#3181 |
istrijan
Lokacija: Novigrad
Postovi: 141
Neznam za 512 -> 1gb. Prije sam imao 256 MB, tako da sad ima razlike. Benchmark iz igirce: Ati Radeon x1950pro Statistics Average FPS: 21.45 Duration: 37.11 sec CPU Usage: 92% System memory usage: 83% Video memory usage: 99% Graphics Settings Video Mode: 1024 x 768 (70 Hz) Texture Quality: Low Render Quality: Low View Distance: 1 Detail Distance: 1 GeForce 9800Gt, CPU: C2D e6300@2.8 GHz Statistics Average FPS: 27.02 Duration: 37.28 sec CPU Usage: 82% System memory usage: 96% Video memory usage: 79% Graphics Settings Video Mode: 1680 x 1050 (59 Hz) Texture Quality: High Render Quality: High View Distance: 45 Detail Distance: 63
#3182 |
**Hajduk**
Lokacija: Hrvatska-Split
Postovi: 282
efo moj rezultat Statistics Average FPS: 38.79 Duration: 37.20 sec CPU Usage: 88% System memory usage: 93% Video memory usage: 93% Graphics Settings Video Mode: 1680 x 1050 (59 Hz) Texture Quality: Medium Render Quality: High Reflection Resolution: High Water Quality: High Shadow Quality: High View Distance: 30 Detail Distance: 35 Definition: Off VSync: On Hardware Microsoft Windows XP Professional Service Pack 3 Video Adapter: NVIDIA GeForce 8800 GT Video Driver version: 181.22 Audio Adapter: Realtek HD Audio output Intel Pentium III Xeon processor File ID: benchmark.cli ![]()
Fassssst.....no0 cooment... |
#3184 |
Bill Gates
Lokacija: Vukovar
Postovi: 1,983
Samo za xbox 360 |
#3186 |
Yippie-Ka-Yay
Postovi: 560
Evo da ne otvaram novu temu. Imam jedan problem, na dva kompa imam instaliran GTA IV i sada pokušam kreirati LAN igru i ne vidim drugi komp, pokušam na drugom kompu kreirat ali ni ovaj moj ne vidi drugoga. Je li možda problem u tome što obe verzije igre nisu originali??? Na oba kompa je instaliran zadnji patch i update za GFWL. |
#3187 |
Postovi: 202
Ma po meni 99% ce doc za pc samo malo kasnije... Razmislite malo, zasto kada je rockstar izbacio igru za pc naveo da su med detalji za danasnja racunala dok je high za buducnost, a posto lost & damned mozemo smatrati kompletno novom igrom, velike su sanse da ce doc i na Pc-u, ipak je microsoft platio 50 miljuna za tu i jos jednu dodatnu epizodu. Isto kao u 4 mjesecu kad je izasla za ps3/x360... Skoro su svi tvrdili da nebu dosla na pc... a danas, jest da je los port al barem igramo. ![]() |
#3188 |
Lokacija: Dubrovnik
Postovi: 1,287
[QUOTE= a posto lost & damned mozemo smatrati kompletno novom igrom[/QUOTE] Par autića, nove motore , par oružja smatrati potpuno novom igrom..... Nećemo ![]() Čista expanzijica. To je ušminkaniji Gta 4 ..... nove misijice i to da ali potpuno nova igra ne.
S3 Trio 64 , Voodoo 2 , Kyro 3d , GeForce MX 440 SE , Radeon 9000Pro , 6600 GT , 9600 GT , 260GTX , 560GTX , 760GTX, 1060 GTX, 1080 GTX, 3080 RTX |
#3189 | |
Postovi: 202
#3190 |
Bill Gates
Lokacija: Vukovar
Postovi: 1,983
#3193 |
Lokacija: Osijek/Ansfelden
Postovi: 225
#3194 |
ludjak
Postovi: 257
moze mala pomoc? imam 9600 GT i cak kad ju klokam sve do artefakta svejedno mi je pre slaba grafulja za GTA, sto mi mozete preporucit da uzmem, recimo da prodam ovu 9600GT i dodam nekih 500kn i uzmem ___________ (nadopunite crtu heh) volio bih jednu od 1GB memorije. hvala na pomoci ! |
#3196 |
ludjak
Postovi: 257
#3201 | |
Lokacija: vel.gorica
Postovi: 303
edit: cak mi call of duty 2 radi sve na ultra hight i very hight detaljima uz rezu 1440*900 |
#3202 | |
Lokacija: na sombra
Postovi: 1,048
#3204 |
tha pilot
Postovi: 647
Evo moj bench, je li bih mogao jos kako izvuci koji fps sa ovom konfom, a da se ne gubi na kvaliteti grafike? Statistics Average FPS: 25.77 Duration: 36.98 sec CPU Usage: 100% System memory usage: 89% Video memory usage: 100% Graphics Settings Video Mode: 1024 x 768 (70 Hz) Texture Quality: Medium Render Quality: Medium Reflection Resolution: Low Water Quality: Medium Shadow Quality: Low View Distance: 6 Detail Distance: 100 Definition: Off VSync: On Hardware Microsoft Windows XP Professional Service Pack 3 Video Adapter: ATI Radeon HD 2600 XT Video Driver version: 6.14.10.6903 |
#3205 | |
ludjak
Postovi: 257
isto tako su mi sjene katastrofa, kad hodam ili se vozim po gradu, na svim zgradama sjene plesu kao da su displayi po gradu, totalno me iritira to. pojacao sam sve na max, reza je 1280*1024, nista ne trza nego jednostavno - ne valja. eto, nadam se da sam uspio malo objasnit, hvala na pomoci! ispunit cu moj komp cim saznam gdje je, tnx! Statistics Average FPS: 45.67 Duration: 37.14 sec CPU Usage: 71% System memory usage: 68% Video memory usage: 99% Graphics Settings Video Mode: 1280 x 1024 (75 Hz) Texture Quality: Medium Render Quality: Very High Reflection Resolution: Very High Water Quality: Very High Shadow Quality: High View Distance: 52 Detail Distance: 100 Definition: Off VSync: Off Hardware Microsoft® Windows Vista" Ultimate Service Pack 1 Video Adapter: NVIDIA GeForce 9600 GT Video Driver version: 180.84 Audio Adapter: Speakers (Realtek High Definition Audio) Intel(R) Core(TM)2 Quad CPU @ 3,00GHz Zadnje izmijenjeno od: studenac. 01.03.2009. u 17:12. |
#3206 |
Registered Abuser
Lokacija: Velika Gorica \ ZG
Postovi: 747
#3207 | |
ludjak
Postovi: 257
ne kuzim kaj ti je 25 max view distance. auto settings su katastrofa, tek onda nista ne valja. - zanima me kakve su sjene drugima koji imaju 9600gt? jel vam plese sve po zgradama ili kako? imam nvidia drivere za GTA i onaj gta patch 2. nista nije promijenilo. |
#3208 |
ludjak
Postovi: 257
probao sam, ali neide vise od ovoga, neznam zakaj, ali zadnji put sam mogao namjestit i vise... by the way, ako procitas pocetak ove rasprave, vidjet ces da sam ja molio prijedlog za nadogradnju, trazio sam neku bolju graficku, jer zelim igrati sa svim max postavkama a ovo se pretvorilo u podsmijavanje i otislo u krivom smijeru tipa: "sta se cudis da nevalja kad si sve pojacao do kraja". uglavnom, i poanta je da sve pojacam do kraja ![]() peace! |
