Staro 23.08.2009., 00:13   #1
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Nvidia ForceWare 190.62 WHQL driveri
New in Release 190.62
* Adds WHQL support on Windows 7 for Microsoft’s new DirectX GPU
* Computing API: DirectCompute.
* Optimized for the latest PhysX gaming titles: Batman: Arkham Asylum and
* Darkest of Days.
* Installs PhysX System Software version 9.09.0814.
* Includes several bug fixes. More information can be found in the release
New in Release 190
* Adds support for OpenGL 3.1
* Adds support for CUDA 2.3 for improved performance in GPU Computing applications. See CUDA Zone for more details.
* Adds a new user-controlled power management setting for select GeForce 9-series and later graphics cards (only available on cards that already support more than one power state). This option allows users to set a performance level for each DirectX or OpenGL application.
* Includes several new control panel features and numerous bug fixes. More information can be found in the release documentation.
* Users without US English operating systems can select their language and download the International driver here.
Link za download novih drivera
evo probano sa 190.62 driverima i problem lockanja brzine venta na 70% nakon izlaska iz igre je ostao. znaci to jos nisu ispravili. a mozda niti nece, mozda je stvarno 9800 gtx+ za njih stara kartica i za nju vise nece raditi full support???
Zadnje izmijenjeno od: Razer. 23.08.2009. u 15:44.
Staro 23.08.2009., 00:30   #2
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,309
Ne znam, imam BFG GTX+ i sve uredno radi sa svim mogucim driverima.
Staro 23.08.2009., 09:56   #3
alengrosevic
Postovi: 3,775
pa evo sinoc poslije ovog mog posta sam skinuo sve moguce drivere od 185.xx do 190.62. i zadnji koji ok rade su 186.18. Poslije njih svi driveri imaju isto ponasanje. u igrama vent od na 70-80% i nakon sto izadjem iz igre, vent ostaje "zaglavljen" na tih 70-80%. Nesto je bilo rijeci da je nvidia pocela regulirati brzinu venta preko drivera, a ne preko biosa kako je bilo do sad. mozda to zeza, a mozda je nesto drugo posrijedi. Inace sve osim venta radi ok, nikakvi artefakti, nikakvi BSOD-ovi niti ista slicno...
Staro 23.08.2009., 10:47   #4
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Mogu potvrditi da sa 190.62 nema nikakvih problema na GTX260 216.
Staro 23.08.2009., 12:00   #5
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
kod mene su 186.35, nemaju tih problema. S 190.xx sam imao, istina samo one prve sam isprobao. Kasnije nisam imao volje kad mi ionako sve radi normalno s ovima.
Staro 26.08.2009., 16:01   #6
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,740
Trenutno sam na 185.85.... ( i zasada najbolji , (meni))
Jel se osjete razlike bilo gdje, naspram 190.62, pošto su 190.3x bili jad prema vasim pisanjima....
Staro 10.09.2009., 17:56   #7
ivan77
Koji bi meni bili najbolji? Trenutno vozim GTS 250 1gb
Zadnje izmijenjeno od: ivan77. 10.09.2009. u 17:56. Razlog: .
Staro 10.09.2009., 20:32   #8
Gx25
RiSeN FrOm tHe BaNNeD
Lokacija: cro
Postovi: 662
Ja koristim zadnje pa probaj i ti
Gx25 je offline   Reply With Quote
Staro 10.09.2009., 22:34   #9
Pantera-N
Pantera-N's Avatar
Lokacija: In front of the monitor
Postovi: 1,593
samo me zanima jel su riješili zadržavanje venta na 80% nakon LOAD-a. Ako netko ima GTS neka proba
Pantera-N je offline   Reply With Quote
Staro 11.09.2009., 08:42   #10
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
Probao neki dan - nisu. Ocito ne misle da je to neki problem ili se prave blesavi
Staro 11.09.2009., 11:17   #11
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Vjerovatno su se kao i ATi poceli isfuravati samo na nove kartice i odjebali starije/losije modele. Cim je izasao HD4870 gotovo da je prestala podrska za HD3870.
Staro 11.09.2009., 11:35   #12
ivan77
ajde nek neko obajsni kak se ono na NVIDIA -i napravi da se može radit switch displaya sa TV na monitor i obrnuto? Piknuo sam DVI to HDMI adapter i spoji na TV , al svaki put moram podešavat one display settingse ,...ima neki easy way ?
Staro 11.09.2009., 13:02   #13
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
Autor Dizel Pregled postova
da ali njima je gts "nova" kartica. Mislim da je ipak rijec o bugu koji ce biti ispravljen, pitanje je kada.
Mozda bi pomoglo flashanje biosa s kartice nekog od ovih koji navodno nemaju taj problem ali to cu ostaviti kao zadnju soluciju ako mi bas budu trebali novi driveri. Za sada i 186 rade sa svime dobro.
Staro 11.09.2009., 18:16   #14
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor ivan77 Pregled postova
desni klik nv control panel i odaberi hoćeš li koristit single display pa prebaciješ po želji i potrebi koji izlaz želiš koristit (tri klika mišem)
ili složiš DualViev
sada ti je slika uvijek na monitoru i tv-u
recimo to ja koristim... pa kad hoću nekaj gledat na TV-u samo na telki prebacim na taj HDMI ulaz i to je to
plus kaj u isto vrijeme na kompu možeš radit nekaj drugo
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
