Staro 01.02.2010., 23:35   #661
domis
Lokacija: Hrvatistan
Postovi: 4,164
tko je kriv ako muškarac pregazi autom ženu?
pa muškarac, nema se on kaj voziti po kuhinji
Staro 01.02.2010., 23:37   #662
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
Evo jednog glupavog:
Kako se zove svemirski moljac?
Vanzemoljac
na ovakve gluposti se najbolje nasmijem
Staro 02.02.2010., 23:29   #663
swordfish
aka: N.W.S.K. b_buha
swordfish's Avatar
Postovi: 215
evo neznam dal je vec bilo ali eto...
Girlfriend 5.0 to Wife 1.0 : )
Dear Tech Support Team:
Last year I upgraded from Girlfriend 5.0 to Wife 1.0.
I soon noticed that the new program began unexpected child-processes that
took up a lot of space and valuable resources.
In addition, Wife 1.0 installed itself into all other programs and now
monitors all other system activities.
Applications such as BachelorNights 10.3, Cricket 5.0, BeerWithBuddies 7.5,
and Outings 3.6 no longer runs, crashing the system whenever selected. I
can't seem to keep Wife 1.0 in the background while attempting to run my
favorite applications.
I'm thinking about going back to Girlfriend 5.0 , but the 'uninstall'
doesn't work on Wife 1.0.
Please help!
Thanks,
"A Troubled User"
REPLY:
Dear Troubled User:
This is a very common problem that people complain about.
Many people upgrade from Girlfriend 5.0 to Wife 1.0, thinking that it is
just a Utilities and Entertainment program.
Wife 1.0 is an OPERATING SYSTEM and is designed by its Creator to run
EVERYTHING!!!
It is also impossible to delete Wife 1.0 and to return to Girlfriend 5.0.
It is impossible to uninstall, or purge the program files from the system
once installed.
You cannot go back to Girlfriend 5.0 because Wife 1.0 is designed not to
allow this. (Look in your Wife 1.0 Manual under Warnings-Alimony-Child
Support) .
I recommend that you keep Wife1.0 and work on improving the environment.
I suggest installing the background application "Yes Dear" to alleviate
software augmentation.
The best course of action is to enter the command C:\APOLOGIZE because
ultimately you will have to give the APOLOGIZE command before
the system will return to normal anyway.
Wife 1.0 is a great program, but it tends to be very high maintenance. Wife
1.0 comes with several support programs, such as Clean 2.5, Sweep 3.0, Cook
1.5 and DoLaundry 4.2. However, be very careful how you use these programs.
Improper use will cause the system to launch the
program NagNag 9.5 . Once this happens, the only way to improve the
performance of Wife 1.0 is to purchase additional software. I recommend
Fineclothes 2.1 and Jewellery 5.0
STATUTORY WARNING : DO NOT, under any circumstances, install
SecretaryWithShortSkirt 3.3. This application is not supported by Wife 1.0
and will cause irreversible damage to the operating system.
Kerry Fordham
A/R Administrator
Greenwin Property Management Inc.
416-544-4838
u alkoholu sigurno ima ženskih hormona , jer ja kad popijem ne znam voziti auto i počnem pričati gluposti.....
swordfish je offline   Reply With Quote
Staro 02.02.2010., 23:50   #664
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Zagreb / Maksimir
Postovi: 4,007
Kako se zove cigan koji dolazi odnekud?
FROM
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
fanATIk je online   Reply With Quote
Staro 03.02.2010., 01:36   #665
sinke.ZG
sinke.ZG's Avatar
Postovi: 733
uhvati plavusa zlatnu zelju
i kaze ona plavusi ako me pustis ispunit cu ti ribicu tri puta
sinke.ZG je offline   Reply With Quote
Staro 03.02.2010., 12:02   #666
dani77
dani77's Avatar
Lokacija: Val
Postovi: 304
Pita Haso Muju:
Bolan Mujo sto ti kad' se predstavljas, uvijek kazes da si iz Bosne, što nikad ne kazes da si iz Bosne i Hercegovine?
Odgovara mujo:
Znas li ti Sulju?
Znam!
Znas li di radi?
Znam, u vodovodu!
E, vidis, on ti radi u vodovodu i kanalizaciji, al' g***a nikad ne spominje!
Sto je to noc vjestica?
Dan zena po mraku!
dani77 je offline   Reply With Quote
Staro 03.02.2010., 17:54   #667
rib@
rib@'s Avatar
Postovi: 1,194
Vec dugo nije bilo
Dnevnik doseljenika u Kanadu
12. avgust - Uselili smo se u nasu novu kucu u Kanadi. Tako sam uzbudjen. Ovdje je tako lijepo. Planine su prekrasne. Jedva cekam da ih vidim prekrivene snijegom.
14. oktobar - Kanada. To je najljepsa zemlja na svijetu. Lisce je poprimilo sve one divne nijanse zute i narandzaste boje. Vozio sam kroz prirodu i vidio par jelena. Tako su graciozni. To su najljepse zivotinje na svijetu. Ovo mora da je raj. Volim Kanadu.
11. novembar - Dan Sjecanja (kanadski drzavni praznik). Lov na jelene ce poceti uskoro. Ne mogu da zamislim da neko moze ubiti tako divnu zivotinju. Nadam se da ce uskoro snijeg. Tako je divno.
2. decembar - Nocas je pao prvi snijeg. Ustao sam i vidio sve pokriveno bijelim pokrivacem. Izgleda kao najljepsa razglednica. Izasli smo napolje, ocistili stepeniste i prilazni put a onda se grudvali (ja pobijedio). Kad je prosla grtalica, morali smo ponovo da ocistimo kapiju. Koja divna zemlja. Volim Kanadu.
12. decembar - Nocas opet snijeg. Opet prosla grtalica i zatrpala kapiju. Ovdje je prekrasno.
19. decembar - Nocas opet snijeg. Nisam mogao izvesti auto da idem na posao. Ovdje je zaista divno, samo sam malo umoran od lopatanja. Opet jebena grtalica.
22. decembar - Ovo bijelo govno opet padalo cijelu noc. Dobio sam zuljeve od lopatanja i ledja me bole. Ovaj majmun sa grtalicom kao da se krije iza coska i samo ceka da ocistim ispred kapije. Supak.
25. decembar - Jos malo usranog snijega. Ako mi ikad padne saka ovaj peder sto vozi grtalicu, ubicu ga. Mater im jebem sto ne posipaju vise soli po cesti, pa da se prije otopi.
27. decembar - Nocas opet snijeg. Ne izlazim vec tri dana, sem sto cistim snijeg kad god prodje grtalica. Ne mogu nigdje ici, auto se zaglavilo u brdu snijega ispred kapije, a i hladno je. Kazu da ce nocas pasti novih 30 cm tih govana.
28. decembar - Prognoza je bila losa. Palo je pola metra. Ako ovako nastavi, nece se otopiti do ljeta. Grtalica se zaglavila i taj supak dosao kod mene da trazi lopatu. Rekao sam mu da sam vec slomio sest lopata cisteci ta govna sa vrata sto ih je on nabacio i zamalo da sam mu je slomio o glavu.
4. januar - Najzad izasao iz kuce. Otisao do prodavnice da kupim nesto hrane i, kad sam se vracao, udario kolima jelena. Steta na kolima 3000 dolara. Te jebene nemani treba da budu ubijene. Svugdje ih ima. Sto ih lovci ne pobise jesenas...
3. maj - Odvezao kola kod mehanicara. Nevjerovatno koliko su zardjala od jebene soli sto je posipaju svuda.
10. maj - Selim na Floridu. Ne mogu ni zamisliti kako neko normalan moze zivjeti u toj jebenoj Kanadi.
Dnevnik doseljenika - Florida
12. maj
Stigli smo na Floridu.
Uselili smo se u novu kucu. Tako je velika, ima sav komfor, naravno i pool. Kako je ovdje samo toplo i prijatno. Vec sam zaboravio Kanadu. Volim Floridu.
20. maj
Ovdje su ljudi neverovatno dobri i uvijek se samo smiju. Stvarno je Florida interesantna a ima puno interesantnih zivotinja. Bas je fino toplo. Ove nedelje sam se zagrijao od one Kanade. Puno volim Floridu.
12. jun
Vec smo mesec dana tu, vrijeme je jos uvijek toplo i jako vlazno. Dobro da u kuci imamo klimu. Susjed mi je pricao kako u jednom restoranu u blizini sluze dobrog aligatora. Kako mogu ljudi da jedu te zivotinje, koje poticu iz doba dinosaurusa. To ne mogu nikako razumijeti.Vidjeli smo puno toga na Floridi, nevjerovatno je interesantna. Najvise te volim, Florida.
30 jun
Odkad smo dosli vrijeme se skoro nije menjalo. Uvjek toplo a sad i pomalo suvise vlazno. Ali klima uredaj u kuci i u kolima radi odlicno. Nocu nam jedino smetaju komarci, kojih ima u ovo doba puno. Upoznao sam jos neke susjede stvarno su ljudi na Floridi dobri.
18 jul
Nevjerovatna vrucina i skoro 100% vlaga, za vikend idemo na obalu. Nadam se lijepom provodu.
20 jul
Kakva noc. Fata je u hotelu slucajno ostavila otvoren prozor. Zamalo da me zivog pojedu ti komarci. Kad smo se htjeli vratiti kuci neko nam je ukrao kola. I tako ima da se vozimo 100 milja taksijem. Crnac taksista uvjek se samo smjeska, imam utisak da je on ukrao kola. Stvarno ima kriminala na Floridi.
21. jul
Posle povratka kuci, opet taksi i na posao, pa ja kao da radim samo za ove taksiste. U firmi sef mi je rekao, da se ne smijem dovoljno, ali kako da glupanu objasnim da nisam sklopio oka od onih komaraca a kamoli da spominjem ukradena kola. Nevjerovatna vrucina.
30.jul
Toplotni val je na maximumu, a nama je u kuci crkla klima. I jos ovi komarci, jedino me spasi ujutro jedno kupanje da prezivim. Kad sam hteo da se bacim u pool vidim u njemu aligatora od 3 metra!! Jos mi je samo ta pizdarija trebala, brzo pozovem policiju da pitam sta treba da radim. Oni kazu da ga pustim na miru i da ce sam otici odakle je dosao. Poludecu.
31.jul
Vec ujutro neverovatna vrucina. Na poslu sam opet kao prebijen. Sef, onaj supak, kaze da se uopste ne smijem i da to nije dobro za klijente. Jebo njega i klijente.
1. avg
Kakva vrucina. Vec drugi dan bez klime sto znaci i bez spavanja. Sve ce da izgori. Komaraca ima sve vise. Onaj mrgan od 3 metra kao da je u mom poolu kampovao. Kazem cjelu pricu susjedu, on se samo smije, kao uvjek, picka li mu lepamila materina.
2. avg.
Jedva docekah, da mi dodju popraviti tu kurcevu klimu. A onaj niger umesto klime sredi mi cerku. Policija kaze samo da treba biti pazljiv, a da crnca verovatno nece moci uhvatiti jer su i onako svi isti. Vrucina kao da smo u paklu. Jebem ti Floridu.
12. avg.
Ne mogu da smislim tu vrucinu. Tu smo jos uvjek kao u paklu a odkad smo dosli vrjeme je isto. Sef me izbacio iz firme sa osmijehom na licu i rekao da su se klijenti pobunili jer se nisam dovoljno smijao. E tako sam ostao bez posla i na putu svratim u kafanu gde se napijem. Svi se meni i mojoj prici samo smiju, a osobito onaj policajac koji me uhapsi pijanog i trazi da mu platim 3000 USD. Majku im, mrzim Floridu, prokleta bila.
13. avg
Boze kakva vrucina. Vracam se kuci iz cuze bez kola, posla i bez para. Mrzim taksiste. Svi bjeze sa osmijehom na licu, a usput mi kazu da dolazi Mitch. Legnem u kucu u kojoj jos uvijek ne radi klima da malo razmislim o svemu. Odjednom nevjerovatan vjetar zapara zrak i kuca nema vise krova, jos minutdva i nema vise kuce. Vjetar se smirio. Nemam vise nista, samo je onaj aligator ostao u poolu. Sto ga nisu pojeli u onom restoranu....
Susjedi se vracaju i sa osmjehom na licu kazu da imam srecu da sam prezivio hurikan Mitch. Opet je vrucina ko prije, a ja bez svega. Mrzim Floridu, selim se odavde.
Gdje ovaj put necu vam reći...
Povratak u Bosnu
1. septembar:
Naplatio pare od osiguranja. Zgadila mi se ova Amerika. Kao i Kanada, uostalom. Ubjedjujem familiju da odemo u Disneyland. Poslije cemo smisliti gdje cemo i kako cemo...
8. septembar:
Potrosio pare od osiguranja. Ne znam gdje cemo, djeca bi vec trebala u skolu. Sinula mi je napokon pametna ideja. Zovem rodbinu da me upute kako da kupim stan u Sarajevu. Ucimo ubrzano gramatiku, ja vec uspjesno razlikujem ekavicu i ijekavicu. Djeca brkaju meko, mehko i tvrdo 'c', zaboravljaju umetnuti h gdje treba, palatalizacija im nijedna ne ide od ruke. Sta li ce od nas biti.
24. oktobar:
Rodbina mi hitno odgovara da ima jedan sto bi prodao knjizicu i da ima ope' jedan u Općtini koji bi pogurao za stan, ukoliko... Prodali auto i kompjuter. Poslali pare za stan.
25. novembar:
Papiri za stan u Sarajevu sredjeni, sreci nema kraja. Mi smo bez para. Djeca ne idu u skolu. Svi pomazemo u obliznjoj samoposluzi, imamo dovoljno za motel i kartu. Pripreme za povratak u toku: gledamo u sobi CNN i pokusavama shvatiti trenutnu politicku situaciju. Ja imam problema sa razumijevanjem unutarnjih,granica, nismo se valjda za to borili. Kazu mi da malo puno naginjem na unitaristicku politiku, a da opet nisam dovoljno ekstreman da mogu prezivjeti lako politicku realnost. Kazu mi isto tako da ne serem.
24. decembar:
Posljednje pripreme za put. Uzeli najjeftinije karte, na prvi dan Bozica, bice prazan avion. Tjeraju me da kupim Leviske, ne mogu me vise gledati u dronjcima. Fino smo se svi obukli, ponijeli smo nesto baterija, svijeca, mlijeka u prahu, kave i dvije-tri cokolade, da obradujemo nase. Posljednja noc na jebenom sjevernoamerickom kontinentu. Nalet ga bilo, i onog ko ga otkri, i ove sto na njemu zive.
25. decembar:
Prvi dan Bozica. Na putu do aerodroma blistaju ukrasi na palmama.Samo da mi je docepati se aviona. Nalecem na Djeda Mraza u bermudama, saljem ga u neku stvar. Predajemo stvari, oduzimaju nam vrecu sa rizom i otpakirane vrece mlijeka u prahu ...kazu supci, zabranjeno po nekom njihovom zakonu. Ovo je vec prevrsilo mjeru. Psujem tecno. Oni se smiju. Budale. Stjuardesa me upozorava da pazim kako se ponasam nakon sto sam ljubazno stisnuo pilota i vikn'o mu na uho: "Vozi Misko!".
27. decembar:
Amsterdam. Mmmm, osjecam miris Europe. Zadrzavaju nas u policiji, kazu istekla nam oba pasosa, i crveni, i plavi. "Ma, koji ste mi vi ..." mislim se, ja - tamo se ja vise ne vracam. Fino mu kazem: "No Amerika, no, niks, kaput, finito..." Prenocili na policiji. Uzelo nam tariguz i svijece, kaze treba da prodje neko ispitivanje. Bas smo se sjebali. U policiji upoznajemo puno naseg svijeta, svi idu na drugu stranu. Svijece mogu s nama, tariguz ostaje, zapaljiva materija. Otkidam malo papira sa jedne rolne, zlu ne trebalo. Niko ne primjecuje.
31. decembar:
Nakon dvije noci prespavane na amsterdamskom aerodromu, evo nas na putu za Bec. Svi smo se vec medjusobno posvadjali. Optuzuju me da sam ih sve uvalio u govna, bez njihove volje. Ubjedjujem ih da ne seru i da ponavljaju gradivo, vec smo skoro kuci. Slijecemo u Bec. Ah, Wienna, Shtrauss, Waltzer, Dunau, jes' klinac. Policija nas odvaja na poseban izlaz.
1. januar:
Novu godinu docekao u krugu familije, u posebno ukrasenoj celiji. Gledam novogodisnji koncert kroz resetke. Djeci poklanjam cokolade, Fati sam uspio maznuti jedan tester na Free Shopu u Amsterdamu - Gyvency for men. Svidja joj se. Mirise. Izgleda da ce nas pustiti vec za dva dana. Hrana puno bolja od one u Amsterdamu. Vec sam skoro zaboravio ona sranja sto smo jeli u onoj poganoj Floridi. Mekdonald, Meklaud, Mekintos, Meksiko, to su samo neke od zabranjenih rijeci nakon naseg groznog McDonald'skog iskustva.
6. januar:
Zagreb. Servus lepi Zabreg moj, kaj se krije v megli toj. Opet bajbok. Uvozenje opasnih materija, oduzimaju nam baterije. Brzo nas oslobadjaju iz policije, izvinjavaju se. Da ne bi placali carinu, ostavljam lazni Rolex u policiji I otkidam dugmad sa Fatine jakne da pokazem da je koristena. Niko iz familije ne prica sa mnom. Tvrde da je moja glupa ideja o povratku. Carinik se smjeska, policajci se smjeskaju, taksista se smije, ja mislim da nesto debelo nije u redu. Nisu me pitali ni za putovnicu, domovnicu, sahovnicu...Pitam treba li mi viza, oni se svi grohotom smiju. Kazu, kak' ste vi Bosanci bedasti.
7. januar:
Oduzimaju nam avio-karte, pominju neki medjudrzavni sporazum. Nije mi jasno, bunim se k'o Grk u zatvoru.Odustajem, iz carapa vadim zadnje dolarske rezerve. Odlucujem se na put autobusom. Taksista prima dolare. Sreca. Bas bih se obruk'o. Stizemo u zadnji cas na Kolodvor, banka jos radi. Mijenjam dolare u kune za kartu i KM (valjda kilometre) za prtljag. U cekaonici svi puse, postaje neizdrzivo. Idem do klozeta da dodjem sebi. Smrdi toliko da jedva stojim na nogama, nekako se dokopam izlaza. Guramo se na ulazu u autobus, neko je prodao visak karata, bice gusto. Ja pristajem na tri sjedista za cetiri karte, pod uslovom da prtljag drzimo u krilu. Bolje ista nego nista. Hajd', mislim se, nek' je ziva glava.
8. januar:
Ovo pisem poslije. Hladno je bilo da bi pingvini u nesvjest pali. Al', opet, mislim se, kako je u Kanadi. Pokusavam zaspati, ne mogu, muzicki ukus sofera je gori od onog vec loseg predratnog. Neko povraca pozada. Neko otvorio Argetu i otpakov'o kuhana jaja. Povraca mi se, da hoce zaustaviti autobus. Autobus se zaustavlja na tri carine i tri policije.Oduzimaju mi koznu jaknu koju sam prije rata kupio u Turskoj. Ja sam ukocen toliko da me policajci skidaju. Kakva noc.
11. januar:
Ovo pisem na kraju puta. Dva dana smo bili zaglavljeni na Makljenu. Sreca, neki iskusni putnik na ovoj relaciji je imao karton kuhanih jaja. Neki svercer pristaje da trampi paket argete za dzepni Nintendo. Glupan, ja platio Nintendo $4.99 na rasprodaji. Nismo gladni. Ja sam ukocen, svaki me misic boli. Sad svi imamo mjesta jer su policija poskidali neke nevaljalce usput.
12. januar:
Stanica u Sarajevu. Tuga me uhvatila, sjetim se kako smo ovdje cekali na konvoj. Budale, ko nas je tjer'o. Pa, nece Bosna nigdje, a ni Hercegovina. Fali nam jedna torba. Jedna mi zena kaze da je vidjela neke momke kako pretovaraju svijece i nesto se domundjavaju oko nasih sjedista.
Prijavljujem policiji. Smije se policajac, neki mlad momak, grohotom, svi mu se krnjatci vide. Kaze, dobro dosli, kuci. Svi nam se zahvaljuju na stanici sto smo ih zabavili. Svi puse. Malo mi je zlo. Nude me picem, odbijam da pijem na javnom mjestu, zakon je zakon. Oni se i dalje smiju, jedan pada sa stolice tako da polomi sve boce ispod stola. Miris alkohola me zapahne, istrcavam na cisti zrak.
13. januar:
Pokusavam prvi put da udjem u "svoj" stan.
14. januar:
Vec nekoliko puta pokusavam da udjem u stan. Provodimo citav dan u raznim opstinskim kancelarijama, vadimo potvrde, pokusavamo da iznudimo nalog za iseljenje "stanara".
15. februar:
Sudskom odlukom donosi se nalog o iseljenju tih nekakvih uljeza u "nasem" stanu. Pokusavam istjerati te nevaljalce. Vise smo dojadili rodbini, ne zna nam se ni za dan ni za noc. Danas kod ovog, sutra kod onog.
20. februar:
Donosim odluku. Idem u policijsku postaju na autobuskoj stanici. Prepoznaju me, kazu da nisu usli u trag lopovima iz autobusa jos, i svi se grohotom smiju. Zamolim ih da mi pomognu, da imam rjesenje za stan i nalog, i da nemam gdje spavati, i da cu se ubiti na mjestu ako nesto ne ucine. Svi se smjesta pokupimo odatle, pozovemo posebnu jedinicu, usput ubijedimo pripadnike Unprotection - Eye For - Ass For - Na To - a da nam se pridruze, i u zdruzenoj akciji ulazimo u stan. Stan prazan. Nigdje nista. Ni parketa, ni lustera, ni bojlera, nista. Al' jebi ga, svoje je svoje, ljubim stokove tako strasno da mi se usne lijepe za hladan metal.
28. februar:
Bas je nas svijet dobar. Sa prvog sprata donose nase cilime sto su komsije cuvale sest godina. Neko na podvoznjaku nasao nas televizor i otkupio od jednog svercera. Sa smeca donijeli nas bojler. Nadjeno dosta nasih slika, predratnih. I moja diploma, zguzvana na mjestu odvaljenih pipa u kuhinji. Sve polahko dolazi na svoje mjesto. Vec pomalo i djeca razgovaraju sa mnom. Fata je rekla da ce mi dati cim ponovo nabavimo krevet.
1. mart:
Danas sam vec poceo da radim u jednog privatnika. Ruke me bole jos od onog autobusa, imam puno unosenja, radim s robom. Fata pocela da sije kod jedne fine zene. I ona je, kaze, bila izbjeglica, u Sarajevo, trebalo joj je dosta da dodje na svoje, ali, kaze, ako radimo vrijedno i imacemo. Imamo dovoljno para da platimo dodatne casove djeci. Oni nisu jos u skoli, do septembra. Sada su nam dali dobru sansu da polazu ove razrede sto su zavrsili u Kanadi i Americi, jer se to ovdje nista ne priznaje.Imaju problema sa gramatikom. Ja jos imam problema sa politikom. Sreca, televizor nam se cesto kvari pa ni ne pratimo vijesti. Ja ocekujem da sa dobrim znanjem jezika i sa vozackom dozvolom mogu dobit' fini posao za neku medjunarodnu organizaciju. Sve je super. Malo me nerviram, gdje god dodjem, svi puse. Puse pravo. Na to se nikako ne mogu navici, k'o da nisam citav zivot zivio ovdje.
2. mart:
Pitate se, gdje cemo sad. Necemo nigdje. Ovdje nam je dobro, tako nam i treba. Dobro se dobrim vraca. Super je nama ovdje. Ne mogu nas odavde vise ni puskom otjerati. Dobro nam je - u pi**u materinu.
cpu e4300/sonictower+nexus120; mbo gigabyte p35-ds3-l; ram kingmax1024/667x2; vga hd3850; psu corsair hx 520w; dvd benq 1655; hdd wd1200jd&samsung hd321kj&ST3160021A; ZM-MFC1; lg22ws; btc6300; mx 518 i sve u chiefu s nekoliko nexusa
rib@ je offline   Reply With Quote
Staro 04.02.2010., 14:28   #668
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Autor rib@ Pregled postova
-cut-.
To sve postoji u audio verziji pre dugo je ovako čitat i pre naporno...barem meni
Staro 04.02.2010., 17:36   #669
Postovi: 8,218
+18°C Na Havajima uzimaju drugi pokrivač
+10°C U zgradama u Helsinkiju isključuju grijanje
+2°C Talijanski automobili ne mogu da upale
0°C Destilirana voda se smrzava
-1°C Dah se vidi. Rusi jedu sladoled i piju pivo.
-4°C Pas vam se uvaljuje u krevet.
-10°C Francuski automobili ne mogu upaliti
-12°C Političari počinju da pričaju o beskučnicima.
-15°C Američki automobili ne mogu upaliti.
-20°C Dah se čuje.
-24°C Japanski automobili ne mogu upaliti.
-28°C Pas vam se uvaljuje u pidžamu.
-29°C Njemački automobili ne mogu upaliti.
-30°C Ni jedan normalan automobil ne može upaliti.
-36°C Ruski automobil ne može upaliti.
-39°C Rusi zakopčavaju sve gumbe na košuljama.
-50°C Automobil ti se uvaljuje u krevet.
-60°C Žitelji Helsinkija se smrzavaju. U Moskvi zakopčavaju kapute.
-70°C Smrzavaju se i u paklu. Univerzitet u Kuznjecku organizira cross-country .
-72°C Advokati zavlače ruke u vlastite džepove.
-120°C Alkohol se smrzava. Rusi su zato potpuno u bedu.
-273,15°C Apsolutna nula. Prekida se kretanje elementarnih čestica. Rus liže smrznutu vodku.
Staro 06.02.2010., 02:24   #670
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
- Koja je najveća neman u Dalmaciji?
- Neman za kavu.
Staro 09.02.2010., 11:01   #671
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Na oglasnoj ploči Slovenskog hidrometeorološkog zavoda je visila obavijest o novonapadalom snijegu na skijalištima u Sloveniji:
Kanin: .....5 cm; ...suh
Vogel: .....2 cm; ...mokar
Cerkno: ....11 cm; ...suh
Krvavec: ...16 cm; ...rahli
Ispod je olovkom bilo dopisano:
Mujo: ...27 cm; ...tvrd
Staro 09.02.2010., 12:03   #672
Bambusha
Bambusha's Avatar
Lokacija: Čepin
Postovi: 297
Autor Dizel Pregled postova
Intel G1610; ASUS B75M-LX Plus; 4096 MB; Intel HD; Hitachi 7K1000.C 500 GB; LG GH24NS95; Silverstone Strider Essential 400 W; Logitech K200; Logitech B110; Logitech X-240 2.1; Philips 200V4LAB 20" DVI; Windows 7 64-bit Professional
Bambusha je offline   Reply With Quote
Staro 09.02.2010., 12:31   #673
DiRT
► Play ▌▌ Pause ■ Stop
DiRT's Avatar
Datum registracije: Jan 2010
Postovi: 1,178
@ rib@ hahaha...audio verzija...ovo je kraljevski
PC:
CPU:
Intel Core i7-7700
COOLER:
SCYTHE Mugen 3 rev. B
MBO:
MSI B250 GAMING M3
GPU:
ASUS Dual Radeon RX 6650 XT OC Edition 8GB GDDR6
RAM:
Kingston HyperX Fury (2x8GB) 2133MHz@2400MHz CL16 DDR4
SSD:
Samsung 870 EVO (500GB)
Samsung 970 EVO Plus (2TB)
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
Seagate Basic Portable Drive (1TB)
WD My Passport (1TB)
WD My Passport (2TB)
WD Elements (2TB)
Verbatim Vx500 (240GB)
Silicon Power PC60 (240GB)
Kingston XS1000 (1TB)
PSU:
Corsair 650W RM650, 2019, 80 PLUS Gold
MONITOR (TV):
Dell G2724D + Dell U2414H
Samsung UE55NU8002TXXH
Samsung QE43Q60AAUXXH
Philips 43PUS8506/12
KUĆIŠTE:
Antec 300, 2xSCYTHE Slip Stream 120mm (500rpm, 7.5 dB)
OS:
Windows 10 Pro 64-bit
TIPKOVNICA:
Logitech K800 Illuminated
MIŠ:
Logitech G502 Proteus Spectrum RGB + SteelSeries QcK Edge - Medium
Logitech MX Master 3 Black
Logitech MX Master 2S Bluetooth Edition Graphite
Logitech M590 Silent
ZVUČNICI:
Logitech Z-5500 (S/PDIF) + Logitech Bluetooth Audio Receiver
MAGNAT Monitor Supreme 202 Black 2-way bass reflex bookshelf speakers
MAGNAT Monitor Supreme Center 252 Mocca
SLUŠALICE:
Logitech Zone Vibe 100
Samsung Galaxy Buds3 Pro
Xiaomi Redmi Buds 5 Pro
Xiaomi Buds 3 Star Wars Edition
Mi True Wireless Earbuds Basic 2
Sennheiser CX 3.00
AKG Samsung Galaxy Earbuds
AKG Y500 Wireless
MOB:
Samsung Galaxy S7 Black, 4/32GB +
Samsung microSDXC 64GB EVO+
Samsung Galaxy S10e Black, 6/128GB +
Samsung microSDXC 256GB EVO+
Huawei P50 Pro Golden Black, 8/256GB
Samsung Galaxy A55 5G Awesome Navy, 8/256GB
Samsung Galaxy S24+ Onyx Black, 12/256GB
LAPTOP:
(Lenovo ThinkPad E560)
CPU: Intel Core i3-6100U
MBO: -
GPU: Intel HD Graphics 520
RAM: 2x4GB DDR3L 1600MHz
SSD: Kingston A400 480GB
OSTALO: 15.6-inch HD TN
PC POSAO:
(HP Z2 Tower G9 Workstation)
CPU: Intel Core i7-14700K
MBO: HP 895C
GPU: Nvidia RTX A2000 12GB
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
MONITORI: 2 komada HP Z27 27-inch 4K UHD
PERIFERIJA: Logitech K750 Solar, Logitech MX Master 3 Graphite + Logitech MX Master 2S Bluetooth Edition Graphite
LAPTOP POSAO:
(Apple MacBook Air 13.6-inch M2 8/256GB MLXY3CR/A Silver)
(HP EliteBook x360 1040 G11 2-in-1, 14-inch WUXGA Touchscreen, Intel Core Ultra 7 155H, 16GB LPDDR5x, Samsung 1TB PCIe Gen4 NVMe TLC M.2 SSD, Backlit Keyboard, Windows 11 Pro)
(HP ProBook 450 G7, 15.6-inch FHD, Intel Core i5-10210U, 8GB DDR4, Samsung 512GB NVMe M.2 SSD, MX250 Graphics, Backlit Keyboard, Windows 11 Pro)
DiRT je online   Reply With Quote
Staro 10.02.2010., 17:35   #674
Postovi: 8,218
Decko ima 10 cura pa je frajer, a cura ima 5 momaka pa je kurva, evo zasto:
-kad ključ otključava puno brava on je najbolji (master key), a kad bravu otključavaju svi ključevi, brava je za kur*c
Staro 11.02.2010., 09:11   #675
Perki
Lokacija: VG
Postovi: 774
Znate li da se Toyota bacila u informatički biznis, nakon kalvarije s automobilima? Počeli su s periferijom. Evo, baš sam si kupio jednu Toyota tipkovniiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
Trust me - I know what I'm doing!
Perki je offline   Reply With Quote
Staro 11.02.2010., 09:31   #676
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
d4rk_ch1ld je offline   Reply With Quote
Staro 11.02.2010., 09:33   #677
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Autor pupo Pregled postova
decko ima 10 cura pa je frajer, a cura ima 5 momaka pa je kurva, evo zasto:
-kad ključ otključava puno brava on je najbolji (master key), a kad bravu otključavaju svi ključevi, brava je za kur*c :d
oooooo da !
Autor hammer_of_thor Pregled postova
blaa
Staro 14.02.2010., 00:10   #678
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
C L O W N I N G A R O U N D
Staro 24.02.2010., 00:32   #679
veve
woot!!!
veve's Avatar
Postovi: 2,497
Pesimist vidi samo tamu u tunelu. - Optimist vidi svjetlo na kraju tunela. - Realist vidi da je to svjetlo ustvari vlak. - A strojovođa vidi 3 idiota na pruzi
veve je offline   Reply With Quote
Staro 24.02.2010., 00:43   #680
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
dobar
nego, oboren je rekord u broju napravljenih sklekova, a rekord je oborio Chuck Norris! napravio ih je sve .
Staro 24.02.2010., 00:49   #681
Slash555
Slash555's Avatar
Lokacija: Slatina
Postovi: 363
Ne radim ništa, ali pravo da ti kažem, nemam ni kad!
D
Najam stana
Oľenjeni muškarac upoznaje prelijepu djevojku i dogovara se da provede noć
s njom za 500 €.
Ujutro, nakon noći provedene zajedno, kaľe joj da nema dovoljno gotovine
kod sebe i da će naloľiti sekretarici da joj pošalje ček sa uplatom na ime
'' NAJMA STANA'' čim stigne u ured.
Na putu u ured shvati da se pokajao, da cijeli taj događaj nije vrijedan
toliko novaca, tako da kada dođe u ured naloľi sekretarici da pripremi
ček na 250 €, i izdiktira joj slijedeće objašnjenje koje će priloľiti uz ček:
Poštovana gospođo,
U prilogu Vam šaljem ček na iznos od 250 € na ime najma stana. Ne šaljem unaprijed dogovoreni iznos, jer sam, u vrijeme kada smo dogovarali
iznos, bio pod dojmom:
a) da stan ranije nije bio korišten;
b) da je dobro zagrijan,
c) da je dovoljno mali da bih se u njemu osjećao ugodno kao kod kuće.
Međutim, shvatio sam da ste ranije već imali podstanare, da grijanje ne
radi, te da je stan suviše prostran.
Srdačan pozdrav
Po primitku ovakvog objašnjenja i čeka na 250 €, dotična gospođica mu
odmah vrati ček, uz sljedeće objašnjenje:
Poštovani gospodine,
Prije svega ne razumijem zašto ste mislili da je onako lijep stan mogao
biti neograničeno dugo prazan.
Vezano za vašu prituľbu glede toplote u stanu, grijanje savršeno
funkcionira, ako znate kako ga uključiti. Što se tiče prostranosti, stan
je normalne veličine. Ukoliko vi nemate dovoljno namještaja da ga
popunite, nemojte kriviti stanodavca.
Molim Vas da pošaljete puni iznos stanarine, u proti vnom ću biti
prisiljena kontaktirati vašu trenutnu stanodavku.
Srdačno Vaša
Zadnje izmijenjeno od: Jelc. 24.02.2010. u 04:04.
Slash555 je offline   Reply With Quote
Staro 25.02.2010., 23:15   #682
Constantine
Constantine's Avatar
Postovi: 668
Ja pimpek, zahtijevam povećanje plaće iz slijedećih razloga:
-radim fizički posao
-radim na velikim dubinama
-prvo zaranjam glavu u sve kaj delam
-nemam Weekende i državne blagdane
-ne plaća mi se prekovremano
-radim na mračnom i vlažnom mjestu bez ventilacije
-radim na velikim temperaturama
-radim posao na kojem sam izložen zaraznim bolestima.
ODGOVOR
Dragi pimpek, poslije razmatranja tvog zahtjeva i uzimanja u obzir svega
što si naveo,administracija odbacuje tvoj zahtjev iz slijedećih razloga:
-nikad ne radiš 8 sati u kontinuitetu
-uspavaš se na poslu odmah nakon odrađenog posla
-ne slušaš naređenja rukovodećeg tima
-ne ostaješ na tebi određenom mjestu,već posjećuješ i druge oblasti
-nemaš samoinicijativu-na tebe se mora vršiti pritisak imoraš biti
stimuliran da bi počeo s radom
-na kraju posla ostavljaš neuredno radno mjesto
-ne osvrćeš se na sigurnosne propise ,kao na primjer,
nošenje zaštitne odjeće
-nisi u stanju odraditi dvije smjene
-napuštaš radno mjesto prije završenog posla
-već si bio viđen kako stalno ulaziš i izlaziš sa radnog mjesta
noseći dvije torbe sumnjivog izgleda.
Nakon svega, ne, ne cemo odobriti ni lipe povisice.
Constantine je offline   Reply With Quote
Staro 02.03.2010., 09:47   #683
WraGG
WraGG's Avatar
Lokacija: Stuttgart
Postovi: 1,598
Mrkla noc, ne cuje se nista, samo dvije sove sjede na grani...
Kaze prva: "Huuuhuuuu!"
kad ce druga: "Idi u picku materinu, prepade me!"
Staro 04.03.2010., 14:59   #684
mujica
črna jetra
mujica's Avatar
Postovi: 453
Najkraci vic o plavusi...
"Jesi li ti Ivana…???"
"Neeeeee, Ivan je mene…..."
Avoid hangovers: stay drunk.
mujica je offline   Reply With Quote
Staro 04.03.2010., 19:36   #685
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
kakav je to znak kad žena moze do dnevne sobe, da je lanac predugačak.
Sreli drago diklic i milo hrnic. Te ce drago: "DRAGO mi je, Diklic". Odgovori Mile: "Milo Mije, Hrnic"
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 11.03.2010., 10:56   #686
Doink the Clown
Postovi: 6,214
Jučer je gospodinu Norrisu bio rođendan, neću reći živio jer Chuck živi vječno
Pa eto, povodom rođendana mali tribute
Duhovi postoje jer Chuck Norris ljude ubija brže nego što ih smrt može obraditi.
Chuck Norris može napraviti snjegovića od kiše.
Chuck Norris može utopiti ribu.
Chuck Norrisov kalendar ne zna za 1. travnja - nitko ne radi budalu od Chucka Norrisa.
Jednom je kobra ugrizla Chucka Norrisa za nogu. Nakon pet dana mukotrpne boli, kobra je umrla.
Staro 11.03.2010., 15:45   #687
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
Idu Chuck Norris i banana po ulici, i banana se posklizne na Chucka...
Zašto Chuck Norris ne nosi sunčane naočale? Zato jer ga se sunce boji pogledat u oči.
T0mB1ll je offline   Reply With Quote
Staro 16.03.2010., 01:01   #688
Necto
Necto's Avatar
Postovi: 748
setaju splico i mujo novon splitskon rivon.
splico ugazi na bananu i razvali se koliko je dug i sirok po betonu,
uz povik: "jeben ti bananu!"
na sta ce njemu mujo: "jeben ja tebi ba mater!"
Necto je offline   Reply With Quote
Staro 17.03.2010., 15:37   #689
MyJoy
MyJoy's Avatar
Postovi: 63
Autor T0mB1ll Pregled postova
Chuck Norris once had sex in a trailer, a bit of his sperm got in the tank. We now know that trailer as Optimus Prime.
Chuck Norris gets paid 99 cents every time he downloads a song from itunes.
The bible was originally titled "Chuck Norris and friends".
MyJoy je offline   Reply With Quote
Staro 17.03.2010., 15:44   #690
Doink the Clown
Postovi: 6,214
Chuck Norris se ukazao Gospi
