Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI cilja na overclockere
Zanimljive specifikacije Sapphire Radeon Xpress 200 ploče, sudeći po njima-overclockeri su ciljana skupina CPU Power Delivery: -4 phase CPU power supply with the ability to deliver 170+ Amps -provision for passive, water block or active air cooled mosfets (heatsink form factor is the same as the northbridge) -voltage range to 2.7V but artificially clamped to 2.0V -voltage increments as fine as 20 mV Memory Power Delivery: -upto 30 Amps delivery potential -voltage range to 4.0V -voltage increments as fine as 20 mV -adjustable VTT (memory termination voltage) to +/- 10% of memory VDD NB Power Delivery: -NB core has it's own power rail with 4 discrete steps HT Power Delivery: - HT I/O has it's own power rail with 4 discrete steps PCI-E 1.2V Power Delivery: - PCI-E 1.2V I/O has it's own power rail with 4 discrete steps PCI-E 1.8V Power Delivery: - PCI-E 1.8V I/O has it's own power rail with 2 discrete steps Board Features: Onboard Devices: -twin Silicon Image SI3132 SATA II w/ NCQ chips connected via PCI-E, each chip providing 2 SATA ports. (8 SATA ports total; 4 are SATAI and 4 are SATAII w/NCQ) -Marvel Gigabit LAN connected via PCI-E -one general purpose single lane PCI-E slot (provisioned for 1 more single lane general purpose slot if one SI3132 is not populated as a build option) -Azalia audio support via SB450 using Realtek codec -POST code LED display -Firewire support with ViaVT6306 -VGA and DVI outputs via Radeon Xpress 200G (enabling upto 4 monitor outputs using an ATI add in card and ATI Surroundview) -onboard power and reset switches -onboard VID code LED display Overclocking Options: -HTT frequency upto 500 MHz -All relevant memory timings and adjustments including support for new Rev E CPUs -HT link ratios X1, X2, X3, X4,X5 -Independent PCI-E overclocking for the graphics bus Thermal Monitoring: -thermal monitoring of CPU power delivery circuitry, CPU, NB and ambient That's all I can remember for now. Here are some pictures of the motherboard and the custom Danger Den waterblocks that will be made available for sale specifically for this application. Sljikice tu: http://www.xtremesystems.org/forums/...ad.php?t=55734 Izgleda jako dobro... |
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,463
E, ovo bi mogla biti jedna dobra generacija ploči. ako su bios uštimali, i ploča nije bugovita. bit će ovo jedna ebena ploča... Kad ovaj moj rig odsluži svoje, čini mi se da ide full ati kombinacija ![]() |
Lokacija: Ispred kompa
Postovi: 2,004
u joj ovo jako dobro zvuci. btw kad bi to konacno trebalo biti dostupno?
#4 | |
Super Moderators
Postovi: 17,485
Sad je valjda sve ok. Navodno će biti jeftinije od Nvidie, trebale bi biti dostupne u roku od 15-tak dana. Ste vidjeli slike sa vodenim blokovima???...baš dobro izgleda ![]() |
Caught Somewhere In Time
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
jedva čekam da ovo isprobam |
#6 | |
Super Moderators
Postovi: 17,485
#7 | |
Postovi: 1,860
jedino sam malo skeptičan prema saphirru ali valjda bu ih ati dobro stegnuo da ovo čudo ispadne dobro |
#9 | |
Super Moderators
Postovi: 17,485
Pogledaj malo specifikacije ploče i do koliko su stavili da možeš dizati proc i memu. Jedino još DFI ima do 4v, nitko više. I samo spominjanje vodenog hlađenja mosfeta i slične perverzije je bilo dosta da mulci po overclock siteovima počnu balit ![]() |
Datum registracije: Apr 2004
Postovi: 301
a i sama dobro izgleda, pogotovo blokovi za cpu/nb/mosfete ![]()
HARDCORE 4 LIFE athlon xp 2500+ @ 3200+ (11x200) gigabyte ga7n400l ( n force2 ) gigabyte radeon9600pro (@ 510/700 ) 2x256 Samsung ddr400 ŽENE SU KAO RAM, ŠTO VIŠE IMAŠ TO BOLJE |
Postovi: 900
ludnica od ploce hebote. konacno za ati freekove... jelc - za 15 dana kod nas u prodaji ili? |
#13 | |
Super Moderators
Postovi: 17,485
#14 | |
Super Moderators
Postovi: 17,485
#16 | |
Super Moderators
Postovi: 17,485
#17 |
Lokacija: Zabok
Postovi: 3,408
Ono je bila demo ploča/inžinjerski primjerak sa lemljenim žicama sa stražnje strane. Bila je OK osim mislim problema sa USB-om. Pretpostavljam sa ova Sapphireova ima noviju reviziju SB-a, a mogli su staviti i onaj novi ULI SB. |
