#2133 |
Lokacija: Splity
Postovi: 3,003
Jasno da nema. ![]() Treba potražit teme u kojima je već riješen taj "problem". Bootloader ostao nakon Viste? I nekoliko stranica prije u ovoj temi… ![]() |
#2134 |
Postovi: 4,203
:whistle: Microsoft Windows Vista and Server 2008 SP2 FINAL RTM xxxxxxx Service Pack 2 for Windows Vista has reached the Release to Manufacturing stage In addition to a number of security and other fixes, the following new features will also be added: * Windows Search 4.0 (currently available for SP1 systems as a standalone update) * Feature Pack for Wireless adds support for Bluetooth 2.1 * Windows Feature Pack for Storage enables the data recording onto Blu-ray media * Windows Connect Now (WCN) to simplify Wi-Fi configuration * Improved support for resuming with active Wi-Fi connections * Enables the exFAT file system to support UTC timestamps, which allows correct file synchronization across time zones * Support for ICCD/CCID smart cards * Support for VIA 64-bit CPUs * Improves audio and video performance for streaming high-definition content * Improves Windows Media Center (WMC) in content protection for TV[ * Provides an improved power management policy that is up to 10% more efficient than the original in some configurations Windows Vista and Windows Server 2008 will share a single service pack binary, reflecting the fact that their code bases were joined with the release of Server 2008. Unlike prior Service Pack releases of both Windows Vista and Windows XP, Microsoft has decided to release Service Pack 2 in the form of an OEM Preinstallation Kit to OEM partners 60 days after the date of Windows 7 General Availability. Size: 1.34 GB
#2136 |
Default
Lokacija: Požega
Postovi: 1,508
ja nikako s tom vistom na zelenu granu Nakon par pokusaja prelaska na Vistu, idem opet pokusati ![]() - BSPlyer mi uopce nece otvoriti film ili seriju. samo se zablokira i moram ga "nasilno" ugasiti. - Compro DTV i DVBViewer (programi za tv karticu) isto se uopce nece pokrenuti, krenu se loadati pa stanu. I nista ne pomaze osim logouta ili restarta (cak nekad nece ni onda proraditi). i sad se opet vratih na XP, isti programi, isti driveri i sve radi ok, bez greske. Znaci problem je u Visti. Nisam jos probao ovu leaked verziju Viste SP2, ali bas me zanima, cim nadem vremene isprobat cu. - svi zadnji driveri instalirani - Bsplayer zadnja verzija + codeci koje nudi za instalirati - XVID codec - ac3filter - ffdshow - vista - svi updateovi U cemu je problem da nije kompatibilno sa Vistom ili se nesto kolje? Jel netko imao takvih problema?
#2137 |
Lokacija: Zagreb, Centar
Postovi: 1,796
#2139 | |
Lokacija: Žepče
Postovi: 407
#2140 |
Lokacija: Irska
Postovi: 1,171
Inst. Vistu sinoć, prvi dojam je da je to KATASTROFA, nepregledno, Windows Explorer neupotrebljiv, video fileovi rade po svojoj volji (par sekundi iz sredine, pa izpočetka, kao da netko mixa)... ne mogu se promjenit ikonice za foldere... volim imat folder sa MP3-em i filmovima da svaki ima svoju ikonicu... za prebacivanje datoteka ili brisanje pita te 55 puta jel oš il neš to obrisat? ma daj.... Što reći nego napola odrađen OS (smeće), probati ću za koji dan Win7, kad uhvatim vremena, inače se vraćam na XP...
#2141 |
Lokacija: Irska
Postovi: 1,171
E DA, zaboravih napisat bitnu stvar, slika mi je mutna i slova imaju nekakvu crvenu pozadinu/sjenu, to mi je isto bilo na jednoj staroj verziji XP-a, i eto sad na Visti, kad bi vistu usporedio sa autom... to bi bio TRABANT ili konjska zaprega.
#2142 |
its slightly turbocharged
Postovi: 5,430
Mhm, glavno da si prosro gro sranja po OSu a nisi pročitao ni neke najvažnije "cake" Npr, isključivanje user account controla (ono što te pita 100 puta za sve), ikone se mogu promjeniti ![]() ![]() Tekst... mutan... a da uključiš clear type? ![]() Napola je odrađen u početku kao i XP, sa SP1 Vista kuca ko švicarski sat, odličan OS Hrpu stvari trebaš napraviti po instalaciji Viste, ali kad utrošiš tih pol sata za uštimavanje miran si.
blaa |
#2144 | |||
Postovi: 553
![]() Citiraj:
![]() Citiraj:
brljezgaš gluposti, i flejmaš bezveze, niti jedan konkretan (i prije svega TOČAN i PROVJEREN) argument nisi dao. Vista je Vista, dakle nije XP, dakle drukčiji OS, dakle treba mu i drukčije pristupit. Vista mi se na ovom kompu ponaša identično kao XP, al naravno tek nakon što sam ju prilagodio svojim potrebama, tu mislim i na sami izgled, znači layout prozora, menija i slično, a to sve sve može fino naštimat, samo treba imat malo volje naučit nešto novo a ne ko pijan plota držat se nečeg. Što se Win7 tiće, probao sam zadnji onaj RC, dobar je, ali ne primječujem bitnu i neku ozbiljnu razliku od Viste (tu ne mislim na "komzetiku", to me ne zanima ionako), ako ti se Vista nije svidjela, neće ni Win7, jer po svemu što si napisao, imam dojam da očekuješ "remake" XP-a, a ne novi OS. Ja sam uz Vistu prvih 2 tjedna izgubio živaca i živaca jer sam uporno pokušao od nje napravit XP, al treba shvatit da to ne ide tak, jednostavno je drukčiji OS, i neke stvari drukčije obavlja. Treba "prokužit" Vistu, i skužit kaj treba kak naštimat. A ista priča je i sa Win7, tako da, mislim da ti ni sedmica isto neće leć. Ovi problemi koje su naveo su tvoji konkretni, pa umjesto da se raspitaš ima li itko riješenje ili neka saznanja, da si recimo googlao malo...Ne, ti popljuješ OS kojim se ne želiš naučit koristit. I da, BTW, SP1 je obavezan za Vistu, neznam jel ga imaš gore, bez njega je Vista neupotrebljiva praktički, to je definitivno istina. Tako da, moja preporuka ti je da si daš više od dan i pol za testiranje i recenziranje nekakvog komada softvera poput OS-a. ![]() |
#2145 | |
Lokacija: Irska
Postovi: 1,171
-Ikonu promjenit i bude prikazana pola sekunde i onda se vrati na ono što je bilo prije. -bolji player? A TO JE??? -clear type je bio uključen, isto je i kad je na standard, i prisutan je samo na npr. tabovima i slično, a tu sad kad pišem ovaj text (crna slova, bijela pozadina) je slika super. Ne pomažu postavke na monitoru..........
#2147 | |
Postovi: 553
Zbilja smo u ovoj temi pregazili hrpu problema i upita oko Viste, tak da ovdje možeš praktički sve nać šta ti treba. A tu je uvijek i ![]() ![]() |
#2148 | ||
Postovi: 5,430
![]() Citiraj:
Neznam... koji koristiš? Meni ni na WMP, ni na KM Playeru, ni na VLC playeru nikad nikakvih problema Nije lako naviknuti se na Vistu, definitivno, i ja sam ju bio brisao i vračao XP par puta, no kad sam jednom naučio ove cake o podešavanju i malo se naviknuo na Vistu, nikad više se nebi vratio na XP Indexsiranje diskova i superfetch isključit, ReadyBoost također, ima tu podosta stvari za podesit, da ručno, ali malo se potrudiš i imaš OS na kojem je milina raditi ![]()
blaa |
#2149 |
Postovi: 553
Ok za indexiranje i ready boost( i još jedno barem 10-ak bezveznih servisa), al zakaj SuperFetch? ![]() Ako išta drugo, vista mi se podiže puno brže od XP-a, pod time mislim i na startup aplikacije (antivirus, CCC i MSN), trenutno se podižu, bez čekanja. Šta nije superfetch zaslužan za to? Moguće da živim u zabludi.... ![]() I btw, kad smo već kod podizanja Viste, sve se upali, ali moram jedno pol minute pričekat da se LAN spoji il šta mu već radi, ne znam. Uglavnom, kod sata gdje mi je ikona ona, prvo je crveni X gore, tad se ne mogu ni spojit, neki programi mi ne reagiraju, sve dok se ne pojavi žuti uskličnik, e tek onda se mogu spojit na net, al do tada ne reagira nekih pol minute. Iritira. Imam od Tcoma router, Dlink 584T. I svaki put kad palim komp, moram se ponovno spajat na net, na XP mi nije bilo tak. To je isto muka jer se rijetko spoji iz prve.....Jel to onaj smrdljivi IPv6 kriv možda? |
#2150 |
Postovi: 5,430
Hmmm, ja superfetch isključujem, ali to je od usera do usera. Osobno dovoljno mi je brzo kad komp i bez tog servisa diže aplikacije. Trpanje programa u RAM za koje windowsi misle da ću ja pokrenuti mi ne treba ![]() Neznam dali si išta propustio, i ne živiš u zabludi ![]() Ja sam isto prije sa Kasdom morao čekati nakon paljenja 30ak sekundi dok se ne pojavi uskličnik pokraj kompova kod sata, i tad sam mogao na net, sad imam Siemens Gigaset SX 763 i u njemu su svi podaci tako da čim upalim komp imam net iste sekunde, nema više konektanja ![]() A IPv6 se mora isključiti, inače stoji cijelu vječnost na onome registering you computer... makar se već i na tom dijelu može na net, iritira jako ![]()
blaa |
#2151 | |
Lokacija: Irska
Postovi: 1,171
#2152 | ||
Lokacija: Irska
Postovi: 1,171
E da, IPv6 sam čak sam skužio da se mora isključit, grrr -neću se vračat na XP, barem ne na ovom hardu, imam XP inst. na drugom ![]() E da, ako smijem reći da je XP puno brže odlazio u standby i podizanje sustava, ali vidjet ću još nakon tjedan dana kak' će mi se činit Vista...
#2154 | |
Postovi: 553
A pogotovo ovo drugo, ide minutu "registering your computer to network..." bla bla bla, iste sekunde se on spoji (vidim po antivirus i MSN da se spoje), al IE ne mogu opće otvorit. Ugasio sam taj IPv6, al opet ostaje to da se moram svaki put konektat ponovno. Kompić ima isti router ko ja, ima XP, i stalno mu je spojen na net, čim ga upali, odma na netu. Tak da nije do routera vjerojatno. Tj., možda jest do routera, ali u postavkama njegovim, a na tom polju sam laik popriličan(net, routeri LAN i slično...). Trebo bih Tcom nazvat, možda će znat, ak nitko ovdje ne zna. |
#2155 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,737
OTOH, gdje imam (mrezni) problem jest pri pristupanju Samba shareu (passwordom zasticenom), niti username niti password ne zele ostati zapamceni nakon restarta, unatoc, dakako, stiskanju "Remember my password" kvacice. Unutar te iste Viste, virtualni XP taj feature odradjuje besprijekorno.
#2157 |
Postovi: 3,074
Otvara mi sve prozore u windowed modu,ne u full screenu.Jel se to može gdje podesit? |
