#511 | ||
Postovi: 359
Phenom II X4 službene cijene i guru3d review
AMD Phenom™ II X4 Processor pricing (direct AMD customers in 1000-unit tray quantities): Phenom II X4 940 'Black Edition' = $275 Phenom II X4 920 = $235 Phenom II X4 review (guru3d) Citiraj:
let my people go! |
#512 |
Postovi: 7,568
Gigabyteova nova serija AM3 ploča
Gigabyte has announced three models of AM3 motherboards supporting DDR3: GA-MA790FXT-UD5P, GA-MA790XT-UD4P and GA-MA770T-UD3P. As AMD doesn’t have plan yet to offer new chipset for motherboard which is compatible with AM3 processor, the above Gigabyte motherboards are all based on AMD 7 Series chipset. The image of GA-MA790FXT-UD5P featuring AMD 790FX+SB750 has already been unveiled. Designed for ultra durable life expectancy, Gigabyte GA-MA790FXT-UD5P supports AMD Over Driver overclocking. Besides, it supports Phenom II processor with maximum TDP of 140W, and features 4 memory slots which means 16GB DDR3 can be connected. Featuring 3 PCIe X1 and 2 PCI slots, it also supports Crossfire with 2 PCIe X16 slots. Equipped with 10 SATA connectors, 6 of which offered by SB750 chip to support SATA RAID 0/1/0+1/5/JBOD, and the remaining 4 offered by Gigabyte SATA2 chip to support SATA RAID 0/1/JBOD. The availabity and pricing of this lineup are unknown yet.Izvor: Expreview Zadnje izmijenjeno od: McG. 30.09.2010. u 17:11. |
#513 |
Postovi: 7,568
AM3 Phenomi stižu 08.02.'09. i najavljen Phenom II 950 X4
According to our usual sources of information from Europe, AM3 processors will go on sale on Feb 8. The AM3 processor which contains two memory controllers for DDR2 and DDR3 will have 938 pins and will work on existing AM2+ boards with DDR2 and future DDR3 boards. Currently, There are a few models and they are 925 915, 820,810, 720 and 710. 9 series has a L2 of 8MB while the 8 series has lesser L3 cache of 6MB and it is also quad core. The 7 series is a tri core processor. Current Phenom II 920 and 940 will not run on AM3+ DDR3 board as DDR3 support is not available on it.Izvor: OCWorkbench i NordicHardware Zadnje izmijenjeno od: McG. 30.09.2010. u 17:11. |
#514 |
Postovi: 1,583
meni se jako cini da je jedan od ovih moj sljedeci proc ![]() ![]() http://www.guru3d.com/article/amd-ph...0-review-test/ |
#515 |
Postovi: 7,568
MSI 790FX i 790GX AM3 ploče
MSI today unveils its AMD AM3 motherboard 790FX-GD70 and 790GX-G65. MSI AM3 motherboard fully supports AMD latest 45nm Phenom II processor and DDR3 memory. Gaming series motherboard even comes with OC Dial and MAX FSB advanced overclocking technologies, as well as M-Flash BIOS update mechanism protection. OC Dial and MAX FSB overclocking enable users to overclock easily and become an expert in a short period of time; M-Flash enables user to load the BIOS files from USB drive to boot up. For better display performance, 790GX-G65 is equipped with 1Gbit DDR3 1333MHz SidePort memory. Users can buy another independent MSI R3400 series graphics card; they simply need to open the Hybrid CrossFireX synergy function to enjoy improved display performance. MSI 790FX-GD70Izvor: VR-Zone Zadnje izmijenjeno od: McG. 14.06.2009. u 00:09. |
#516 |
Postovi: 7,568
Jetway MA3-79GDG Combo mATX AM2+ ploča s podrškom za DDR2 i DDR3 module
MA3-79GDG COMBO supports a hybrid design, supporting both DDR2 or DDR3 for upcoming AM3 processors.Izvor: OCWorkbench i Jetway Zadnje izmijenjeno od: McG. 30.09.2010. u 17:12. |
#517 |
Postovi: 1,816
Znao sam da mi je nesto bilo sumnjivo kada su startali s 2.8GHz i oznakom X4 920 ![]() http://www.techpowerup.com/83608/AMD...ew_Models.html Dalek je put do 990 (995)! ![]() BTW, one price od prije koji mjesec o FX modelu koji radi na 4.0GHz na defoultu sada i nisu tako nerealne. S obzirom na potraznju za procevima od 1000$ i jedan takav po waferu ako se izvadi bio bi dovoljan!
Stupid is as stupid does |
#518 |
Postovi: 1,816
MSI 790FX-GD70 + AM3 X3 ES + DDR3
Test nije bas velik ali za pocetak je sasvim OK. ![]() BTW, izgleda da ce Propos jezgra bez L3 cachea biti pun pogodak! 3.6GHz na defoult voltazi! ![]() 3DMark 06 CPU score X3 8750 : 2945 Ath X3 2.8 : 3383 Ath X3 3.6 : 4219 C2D E8500 (3.16) : 2978 http://itbbs.pconline.com.cn/diy/9762248.html
#519 |
Lokacija: VG
Postovi: 1,758
AMD Phenom II X4 810 and X3 720BE review (AM3) by Guru3d ![]() ASUS M4A79 Deluxe by Guru3d ![]() linkovi na sluzbene stranice dva nova modela mbo: M4A79 Deluxe M4A79T Deluxe |
#521 |
Postovi: 2,644
Dobar je taj X3 ![]() Malo me čudi loš overclock rezultat s X4 810. Zaključani X4 920 ganjaju bez problema na puno više frekve (redovito preko 3.4 GHz uz dobru matičnu što ova Asusica koju su koristili je). Ne kužim gdje je ovdje zapelo, trebalo bi biti slično? Treba vidjeti što donose Propusi:
Na Anandtechu su dobili 3.7 GHz s X4 810 Anandtech Phenom II X4 810 & X3 720 review
i9-10850K / asrock z490 taichi / 64gb DDR4/ 1gb ssd / 4 tb wd hdd / Gigabyte 6600xt / Zadnje izmijenjeno od: Roberto. 09.02.2009. u 12:25. |
#522 |
Postovi: 337
Dobro izgleda M4A79 Deluxe iako reviewi za sada nisu na nivou, zadnjih 10ak dana ju želim kupit i nema teorije da dođe tako skoro u HR, bar tako kažu u M Sanu a vani ju normalno kupuju, pa sam se ipak odlučio na DFI LP DK 790FXB-M2RSH i naručio ju... 720 se čini ok proc, mogao bi se fino prodavati iako se slažem s dijelom teksta gdje kažu da im je čudno imat 3 jezgre, i meni je draže 4, a jako me čudi kako ne mogu clockati preko 3 ghz x4 810 |
#523 | |
Doomster
Datum registracije: Mar 2008
Lokacija: Kraj Donji
Postovi: 400
Zbilja čudno, ali kaže da je puno teže klokati proc bez otključanog množitelja zbog toga jer treba uskladiti sve one faktore itd... uglavnom, ne znam jel se to meni samo čini ili je lik dignuo FSB na 230 i tu naišao na zid jer nije smanjio NB, HT množitelje i te RAM djelitelje... ![]() Citiraj:
#524 |
Postovi: 337
To i mene čudi jer sam ja na Asrocku prešao 250 a da nisam ništa smanjio, kad sam išao smanjivat sam prešao 280... a ljudi su definitivno postali gotovani, više im se ni u bios ne da ulazit, sve bi gospoda iz windowsa u dva tri klika htjela... ![]() Zadnje izmijenjeno od: McG. 16.06.2009. u 01:32. |
#525 |
Postovi: 7,568
Biostar TA790GX A3+ AM3 ploča
Biostar today announced the TA790GX A3+, the first AMD “Dragon Platform” qualified motherboard with next generation AMD AM3 Phenom II processors support. The Phenom AM3 processors are able to support up to DDR3 1600MHz memory speed equipped with AMD 790FX North Bridge, the TA790GX A3+ offers Dual x16 PCI-E 2.0 graphics interfaces to deliver up the latest ATI CrossFireX support for the ultimate gaming platform. The TA790GX A3+ brings the AM3 CPU performance into full play - providing users with the perfect choice for the AM3 processors usage.Izvor: OCWorkbench Zadnje izmijenjeno od: McG. 30.09.2010. u 17:07. |
#526 | |
Postovi: 2,644
Vidi gore, dao sam link na Anandtech, oni su ga pošteno kloknuli, ide skoro kao i BE ![]()
#527 | |
Postovi: 1,816
AMD puts on the ritz with six-core Opteron demo
Izgleda da ce ovi Opteroni biti glavni konkurenti novim Xeonima baziranim na Nehalem arhitekturi u 2P i 4P segmentu. Drop-In su kompatibilni s postojecim socket F plocama tako da oko upgradea postojecih sustava nema problema. Na kraju ostaje da vidimo sto ce prevagnuti - 6 stvarnih jezgri ili 4 stvarne i 4 SMT. ![]() http://www.techreport.com/articles.x/16448 Citiraj:
#528 |
Postovi: 7,568
Phenom II 955 X4, te 550 i 545 X2 AM3 procesori
The first of the three new chips will be the Phenom II X4 955 processor with a clock frequency of 3.2GHz. Certainly, 3.2GHz is nothing to scoff at -- with the release of this new Phenom II X4, the Intel/AMD quad core price-war is going to be elevated yet another little step. The socket AM3 Phenom II X4 955 will have 8MB cache, and will support DDR3-1333. The next parts are dual-core Phenom IIs. AMD is prepping 3.0GHz Phenom II X2 545 and 3.1GHz Phenom II X2 550 processors for launch in mid-May. Both chips will be based on Callisto, which is supposedly the quad-core Deneb die with two cores disabled. So while they are 'only' dual cores, they will benefit from having a good 6MB shared L3 cache, and 512KB of L2 cache for each core. You can expect that these two new dual-core Phenom IIs will be very reasonably priced, as Intel has a slew of high-performing, budget dual-core Core 2 Duo parts on the market. Maybe, with a great deal of luck, some of the cores on these dual-core X2 parts might be able to be unlocked with the right motherboard, like some of the recent X3 chips.Izvor: Neoseeker i The Tech Report Zadnje izmijenjeno od: McG. 30.09.2010. u 17:07. |
#529 |
Postovi: 2,644
Ak se budu stvarno ta X2 čuda dala uspješno otključati u X4, onda je stvarno vrijeme za upgrade ![]()
#530 |
Postovi: 7,568
ASRock ploča s 780G + SB710 čipsetom i ECS 880G ploča
ASRock A780GMH/128M If you are looking for a matx board that can support unlocking of 4 cores from Phenom II X3 710 or 720, this board is something to look for as it has the best cost/performance ratio. ECS A880GM-M ECS showcased the near final version of the upcoming Black series motherboard based on the new AMD 880G chipset, from which we still know very little. The board comes with a pair of beefy chipset and MOSFET coolers, being an AM3 board supporting DDR3-1333 memory instead of DDR2/AM2/AM2+. Release date is not know yet, since it will only be release by the time AMD delivers the 880G to the masses.Izvor: OCWorkbench i Silicon Madness Zadnje izmijenjeno od: McG. 14.06.2009. u 00:16. Razlog: Dodana bolja slika ECS 880G ploče. |
#531 |
Postovi: 7,568
DFI LanParty JR 790GX-M3H5
This neat little board is based on mATX form factor sporting a 4-layer black PCB. It uses 790GX chipset supporting 45nm AM3 Phenom II processors and DDR3 800/1066/1333 DIMMs. It has 4 DIMM slots up to 8GB of memories and has an additional 128MB DDR3 SidePort memory support. There are 2 x16 PCIe 2.0 slots (x8 bandwidth) for supporting Crossfire and Hybrid Crossfire. There is a PCie x1 and PCI slot as well. The board supports 6 SATA 3Gbps ports, 12 USB 2.0 ports, Realtek ALC885 for 8CH HD audio, Marvell 8056 1GbE LAN. The power department consists of 4-phase Vcore and 1 phase NB digital PWM. The BIOS allows the usual tweaking and tuning on Vdimm, Vnb, Vcore, Vsb, VHT, FSB, Multiplier etc.Izvor: VR-Zone Zadnje izmijenjeno od: McG. 30.09.2010. u 17:07. |
#532 |
Postovi: 337
Da se nadovežem na tvoju ploču, šteta ju je ne spomenuti... ![]() DFI finally added an AM3 motherboard based on the AMD 790FX chipset to its lineup. The LANParty Dark 790FXB-M3H5 makes it to the tier of motherboards that are based on the AMD 790FX + SB750 chipset, and support DDR3 memory. Looks and feature-wise, this board is near-identical to the LP DK 790FXB-M2RSH, except for the fact that it features the AM3 socket, supports the latest AMD AM3 CPUs out of the box, and supports DDR3 memory. DFI advertises this board to be "the best OC platform". The board features a 4+1 phase CPU power circuit. It features two full-length electrically 16-lane PCI-Express 2.0 slots to support ATI CrossFireX. The third full-length slot is electrically x4. The board supports DDR3 800/1066/1333 MHz memory, and DDR3-1600 by overclocking. DFI uses the Marvell 8056 gigabit Ethernet controller, which is advertised to be 15% faster than competing models. Audio is care of Realtek ALC885 HD audio. LANParty ABS II on the fly overclocking feature, backed by DFI's iconic Genie BIOS, make for the rest of the feature-set. techPowerUp! Zadnje izmijenjeno od: McG. 16.06.2009. u 00:32. Razlog: Malo prevelika slika pošto je 50KB maksimalno dopušteno za direktno učitavanje. |
#533 |
Postovi: 7,568
Triple i Quad-Core Athlon II serija, te detalji oko dvojezgrenih Phenom II modela
Advanced Micro Devices has decided to delay affordable quad-core and triple-core microprocessors made using 45nm process technology that it plans to sell under Athlon II brand and the chips will not be available before August-September. Still, the new breed of dual-core Athlon II X2 microprocessors is due in June timeframe during Computex trade-show. Earlier AMD planned to release its code-named Propus and Rana microprocessors in April, whereas the dual-core Regor was scheduled for June launch. However, the latest plans of Advanced Micro Devices seen by X-bit labs indicate that the world’s second largest maker of x86 microprocessors will only release Propus and Rana in August-September timeframe, more or less inline with the company’s new mainstream desktop platform code-named Pisces.Izvor: X-Bit Labs Zadnje izmijenjeno od: McG. 30.09.2010. u 17:08. |
#534 |
Postovi: 7,568
Detalji oko nadolazeće AMD K11 (Bulldozer, Fusion i Bobcat) arhitekture
It is never boring in the world of CPUs. Regardless of who's on top, plans for next generations tend to excite everybody in the eco-system… if you deliver, that is. The Ex-Alpha engineering teams lead by Dirk Meyer that created K7 and K8 architecture messed everything up with Barcelona/Agena and the infamous TLB-bug (Translation-Lookaside Buffer). Shanghai/Deneb cleaned a lot of things up and AMD is back being competitive again, but Intel is pushing hard: Intel is operating in tick-tock architectural mode, and so far - AMD isn't able to answer back. K10 and K10.5 were nothing else but improvements over the K8 architecture. AMD's Kryptonite versus Intel's Tick-Tock or are things really as they seem? Looking at public and leaked roadmaps, it looks like AMD's K11, or Bulldozer core is shaping up to be what Core architecture was for Intel. AMD went to the drawing board back in 2005, and started to work on "K11" architecture. Up to today, AMD only delivered three "ticks" and seven "tocks" architectures, with the latest one breaking the tradition: K5 was launched in 1996, K7 followed up three years later. K8 was an evolution planned to debut in late 2001, but numerous (manufacturing-related) delays postponed the part until April 2003. If the current schedule sticks to K8 and K11, we'll have to wait for eight years between the two. At the same time, even though Intel likes to ponder the "Tick-Tock" architecture, the reality is such that even the Nehalem architecture is remotely based on the Pentium Pro core, and if we look through the "P6" architecture, we see that Intel has delivered five genuinely new architectures as ticks, and a gazillion tocks. M-SPACE or how Fusion came to be… Bulldozer architecture is actually a consequence of the failed tie-up between AMD and nVidia. Back in 2005, AMD felt that it had Intel by that certain part of male body (direct quote from an unnamed exec) and wanted to merge with nVidia. That fell through because Jen-Hsun Huang wanted the CEO position, and the rest is history; AMD already borrowed money to buy nVidia and had no choice but to seal the deal with ATi Technologies. The key reason for the birth of the Bulldozer architecture is M-SPACE design (Modular-Scalable Portable Accessible Compatible Efficient), GPU-resembling a "LEGO block" architectural concept that became a mantra in AMD's halls. Under the M-SPACE design guidelines, Bulldozer (10-100W TDP) and Bobcat (1-10W) cores were supposed to address different market segments, but the way of creating a processor was exactly the same. The goal was to have Bobcat addressing the OLPC/netbook/MID market, then considered as a crazy vision by Nicholas Negroponte - can anyone today say "Nicholas was crazy"? Bulldozer was the "big daddy" core, going head to head against then Pentiums and Xeons. Unfortunately for AMD, Intel got there first (Core 2, Atom). CPU becomes APU The Bulldozer core will be implemented across the range: Server, Desktop, Notebook, launching as server first, followed by desktop and notebook. Server-wise, AMD plans to introduce three parts: single die quad-core & octal-core for the launch, with dual-die hex-core (16 Cores) to follow later. Quad-core and Octal-core are succeeding Sao Paolo (Istanbul on Socket G34), while Magny-Cours (12-core dual-die on Socket G34) will be succeeded by Montreal, a 16-core dual-die part. We heard about the "Montreal" codename back in 2006, so it might have changed by now. All of these parts sit on the Maranello platform, which will be introduced early next year. If we look at thr specs, it is beyond any doubt that this architecture is another "hammer", but is a hammer for Intel's line-up of today. Intel will launch 32nm Westmere in 2010, and have roughly 11 month advantage over AMD in terms of manufacturing process. To make the matters worse, Sandy Bridge is Intel's new architecture en route 2011, and there is a big question looming above heads at AMD: what will the state of the market be once that Bulldozer finally launches? 2011 is not too late for a Fusion "APU", though. Even though Intel will launch its 32nm Arandale processor in Q1'10, performance and compatibility of integrated graphics is a far cry from usability standpoint. Intel's integrated graphics currently does little more than output picture on the display, and DX11-compliant, OpenCL-compliant, decent low-res gaming performer will cause serious headaches for Intel. Once Intel integrates those features into Larrabee and Sandy Bridge, then we will be able to speak about problems for AMD. For us, it looks like AMD is on a path of innovation. But when AMD will stop being "late to the party"? Izvor: Bright Side of News ![]() Je da je Theo Valich ![]() |
#535 |
Postovi: 7,568
Jetway XBLUE-77A3 i XBLUE-78GA3 AM2(+)/AM3 combo ploče
Jetway has launched two new models for AMD's Phenom platform and it has stuck to two things, full backward compatibility and the color blue. Jetway XBLUE-77A3 and Jetway XBLUE-78GA3 both use blue colors throughout the design, which do make the board stand out. Another thing making Jetway's two AMD motherboards unique is that they support both Socket AM2/AM2+ and AM3 with both DDR2 and DDR3 memory slots.Izvor: NordicHardware Zadnje izmijenjeno od: McG. 30.09.2010. u 17:08. |
#536 | |
Lokacija: doma
Postovi: 964
Oni misle sve sami ili ? Zadnje izmijenjeno od: McG. 20.04.2009. u 08:02. |
#537 |
Postovi: 7,568
Ko bi ih znal. ![]() Prvo nek naprave taj procesor kojeg najavljuju, a onda se nek pozabave CPU + GPU kombinacijom. Samo je pitanje di bude već AMD na tom područuju kad (i ako) se nVidia odluči na slično rješenje. |
#538 |
Lokacija: doma
Postovi: 964
Nemaju se kaj odlučiti moraju pratiti konkurenciju ili ? nema ili ![]() Zadnje izmijenjeno od: McG. 16.06.2009. u 01:29. |
#539 |
Postovi: 337
#540 |
Lokacija: Zabok
Postovi: 3,383
AMD demonstrirao prvi 12-core Opteron procesor (Magny-Cours). Riječ je o prvom "twin native 6-core" procesoru za novi G34 socket, a u planu su i "twin native 4-core" procesori. U biti se radi o MCM pakiranju, nečemu što Intel koristi već duže vrijeme (Pentium D, Core2 Quad, Dual core Atom). Procesori bi trebali biti predstavljeni u Q1 2010. Prvi native 6-core Opteron (Istambul jezgra) bi trebao biti predstavljen u lipnju. Više o novom G34 socketu: Shema G34 socketa: ![]() Zadnje izmijenjeno od: McG. 16.06.2009. u 00:23. Razlog: Više od 1.5MB slika s direktnim učitavanjem. |
