Staro 21.03.2005., 21:03   #1
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Thumbs up Media Player Classic v6.4.8.4 NOVA VERZIJA
Nova verzija najboljeg video playera
Homepage:
http://sourceforge.net/project/showf...ckage_id=84358
Download:
Win2000/XP:
http://prdownloads.sourceforge.net/g...4.zip?download
Win98/ME:
Promjene:
  • # remembering playlist items can be turned off in the context menu
    # Changes: fixed shaders randomly disappearing from the menu
    # Changes: aspect ratio presets at view/video frame/override aspect ratio (default, 4:3, 5:4, 16:9)
    # Changes: ctrl held during resizing keeps the window tight around the video
    # Capture mode: better compatibility with terratec cinergy and other cards which output audio themselves
    # Capture mode: the television standard can be set indirectly by the country code at the open device dialog (there is no other way in directshow...)
    # Capture mode: a deinterlacer filter is loaded when the height is larger than 288 lines, only for previewing (the following color formats are supported: yuy2/uyvy/yv12/i420/iyuv)
    # Capture mode: if there is only one video format offered by the video capture pin (320x240 for example) then mpc adds several other standard resolutions to the combo box
    # Vmr9 renderless: bilinear + bicubic resizers, using pixel shader 2.0 (3d mode only)
    # Vmr9 renderless: speed issues on secondary display may be fixed now (the file has to be opened there)
    # Webserver: fixed the bug of serving external files from certain paths
    # Webserver: cgi support (tested with php only)
    # Webserver: default page can be set (index.html, etc.)
Staro 22.03.2005., 07:49   #2
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,099
Sta su se developeri toliko zalaufali
Dve verzije u 10tak dana.
Verifikacija poštenog trgovca #1, #2, #3, #4, #5, #6, #7, #8, #9
pogi je online   Reply With Quote
