Staro 22.08.2009., 20:21   #1
WTFFTW
Postovi: 52
Acer Aspire 5520 - nesta dvd-rw
Ne prikazuje mi se u exploreru iako radi (može se izvadit i ubacit cd itd.) prije se to isto dešavalo al ne ovako samo bi uninstallira drivere iz device managera a sad ga tamo uopće ne prikazuje.
WTFFTW je offline   Reply With Quote
Staro 22.08.2009., 20:26   #2
potemkin.hr
Akutna lijenčina
potemkin.hr's Avatar
Lokacija: Fiume
Postovi: 1,834
Možda krepal drive? Pogledaj u BIOS-u ako ga prepozna.
potemkin.hr je offline   Reply With Quote
Staro 22.08.2009., 20:50   #3
WTFFTW
Postovi: 52
Ne prepoznaje.
Staro 22.08.2009., 22:02   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Onda je otišo ili drive ili kontroler.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 22.08.2009., 22:13   #5
WTFFTW
Postovi: 52
Autor Mortal Pregled postova
hm...a kako mogu provjerit jel otiša kontroler? Naime nikad nisan rastavlja laptope samo kompove i mrzim laptope baš radi ovakvih stvari.
Staro 23.08.2009., 00:58   #6
nino
nino's Avatar
Postovi: 12,613
Autor WTFFTW Pregled postova
....Naime nikad nisan rastavlja laptope samo kompove i mrzim laptope baš radi ovakvih stvari.
Onda ni nemoj rastavljat. Daj nekom ko zna, nije puno posla. Vida koja drzi taj slim dvdrw unutra ti je ispod tipkovnice.
Staro 23.08.2009., 07:31   #7
WTFFTW
Postovi: 52
Autor nino Pregled postova
Ja san odvida sa stražnje strane sve vide, skinija san prvu plastiku di su zvučnici i tipkovnicu naša san vidu neku crnu odma do ili iznad dvdrw odvida san je i dvdrw ne izlazi?
Staro 23.08.2009., 11:39   #8
nino
nino's Avatar
Postovi: 12,613
Znaci ispod tipkovnice mora biti, negdje na sredini. Ako si je odvido mora ic van.
Edit: Pomijesao sam modele. Ispod je vida znaci, ne ispod tipkovnice nego sa donje strane laptopa.
Evo ti na linku service manual, skini i sve ti je objasnjeno.
http://rs70.rapidshare.com/files/146...0_5220_eng.pdf
Staro 23.08.2009., 14:49   #9
WTFFTW
Postovi: 52
znači moram dignit ovu crnu plastiku u predjelu od ventilatora do hard disk utora? i tu je vida? provat cu kad dodem doma sad sam trenutno na poslu pa javim.
Staro 23.08.2009., 20:16   #10
WTFFTW
Postovi: 52
Vrlo čudno. Doša san doma i vid vraga radi dvdrw (ne znan kako) i onda san iša reinstallirat windowse al mi je na windows is starting up poruci otiša u bsod da bi opet nesta u biosu?! nisan ništa dira još ni bios ni ništa sam je doša i otiša.
Staro 23.08.2009., 20:36   #11
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Vrlo vjerojatno DVDRW (uredjaj) ne sjeda dobro na utor/leziste, tj. gubi kontakt ... trebao bi raditi kada cijeli uredjaj malo utisnes ...
The Secret ...
Staro 23.08.2009., 21:02   #12
WTFFTW
Postovi: 52
Autor dh41400 Pregled postova
to ću ga sad rastavit i vidit, mislim da nema smisla flashat bios doduše roknija san driveu sad najnoviji firmware sta san naša, a bsod mi izbacuje ove poruke:
0x0000007b , 0xf78de524 , 0x0000034 , 0.00000000 , 0.0000000
izgleda da je dosta ljudi imalo problema sa ovim optiarc sonyjevim dvdrwom, čak ga nema na njihovoj stranici.
http://www.notebookforums.com/thread226852.html
Staro 24.08.2009., 18:31   #13
WTFFTW
Postovi: 52
Malo san prčka po lapu kad san ga otvorija, izbacija dvdrw ispuha prašinu i proradija je! instalira san windowse i sve. Fala lipa.
Samo da još pitam temperatura cpu mi je 60-65 jel to malo previše?
Staro 04.09.2009., 00:46   #14
WTFFTW
Postovi: 52
shi*fuc* evo opet ne radi.
Staro 04.09.2009., 08:13   #15
Postovi: 33,958
Ako je tvoj zaista riknuo, odi na tržnicu - nekidan je lik iz Rijeke prodavao dvd-rw od svog riknutog lapa.
Staro 28.09.2009., 11:22   #16
WTFFTW
Postovi: 52
Autor coconut Pregled postova
imaš li link?
Staro 28.09.2009., 11:47   #17
Postovi: 33,958
Rano si se sjetio...
Staro 21.10.2009., 15:27   #18
WTFFTW
Postovi: 52
probat cu stavit novi firmware pa ako ne uspije, izvadit i krenit čekićem na njega.
Staro 29.10.2009., 18:53   #19
WTFFTW
Postovi: 52
kupija novi model dvdrwa ista firma sony nec optiarc i ne vidi ga bios, sad do čega more bit jel do kontrolera? kako to popravit ako se može? treba mi brzi odgovor.
Staro 30.10.2009., 14:03   #20
Gjur0
Gjur0's Avatar
Lokacija: Kutina
Postovi: 53
Ja isto imao problema i nikako nisam mogao rijesiti ga! Pomoglo je nesto jako glupo! Vadio sam i probavao druge przilice i sve je radilo, al kad sam svoju stavio nije htjela, dok je na dr. lapu uredno radila, onda sam je izvadio rastartao komp BEZ nje, i pustio ga da se podigne, ugasio komp, vratio przilicu, upalio i radi sve i dan danas! Probaj, mozda pomogne!
Gjur0 je offline   Reply With Quote
Staro 30.10.2009., 16:12   #21
WTFFTW
Postovi: 52
Autor Gjur0 Pregled postova
jep, proba i to ne radi.
Staro 30.10.2009., 21:43   #22
Gjur0
Gjur0's Avatar
Lokacija: Kutina
Postovi: 53
probaj skinut przu i probat je piknut u drugi lap (samo skini prednju masku jel inace nece ic!
Staro 01.11.2009., 17:43   #23
WTFFTW
Postovi: 52
e jbga neman tu mogućnost trenutno.
Staro 24.11.2009., 00:58   #24
WTFFTW
Postovi: 52
Thumbs down
Danas san rastavija cili laptop skroz do zadnje vide. Doša san do kontrolera, čini se ok. Vidim da ima dvi vide (šarafa), al nema svrhe kad se to odvida onda se može skinit plastika koja je na njemu. On je isto zalemljen na matičnu. prijedlozi?
