Staro 19.06.2009., 21:40   #31
Kinfa
Kinfa's Avatar
Postovi: 54
Hrpa problema, i poneko rjesenje:
http://aaotracker.com/index.php
Last one alive, close the door.
Kinfa je offline   Reply With Quote
Staro 20.06.2009., 10:46   #32
chingyos
chingyos's Avatar
Postovi: 375
chingyos je offline   Reply With Quote
Staro 20.06.2009., 11:18   #33
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
Izašao patch koji navodno dosta problema rješava. Sada bi se možda moglo i zaigrat.
S3 Trio 64 , Voodoo 2 , Kyro 3d , GeForce MX 440 SE , Radeon 9000Pro , 6600 GT , 9600 GT , 260GTX , 560GTX , 760GTX, 1060 GTX, 1080 GTX, 3080 RTX
Michel je offline   Reply With Quote
Staro 20.06.2009., 11:24   #34
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
jel ko od vas uspio forsati AA u igri?
thuNdeR je offline   Reply With Quote
Staro 20.06.2009., 12:01   #35
Kinfa
Kinfa's Avatar
Postovi: 54
Autor thuNdeR Pregled postova
Da. Radi bez problema, al trebas procitat ovo:
http://ri051.com/news.php?extend.275
Staro 20.06.2009., 12:17   #36
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
I dalje je ovo poprilično neigrivo ali stvari kreću nabolje. Uspio sam bar treninge završit.
Staro 20.06.2009., 12:21   #37
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
Autor Kinfa Pregled postova
e fala ti puno
Staro 20.06.2009., 12:27   #38
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Aj, da vidimo sad...
Step #1) Nvidia users go here and download nHancer.
(Sorry ATI guys, I have nothing comparable to link you to)
Step #1.A) Before starting work in nHancer, click the radial button named "Global" at the top.
Step #1.B) After installing nHancer, goto the compatbility mode tab, and change the "Anti-Aliasing compatbility" to 0000041: Unreal Engine 3. This works around Unreal3's inability to produce AA properly, and allows crisp textures with AAx8 on.
Step #1.C) At the bottom of the "Compatibility" tab check the radial button for "Multi-Core Support", this will FORCE AA3 beta to use Multi-Core support (dual-core, or Quad-Core) when rendering textures/objects.
Step #2) In the nHancer program (still nvidia people), goto the "Optimizations" tab, and check "High Quality", "Trilinear Optimzation = On", "Aniso.sample optimization = on", "Negative LOD BIAS= clamp", and "Force DXt3 [OpenGL]= On".
Step #3) (Still Nvidia users =P) Set your Anti-Aliasing as high as you want depending on your card's settings. I have a 280GTX, so my gettings are "Combined = 32xS". Set "Enhance in-game AA setting" UNCHECKED, "Gamma Correction" checkbox checked, and Super-Transparency AA checkbox checked(these three settings are for high end cards, as you might lag with anything below an 8800).
Continue, by setting your Anisotropic Filtering to however high you want, mine is 16x...again 280gtx here happy ! My vertical-sync is forced ON, along with OpenGL triple buffering happy ! I also have ambient occlusion set to FarCry2, just for visual appearances sake, again I'm still fiddling with Ambient Occlusion as it adds soft shadows around objects in-game. You might want to fiddle with other settings as well IF you want to.
Step #3) Close nHancer, and it should goto your desktop tray.
Jel mogu to ikako podesiti da vrijedi samo za AA, a ne za cijeli sistem na global?
EDIT: Mogu napravit novi profil pa dodat AA3Game.exe unutra pa ce radit?
Zadnje izmijenjeno od: IcyTexx. 20.06.2009. u 12:45.
Staro 20.06.2009., 13:52   #39
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
ja sam i prije hot fixa mogao zavrsiti treninge, ali mi se nisu upisivali... a taman dobio medalju u prvom i 98% fiješeno u drugom treningu, nakon trečeg me uvijek vrati u main menu..
a nakon hot fixa.... stvari mi se nisu promjenile
užas...
Nemam više lema!!!
Staro 20.06.2009., 14:33   #40
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Dobro, ni meni... Dokad trebam radit te glupe treninge??
Isto mi je ko i Lordu.
Staro 20.06.2009., 15:09   #41
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
Nakon hotfixa trening mi je fakat proradio potpuno normalno tako da ne znam da li još netko ima problema s time, nadam se da je to riješeno.
Ono što je skoro nemoguće je igrat na serverima. Previše ljudi se joina i disconnecta u isto vrijeme. Je li netko voljan napravit hamachi server za pcekspert ekipu ?
Staro 20.06.2009., 15:15   #42
Necto
Necto's Avatar
Postovi: 747
Ne radi trening ni sada ... Zavrsim prvi i drugi dio sve excelent i vrati me na Main Menu i resetira sve ...
Nema nista od ovog jos bar 2-3 patcha
Necto je offline   Reply With Quote
Staro 20.06.2009., 15:15   #43
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
Moj ip 78.2.160.64
Hamachi ip : 5.86.70.235
Ime mreže AA3PCE
password PCE
Staro 20.06.2009., 16:01   #44
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
meni treninzi rade normalno
Staro 20.06.2009., 16:03   #45
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Ekšli sam sad ponovno uso u igru i skuzio da su se treninzi apdejtali. Bravo.
Staro 20.06.2009., 16:37   #46
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Evo, uspostavio sam server, dodjite igrat!
IP: 5.221.141.100:8777 (kad udjete u Hamaci)
Staro 20.06.2009., 23:02   #47
veve
woot!!!
veve's Avatar
Postovi: 2,496
Ma daj kakav je to njima patch... igra mi se rusi u 90% slucaja i 10 put duze ucitava nego prije
veve je offline   Reply With Quote
Staro 20.06.2009., 23:36   #48
Necto
Necto's Avatar
Postovi: 747
Ma nema ovo svrhe bez jedno 5 dobrih patcheva ... ili jedan ogromni ...
Prodjem 3 treninga i spremi mi ih normalno ... prodjem cetvrti i bloka na kraju kada ono sprema trening ... ugasim priko task managera udjem ponovo u igru i opet svi treninzi resetirani
Krenem ponovo ... pocme loadat prvi trening i bloka citav komp ... pustija san ga 15min dok san otisa vecerat i nista ... samo reset pali
Ovo trenutno nije niti beta ... ovo je pre-alpha
Staro 21.06.2009., 00:34   #49
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
Autor Necto Pregled postova
Oko ovog zadnjeg se moram složit. Nikad dosad nisam za dobrih 20 minuta traljavog gameplaya jebe sam sebe u mozak 8 ura .....
Idem sad izbrisat igru i instalirat je tek kad vidim forume presretnih ljudi
Staro 21.06.2009., 00:37   #50
BeroVK
Lokacija: Vinkovci
Postovi: 780
Ja se nemogu connectat niti na jedan server, tj. connecta se ali kad treba kao profil ucitat jednostavno me vrati u glavni meni xD I kod mene pada uninstal.
BeroVK je offline   Reply With Quote
Staro 21.06.2009., 01:44   #51
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Strasno...
Bit ce kojih 20 patcheva pa ce proradit. Inace, priznajte da ima potencijala.
Staro 21.06.2009., 02:07   #52
BeroVK
Lokacija: Vinkovci
Postovi: 780
Potencijala svakako ima sam da rijese te probleme i nadam se da ce to bit ubrzo
Staro 21.06.2009., 02:12   #53
Necto
Necto's Avatar
Postovi: 747
Naravno da ima potencijala
Evo i dokaz da ima
Klik na link <----
Zadnje izmijenjeno od: Necto. 21.06.2009. u 13:08.
Staro 21.06.2009., 08:54   #54
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
Autor Michel Pregled postova
mislim da bum i ja tako jer ovako me nije ispizdio ni famozni GTAIV i njegova optimizacija
Staro 21.06.2009., 11:30   #55
Kinfa
Kinfa's Avatar
Postovi: 54
Klonete duhom a to nije dobro. Sinoc sam igrao u komadu od 11 - 02 h na Danskom serveru, "DanishEliteForce". Igra ima bugova tu se slazem. Tipa bomba i puska u ruci , cak sam i nevidljivi zid naso .
Kolko ja kuzim sta treba radit:
1. U meniju imat strpljenja da se sve loada, treba cekat jedno pol minute. Jednostavno se logirajte i ne znam odite po kikiriki
2. Kad odaberete Multiplayer nikako se nemojte spajat na servere koji sa desne strane imaju STIT (oznaka PB-a) to je jedan od glavnih problema Steam verzije.
3. Kad se serveri izlistaju stisnite na vrhu na PING da se poredaju od najmanjeg prema najvecem. Nemojte ulazit na servere sa pingom vecim od 40, to nije ping 40 btw?, ali skuzio sam da je to maximum ako ne uspijete upast a hocete se vratit bez Ctrl - Alt - Del nazad u meni.
4. Ciljajte servere sa barem 10 igraca ispod maximuma, npr. 16/26 ili 7/14, jer postoji velika mogucnost da cete upast u guzvu. Ogroman broj igraca se spaja istovremeno i tu je lutrija upast na server kojem fale samo 2 - 3 igraca ispod maximuma. Ako upadate na server koji se taman popunio igra vas baca nazad u meni. Zato ne mozete igrat on line i uvjek vas izbacuje. 160 000 registriranih igraca, a samo 100-njak servera :P. Samo da vas podsjetim, prvog dana je bilo 30-tak servera.
5. Kad udjete u server i niste imali srece za vrijeme loadanja server se popunio ili ima neki drugi problem. NIKAKO ne stiscite SPECTATE igra ce se smrznut i morat cete odradit Ctrl - Alt - Del
6. Samo jos nesto kad udjete na server koji puta je potrebno pricekat minutu do dvije da autorizacija prodje. Eto ja sam ceko pa sam uspio odigrat dobra 3 sata.
Meni igre je spor do zla boga i cesto kad mislite da se igra smrzla u stvari nije, svi oni loading screenovi kad se vracate iz treninga ili servera dugo traju ali samo treba cekat. Sporo odradjuje ali odradjuje, ipak
Zadnje izmijenjeno od: Kinfa. 21.06.2009. u 13:47.
Staro 21.06.2009., 14:23   #56
Hunt.ONE
ЬГΛY.Z0ИЗ
Hunt.ONE's Avatar
Lokacija: Sisak
Postovi: 258
Da, i ja sam primjetio da serveri koji imaju pb uglavnom zezaju..
Vjerujem da bi se kroz tjedan-dva sve moglo stabilizirati...
btw.
da li se tko sjeca otvorenje cod2 i cod4?
ovo je daleko bolje
a opet ne valja.
Autorizacija cesto pada, pa bez obzira ako i pocnete igrati, sanse su da svi serveri padnu radi toga.
Prevelika navala ljudi
This post is copyrighted ©
Hunt.ONE je offline   Reply With Quote
Staro 21.06.2009., 17:09   #57
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
Ono malo što sam odigro je bilo fora. Ubio sam 5 likova sa sawom zaredom u istoj kući kako dobro. Svi zajedno išli troje odma s leđa a dvoje naknadno. I onda kad sam se osjećao ko rambo reloadam kad vidi vraga nemože se više pucat a tek reloado. Lupam middle mouse da nije na safe kad nije i tako. Uglavnom onda me lik lijepo ko švicarski sir.
Staro 22.06.2009., 09:29   #58
sinn69
sinn69's Avatar
Lokacija: ZGB
Postovi: 29
uopce se nisam mogao spojiti na nijedan server i igra se rusila svako malo,zatim sam obrisao igru i deploy client i sve nanovo instalirao i sada mi nadje samo 12 servera za igru,ali na njih se bez problema konektam i igram,gdje su nestali ostali serveri nakon moje nove instalacije igre prije ih je bilo oko 100?
sinn69 je offline   Reply With Quote
Staro 22.06.2009., 12:29   #59
Kinfa
Kinfa's Avatar
Postovi: 54
Izasao je Punk Buster koji podrzava AA 3.0. Mozete ga skinut ovdje:
http://www.evenbalance.com/index.php?page=pbsetup.php
Instalirate ga u unutar pb foldera: AmericasArmy/Binaries/pb. Na padajucem izborniku izaberete AA version 3 i stisnete update, i to je to.
Staro 22.06.2009., 12:51   #60
Tuna
Unregistered User
Tuna's Avatar
Lokacija: Našice
Postovi: 426
jučer sam igrao na nekom [SRB] serveru... ima balkanaca koliko god hoćete
i što je najbitnije svaki put sam normalno ušao u server, jedino nije radio 10-tak min dok se mjenjala mapa
e da. ja sam Lazy_Tuna ako me netko sretne da zna
Tuna je offline   Reply With Quote
