Staro 13.02.2009., 13:58   #3181
Tovar Muš2
istrijan
Tovar Muš2's Avatar
Lokacija: Novigrad
Postovi: 141
Neznam za 512 -> 1gb. Prije sam imao 256 MB, tako da sad ima razlike.
Benchmark iz igirce:
Ati Radeon x1950pro
Statistics
Average FPS: 21.45
Duration: 37.11 sec
CPU Usage: 92%
System memory usage: 83%
Video memory usage: 99%
Graphics Settings
Video Mode: 1024 x 768 (70 Hz)
Texture Quality: Low
Render Quality: Low
View Distance: 1
Detail Distance: 1
GeForce 9800Gt
, CPU: C2D e6300@2.8 GHz
Statistics
Average FPS: 27.02
Duration: 37.28 sec
CPU Usage: 82%
System memory usage: 96%
Video memory usage: 79%
Graphics Settings
Video Mode: 1680 x 1050 (59 Hz)
Texture Quality: High
Render Quality: High
View Distance: 45
Detail Distance: 63
Tovar Muš2 je offline   Reply With Quote
Staro 13.02.2009., 15:06   #3182
Kr&m&
**Hajduk**
Kr&m&'s Avatar
Lokacija: Hrvatska-Split
Postovi: 282
efo moj rezultat
Statistics
Average FPS: 38.79
Duration: 37.20 sec
CPU Usage: 88%
System memory usage: 93%
Video memory usage: 93%
Graphics Settings
Texture Quality: Medium
Reflection Resolution: High
Water Quality: High
Shadow Quality: High
View Distance: 30
Detail Distance: 35
Definition: Off
VSync: On
Hardware
Microsoft Windows XP Professional
Service Pack 3
Video Adapter: NVIDIA GeForce 8800 GT
Video Driver version: 181.22
Audio Adapter: Realtek HD Audio output
Intel Pentium III Xeon processor
File ID: benchmark.cli
Fassssst.....no0 cooment...
Kr&m& je offline   Reply With Quote
Staro 13.02.2009., 15:26   #3183
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
e ova ekspanzija Lost & Damned, to bu samo za x360 ili bude i za pc???
xGAME je offline   Reply With Quote
Staro 13.02.2009., 15:50   #3184
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
Samo za xbox 360
I ja imam na ploci.
Staro 14.02.2009., 15:13   #3185
aoxsys
Lokacija: Metkovic
Postovi: 30
mjenjam fc2 key za gta4 key.PM me
aoxsys je offline   Reply With Quote
Staro 18.02.2009., 20:40   #3186
R@zzoR
Yippie-Ka-Yay
R@zzoR's Avatar
Postovi: 560
Evo da ne otvaram novu temu. Imam jedan problem, na dva kompa imam instaliran GTA IV i sada pokušam kreirati LAN igru i ne vidim drugi komp, pokušam na drugom kompu kreirat ali ni ovaj moj ne vidi drugoga. Je li možda problem u tome što obe verzije igre nisu originali??? Na oba kompa je instaliran zadnji patch i update za GFWL.
R@zzoR je offline   Reply With Quote
Staro 18.02.2009., 23:29   #3187
Independent
Independent's Avatar
Postovi: 202
Autor xGAME Pregled postova
Ma po meni 99% ce doc za pc samo malo kasnije... Razmislite malo, zasto kada je rockstar izbacio igru za pc naveo da su med detalji za danasnja racunala dok je high za buducnost, a posto lost & damned mozemo smatrati kompletno novom igrom, velike su sanse da ce doc i na Pc-u, ipak je microsoft platio 50 miljuna za tu i jos jednu dodatnu epizodu. Isto kao u 4 mjesecu kad je izasla za ps3/x360... Skoro su svi tvrdili da nebu dosla na pc... a danas, jest da je los port al barem igramo.
Independent je offline   Reply With Quote
Staro 19.02.2009., 19:44   #3188
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
[QUOTE= a posto lost & damned mozemo smatrati kompletno novom igrom[/QUOTE]
Par autića, nove motore , par oružja smatrati potpuno novom igrom.....
Nećemo
Čista expanzijica. To je ušminkaniji Gta 4 ..... nove misijice i to da ali potpuno nova igra ne.
S3 Trio 64 , Voodoo 2 , Kyro 3d , GeForce MX 440 SE , Radeon 9000Pro , 6600 GT , 9600 GT , 260GTX , 560GTX , 760GTX, 1060 GTX, 1080 GTX, 3080 RTX
Michel je offline   Reply With Quote
Staro 19.02.2009., 22:13   #3189
Independent
Postovi: 202
Autor Michel Pregled postova
Nećemo
Ova ti je dobra... uz sve to dobijas i potpuno novog lika (bajkera) koji ima potpuno drugaciju pricu od naseg Nike,a prica znamo u gta nije bas kratka najvjerojatnije ce poboljsati motore, imat cemo nove radio stanice aute motore kao sto si reko prakticki sve novo jedino sto ostaje isto je grad, znaci sve drugacije samo u istom gradu u kojem smo se udomacili
Staro 19.02.2009., 22:30   #3190
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
I ja imam na ploci.
Staro 22.02.2009., 18:37   #3191
-=_GTI_=-
-=_GTI_=-'s Avatar
Lokacija: Osijek/Ansfelden
Postovi: 225
Jel se moze igrati s volanom gta ?
-=_GTI_=- je offline   Reply With Quote
Staro 22.02.2009., 19:06   #3192
dario_cile
Troll
dario_cile's Avatar
Lokacija: Doboj
Postovi: 282
Autor -=_GTI_=- Pregled postova
ja mislim da moze ali meni licno nije fora igrati sa volanom.....
Bolje džaba ležati nego džaba raditi
dario_cile je offline   Reply With Quote
Staro 22.02.2009., 19:22   #3193
-=_GTI_=-
-=_GTI_=-'s Avatar
Postovi: 225
Autor dario_cile Pregled postova
Meni je spojen volan i instaliran ali neznam kako kontrole u gta namjesit za volan... u custom mapping nemos...
i stavio bi si jos onaj mod di mos iznutra gledat pa bi bilo zanimljivo meni...hehe
Staro 22.02.2009., 20:40   #3194
studenac
ludjak
studenac's Avatar
Postovi: 257
moze mala pomoc? imam 9600 GT i cak kad ju klokam sve do artefakta svejedno mi je pre slaba grafulja za GTA, sto mi mozete preporucit da uzmem, recimo da prodam ovu 9600GT i dodam nekih 500kn i uzmem ___________ (nadopunite crtu heh) volio bih jednu od 1GB memorije.
hvala na pomoci !
studenac je offline   Reply With Quote
Staro 22.02.2009., 20:48   #3195
boris87
boris87's Avatar
Lokacija: Žepče
Postovi: 407
grafa bi trebala bitit dovoljna za gta,100% procesor loš..al kad popunis moj komp onda možemo dalje...
boris87 je offline   Reply With Quote
Staro 22.02.2009., 20:49   #3196
studenac
ludjak
studenac's Avatar
Postovi: 257
Autor boris87 Pregled postova
molio sam preporuku za nadogradnju, a ne ocjenu sistema. komp je quad 3,0 GHz sa 4 GB rama. mozemo odmah dalje. tnx.
Staro 22.02.2009., 21:05   #3197
boris87
boris87's Avatar
Lokacija: Žepče
Postovi: 407
onda hd4850
Staro 25.02.2009., 16:39   #3198
hellboy152
hellboy152's Avatar
Lokacija: Pakrac
Postovi: 179
ja sam dobio tu igricu od frenda i traži me neki serial kod uključivanja, koji ja nemam, pa me znaima gdje bi ga mogao naći. . .
hellboy152 je offline   Reply With Quote
Staro 25.02.2009., 17:11   #3199
Facelessone
Facelessone's Avatar
Postovi: 4,204
u algoritmu vjerojatno
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 25.02.2009., 17:37   #3200
hellboy152
hellboy152's Avatar
Lokacija: Pakrac
Postovi: 179
imam samo dva dvd-a kao .iso i to je to
Staro 25.02.2009., 17:51   #3201
brunci-vg
Lokacija: vel.gorica
Postovi: 303
Autor studenac Pregled postova
hvala na pomoci !
imam gainwardovu grafulju 9600gt dual slot sa 512mb ddr3 rama i radi mi savrseno, uz standardni takt, znaci nisam nista dirao po perfomansama graficke... cak i uz vistu na 2 gige rama sve dobro sljaka.. bilo bi pozeljno imati gigu rama za graficku ako bas zelis max detalje u igri...
edit: cak mi call of duty 2 radi sve na ultra hight i very hight detaljima uz rezu 1440*900
brunci-vg je offline   Reply With Quote
Staro 26.02.2009., 12:46   #3202
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
hvala na pomoci !
definiraj to ''pre slaba'' ja sam sa svojom konfom gta vrtio na high na rezi 1440x900 i ispuni si opciju moj komp
thuNdeR je offline   Reply With Quote
Staro 26.02.2009., 12:56   #3203
dario_cile
Troll
dario_cile's Avatar
Lokacija: Doboj
Postovi: 282
sta ce ti jaca grafa kad sam ja vrtio na medium detalji i texture a rezolucija je bila 1280x720.....
Staro 26.02.2009., 13:03   #3204
Mejzlik
tha pilot
Mejzlik's Avatar
Postovi: 647
Evo moj bench, je li bih mogao jos kako izvuci koji fps sa ovom konfom, a da se ne gubi na kvaliteti grafike?
Statistics
Average FPS: 25.77
Duration: 36.98 sec
CPU Usage: 100%
System memory usage: 89%
Video memory usage: 100%
Graphics Settings
Render Quality: Medium
Reflection Resolution: Low
Water Quality: Medium
Shadow Quality: Low
View Distance: 6
Detail Distance: 100
Definition: Off
VSync: On
Hardware
Service Pack 3
Video Adapter: ATI Radeon HD 2600 XT
Video Driver version: 6.14.10.6903
Mejzlik je offline   Reply With Quote
Staro 01.03.2009., 18:01   #3205
studenac
ludjak
studenac's Avatar
Postovi: 257
Autor thuNdeR Pregled postova
pre slaba znaci da mi se rusi igrica kad god treba nacrtati nesto malo zahtijevnije, recimo kad se dignem helicem u zrak i gledam grad odozgor, za par sekundi odmah se srusi gta.exe i moram sve ispocetka....ako udjem u vodu i pocmem trcat po vodi ili plivat, odmah se rusi gta.exe. ako se zaletim malo brze s autom, nestaje i cesta i zgrade i zabijam se u praznine nasred "ceste" jer ne vidim da tu stoji zgrada.
isto tako su mi sjene katastrofa, kad hodam ili se vozim po gradu, na svim zgradama sjene plesu kao da su displayi po gradu, totalno me iritira to. pojacao sam sve na max, reza je 1280*1024, nista ne trza nego jednostavno - ne valja.
eto, nadam se da sam uspio malo objasnit, hvala na pomoci!
ispunit cu moj komp cim saznam gdje je, tnx!
Statistics
Average FPS: 45.67
Duration: 37.14 sec
CPU Usage: 71%
System memory usage: 68%
Graphics Settings
Video Mode: 1280 x 1024 (75 Hz)
Render Quality: Very High
Reflection Resolution: Very High
Water Quality: Very High
View Distance: 52
Definition: Off
VSync: Off
Hardware
Microsoft® Windows Vista" Ultimate
Service Pack 1
Video Adapter: NVIDIA GeForce 9600 GT
Video Driver version: 180.84
Audio Adapter: Speakers (Realtek High Definition Audio)
Intel(R) Core(TM)2 Quad CPU @ 3,00GHz
Zadnje izmijenjeno od: studenac. 01.03.2009. u 18:12.
Staro 01.03.2009., 18:14   #3206
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
View Distance: 52
i kaj se čudiš
view distance na 25 max , detail 60 uvrh glave, u biti auto settings i amen
EDIT; lol, stavi onda i texture na max a view distance na 100
Pizz je offline   Reply With Quote
Staro 01.03.2009., 18:19   #3207
studenac
ludjak
studenac's Avatar
Postovi: 257
Autor Pizz Pregled postova
i kaj se čudiš
nisam se cudio nicemu, thunder je pitao da definiram sto znaci pre slaba grafa, pa sam napisao.
ne kuzim kaj ti je 25 max view distance. auto settings su katastrofa, tek onda nista ne valja.
- zanima me kakve su sjene drugima koji imaju 9600gt? jel vam plese sve po zgradama ili kako? imam nvidia drivere za GTA i onaj gta patch 2. nista nije promijenilo.
Staro 01.03.2009., 18:37   #3208
studenac
ludjak
studenac's Avatar
Postovi: 257
probao sam, ali neide vise od ovoga, neznam zakaj, ali zadnji put sam mogao namjestit i vise...
by the way, ako procitas pocetak ove rasprave, vidjet ces da sam ja molio prijedlog za nadogradnju, trazio sam neku bolju graficku, jer zelim igrati sa svim max postavkama a ovo se pretvorilo u podsmijavanje i otislo u krivom smijeru tipa: "sta se cudis da nevalja kad si sve pojacao do kraja".
uglavnom, i poanta je da sve pojacam do kraja
peace!
Staro 01.03.2009., 19:39   #3209
Reedy
Reedy's Avatar
Postovi: 770
Ma meni se igra ruši svakih 20 min igre,,,
Reedy je offline   Reply With Quote
Staro 01.03.2009., 21:28   #3210
Neo-ST
Neo-ST's Avatar
Postovi: 8,465
Meni i dalje ne radi, a jedna je od rijetkih igara koje sam stvarno kupio...
