Staro 26.09.2009., 16:25   #751
alen.s
alen.s's Avatar
Postovi: 1,441
nisam pc expert ali mislim da kod ati korisnika fiziku obavlja cpu a kod nvidie grafa . Sve u svemu nije razlog da igra zbog toga ne radi
Staro 26.09.2009., 16:31   #752
markmofa
Skupljam pare za LCD :)
markmofa's Avatar
Postovi: 32
ma radi ona, odigram ja 2,3 utrke super, sve 5 i onda zašteka... a čuo sam da dosta njih imaju taj problem...
skužio sam, sve 5 radiiii
Mod: mogao bi i napisati što je bilo ako netko drugi ima sličan problem. Naravno nemoj napisati ako riješenje krši pravila.
riješenje krši prava... zato i nisam napisao
Zadnje izmijenjeno od: Hamm. 26.09.2009. u 21:35.
markmofa je offline   Reply With Quote
Staro 26.09.2009., 19:06   #753
alen.s
alen.s's Avatar
Postovi: 1,441
jel ima tko rjesenje za hamachi ? proba sam verziju 1013 i najnoviju i ne radi proba san i ovo ...isto nece ;
for those who cant host or find follow these steps. 1. go to control panel 2. open network and sharing centre (vista or windows 7) xp users go to network connections 3. on left side click adapter settings or manage networks 4. press alt on keyboard then at top press advanced- advanced settings 5. make sure hamachi is at top of the list then press ok 6. right click hamachi and press properties 7. make sure internet protocals version 6 is unchecked 8. click internet protocals version 4 and press properties 9. press advanced 10. in the default gateway it should say 5.0.0.1 if not click add aqnd put 5.0.0.1 11. set metrics to 10 (if this still dont work tick auto metrics) but for now set it to 10 and leave auto unchecked. 12. press ok then load need for speed shift and now look for game. my server is deebs so pop in every now and then for a race. i hope this solved your problem.
Staro 26.09.2009., 19:23   #754
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,734
Ima ko za NFS?
Staro 26.09.2009., 19:50   #755
markmofa
markmofa's Avatar
Postovi: 32
Ima ko za NFS?
Ja bih rado, ali me volan zeza, osjetljiv je full na desnu stranu, a za lijevu trebam okretat ko budala..
Ako netko zna gdje u Puli ima servis za te stvari. hvala
NE mogu vjerovat rastavio sam volan i popravio... sad radi weee xD
Staro 26.09.2009., 20:35   #756
Wolverine
Wolverine's Avatar
Postovi: 12,425
koristi edit, nema potrebe za duplim postovima
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 26.09.2009., 20:44   #757
Ati freak
aka Striko
Ati freak's Avatar
Postovi: 1,734
alen.s
Sutra u 19h , voznja opet
Staro 26.09.2009., 21:37   #758
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Ako netko ce nabaciti, ja i alen.s se naganjamo po Nurbu :
Pass: 1234
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Gjurovski je offline   Reply With Quote
Staro 26.09.2009., 22:37   #759
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
Ima tko da ganja najbolja vremena na Nurburgringu??
evo maloprije odvozio 3 kruga, skinuo svoje najbolje vrijeme sa bmw-om (m3 e36, svi upgrade-ovi osim works-a) za 30ak sekundi
dali je netko za natjecanje? nekakav custom auto (tier 1 ili 2, 3 i 4 su glupavi jer auti idu prebrzo) i ganjanje vremena sa istim , nece mi jos dugo biti zabavno igrat protiv samog sebe
Staro 26.09.2009., 22:42   #760
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor papčić Pregled postova
skinuo svoje najbolje vrijeme sa bmw-om za 30ak sekundi
sva sreća pa je samo jedan u igri
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 26.09.2009., 23:20   #761
panisher20
panisher20's Avatar
Postovi: 939
vjerojatno je bug da nakon restarta urke auti imaju drugacija vozna svojstva, valjda ce to popravit sa nekim pathem
panisher20 je offline   Reply With Quote
Staro 26.09.2009., 23:51   #762
alen.s
alen.s's Avatar
Postovi: 1,441
a ljudi koji je fajt bija na Ringu , ajd svratite i sutra....
Staro 27.09.2009., 00:15   #763
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Bome je bilo fino na Nurbu ja sam se sa 6 pozicije na 2 izgurao, za misju dlaku mi utece prvo mjesto
Za koelge koji se prvi puta spajaju:
1.Nabaviti Patch 1.1 (napraviti update igre, bez toga nema local networka, samo EA mreza)
2.Traziti peru za ispricnicu
3.Skinuti Hamachi - 1.0.1.3 (pomogucnosti imati istu verziju Hamachia, iako nije pravilo, ja koristim ovu gore)
4.Iskljuciti uTorent, firewall, antivirus....
5.Za usere koji imaju Win7 Hamachi postaviti kao prvu konekciju (u control panelu mislim, ja imam xp pa neznam tocno)
6. Kad se spojite preko Hamachija bilo tko moze hostati igru..
7.Kad se ude u igru: ONLINE - LOCAL NETWORK - FIND i trebali bi ste vidjet igru, ako ne, nesto nevalja od gore navedenoga...
Evo njih cetvorica jos peglaju pa mozete probat na:
Pass: 1234
E sad nadam se da seka nece upaliti utorent prek noci
Staro 27.09.2009., 00:44   #764
mr. unstoppable
...nobody fucks with me
mr. unstoppable's Avatar
Postovi: 11
Dosta se ljudi žali na drift, meni je lakši neg u GRiDU, to je očito, jer vi očito dodjete na drift sa tunanim autom, e pa, ne!
Dodite sa SERIJSKIM i onda je cica laganica
_Da je život lijep, nebi se rodili plačući_
mr. unstoppable je offline   Reply With Quote
Staro 27.09.2009., 01:30   #765
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Autor Gjurovski Pregled postova
i vistu
Evo ova dva koraka: http://blog.p2pvine.com/far-cry-2-ha...owto-01112008/
Core2Duo22 je offline   Reply With Quote
Staro 27.09.2009., 02:28   #766
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
Eto da i ja kazem nesto o igri. Koliko sam skuzio, igra obozava kada kartica ima 1GB ili vise video RAMa. Na mojoj Gainward 4850 GS je framerate gladak ko tigar na maslacu u 1920x1200 s 4xAA i 16xAF. Pajdas ima 4870 s 512MB i dosta mu "propada" framerate. Obojica imamo Intel e8500 na 4+ GHz.
Posudio sam od pajdasa original igru i probao danas popodne i nakon jedno 5 sati igranja mogu reci da je NFS:S kopirao jako puno igara, ali kada se sve to skupi u jednu igru - vidi se kako su iste stvari u originalnim igrama bile bolje. Nema sto, graficki je igra dosta napredovala, ali igrivost je i dalje ispod razine koju su postavili najslavniji NFS-ovi (po meni to su "trojka", "cetvorka", Porsche i HP2).
Stajaznam, mogli su se ipak malo "poigrati", dodati nocnu voznju ili voznju po kisi/snijegu, nitko im ne bi zamjerio da su dali mogucnost vozenja staza u suprotnom smjeru ili da su napravili mirror nekih staza (to je bilo u starijim NFS-ovima). A kako bi tek luda bila opcija voznje po gustoj magli!
Da ne duljim, kupujem originale, ali ova igra nije zasluzila mojih 300 i nest kuna.
Valjda ce dogodine izaci bolji NFS... to vec zadnjih jako puno godina govorim...
Staro 27.09.2009., 09:30   #767
jurbAs
jurbAs's Avatar
Postovi: 2,582
Ampeshi dobro si rekao fale ti uvijeti snjeg kisa magla a ne sve suncano i lijepo i da postoji biranje guma i toga. Makar i ovaj NFS je jako zabavan i zanimljiv meni je igra odlicna.
Ja drift nisam ni takao trebao bi zapravo sjest i pokusat drugacije ne bi islo... makar mislim da je drift dosta lagan kad se ude u stos kako sto napravit.
Staro 27.09.2009., 09:43   #768
mr. unstoppable
Postovi: 11
Amepshi slažem se sa tobom, meni je najbolji NFS ikad Hot Pursuit 2
Staro 27.09.2009., 11:12   #769
jurbAs
jurbAs's Avatar
Postovi: 2,582
Stavio patch i stvarno se igra brze ucitava.
Staro 27.09.2009., 12:13   #770
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
jep, sada mi load na stazu traje kakvih 15-ak sekundi i nije vise naporno cekati, dok sa eventa u meni izlazi za par sekundi
Staro 27.09.2009., 12:27   #771
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
Ja vjerujem da se nitko od igraca ne bi ljutio da je razvojni tim shifta stazu Spa "odveo u paralelni svemir". OK, neka bude i originalna uz promijenjenu, ali sta ne bi bilo zabavno da su pustili masti na volju, malo promijenili koji zavoj, dodali koji tunel, cisto da bude nesto novo.
Ja jos uvijek stojim iza svoje tvrdnje da bi NFS bio najbolja igra na svijetu kada bi se odvijao po jadranskoj magistrali od Rijeke pa do Zadra. Slag na tortu bi bilo kada bi dodali uspone od Karlobaga i Senja (kako smo za vrijeme rata isli u unutrasnjost). Danasnje graficke kartice bi mogle pruziti dovoljno snage za taj vizualni slatkis, RAM memorija je dovoljno jeftina, a i HDDovi nisu vise kao s pocetka desetljeca. Da ne zaboravim, ni SSDovi nece dugo biti u stratosferi.
I onda ATI se nada da cu se ja pomamiti za njihovom 5xxx serijom grafickih - cemu? Pa gdje mi je softver kojim cu ja (barem sebi) pravdati trosak? Sjetite se samo VooDoo 1 i 2 kartica, razloga sa softverske strane je stvarno bilo dovoljno za nabavku 3dfx kartice!
NFS jest zabavan neko vrijeme, za nas koji nemamo konzole uz Grid to je jedina mogucnost za natjeravanje vozila bez volana (govorim o arkadama). No pogledamo li istini u oci - i ovaj NFS je mucak...
Staro 27.09.2009., 12:30   #772
mr. unstoppable
Postovi: 11
da to patch popravlja
Staro 27.09.2009., 12:46   #773
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,223
Autor Amepshi Pregled postova
Forza 3 bi trebala imati tako nešto...
Staro 27.09.2009., 13:53   #774
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
Autor Neo-ST Pregled postova
Hehe, kada sam to napisao nekoliko stranica prije, htjeli me ljudi razapeti... Tko zna sto ce vrijeme donijeti.
Staro 27.09.2009., 14:28   #775
Ludy
Postovi: 204
ne radi mi igra na win7 ultimate, ima jos neko takvih problema?
Ludy je offline   Reply With Quote
Staro 27.09.2009., 14:33   #776
UltimatGamerXFX
Postovi: 105
bas si skidam napokon taj demo jedva cekam !!!
nemreš verovat, proradila mi 8800 gt-ica koja je bila 99% crknuta??? sad radim s njom bez žvake, koju da si kupim i kak da ju stavim? nemogu nigdje nac temu kako stavit žvaku na grafičku...
UltimatGamerXFX je offline   Reply With Quote
Staro 27.09.2009., 14:35   #777
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
Autor Ludy Pregled postova
Vec vidim da ce netko uletjeti s protupitanjem - a jesi li uopće uštekao komp u struju? Daj ljudima malo više podataka...
Eto, cak sam i s original igrom imao problema dok nisam stavio patch 1.01, onda se htjela pokrenuti. Prije toga, izbacivala je prilikom pokretanja utrke :-(
Staro 27.09.2009., 14:36   #778
tech
Postovi: 1,687
Kupiš pastu as usual, i tanko naneseš?
Naravno prije nego postane 100% mrtva...
Staro 27.09.2009., 15:26   #779
Beo
Lokacija: United Kingdom
Postovi: 512
Eto da se nadovezem na ovo sto je gore nabrojo kolega Gjurovski
Eto za postavit hamachi ko no.1 pod network eto kratki filmic
za win vista i win7
http://www.youtube.com/watch?v=WCXgG2StOCM
Beo je offline   Reply With Quote
Staro 27.09.2009., 15:41   #780
alen.s
alen.s's Avatar
Postovi: 1,441
onda cu se i ja nadovezat ; meni na "sedmici" nije tija radit dok nisam napravio ovo :
odznačit internet protokol 6 a pod internet protokol 4 namjestit ovako ; default gateways stavit 5.0.0.1 , metrik na automatik a onaj dole metrik na 10 . Evo slija ;
