|  13.02.2009., 13:58 | #3181 |
| istrijan Datum registracije: Jan 2007 Lokacija: Novigrad
					Postovi: 141
				 | Neznam za 512 -> 1gb. Prije sam imao 256 MB, tako da sad ima razlike. Benchmark iz igirce: Ati Radeon x1950pro Statistics Average FPS: 21.45 Duration: 37.11 sec CPU Usage: 92% System memory usage: 83% Video memory usage: 99% Graphics Settings Video Mode: 1024 x 768 (70 Hz) Texture Quality: Low Render Quality: Low View Distance: 1 Detail Distance: 1 GeForce 9800Gt, CPU: C2D e6300@2.8 GHz Statistics Average FPS: 27.02 Duration: 37.28 sec CPU Usage: 82% System memory usage: 96% Video memory usage: 79% Graphics Settings Video Mode: 1680 x 1050 (59 Hz) Texture Quality: High Render Quality: High View Distance: 45 Detail Distance: 63
				__________________   |
|  13.02.2009., 15:06 | #3182 |
| **Hajduk** Datum registracije: Apr 2006 Lokacija: Hrvatska-Split
					Postovi: 282
				 | efo moj rezultat Statistics Average FPS: 38.79 Duration: 37.20 sec CPU Usage: 88% System memory usage: 93% Video memory usage: 93% Graphics Settings Video Mode: 1680 x 1050 (59 Hz) Texture Quality: Medium Render Quality: High Reflection Resolution: High Water Quality: High Shadow Quality: High View Distance: 30 Detail Distance: 35 Definition: Off VSync: On Hardware Microsoft Windows XP Professional Service Pack 3 Video Adapter: NVIDIA GeForce 8800 GT Video Driver version: 181.22 Audio Adapter: Realtek HD Audio output Intel Pentium III Xeon processor File ID: benchmark.cli
				__________________ Fassssst.....no0 cooment... |
|  13.02.2009., 15:50 | #3184 |
| Bill Gates Datum registracije: Jan 2007 Lokacija: Vukovar
					Postovi: 1,983
				 | Samo za xbox 360 |
|  18.02.2009., 20:40 | #3186 |
| Yippie-Ka-Yay Datum registracije: May 2007 Lokacija: Split
					Postovi: 560
				 | Evo da ne otvaram novu temu. Imam jedan problem, na dva kompa imam instaliran GTA IV i sada pokušam kreirati LAN igru i ne vidim drugi komp, pokušam na drugom kompu kreirat ali ni ovaj moj ne vidi drugoga. Je li možda problem u tome što obe verzije igre nisu originali??? Na oba kompa je instaliran zadnji patch i update za GFWL. |
|  18.02.2009., 23:29 | #3187 |
| Premium Datum registracije: Feb 2008 Lokacija: Pula
					Postovi: 202
				 | Ma po meni 99% ce doc za pc samo malo kasnije... Razmislite malo, zasto kada je rockstar izbacio igru za pc naveo da su med detalji za danasnja racunala dok je high za buducnost, a posto lost & damned mozemo smatrati kompletno novom igrom, velike su sanse da ce doc i na Pc-u, ipak je microsoft platio 50 miljuna za tu i jos jednu dodatnu epizodu. Isto kao u 4 mjesecu kad je izasla za ps3/x360... Skoro su svi tvrdili da nebu dosla na pc... a danas, jest da je los port al barem igramo.  |
|  19.02.2009., 19:44 | #3188 |
| Premium Datum registracije: May 2004 Lokacija: Dubrovnik
					Postovi: 1,287
				 | [QUOTE= a posto lost & damned mozemo smatrati kompletno novom igrom[/QUOTE] Par autića, nove motore , par oružja smatrati potpuno novom igrom..... Nećemo  Čista expanzijica. To je ušminkaniji Gta 4 ..... nove misijice i to da ali potpuno nova igra ne.
				__________________ S3 Trio 64 , Voodoo 2 , Kyro 3d , GeForce MX 440 SE , Radeon 9000Pro , 6600 GT , 9600 GT , 260GTX , 560GTX , 760GTX, 1060 GTX, 1080 GTX, 3080 RTX |
|  19.02.2009., 22:13 | #3189 | |
					Postovi: 202
				 | Citiraj:
  najvjerojatnije ce poboljsati motore, imat cemo nove radio stanice aute motore kao sto si reko prakticki sve novo jedino sto ostaje isto je grad, znaci sve drugacije samo u istom gradu u kojem smo se udomacili  | |
|  19.02.2009., 22:30 | #3190 |
					Postovi: 1,983
|  22.02.2009., 19:22 | #3193 |
| Premium Datum registracije: Jan 2006 Lokacija: Osijek/Ansfelden
					Postovi: 225
|  22.02.2009., 20:40 | #3194 |
| ludjak Datum registracije: Feb 2006 Lokacija: zagreb
					Postovi: 257
				 | moze mala pomoc? imam 9600 GT i cak kad ju klokam sve do artefakta svejedno mi je pre slaba grafulja za GTA, sto mi mozete preporucit da uzmem, recimo da prodam ovu 9600GT i dodam nekih 500kn i uzmem ___________ (nadopunite crtu heh) volio bih jednu od 1GB memorije. hvala na pomoci ! |
|  22.02.2009., 20:49 | #3196 |
					Postovi: 257
|  25.02.2009., 17:51 | #3201 | |
| Premium Datum registracije: Oct 2008 Lokacija: vel.gorica
					Postovi: 303
				 | Citiraj:
 edit: cak mi call of duty 2 radi sve na ultra hight i very hight detaljima uz rezu 1440*900 | |
|  26.02.2009., 12:46 | #3202 | |
| Premium Datum registracije: Dec 2005 Lokacija: na sombra
					Postovi: 1,048
				 | Citiraj:
|  26.02.2009., 13:03 | #3204 |
| tha pilot Datum registracije: May 2008 Lokacija: Zagreb
					Postovi: 647
				 | Evo moj bench, je li bih mogao jos kako izvuci koji fps sa ovom konfom, a da se ne gubi na kvaliteti grafike? Statistics Average FPS: 25.77 Duration: 36.98 sec CPU Usage: 100% System memory usage: 89% Video memory usage: 100% Graphics Settings Video Mode: 1024 x 768 (70 Hz) Texture Quality: Medium Render Quality: Medium Reflection Resolution: Low Water Quality: Medium Shadow Quality: Low View Distance: 6 Detail Distance: 100 Definition: Off VSync: On Hardware Microsoft Windows XP Professional Service Pack 3 Video Adapter: ATI Radeon HD 2600 XT Video Driver version: 6.14.10.6903 |
|  01.03.2009., 18:01 | #3205 | |
					Postovi: 257
				 | Citiraj:
 isto tako su mi sjene katastrofa, kad hodam ili se vozim po gradu, na svim zgradama sjene plesu kao da su displayi po gradu, totalno me iritira to. pojacao sam sve na max, reza je 1280*1024, nista ne trza nego jednostavno - ne valja. eto, nadam se da sam uspio malo objasnit, hvala na pomoci! ispunit cu moj komp cim saznam gdje je, tnx! Statistics Average FPS: 45.67 Duration: 37.14 sec CPU Usage: 71% System memory usage: 68% Video memory usage: 99% Graphics Settings Video Mode: 1280 x 1024 (75 Hz) Texture Quality: Medium Render Quality: Very High Reflection Resolution: Very High Water Quality: Very High Shadow Quality: High View Distance: 52 Detail Distance: 100 Definition: Off VSync: Off Hardware Microsoft® Windows Vista" Ultimate Service Pack 1 Video Adapter: NVIDIA GeForce 9600 GT Video Driver version: 180.84 Audio Adapter: Speakers (Realtek High Definition Audio) Intel(R) Core(TM)2 Quad CPU @ 3,00GHz Zadnje izmijenjeno od: studenac. 01.03.2009. u 18:12. | |
|  01.03.2009., 18:14 | #3206 |
| Registered Abuser Datum registracije: Oct 2008 Lokacija: Velika Gorica \ ZG
					Postovi: 747
|  01.03.2009., 18:19 | #3207 | |
					Postovi: 257
				 | Citiraj:
 ne kuzim kaj ti je 25 max view distance. auto settings su katastrofa, tek onda nista ne valja. - zanima me kakve su sjene drugima koji imaju 9600gt? jel vam plese sve po zgradama ili kako? imam nvidia drivere za GTA i onaj gta patch 2. nista nije promijenilo. | |
|  01.03.2009., 18:37 | #3208 |
					Postovi: 257
				 | probao sam, ali neide vise od ovoga, neznam zakaj, ali zadnji put sam mogao namjestit i vise...  by the way, ako procitas pocetak ove rasprave, vidjet ces da sam ja molio prijedlog za nadogradnju, trazio sam neku bolju graficku, jer zelim igrati sa svim max postavkama a ovo se pretvorilo u podsmijavanje i otislo u krivom smijeru tipa: "sta se cudis da nevalja kad si sve pojacao do kraja". uglavnom, i poanta je da sve pojacam do kraja  peace! |
