Staro 16.06.2004., 19:24   #1
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
BS player 1.0 809
Klikni!!!
Nažalost mora se unijeti mail pa ti oni šalju link za download...
Version 1.00 RC1 Build 809 released (16 Jun 2004) - Fixed problem with Matroska files with only audio streams - Sometimes audio stream names with Ogg files was corrupted, fixed - Selected audio output device will now be remembered when switching audio streams - Sometimes skin would revert back to base skin, should be fixed now - Fixed problem with freezing when seeking - Movie length was displayed as 0 after stop, fixed - Last subtitle line was still displayed after switching subtitles off, fixed - AC3 filter will be visible now in filter list - If video window was left on secondary monitor and in full screen mode, position wasn't remembered, fixed - chapters from ini files should now be read like in 0.8xx versions - ini shutdown option wasn't working, fixed - fixed bug with resolution switching in full screen mode - fixed freezing problem with some skins under Windows 98 * filters defined in bspfilters.dat will now be loaded even if other libraries are required (for ex. xvid.ax require xvidcore.dll), just put them all in .\filters directory + added option to open locked (in use) files + subtitle position will now also work when 'Draw subtitles to overlay surface option is checked' + Subtitle language for subtitles in Matroska files is now properly displayed
tor je online   Reply With Quote
Staro 16.06.2004., 19:51   #2
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
Tor , aj ga skini pa stavi na OCE za downlaod:-))
POsto je freeware valjda se smije
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 16.06.2004., 21:00   #3
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Pa bar je link lako naci
http://majorgeeks.com/download4147.html
Poludirektno:
http://majorgeeks.com/downloadget.ph...7a76b08b96384f
Samo ne znam kaj ce vam to
Staro 16.06.2004., 21:10   #4
Freek
Freek's Avatar
Lokacija: Zagreb/Dubrava
Postovi: 2,869
A šta ono ti predlažeš
Staro 16.06.2004., 21:17   #5
Costa
Costa's Avatar
Postovi: 3,193
Trenutno 3 programa:
Mv2 Player:
http://mv2.czweb.org/
Media Player Classic:
http://sourceforge.net/projects/guliverkli/
Zoom Player (Uz freeware ima i shareware verziju):
http://www.inmatrix.com/files/zoomplayer_download.shtml
Mv2 je glavni za filmove s titlovima, MPC za sve ostalo (titlove kroz ffdshow ili vobsub a ima i on nekakvu jadnu podrsku). Zoom trenutno isprobavam ali ima potencijala (ista opis kao i za MPC).
A do ovoga svega dodjes Mozillom
Staro 16.06.2004., 21:24   #6
Freek
Freek's Avatar
Postovi: 2,869
Mv2 Player:
Dobar si, dobar .
Imam ja te sve već na hardu osim browsera Mozillice. Ipak mi je Opera nekako draža.
jedino mi se ovaj Zoom ne sviđa pregledavao sam svaku verziju al nije baš nešto. Ili BS ili Mv2.
Staro 16.06.2004., 22:49   #7
ßellerophon
Sannin
ßellerophon's Avatar
Datum registracije: Jun 2003
Postovi: 1,568
jeeeeeeeej :clap:
YES - BUT /
