Staro 31.05.2009., 23:31   #1
rams
80286
rams's Avatar
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
Osijek i Protis
Zanima me da li ej tko iz Osijeka kupovao u Protisu preko web-shopa. Vidim da salju HP expressom.
Zanima me koliko vam je ispala postarina i brzina posiljke?
rams je offline   Reply With Quote
Staro 31.05.2009., 23:47   #2
domy_os
domy_os's Avatar
Postovi: 18,866
Uzimao sam ja i poštarina je bila 50-ak kn. Čekao sam 5-6 dana jer robu nisu imali na stanju.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 03.06.2009., 11:53   #3
sick_boy
sick_boy's Avatar
Postovi: 680
I ja sam uzeo od njih jedan ssd. Također nisu imali na stanju (inače malo što imaju odmah na raspolaganju), čekao sam cca. 10-tak dana, a poštarina je bila nešto ispod 50kn, ako se dobro sjećam.
Bez obzira na sve, preporučujem ih, jer su im cijene super.
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 03.06.2009., 12:03   #4
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,297
meni je ATEN switch stigao za 2 dana bez problema, dostava isto tako nesto ispod 50kn
Staro 31.07.2009., 17:27   #5
Protis
Protis's Avatar
Postovi: 136
sa hp ekspresom u zadnje vrijeme imamo dosta problema, ne dodu po robu, ne dostave na vrijeme.... pa prelazimo na overseas, cijene su slicne, manje stvari mozda malo skuplje dok su vece stvari jeftinije, uglavnom overseas bi trebao biti dosta pouzdaniji
Protis je offline   Reply With Quote
Staro 31.07.2009., 18:24   #6
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Još da se uvede recimo ako kupci uzmu nešt preko 1000kn,1500kn da je poštarina bespla,više bi ljudi kupovalo...
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 31.07.2009., 23:08   #7
domy_os
domy_os's Avatar
Postovi: 18,866
Autor Lihto Pregled postova
A kako bi bilo da ja konačno dobijem one besplatne ćevape od tebe? Ali u somunu mora biti barem 15 ćevapa, a može i 20 s pola kile luka.
Teško je u današnje vrijeme očekivati išta besplatno obzirom na recesiju i krizu...
Staro 31.07.2009., 23:24   #8
dejanbinladen
konjpjukter
Postovi: 934
Autor domy_os Pregled postova
e imas u bonusu u hrv rep 20kn sarajveske cevape velika porcija
dejanbinladen je offline   Reply With Quote
Staro 01.08.2009., 20:50   #9
Joke
N00B
Joke's Avatar
Postovi: 3,886
Nema sanse da bi to pojeo cak i kad bi lihto (pica) popola to sa tobom...
IE6
Linux is Not Windows
Staro 01.08.2009., 22:41   #10
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
Autor Protis Pregled postova
to su neki vasi lokalni problemi, nista sto reklamacija na pravoj razini ne bi rjesila
a dostava....ovi manji dostavni su sranje sto se tice manjih mjesta. Za gradove sumljam da ce biti problema s njima. Veci je problem sto su im rokovi dostave puno vise opceniti nego kod hpexpresa. I sto je mala sansa da ce treci dan do 17 isporucivati kao hpex sutra ujutro ako je covjeku usput (a gotovo uvijek im je usput ). Dakle dobit cete skuplju dostavu s sporijom isporukom. I to samo zato sto netko u lokalnoj posti nema vjerovatno dovoljno vozaca da pokrije sezonu godisnjih
Staro 03.08.2009., 12:18   #11
domy_os
domy_os's Avatar
Postovi: 18,866
Overseas i Intereuropa bi trebali biti OK, dosta su brzi, ali znaju im zalutati paketi, pogotovo kod Intereurope.
Autor Joke Pregled postova
Svaki mjesec roknem 15 komada u Orašju pa se ti misli... Lihto jedva 5 pojede...
Staro 03.08.2009., 16:00   #12
Joke
N00B
Joke's Avatar
Postovi: 3,886
Pa nisam ni mislio da Lihto moze pojest vise ..
IE6
Staro 03.08.2009., 16:09   #13
Lihto
Lihto's Avatar
Postovi: 3,945
Sad već spamate obojica,samo on neće dobit ban jer je moderator...I da mogu pojest 10 čevapa bez problema...
iPhone XR 128gb
Staro 05.08.2009., 11:02   #14
Protis
Protis's Avatar
Postovi: 136
Autor greg SE Pregled postova
a ne znam jel lokalno ili ne ali obecamo ljudima da cemo poslati pakete danas i nazove hp ekspres i "unesemo" posiljke i kad trebaju doci pokupiti nema ih i to se dogodilo vec nekoliko puta, naravno da su nama naplatili za to iako nisu dosli, kupci su nezadovoljni jer nisu dobili robu...
overseas ima svoj aplikaciju sa kojom mi sami zaprimimo pakete isprintamo naljepnice i oni dodu i pokupe to, prvi dojmovi su puno bolji od hp ekspresa, paketi od par kg su nesto skuplji nego hp ekspres ali bolje dati par kn vise pa da ti stigne na vrijeme, veci paketi su jeftiniji nego kod hp ekspresa
