Staro 06.12.2008., 12:13   #1
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
LC Power napajanja.. ?
ovako ljudi, našao sam samo neke stare threadove, pa da vidim kakva je trenutna situacija sa ovim napajanjima, u Linksu imaju valjda sve moguće modele,
kakva je situacija sa ovim skupljjim modelima, tipa model taurus, i ovi silent modeli?
550W
i
480W taurus mdoeli?
Staro 06.12.2008., 12:26   #2
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,309
Koliko sam upoznat, dio su SHENZHEN CHI YUAN INDUSTRIAL CO LTD ... bla bla bla...kineski poluproizvod, a dio su CWT (mislim samo metatron serija).
Svi su krivo označeni, odnosno ako je deklarirano na 500W, max je 400W.
Evo jedan quote JG sa badcaps foruma (nevezano za CWT).
Just a little bump because I got some inside info on Shenzhen Chi Yuan Industrial Co Ltd US Pat Off LLC, Inc.
First off, Huntkey is the same company. Huntkey is the house brand, but it's all the same. Sort of like ePower is to Topower.
Second, it seems that all of their units have exactly 100W of "wiggle room" on the label. In other words, they're all rated at "peak" and this is exactly 100W from continuous. If you have a Huntkey built 500W, it's a 400W.
Third, they do seem to have some decent units. the units that Huntkey sells as "Titan" is independently regulated and has Chemi-Con and Teapo caps within (except for a little secondary PCB that I've yet to figure out what it's for.) Despite this huge jump in quality, they still choose to rate 100W over continuous. This is likely because of the corner they've painted themselves into. If you didn't know any better and were comparing a 500W peak vs. a 500W continuous from the same company and the 500W continuous was $40 more, would Joe Consumer even give the $40 more unit a second look?
CWT based napajanja brandiraju mnogi, vrlo kvalitetna ali LC power ne nudi ništa povoljniju cijenu od konkurencije, pa je isplativije uzeti npr CWT Hipera. Ovi jeftinije modeli nisu nešto osdveć kvalitetni, ali ne možemo reći da su drek. Svjetliji primjer je 420W model, sa cijenom od 150kn i vrlo dobrim performansama. Taj model sam već ti ponudio u drugoj temi.
Staro 06.12.2008., 12:30   #3
Wolverine
Wolverine's Avatar
Postovi: 12,425
Isprobao sam one iz Green serije i OK su za neku ne zahtjevnu konfu (iako je 550W model vrtio i naklokane s939 konfe sa GF6800GT sa manjim padom napona od npr Tagana 2Force 430W)
Također sam probao modele iz metatron serije
to su modeli koje radi CWT i radi se o praktički istom napajanju kakvo je npr TT Toughpower
dakle naponi su odlični no problem su užasno kratki kablovi
ove iz taurus i super silent serije nisam imao prilike koristiti
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 06.12.2008., 12:43   #4
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
e pitanje je sad, koliko su tiha? te da li vrijedi ovaj model od 480W 309kn?
bitna mi tišina, te da ima zaštite od napona, i te stvari... količina W me ne zanima uopće..
Staro 06.12.2008., 13:04   #5
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
LC Power 420W (onaj jeftini) nemoze pogonit kantu iz siga.
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 06.12.2008., 13:19   #6
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
Autor Renesis Pregled postova
Tu se pokazal čist vredu, tko tu koga?
Iako ako gledamo logički, 150kn ne može biti dovoljno za pošteno napajanje. I btw, tamo piše ~ 35 jura, a to nikako ne može biti 150kn. Možda u Linksu prodaju drugu verziju?!
Staro 06.12.2008., 13:20   #7
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
ma ne bi onaj najjeftiniji, nego one oko 300kn, 480 ili 560W model.. samo me ta 2 zanimaju.. jedino što za te novce mogu uzet je Chieftec 400W i fortoron 400W, no Fortron znam da nije tih, a Chieftec.. ne znam.. čisto sam sumnjičav...
Staro 06.12.2008., 13:48   #8
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor Gilbert5 Pregled postova
Ovaj ovdje je uredno pogonio DFI LP NF4 Ultra-D + 3000+ Venice na 2,8GHz + 2x 512MB UTT-a na 500MHz 1,5-2-2-5 3,5V + 6800GT + dva diska + Audigy2 PlatinumES
i još radi
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 06.12.2008., 13:51   #9
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
čuj, konfa u sigu, sestra isla igrat sims2 i nakon 20ak minuta, trafo je cvršao ko lud, vent je puhao vruće, i lagano je smrdilo... tako da... nije se skurilo, ali sumnjam da bi duze tako radio...
Staro 06.12.2008., 14:06   #10
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
i još radi
Ako je smrtbox rebrand toga (a po izgledu bi mogao bit) onda je vrtio moju konfu -8800GT ali sa 6800 Ultra unutra...
Edit:
@Codiac
Upravo to...
Have a nice day...
Staro 06.12.2008., 14:09   #11
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
i još radi
moze raditi koliko hoce al glavno je pitanje kad umre oce li povuci za sobom sve kao npr jnc ili ce samo ono crknuti
.i.
Razer Blade 15
Staro 06.12.2008., 15:05   #12
Wolverine
Wolverine's Avatar
Postovi: 12,425
upravo ga zato nebi preporučio nekome
nisam reko da je to napajanje koje bi nekom preporučio već samo da je to tjeralo
radije bi ubo Sharkoon, Chieftec ili Fortron za te pare
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 06.12.2008., 15:32   #13
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Daj koju 100icu vise i kupi nesto posteno. Ili tog forta/chifa pa mjenjaj vent.
Ta napajanja nisu dobra napajanja i gotovo...
Staro 06.12.2008., 22:18   #14
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
kupljen corsair 400W
još ostao disk za kupnju.. preporuka od 500gb ?
Staro 06.12.2008., 22:19   #15
Router
Hejter
Postovi: 6,521
Autor Gabre Pregled postova
Pametno , za taj sam navijao i u onoj drugoj temi ...
Staro 06.12.2008., 22:22   #16
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Jako pametno !
Ja bi ti iz prve ruke preporucio samsunga. WD onaj od 640. Ostalo samsung.
Staro 07.12.2008., 11:44   #17
yedwy
yedwy's Avatar
Postovi: 6,956
Hihi vidim da si rezonirao kao i većina nas na kraju...
Što se diska tiče - potpis fleksa...
Have a nice day...
Staro 09.12.2008., 19:29   #18
pyzdek
pyzdek's Avatar
Postovi: 96
Kod mene još uvijek radi LC 550w,već oko 3 godine bez beda.i ako sad prdne mogu reć da me je poslužilo dobro,pogotovo za tu lovu.
pyzdek je offline   Reply With Quote
