Staro 25.08.2004., 23:35   #1
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
Logitech MX1000
Logitech has silently launched a new cordless MX-series mouse, the MX1000 Laser Cordless Mouse. This will probably be the successor of the MX700 mouse. The main difference between the MX700 and the MX1000 is that newer one doesn't use an optical sensor, but a new laser which is according to Logitech 20 times more accurate than an optical sensor.
The Logitech MX1000 has a Tilt Wheel and it uses a lithium-ion battery. The status of this battery can be read out directly from the mouse. Just like the MX700 this one uses the FastRF technology to transfer data from the mouse to the cradle.
Tweakers reports that the mouse has about the same form as the older mouses, but that it has a darker exterior.
The advice price in Europe seems to be 79.99EUR, but some shops have it listed for less than 60EUR.
Veky je offline   Reply With Quote
Staro 26.08.2004., 00:09   #2
horza
ono ispred konpjuktora
horza's Avatar
Datum registracije: Apr 2003
Postovi: 3,659
mislim da ti nara ima nešto za reći
slinio sam dok je pričo o njemu...
logitech fetish
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 26.08.2004., 00:40   #3
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
O predmetu mojih željaaaaaaa ! slin slin...
MX1000 TI SI MOJ!
Da bacim u staro željezo ovaj explorer (igram pucačine sa prvim optičkim mišem, pa zašto mi nejde )
Staro 26.08.2004., 00:41   #4
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,466
Dajte ima možda koji review, lijen sam za pogledat. I kad će na PCX?
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 26.08.2004., 01:13   #5
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
MX1000 TI SI MOJ!
isti slucaj i kod mene. mislil sam 510mx zeti ali sad kad vidim ovo : nuts : : nuts : .
sad ce rail radit jos i bolje
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 26.08.2004., 01:43   #6
dr.fiksi
doktor, trekkie, amd-ovac
dr.fiksi's Avatar
Postovi: 1,043
Opet sam popušio!!!!
Svijet je monitor s beskonačnom rezolucijom!
1.a64 3500+,abit av8,1.5gb corsair, leadtek geforce 6800 ultra,2x200gb seagate@raid 0,tagan 480w...
2.mobilac 2600+ na 2332mhz,epox 8rda3i,r9800pro,120gb,512ddr,ener 350w...
3.MSI centrino 1.5(dothan), ati9600,40gb...
-->HDD u externom kućištu USB 2.0+firewire-hitachi 200 giga
dr.fiksi je offline   Reply With Quote
Staro 26.08.2004., 02:19   #7
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
definitivno se radi o najboljem mišu kojeg sam ikad probao još ako cijena bude kolko tolko pristojna bit će prava stvar
pinsla je offline   Reply With Quote
Staro 26.08.2004., 13:28   #8
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
jupiiiiii . Ako prodjem (u skoli) dobit cu misa .
Staro 26.08.2004., 14:07   #9
dr.fiksi
dr.fiksi's Avatar
Postovi: 1,043
Da, samo nisam siguran baš za cijenu...
mogla bi biti, ali zna se što je logitech, pa mislim da će to oni i FINO naplatiti.
Staro 26.08.2004., 14:09   #10
Rivi
Ovo ispod nisam ja! :)
Rivi's Avatar
Postovi: 1,692
Majko mila, grozno. Ne za miša, koji je zakon, kao i većina Logiteka, nego za ovo sa školom.
Potpisujem!
Rivi je offline   Reply With Quote
Staro 26.08.2004., 14:47   #11
pinsla
pinsla's Avatar
Postovi: 1,860
ptičica sa grane mi je šapnula da će cijena bit vrlo povoljna
Staro 26.08.2004., 14:51   #12
dr.fiksi
dr.fiksi's Avatar
Postovi: 1,043
In any case:
miš ima neki dobar futuristički look.
E sad, CORDLESS, to mi se nikad nije sviđalo...
previše LAGA, bez obzira na brzinu senzora(ili čega god već) itd.
Dakle, budite sigurni da oni imaju već modele 1500, 2000, ako ne i 2500(kako bi se već zvali ovisi) "spremne".
Staro 26.08.2004., 15:12   #13
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Lijepo, milo, prekrasno :nuts
Samo ... već imam relativno novog mišonju, tak taman da košta 50 Kn - žena bi mi jaja odrala da ga nabavim
Ah ko ga šljivi
S ovim sam jako zadovoljan
Staro 26.08.2004., 19:20   #14
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Kada? Koliko? Nema veze!!!! Moj! Samo moj! Jao! Zaljubio sam se! Cvrect, cvrect...KADA DOLAZI KOD NAS??????????????
Staro 26.08.2004., 21:10   #15
pinsla
pinsla's Avatar
Postovi: 1,860
samo što nije
Staro 26.08.2004., 21:17   #16
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
waaa....ja cu prije tebe ja cu prije tebe :P :clap:
Staro 26.08.2004., 21:21   #17
Bl@de
Bl@de's Avatar
Postovi: 2,004
oce biti koja verzija sa "zicom"? nekak su mi "fiksni" drazi.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 26.08.2004., 22:56   #18
Clifton
humanoid carbon unit
Clifton's Avatar
Lokacija: tamo
Postovi: 347
Vraški dobro zgleda, moram priznat... al' nedovoljno da bi se odrekao svog vjernog kugličara/žičara...
Clifton je offline   Reply With Quote
Staro 26.08.2004., 23:02   #19
MentalHarikiri
MentalHarikiri's Avatar
Postovi: 2,560
opaki je razor sumnjam da će tak skoro biti optikanera koji će imati tu preciznost
Staro 26.08.2004., 23:47   #20
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,466
E, sad znam šta moooram dobit za božić... trenutačno skupljam za psu, al ovo moram nekako nažicat
Staro 26.08.2004., 23:55   #21
Clifton
Clifton's Avatar
Lokacija: tamo
Postovi: 347
Kaj je - je... još da mi se ruke tak ne znoje, bodycount u kLANju bi bio kudikamo veći. Nema goreg neg kad kuglica prokliže, a mrski neprijatelj ti skakuće pred nosom...
Staro 27.08.2004., 00:02   #22
CatKiller
CatKiller's Avatar
Postovi: 3,312
...ili kad s Kar98 promašiš nekog a cijev mu je prislonjena na čelo... frustrijajuće.
na mojoj kasici piše Logitech MX1000
Staro 27.08.2004., 00:02   #23
horza
horza's Avatar
Postovi: 3,659
ma ti nisi normalan
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 27.08.2004., 00:10   #24
Clifton
Clifton's Avatar
Lokacija: tamo
Postovi: 347
Hehe... Mosin-Nagant je moj izbor... zato imaš kundak...pardon, usadnik u meleeju...ništa slađe neg' nekog iskundačit...pardon, usadit u close quarter fajtu...
Staro 27.08.2004., 00:18   #25
ćiber_manija
CyberSky
ćiber_manija's Avatar
Datum registracije: Feb 2004
Lokacija: Jastrebarsko
Postovi: 1,168
Meni je najbolji mosion nagat sniper, m1 Garand i onaj američki karabin
The šuma...
Staro 27.08.2004., 00:34   #26
ßellerophon
Sannin
ßellerophon's Avatar
Datum registracije: Jun 2003
Postovi: 1,568
mosin-nagant nice
ovo BOZIJE REMEK DJELO.... MX1000 - OCI SU MI ISPALE!!!!!!!
MOOOORAAAAAAN TO IMAAAAT!!!! MOOOOOOORAAAAAAAN!!!!
YES - BUT /
Staro 27.08.2004., 00:48   #27
ćiber_manija
CyberSky
Postovi: 1,168
Jel se zna cijena odprilike
The šuma...
Staro 27.08.2004., 01:01   #28
Njusskallo
Njusskallo's Avatar
Postovi: 955
A u kurac ... kak sam se sad sjebo
Sad sam totalka
Nema pola sata kak sam naručio miša iz HGŠrota ... nekog Microsoftovog za 260kn ... da sam dodo još 200 i pričakao kojih 10 dana .... jooooj.
UBIT ČU SE
Njusskallo je offline   Reply With Quote
Staro 27.08.2004., 01:04   #29
Vedran_Links
Postovi: 55
Možda bi bilo dobro da počinjemo stavljati takve komponente u cjenik. Dolaze nam za 5 dana ali jedna izuzetno mala količina.
Sutra tokom dana ćemo ih staviti pa kome se žuri neka rezervira ;-). Cijena će biti forimirana sutra.
Vedran_Links je offline   Reply With Quote
Staro 27.08.2004., 01:10   #30
ßellerophon
Sannin
Postovi: 1,568
Description: HIGH PERFORMANCE CORDLESS MOUSE WITH LASER TRACKING
PI DATE : JULY 2004
TECHNOLOGY : Fast RF cordless
SYS REQS : IBM or compatible PC,
Windows 98, 2000, Me or XP,
Available USB or PS2 port, CD-ROM drive
Macintosh system - Mac OS X+,
Available USB port, CD-ROM drive
FEATURES : * MX Laser Engine provides 20 x times the tracking power
of optical
* a built-in lithium-ion battery & rapid-charging base station
* Fast RF cordless delivers cordless performance that equals USB
corded connection
* New thumb-button controls include universal page forward and back
buttons and application switch to quickly move between open windows
* Illuminated 4-level batt indicator precisely monitors batt strength
* Wheel tilts for side-to-side scrolling, zoom with a click of the
wheel
* Cruise Control rocker for speed scrolling up and down
* Deep-sculpted thumb support for incredible comfort,
outside finger grips enhance control
PACKAGE CONTENT : * Logitech MX-1000 Laser cordless mouse
* Recharging base station, * CD-ROM with SetPoint SW
* Installation guide, * PS2 to USB adapter
* 240V AC power adapter
YES - BUT /
