#91 |
DBS
Datum registracije: Nov 2010
Postovi: 1,855
Ja sam dobio nekih 10 FPS-a gore i sad igra ne pada ispod 50 FPS-a. Neki sa slabijim konfama koji ne vrte ultra postavke javljaju da je skok i do 20 FPS-a na pojedinim mapama. Uglavnom patch popravlja dosta stvari, sad to već liči na finalni proizvod. |
#94 |
Postovi: 251
Meni su ovi tweakovi dosta pomogli jer imam kantu od kompa, FPS se značajno popravio: http://forums.tripwireinteractive.co...ad.php?t=64126
Kad sam bio mlad mislio sam da je novac najvažnija stvar u životu; sad kad sam ostario znam da jest! - Oscar Wilde |
#95 |
Datum registracije: Feb 2003
Lokacija: Velika Gorica
Postovi: 499
Doctor!!!... Doctor!!!... MY BRAIN HURTS... |
#96 |
Postovi: 251
Izašao novi update "težak" 223.8MB: October 13, 2011 -Fixed a bug which would sometimes cause the first click (fire, alt fire, or ironsights) after respawning to not register. -Player stats will now save at the end of each round in addition to the end of the match. -Minor tweaks to the high end of the honor level ranking. While some very high level players may notice an honor level change their earned XP is unaffected by this update. -There is now a console command for any players wishing to manually do a stats reset. The command is 'ResetStats' and must be followed by your steam nickname for confirmation (in quotes, case sensitive) -Fixed a problem with music in countdown where the morale state (and music) would jump around and transition too often. -Fixed neutral objectives showing up in the compass as Allied objectives. -Fixed getting a black screen when getting suppressed for non-English languages ------------------------------------------------------------------------------ Hvala Bogu da su riješili ovaj bug s (ne)pucanjem nakon spawnanja. Usput, ako je netko žedan FPS-a, a grafika mu nije bitna neka proba ovo: http://forums.tripwireinteractive.co...ad.php?t=64408
Kad sam bio mlad mislio sam da je novac najvažnija stvar u životu; sad kad sam ostario znam da jest! - Oscar Wilde Zadnje izmijenjeno od: -_Bad$ector_-. 14.10.2011. u 01:53. |
#97 | |
noob in da game
Lokacija: karlovac
Postovi: 138
Hehe, ovaj screenshot tweak-ane igre sa linka izgleda koda je igra cod2 |
#98 |
Postovi: 251
Ma CoD 2 u DX9 je lijep k'o slika u odnosu na ovo. ![]() Ali u DX7 su tu negdje.. Dobije se nekih 20 do 30FPS-a, a i vidljivost je stvarno bolja...samo koliko ima smisla igrati s takvim postavkama, nije to to..
#99 |
Postovi: 1,212
Evo naručio pa stiže za nekih 10 dana. Valjda budem našao i grafičku do tada. Da li se stvarno igra sporije/"pametnije" nego u COD-u i koliko? I najvažnije, ima li f*cking cheatera kao u COD-u?
Jel' ima šta ženskih starih
što vole strance da nas vozaju u autu i kupuju skupe lance |
#100 |
Postovi: 251
Igra nema nikakve veze s CoD-om. Potpuno drugačiji način igranja, puno realnije, i da igra se dosta sporije jer ćeš inače popit metak u roku odmah. Moraš koristit zaklone na mapi, otvorit širom oči jer se protivnici stvarno skempaju na sve moguće lokacije. U pravilu 1 metak ubija, nekad se zna dogodit da budeš ranjen pa se moraš nabrzinu pokrpati sa bandage-om(imaš ih 2). Cheatera nisam primjetio da ima, nisam igrao previše igru pa ti ne mogu točno reći, ali mislim da RO2 igra starija i ozbiljnija ekipa već CoD, zapravo gotovo sam sguran u to. ![]()
#101 |
DBS
Postovi: 1,855
Igra nema veze s CoD-om. Zaboravi CoD jer u ovoj igri nema skakanja, točkice za nišan i sličnih gluparija. Ako ne prisloniš pusku na rame i sam pogledaš kroz ciljnik - nema preciznog ciljanja. Mape su ogromne i nigdje nisi siguran. Moraš se micat od zaklona do zaklona, koristit dimnu zavjesu i prave taktike. Naprema ovoj igri CoD je za ekipu iz vrtića. Ovo igraju veliki dečki = pripremi se na puno umiranja u početku. ![]() |
#102 |
Postovi: 1,212
Fala. Ma citao sam i nesto mrvicu probao igrati SP jedinice kada je izasla i svidjelo mi se, no kako ju nisam kupio nisam igrao na netu. Nesto su govorili da su dvojku malo omeksali, drago mi je cut da je i dalje potpuna suprotnost.
#103 |
DBS
Postovi: 1,855
Nisam igrao jedinicu pa ne mogu uspoređivat oboje igre, ali mogu reć da je pravi doživljaj igrat na "full switch" serverima. Tad igra jednostavno sjaji i nema joj premca. Pogotovo u kombinaciji s Countdown modom igranja. Nažalost, velika većina servera preferira Territory mod i ne totalno hard core postavke. Doći će i to s vremenom. ![]() EDIT: Daleko od toga da je Territory mod loš, upravo suptrotno. I još sam zaboravio spomenut nenadhebiv supression sustav koji su implementirali. Ako vidiš da se netko sakrio iza zida - slobodno opleti mašinkom po njemu da se malo "rastrese" i zamuti mu se vid od straha. Zadnje izmijenjeno od: T}{OR. 16.10.2011. u 23:04. |
#104 |
Postovi: 251
Countdown mod još nisam ni probao jer u server browseru ih nakon refresha izbaci 5-6 i to su svi sa pingom iznad 140+. Jel i vama tako?
#105 |
Datum registracije: Oct 2011
Lokacija: Ogulin
Postovi: 3
Pročitao sam sve komentare na ovu temu....nađem neki loš,pa pomislim da nema smisla kupovati igru,no onda naletim na hrpu pozitivnih utisaka. Kupujem igru,pa kud puklo da puklo. |
#106 | ||
DBS
Postovi: 1,855
#107 |
Lokacija: Ogulin
Postovi: 3
Zna li netko kada bi RO2 mogao stici kod nas.....ali u fizickom obliku.....kutija,dvd,..
#108 |
Postovi: 1,942
Najavljena prva ekspanzija Rising Storm. http://www.1cpublishing.eu/game/rising-storm/overview Mape izgledaju nešto šarenije što mi se nasprav trenutnih dosta monotonih mapa sviđa, da se razumijemo sve te mape su inače jako dobro dizajnirane. A i ako se dobro sječam, nešto su developeri pričali da bi svi buduću dlc-ovi mogli biti free. |
#109 | |
DBS
Postovi: 1,855
IIRC... Te veće ekspanzije kao Rising Storm i druga za Europsko ratište mislim da će se ipak nekaj naplaćivat. Sam DLC za RO2 tipa nova vozila, mape i oružja će bit besplatan (hint: oni topovi razbacani po pojedinim mapama). Citiraj:
Nemam pojima, nisam ni znao da će ga izdavat kao takvog. U svakom slučaju je kupnja preko Steama već ogroman popust nego da ga kod nas ideš nabavljat. Ako kao takav i izađe prije bih ga osobno uzeo preko eBay-a. |
#110 |
Postovi: 1,212
Evo je ovdje ispod 140kn s poštarinom, a dobiješ normalno retail pakiranje... barem bi trebao, stiže sljedeći tjedan pa javim.
#111 |
Lokacija: Ogulin
Postovi: 3
Ok,hvala vam ![]()
#112 |
Postovi: 1,212
Stigla igra no još moram čekati grafičku vjerojatno do ponedjeljka, taman dosta vremena dok se svi patchevi poinstaliraju ![]() Da li se vi s foruma nalazite pa zajedno igrate? Preko Xfirea? Netko je spominjao 3GB updatea? ![]()
što vole strance da nas vozaju u autu i kupuju skupe lance Zadnje izmijenjeno od: Srdan. 28.10.2011. u 14:23. |
#113 | |
Datum registracije: Dec 2010
Postovi: 327
Zalosno koliko je slabo optimizirana, proc mi je jedva 50% iskoristen dok igram, grafa jos manje. Stavio sam igru na led dok ne dođe razdoblje u kom ce se dat igrat kako spada. |
#114 |
Postovi: 17,073
To uopće nema veze s optimizacijom, nemože na gts raditi bolje nego na HD6950.. Imaš preslabi proc za tu grafu kak je i meni bilo. Ja sam svoga stavio na 3.4 i dalje je bio bottleneck za grafu.. U tome je problem. |
#115 | |
Postovi: 327
Al i dalje stoji da je igra odvratno lose optimizirana. EDIT: kak ti sad radi na tom phenomu? koja je fazna regulacija te ploce? jesi probo clockat phenoma? hrpa pitanja ![]() |
#116 |
DBS
Postovi: 1,855
Ko Ferrarijev motor u Stojadinu. ![]() Šalu na stranu, je igra je stvarno loše optimizirana. Kad sam SB dignuo na 4,5 FPS je poraso za nekih 10 više manje (sa ~50 na +60). Tako da je podosta CPU zahtjevna. Ja sam jedan od sretnika koji nema nikakvih problema s igrom izuzev resetiranja routera prilikom korištenja in game server browsera. |
#117 | |
Postovi: 327
![]() I ja planiram ubost 2500k...nadam se sto prije. Iako, BF3 s ovim kompom vrtim na 60 fpsa bez problema, doduše na high, ne ultra. Al izgleda isto, jer su teksture ogavne izbliza na kojim god postavkama igrao console ports ftw-.- |
#118 |
Postovi: 1,212
Evo malo igrao/ginuo... mrak je igra. Ovo sam samo malo prije spavanja 2 partije tek toliko da probam, sutra kak se spada.
#119 |
Postovi: 1,212
Evo meni ide ok na 1680 ultra settings (jedino AA na low) i vrti se 30-55fps-a. Prvih pola minute minutu bude koma (15-25), zatim se dogne na 25-40 neko vrijeme i dalje 30-55. Servere biram iz igre i još mi nije resetiralo router, možda sam i ja jedan od sretnih, a možda nisam dovoljno igrao ![]()
