Staro 23.05.2010., 14:30   #4021
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor Neo-ST Pregled postova
Odlično!
Kako ne, i opet ćemo
Treba jednom probat onu shemu, netko ubija snajperistu, a ja ga oživljavam, pa tako stalno
Učinjeno.Proudixz i ja smo nekog snajperistu doslovno izmrcvarili.Ja ga oživljavam,Proudixz ubija.Kad Proudixz ostane bez metaka,ja defibrilatorom ubijem snajpera,Proudixz nabavi ammo,ja oživim snajpera,itd.
lol
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 23.05.2010., 14:31   #4022
The Fury
The Fury's Avatar
Lokacija: Velika Gorica
Postovi: 178
Došli su novi driveri za ATI grafičke kartice, probaj snimiti 10.4. ako već nisi.
Preporučujem i ostalima isto. http://game.amd.com/us-en/drivers_ca...=xp/radeonx-xp
"Battlefield 2: Bad Company" maps no longer takes unusually long to load for ATI
Radeon™ HD 5000 Series
Flickering corruption and flashing textures are no longer visible in "Battlefield 2: Bad
Company"
Ali kaže i sljedeće: Known Issues Under All Windows Operating Systems
The following section provides a summary of open issues that may be experienced under
the Windows operating system in the latest version of Catalyst™. These include:
�� Loading time between maps in "Battlefield 2: Bad Company" may be long for ATI
Radeon™ HD 2000, 3000 and 4000 Series
The Fury je offline   Reply With Quote
Staro 23.05.2010., 14:32   #4023
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
Autor hobitxxx Pregled postova
svi driveri su novi skroz tj najnoviji neznam al je patchana el to ono dok se updejta na pocetku ili?
Da
xGAME je offline   Reply With Quote
Staro 23.05.2010., 14:50   #4024
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor The Fury Pregled postova
Company"
Imaš pravo,možda bi trebao staviti ATi drajvere na eNvidijinu grafičku,sigurno će mu to riješiit sve probleme.
Staro 23.05.2010., 14:53   #4025
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,271
Autor Mansky Hunt Pregled postova
lol
a daj?? kada ste to? ja nisam bio tu da se smijem
"Battlefield 2: Bad Company" maps no longer takes unusually long to load for ATI Radeon™ HD 5000 Series
Loading time between maps in "Battlefield 2: Bad Company" may be long for ATI Radeon™ HD 2000, 3000 and 4000 Series
Meni ovo nije jasno. Imam 4870X2 i zadnje drivere (10.4 final) i svejedno se dugo učitavaju mape. Da li to znači da će se nakon ovog "fixa" još duže učitavat ili smanjit ili ostat isto ?
Staro 23.05.2010., 15:03   #4026
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Ma no frks brat,eo danas ćemo ti i ja izmrcvarit nekog snajpa.
JA BI VOZILA ČOPEEEERAAAAAAAAAAAAAA
Staro 23.05.2010., 15:22   #4027
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,271
Ma idi baci motion sensor ili nešto
Staro 23.05.2010., 18:55   #4028
The Fury
The Fury's Avatar
Postovi: 178
Ja imam 4850 i imam neke starije drivere. Meni recimo očitava duže mapu nego inaće jer je ekipa ugl već krenula sa igrom kada se ja spojim. E sada, bemu vrapca, ovaj 10.4. mi je zbunjujuć kao i tebi.
Da ga metnem il da ga ne metnem pitanje je to?
Možda isprobam pa ću vidjet razliku. Ćemo da vidimo.
Staro 23.05.2010., 19:13   #4029
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Več sam ti bio napisao odgovori i dao link i to prije 21 dan
Trebaš 10.4a Preview drivere koji u sebi imaju i fix za 4xxx seriju.
Autor Veki-os Pregled postova
Staro 23.05.2010., 19:32   #4030
The Fury
The Fury's Avatar
Postovi: 178
Hvala Veki, to je mene isto mučilo. Baš si srce
Ovo je fix za Vistu i Win 7. Ja sam na XP-u
Staro 23.05.2010., 21:17   #4031
Veki-os
Veki-os's Avatar
Postovi: 3,996
Staro 23.05.2010., 23:53   #4032
The Fury
The Fury's Avatar
Postovi: 178
Battlefield: Bad Company 2 - Long load times for new maps when using a Windows® 7 / Windows Vista® based system with an:
Malo si fulao ali nema veze.
Triumpj mi je objasnio da je do procesora tako da badava meni ovo. Ali hvala.
Zadnje izmijenjeno od: The Fury. 23.05.2010. u 23:58.
Staro 24.05.2010., 01:09   #4033
thesekiman
Pr0d1gy
thesekiman's Avatar
Postovi: 288
e decki more mala pomoc u vezi battlefielda ovak igram jedno 10 minuta i onda mi slika jednostavno zasteka i moram sa task managerom gasiti jel nekome bilo slicno kaj?
meni se ne zamrzne dok igram, nego kad hoću izaći iz igre, stisnem exit, pojavi mi se ono "are you sure bla bla", i kad stisnem yes tako mi zablokira. Isto moram izaći u task manager pa ugasit proces iz njega. Na Win7 x64
thesekiman je offline   Reply With Quote
Staro 24.05.2010., 08:34   #4034
zgmmax
zgmmax's Avatar
Postovi: 1,659
JA imam 4890 i dok sam imo stare drivere mi se loadalo nekih 30ak sekundi, kada sam stavio ove 10.4a sada mi loadanje traje nekih 10ak sekundi
isplati ih se stavljat
stare drivere nisam uninstaliro nego sam ih sam pregazio sa novima i nemam nikakvih problema
Staro 24.05.2010., 09:17   #4035
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Evo ja sam malo obnovio konfu i sad mi igra radi dosta fluidnije!
Staro 24.05.2010., 10:18   #4036
lajchi
Postovi: 506
Ček malo, koja je razlika između 10.4 i 10.4a ?
Imam 10.4 i 4850 i učitava užasno dugo.
lajchi je offline   Reply With Quote
Staro 24.05.2010., 10:43   #4037
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Autor lajchi Pregled postova
10.4a je valjda alpha a onda ocito je 10.4 gotov proizvod tj driver za masovnu uporabu ..pa iz nekog logicnog razmišljanja se doalzi do zakljucka da je 10.4 bolji nego a ,ili sam u krivu?ja imam 10.4(ati 4850) i sve je ok,malo duze se load al sta cu ,neznam kako je bilo prije jer nisam imo bc2.
viper je offline   Reply With Quote
Staro 24.05.2010., 10:57   #4038
RiSbO
RiSbO's Avatar
Postovi: 254
Za BC2 serija 4xxx najibolje je 10.4b verzija..mape se load-aju stvarno brzo
RiSbO je offline   Reply With Quote
Staro 24.05.2010., 11:02   #4039
zgmmax
zgmmax's Avatar
Postovi: 1,659
mislim kaj vi ne znate citat
http://support.amd.com/us/kbarticles...-a-Hotfix.aspx
tu sve lijepo pise
The ATI Catalyst 10.4a Preview provides resolution for the following issue:
  • Battlefield: Bad Company 2 - Long load times for new maps when using a Windows® 7 / Windows Vista® / Windows XP® based system with an:
    • ATI Radeon™ HD 5xxx series graphics card
    • ATI Radeon HD 4xxx series graphics card
    • ATI Radeon HD 3xxx series graphics card
    • ATI Radeon HD 2xxx series graphics card
stavi ove 10.4a i skratit ce ti se vrijeme loadanja
Staro 24.05.2010., 12:27   #4040
xGAME
xGAME's Avatar
Postovi: 4,777
EuroGamers klan organizira friendly turnir (16vs16) početkom 6. mjeseca, 2 tima su, Warthogs i Cobras, pa si vi sami brate u kojem želite biti; znači nije da se klanovi prijavljuju za to nego vi pojedinačno ulazite u pojedini tim koji odaberete...
Uglavnom evo linkove za sve:
Pravila
Timovi
Registracija
Prijavio bi se, al ne znam koliko ću vremena imat u 6. mjesecu
Btw pogledajte ovo:
http://www.youtube.com/watch?v=k_XyPvK3bG0
Predobro
Zadnje izmijenjeno od: xGAME. 24.05.2010. u 12:38.
Staro 24.05.2010., 13:06   #4041
CyCl0p$
op vidim da se igra conquest. zanimljivo kako nisu rush stavili...
softcore i killcam off, to je to
Staro 24.05.2010., 13:38   #4042
viper
super user
viper's Avatar
Postovi: 1,805
Autor zgmmax Pregled postova
gle stvarno brže je ... onda zasto to nisu stavili i u 10.4?lol
Staro 24.05.2010., 13:44   #4043
Terminator02
Terminator02's Avatar
Postovi: 602
Jesu li ovo ti najnoviji driveri?
Nemam instaliran CCC pa mogu vidjeti samo odavde, a nigdje mi ne piše 10.4
Primjetia sam da mi i dalje bljeskaju mape dok se ne uključim u igru.
Terminator02 je offline   Reply With Quote
Staro 24.05.2010., 13:59   #4044
viper
super user
viper's Avatar
Postovi: 1,805
Autor Terminator02 Pregled postova
meni pise
Driver date:19.04.2010
Driver version: 8.723.5.0 a te sam sad instaliral ,10.4a
ljepo skini opet i instaliraj ,nist te nekosta ...
Staro 24.05.2010., 14:05   #4045
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,809
Moram se ispricati B3mti-u za jucerasnje prebacivanje po kanalima. Ali mislim da nit nije uredu da budes na TS i u suprotnom timu si, a da nit neznamo da si na kanalu.
Eto sljedeci put se barem javi pa cemo te prebaciti u nas tim ili cemo paziti sta pricamo
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 24.05.2010., 16:37   #4046
Terminator02
Postovi: 602
Autor viper Pregled postova
meni pise
Sad vidim da ti imaš Win 7, a ja Xp.
Meni je ponudilo ove drivere kao zadnje.
Staro 24.05.2010., 19:17   #4047
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Aww,predivan post Bazajaytee-a na Twitteru:
NO PATCH FOR YOU TODAY.
_____________
Aww <3
I kaže da imaju,pazi sad,DRUGOG programera koji radi na patchu,pošto je glavni na godišnjem.Divno.Unajmili su nekog lijevog da krpa njihov posao.
Staro 24.05.2010., 19:33   #4048
kill
Datum registracije: Jun 2003
Postovi: 533
možda taj lijevi napravi posao kako spada
kill je offline   Reply With Quote
Staro 24.05.2010., 19:41   #4049
Veki-os
Veki-os's Avatar
Postovi: 3,996
To su budale,koliko sam skontao na EA forumu,ti što prave patch ne rade subotom nikada a u Švedskoj svaki tjedan ima bar dva praznika u ovih 5 radih dana,komedija.
Staro 24.05.2010., 21:48   #4050
xGAME
xGAME's Avatar
Postovi: 4,777
Ajmo svi u švedsku živjet ako je toliko praznika
Ma boli njih k.., oni su novce pokupili i to je to
