našao treba biti poseban VLAN tab kako bih omogućio olmajti maxtv da radi.
Freak Show Inc.
Staro 03.03.2012., 22:13   #208
uncut
Postovi: 58
daj link na taj tutorial???
dodatne VPI/VCI veze se na dd-wrt-u jos uvijek ne mogu definirati u webgui, ali se zato moze iz naredbenog retka samo triba znat...
eh da i onda se na ovom VLAN tabu (pozdrav mu ma gdje bio) mora definirat dodatni vlan za IPTV
Staro 03.03.2012., 22:18   #209
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
Jel znaš to napraviti? Mislim, uređaj je fizički za to sposoban (evidentno), fali malo magije
Freak Show Inc.
Staro 03.03.2012., 22:24   #210
uncut
Postovi: 58
nisam to jos ima prilike napravit jer nemam nigdje kombinaciju dd-wrt@sx763 + maxtv, ali ako ima interesa mogu moj sx testirat kod prijatelja on ima maxtv
