Split resist itself!
Postovi: 4,037
Arctic Cooling Accelero Mono PLUS
![]() ![]() ![]() Specifikacije: Max. Cooling Capacity 200 Watts Heatpipe Ø 6 mm x 5 Heatsink Material Aluminum fins x 43, thickness 0.4 mm Fan (mm) 120 mm, 400 - 1,500 RPM (controlled by PWM) Bearing Fluid Dynamic Bearing Noise Level 0.4 Sone Current, Voltage 0.08A - 0.13A, 4.2V - 12.0V Dimensions (Product) 136 (L) x 138 (W) x 51 (H) mm Dimensions (Packaging) 140 (L) x 140 (W) x 58 (H) mm Net Weight 348 g Limited Warranty 6 years Accessories Heatsink 26 pcs Screw (M2) 4 pcs Washer 4 pcs Spacer (2.0 mm) 4 pcs Spacer (4.0 mm) 4 pcs G-1 Thermal Glue (2.0 g Grey Compound) 1 bag G-1 Thermal Glue (2.0 g White Compound) 1 bag Mixing Wand 1 pc 4-Pin Fan Power Adapter 1 pc VGA Bracket 1 pc Mounting Plate 2 pcs itemnumber DCACO-V430001-BL UPC 0872767004665 Gross Weight 0.8 kg Cijena: 59,95$ ![]() Podržane grafičke: AMD Radeon 6000 6950, 6870, 6850, 6790, 6770 5000 5870, 5850, 5830 4000 4890, 4870, 4850, 4830, 4770 3000 3870, 3850 2000 2600 XT 1000 1950 XTX, 1950 XT, 1950 Pro, 1950 GT, 1900 XTX, 1900 XT, 1900 GT, 1800 XT, 1800 XL, 1800 GTO, 1650 XT, 1650 Pro, 1600 XT, 1600 Pro, 1550, 1300 XT, 1300 Pro, 1300 NVIDIA GTX 560Ti, 560, 550Ti, 550, 465, 460 SE, 460 GTS 450, 250, 240 (OEM), 150 (OEM) GT 340, 330, 320, 130 (OEM) 9000 9800 GTX+, 9800 GTX, 9800 GT, 9600 GT, 9600 GSO 512, 9600 GSO 8000 8800 GTX (G80), 8800 GTS 512 (G92), 8800 GTS (G92), 8800 GTS (G80), 8800 GT, 8800 GS (9600GSO) 7000 7950 GT, 7900 GTX, 7900 GT, 7900 GS, 7800 GTX 512, 7800 GTX, 7800 GT 6000 6800 XT AGP, 6800 XT, 6800 Ultra Extreme, 6800 Ultra, 6800 LE, 6800 GT, 6800 GS AGP, 6800 GS, 6800 AGP, 6800, 6600 LE, 6600 GT AGP, 6600 GT, 6600 DDR2, 6600 Recenzije: Nema Conclusion: Iako bi valjalo pričekati koji review i da vidimo cijenu kad dođe u nas (Links/ADM-a), smatram da je bolja kupovina (i po pitanju cijene i performansi) AC S1 rev. 2 s neka 2 vulgaris 12cm venta (nažalost trenutno nedostupan). Kao šta stara "poslovica" kaže Fata je Fata ali dvaput je dvaput - odnosi se na broj ventova ![]()
![]() Pomelo mi sig -.- |
Takozvani influenser
Lokacija: Dublin
Postovi: 649
zanimljiv dizajn, samo u kakvo kućište stane ta grdosija? |
Postovi: 4,037
Daleko je to od grdosije - ovo je praktično uvećani Arctic Cooling L2 Pro, pogledaj malo njihove druge modele (ili drugih proizvođača), taman je nekakve "srednje" veličine/težine S1 PLUS je ionako tek proizveden (valjda je to duhovni nasljednik), samo je pitanje Linksovih "nameta" , u odnosu na S1 Rev. 2Alternativa je naravno lurkanje polovnjača po tržnjacima ![]()
Postovi: 8,218
Sent from AS/400. |
Datum registracije: May 2009
Postovi: 389
Pa S1 rev 2 bude sigurno EOL, ali zato postoji S1 PLUS. Isti vrag sa nekom plastikom okolo i pomaknutom bazom. Ljepši mi je stari iako ovaj novi paše i na moju kartu. Edit: a j.g sori nisam pročital taj tvoj post poslje, kad sam tup .Zadnje izmijenjeno od: Elpresidente1. 19.10.2011. u 20:56. |
#8 | ||
Postovi: 4,037
![]() Inače izgledom oba nisu ništa specijalno (S1 + i S Rev. 2), posebno kad DIY metodom prikeljiš par ventova, ali koga uopće briga za ljepotu - važna je termalna učinkovitost i cijena ![]() Usput thread je o AC Mono + modelu
#9 | |
Xulos :)
Postovi: 7,567
BTW : http://www.kitguru.net/components/gr...oler-review/2/ Ovo su takva dva "spojena" obicnim komadom lima da se drza jedan za ddrugi i hlade 6990, IMHO ako je 1 takav u stanju ohladiti 1 gpu od 6970 mislim da bi i ove nvidie izdrzao
Postovi: 8,218
Kom će onda prodat ostale kulere ak ovaj bude mogao na sve ![]()
Sent from AS/400. |
Postovi: 5,991
470 je gora od bilo koje AMD kartice za ohladit i ovaj polovicni hladnjak nebi bio optimalan izbor za nju..AMD se moze hladit i sa slabijim hladnjacima a high end Nvidia nema sansi.. Sve je savrseno jasno kad se otvore grafe i stave jedna pored druge, nebo i zemlja.. |
