Staro 31.05.2010., 00:04   #1
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,217
BSOD za vrijeme igranja bad company 2
nakon 2-3 sata igranja dobio sam bsod
uploudao sam minidump pa ako netko iz toga možda zna očitat problem
http://www.sendspace.com/file/o9ea3y
Staro 31.05.2010., 03:15   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
MODULE_NAME: nt
FAULTING_MODULE: fffff80002e03000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4b88cfeb
BUGCHECK_STR: 0x1a_41284
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff80002ec9df3 to fffff80002e73600
STACK_TEXT:
fffff880`047ec038 fffff800`02ec9df3 : 00000000`0000001a 00000000`00041284 00000000`5bc47001 00000000`0003e64f : nt+0x70600
fffff880`047ec040 00000000`0000001a : 00000000`00041284 00000000`5bc47001 00000000`0003e64f fffff700`01080000 : nt+0xc6df3
fffff880`047ec048 00000000`00041284 : 00000000`5bc47001 00000000`0003e64f fffff700`01080000 00000000`00000297 : 0x1a
fffff880`047ec050 00000000`5bc47001 : 00000000`0003e64f fffff700`01080000 00000000`00000297 fffff680`002de238 : 0x41284
fffff880`047ec058 00000000`0003e64f : fffff700`01080000 00000000`00000297 fffff680`002de238 fffff800`02ea4315 : 0x5bc47001
fffff880`047ec060 fffff700`01080000 : 00000000`00000297 fffff680`002de238 fffff800`02ea4315 fffff700`01080000 : 0x3e64f
fffff880`047ec068 00000000`00000297 : fffff680`002de238 fffff800`02ea4315 fffff700`01080000 e4f00000`79e1980d : 0xfffff700`01080000
fffff880`047ec070 fffff680`002de238 : fffff800`02ea4315 fffff700`01080000 e4f00000`79e1980d e0a00000`7f0d4c0c : 0x297
fffff880`047ec078 fffff800`02ea4315 : fffff700`01080000 e4f00000`79e1980d e0a00000`7f0d4c0c 00000000`00000000 : 0xfffff680`002de238
fffff880`047ec080 fffff700`01080000 : e4f00000`79e1980d e0a00000`7f0d4c0c 00000000`00000000 00000000`00000000 : nt+0xa1315
fffff880`047ec088 e4f00000`79e1980d : e0a00000`7f0d4c0c 00000000`00000000 00000000`00000000 fffff8a0`0a36b000 : 0xfffff700`01080000
fffff880`047ec090 e0a00000`7f0d4c0c : 00000000`00000000 00000000`00000000 fffff8a0`0a36b000 fffffa80`05749790 : 0xe4f00000`79e1980d
fffff880`047ec098 00000000`00000000 : 00000000`00000000 fffff8a0`0a36b000 fffffa80`05749790 fffff680`002deff8 : 0xe0a00000`7f0d4c0c
STACK_COMMAND: kb
FOLLOWUP_IP:
nt+70600
fffff800`02e73600 48894c2408 mov qword ptr [rsp+8],rcx
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt+70600
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntoskrnl.exe
BUCKET_ID: WRONG_SYMBOLS
Followup: MachineOwner
Autor M4mut Pregled postova
Sto je tocno pisalo na bsod-u?
Ram ispravan, (koliko se sijecam nedavno si dobio nove keksice)?
Jesi probao "presaltat" po utorima?
Sto kaze Event viewer, control panel -> administrative tools -> ljevo windows logs -> system?
MODULE_NAME: nt
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
nt+70600
IE6
Linux is Not Windows
Staro 31.05.2010., 07:20   #3
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,217
event viewer kaže critical i The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly., sad neznam što te zanima točno
sad u vezi BSODa, ovako, nisu zamijenili keksiće već očistili konektore na postojećim i onda radi
no desilo se nešto zanimljivo sinoć, nedugo nakon BSODa išao sam odvrtit memtest i bacao je errore, onda sam ugasio komp i sad da ću već nosit pc na servis i idem odvrtit memtest i odvrti 2 passa bez ijednog errora
:O
Staro 31.05.2010., 12:18   #4
Joke
N00B
Joke's Avatar
Postovi: 3,886
Pa odvrti memtest preko noci za svaki keksic posebno..
IE6
Staro 31.05.2010., 12:48   #5
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,217
nesmijem vadit keksiće
Staro 31.05.2010., 12:55   #6
mirdaVG
mirdaVG's Avatar
Datum registracije: Jul 2009
Lokacija: Velika Gorica/Zagreb
Postovi: 77
U tvome minidump-u piše da je razlog bsod ntoskrnl.exe. Negdje sam letimično pročitao da to ima veze s diskom ili driverima od grafe,ali pogledat ću malo detaljnije
mirdaVG je offline   Reply With Quote
Staro 31.05.2010., 13:05   #7
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,217
sad sam isto nakon igranja bad companya (nije bilo bsoda) išao vidit memtest, i prošao je bez errora
bsod sam samo jučer dobio, znači nije da ga uvijek dobijem..ali opet :S
Staro 31.05.2010., 13:25   #8
mirdaVG
mirdaVG's Avatar
Postovi: 77
Također ti se u file-u spominje dxgmms1.sys što je vezano za sami driver grafičke. Probaj sljedeće stvari:
1.skeniraj memoriju s goldmemory
2.provjeri disk za bad sektore
3.upiši u run sfc /scannow
4.napravi stability test grafičke u furmarku
5.probaj staviti druge drivere,po mogučnosti od samog proizvođača grafičke
Staro 31.05.2010., 13:57   #9
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,217
1.nemam prazan CD pa to nemogu napravit (((
2.prošao sa HD Tune i sve zeleno (nema bad)
3.napravio, al sam ti pokrenuo i otišao afk kad sam se vratio ugasilo se, neznam jel ok
4.napravio sve ok
5.nisam još, bude li bsod-a napravit ću
Staro 31.05.2010., 14:33   #10
mirdaVG
mirdaVG's Avatar
Postovi: 77
4.napravio sve ok
1.nabavi prazan cd
2.ok
3.to je ok
4.ok
5.ovo me najviše zanima
Staro 31.05.2010., 14:42   #11
Joke
N00B
Joke's Avatar
Postovi: 3,886
Autor mirdaVG Pregled postova
Da ako nije graficksa syebana onda da je syebe sa furmarkom..
1.nabavi prazan cd
Nabavi USB stick..
IE6
Staro 31.05.2010., 14:43   #12
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,217
imam musb al memtest uspijem stavit na njega, a golden memory ne
kroz sat vremena ću dobit prazan cd pa ću stavit golden memory
Staro 31.05.2010., 14:48   #13
mirdaVG
mirdaVG's Avatar
Postovi: 77
Autor Joke Pregled postova
Nabavi USB stick..
Napisao sam "stability test" ne "burning test"
