Staro 11.03.2010., 15:59   #1261
sick_boy
sick_boy's Avatar
Postovi: 680
Beljska Graša - 11kn/lit (barem bila prije par mjeseci) a vino skroz solidno - nekoliko puta se ubio od čistog bez neželjenih posljedica.
Crno ipak preferiram iz butelje - nekako loše podnosim ova rinfuzna (ima Matuškovog plavca na akciji za 24kn/butelja u Intersparu - skroz solidno vino za te pare).
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 11.03.2010., 16:01   #1262
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Autor sick_boy Pregled postova
To na Sjenjaku?! 22KN 2L vina, 5KN 1.5L kisele. Lijepo...
Staro 11.03.2010., 16:02   #1263
sick_boy
sick_boy's Avatar
Postovi: 680
Da, na Sjenjaku. Doduše, nisam bio u zadnjih par mjeseci (točnije, od 10.-tog mjeseca prošle godine)-
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 11.03.2010., 19:48   #1264
domy_os
domy_os's Avatar
Postovi: 18,848
Kad se meni pije vino, skoknem do Iloka i pijem u iločkim podrumima...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 11.03.2010., 19:51   #1265
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Autor timmy Pregled postova
Jel ima tko kakav s.939 procesor za posudit na sat-dva samo da isprobam jednu ploču? Centar i bliža okolica, treba mi večeras, sutra ili što prije. Plaćam ćevape
EDIT: kontakt na PM.
Imam ja jednog San Diega 3700+.
Kada će neki sastanak u OS, ali nešto malo masovnije, da ne dolazim bezveze?
Staro 11.03.2010., 21:03   #1266
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
Po ovakom vremenu ni po kruh neidem ... nisu mi se udostojili kroz ulicu ralicom proci...ali ako ima ekipe budem došel
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 12.03.2010., 00:48   #1267
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
Ja sam za neko opijanje i žderanje, ako ima još koga nek predloži mjesto i vrijeme.
Autor Milentije Pregled postova
Hvala, riješio u servisu (da mi režeš glavu zaboravio kako se zove i sad ih ne mogu izreklamirat), čovjek mi posudio Opterona 144.
timmy je offline   Reply With Quote
Staro 12.03.2010., 12:12   #1268
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Ajde skontajte se nekako da tu budu i Domy, Veki, Srky, Mislav, POP, Momir i ekipa, pa da doletim i ja.
Staro 12.03.2010., 13:17   #1269
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
A teško se skontat kad nekom paše jedan dan, drugom drugi dan.
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 12.03.2010., 15:28   #1270
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Ja dolazim samo ako se loče!
Staro 12.03.2010., 16:17   #1271
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Onda ja čekam jedan od onih dana u mjesecu kod POPa. Pa mislim, ja se moram nekako vratiti autom, dakle nema pijancenja za mene.
Staro 12.03.2010., 16:44   #1272
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
haha Kroner Neznam za vas, ali npr u TOP-u je cist oke. A moglo bi se dat nesto i prezalogajiti
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 12.03.2010., 17:16   #1273
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Samo nek nisu oni "ćevapi" iz Citya i sve 5.
Staro 12.03.2010., 17:34   #1274
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
ma ovdje ima dobre klope mislim da dobijes onaj sendvic od 30-40cm za kojih 50kn...bar su mitak pricali a nemam prilike nikak otici i provjeriti
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 14.03.2010., 00:14   #1275
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
haha ovo je samo priča, a sastanka neće biti još 6 mjeseci. sa mnom možete na miting svake subote, nekad i petkom
Staro 14.03.2010., 14:25   #1276
mislav_os
freak
Postovi: 2,688
Autor fre@k Pregled postova
Istina,ziva istina. Za 28kn sendvic od 30cm ...probao.
Ali TOP je mal,nemas gdje sjest itd .
Ajmo ekipa stvarno,jel netko zainteresiran?? Vidim sad tu vas par da jeste,ali di je jos ljudi??
Ajde napisite ako zelite ici pa ako nas se skupi idemo bilo gdje,neki neka jedu,neki neka piju .
Mislim,sramota...Mile bi iz Doboja dosao a vama tesko prosetat malo..ccc
Staro 13.04.2010., 19:39   #1277
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Dolazim u petak naveče. Krećem iz Doboja oko 17, dakle tamo sam oko 20h.
Organizujte se.
Staro 13.04.2010., 19:47   #1278
Srky
Srky's Avatar
Postovi: 3,263
Sta onda ko bi došo sve da vidimo i gdje bi se našli?
Staro 13.04.2010., 19:50   #1279
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Evo sad sam sa Domyem preko MSN-a pricao. On rece da ce sutra znati hoce li biti tu ili ce morati na put, pa ce mi javiti. Mislavu sam poslao PM, pa cekam odgovor. Moze li neko obavjestiti Momira, da vidimo je li on zainteresovan? POPu sam poslao link na temu na MSN-u ali ljudina izgleda spava, cekamo i njega da se izjasni ovde.
Mjesto mi je apsolutno nebitno, samo bi bilo dobro da me neko saceka na ulazu u grad, da se ne zagubim negdje. Dolazim autom.
Dakle za sada su na spisku:
1. Srky
2. Milentije
3. Djuxoni (moja pratnja)
4. Domy ?
5.
Staro 13.04.2010., 23:32   #1280
mislav_os
freak
Postovi: 2,688
U petak mi je rodjendan. Idem popodne u skolu i poslije skole moram kuci jer dolaze gosti.
Kvragu,bas mi je zao .
Hebem te Mile,jel od svih 365 dana u godini ti bas moras na moj rodjendan?
Stv,zao mi je...pa de jel moze u subotu?
Staro 13.04.2010., 23:44   #1281
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Ja radim 15-23
Staro 14.04.2010., 00:01   #1282
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Ne mogu u sobtu. U subotu moram u Banja Luku po LN2.
POP, ti ono radis u nekoj piceriji? Ako sam u pravu, mozemo se skupiti kod tebe na poslu da ti smetamo i zderemo dok ti radis.
Staro 14.04.2010., 00:02   #1283
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
Milentije možeš spavat kod mene ako ostanem u OS
Staro 14.04.2010., 00:03   #1284
mislav_os
freak
Postovi: 2,688
Ali POP je dostavljac
A nista onda od mene...al hebemu,cijelu godinu vas nagovaram,i vi taman na moj rodj sastanak dogovorite..ccc.
Staro 14.04.2010., 00:10   #1285
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Ne možete...
Staro 14.04.2010., 00:21   #1286
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
A pazi, rijetko odbijam poziv na orgije, ali šta ćemo sa maloljetnom osobom koja dolazi u pratnji?
Hvala na ponudi ali nema ništa od spavanja, moram u suboru rano ujutru biti u BL.
Autor -POP- Pregled postova
Ne možete...
E jesi nekiiiiiiiiiiiiiiiiiiiiiiii...
Staro 14.04.2010., 00:29   #1287
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
http://forum.pcekspert.com/showpost....&postcount=549
Bolje mi riješite ovu misteriju...
Staro 14.04.2010., 07:06   #1288
Momir
Momir's Avatar
Postovi: 1,011
ja mogu u petak, meni subota neodgovara
Momir je offline   Reply With Quote
Staro 14.04.2010., 09:50   #1289
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
1. Srky
2. Milentije
4. Domy (?)
5. Momir
6. Veki (?)
Pope, opstuišeš na dogovore oko sastanka.
Staro 14.04.2010., 10:08   #1290
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
1. Srky
2. Milentije
3. Djuxoni
4. Domy (?)
5. Momir
6. Veki (?
7. timmy (ako ostane u Osijeku za vikend)
