Staro 15.01.2009., 14:55   #1
Manjacha
Manjacha's Avatar
Postovi: 78
Problemi s mrežom
Pozdrav
imam jedan cudan problem s mrezom.
ne zeli pristupit netu preko mrezne, treba mu 100 godina da si dodijeli IP adresu, i kad mu stavim staticku isto samo javi "limited or no connectivity".
mijenjao sam mrezne kartice, kabel, cak sam radio novu instalaciju win i nista nije pomoglo.
jel ima iko kavku ideju do cega bi to moglo bit?
hvala unaprijed
I am no geek, I am level 12 warrior!
Manjacha je offline   Reply With Quote
Staro 15.01.2009., 18:04   #2
zmikic
zmikic's Avatar
Postovi: 206
ajd, kad mu dodijeli adresu odi na start --> run --> cmd i pokreni ipconfig /all i postaj rezultat
walk the talk
zmikic je offline   Reply With Quote
Staro 16.01.2009., 10:16   #3
Manjacha
Manjacha's Avatar
Postovi: 78
kako mogu postat sliku?
Staro 16.01.2009., 11:05   #4
thopok
Lokacija: Splity
Postovi: 3,003
Za to nije potrebno slanje slike, dovoljno je copy & paste.
Staro 16.01.2009., 11:59   #5
Manjacha
Manjacha's Avatar
Postovi: 78
Windows IP Configuration
Host Name............................:ivan
Primary DNS Suffix..................:
Node Type............................:Unknown
IR Routing Enabled..................:No
WINS Proxy Enabled................:No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix.:
Description...........................:Realtek RTL8193/810x Family Fast Ethernet NIC
Physical Adress......................:00-1E-2A-3A-9E-CA
DHCP Enabled........................:Yes
Autoconfiguration Enabled.......:Yes
Autoconfiguration IP Adress.....:169.254.204.131
Subnet Mask.........................:255.255.0.0
Default Gateway....................:
da napomenem da se ne radi o mojoj konfi, nego o sljedecoj:
mbo - msi KT6 delta
os - win xp sp2
mrezna je pci
Staro 16.01.2009., 12:05   #6
Postovi: 23,515
Sticky ADSL Biblija i DNS by ISP, tu sve piše, podesi parametre mreže (IP, Subnet, Gateway, DNS - ovi) fiksno a ne na idiot (automatic).
Staro 16.01.2009., 12:09   #7
thopok
Lokacija: Splity
Postovi: 3,003
Staro 16.01.2009., 12:17   #8
amaric
Datum registracije: Apr 2008
Lokacija: Kanfanar-Zagreb
Postovi: 17
Imao sam i ja takav problem kad sam namještao Micronet usb wlan adapter na način da pod dostupne mreže izaberem moj router i stvorim profil. Rješenje je bilo namještati vezu preko Wizarda, a razlika je u Gatewayu koji je bio prazan kao tebi, a bar za Zyxel je 192.168.1.1
amaric je offline   Reply With Quote
Staro 16.01.2009., 12:25   #9
Manjacha
Manjacha's Avatar
Postovi: 78
Autor Nikky Pregled postova
stvar je u tome sta mi se ista stvar dogada i kad ja dodijelim ip adresu i gateway
kako mislis na sta se prikljucuje?
Staro 16.01.2009., 12:29   #10
thopok
Lokacija: Splity
Postovi: 3,003
2. kraj kabela?
Stvarno bi bilo dobro navest sve potrebne podatke…
Staro 16.01.2009., 12:30   #11
Postovi: 23,515
Koji je ISP i koji je modem / router?
Staro 16.01.2009., 12:38   #12
Manjacha
Manjacha's Avatar
Postovi: 78
ISP je metronet, ali spaja se preko servera
Staro 16.01.2009., 12:52   #13
Postovi: 23,515
Onda znači da ti je DHCP + možda još ponešto na serveru u banani, kako se to "stručno" sad kaže. Daj još podataka a ne da moramo udicom vadit. Koji je modem / router?
"Stvar" mora radit sa fiksnim parametrima mrežne samo moraš znati kako je mreža "složena".
Staro 16.01.2009., 13:07   #14
Manjacha
Manjacha's Avatar
Postovi: 78
sad sam dodijelio ip adresu i gateway i pise mi da je spojen, ali je promet skroz slab.
server se koristi kao router, a taj server je spojen na drugi (glavni) server, ne znam na koji je on modem/router spojen.
ostala racunala se normalno spajaju
Zadnje izmijenjeno od: Manjacha. 16.01.2009. u 15:30.
Staro 16.01.2009., 13:41   #15
Postovi: 23,515
Na serveru (i jednom i drugom) imaš soft / konfig za ograničenje prometa ili neš slično?
Dalje ćeš morat sam istraživat.
Staro 16.01.2009., 13:47   #16
Manjacha
Manjacha's Avatar
Postovi: 78
nema nista slicno na serveru. kao sto rekoh ostala racunala se normalno spajaju. jebiga. ako rijesim javim
Staro 16.01.2009., 14:01   #17
thopok
Lokacija: Splity
Postovi: 3,003
A radi li live CD-om?
Staro 16.01.2009., 14:19   #18
Manjacha
Manjacha's Avatar
Postovi: 78
radi s linuxom
Staro 16.01.2009., 15:04   #19
Postovi: 23,515
Onda škola ponavljanja (sori pa diži) winse.
Staro 16.01.2009., 15:13   #20
thopok
Lokacija: Splity
Postovi: 3,003
radi s linuxom
Stvarno čudno…
Staro 16.01.2009., 15:20   #21
Manjacha
Manjacha's Avatar
Postovi: 78
pa meni je isto to cudno. evo upravo radim ponovo novu inst pa cu malo kemijat po tome jos da vidim, mozda sam nesto izostavio. ma banana...
