Staro 26.11.2008., 00:12   #841
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Ja evo sad uspio sam nagurati do 9. lvla u Zombiima
Double Barreled shotgun i BAR
blaa
Staro 27.11.2008., 03:49   #842
bego2
bego2's Avatar
Postovi: 2,724
heeelp
sve oke proslo sa instalacijom, pokrenem igru, kliknem na solo pa na new game i odaberem jačinu i kad sam kliknuo na jačinu vrati me kod opcija new game i mission selec. heeelp
bego2 je offline   Reply With Quote
Staro 27.11.2008., 05:44   #843
Mad_Duke
Autor bego2 Pregled postova
heeelp
Kupio igru?
Instalirao patch?
Staro 29.11.2008., 04:40   #844
hammer_of_thor
Postovi: 5,430
Malo igrao single player zombie sada, do 11 lvla došao, dalje neide zasada, ybg, kad svi zombii već počnu biti oni brzi, što trče.
blaa
Staro 29.11.2008., 16:55   #845
Spirit
Spirit's Avatar
Postovi: 723
jel ima koji nasi serveri koji su original?
thx
Spirit je offline   Reply With Quote
Staro 29.11.2008., 16:58   #846
DoX_Chabar
DoX_Chabar's Avatar
Lokacija: Čabar/Rijeka
Postovi: 655
Ja sam isto do 11, puno mi je lakše kad si samo ona dolje vrata otkljucam i uzmem thopsona, gore uopce ne idem, odmah me ubiju ovako je najlakse, stane se u kut tamo di je ono random oružje i nitko ne moze s leđa doći jedino je glupo što su pretihi, uopce ih nečuješ, a trče...
DoX_Chabar je offline   Reply With Quote
Staro 29.11.2008., 21:04   #847
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Ako sad ko hoce malo bacit CoD5, coop hamachi:
soba: 2G MIOC
pass: drugige
Staro 30.11.2008., 00:18   #848
mis
Postovi: 60
heeelp
ne mozes napravit svoj profil.meni je pomoglo ovo samo moras imati otvorene hidden foldere
Here’s how to fix the profile error:
Vista: Browse to C:\Users\Username\AppData\Local\Activision\CoDWaW\players and delete everything except for the active.txt. You may need to go into the game one more time, back out, and delete more. Right click on the “players” folder and make sure it’s not set to Read Only. Now you’ll be able to create a profile for yourself.
Windows XP: “Users” is called “Documents and Setting”
mis je offline   Reply With Quote
Staro 30.11.2008., 11:55   #849
Ruky
Ruky's Avatar
Postovi: 50
Autor mis Pregled postova
imam vistu 32 bit sp1, rel_____ verziju igrice instalirao sam patch 1.1 i probao sam po ovom gore postupku i dalje ne radi. isti problem ko i kod bego2. help
Ruky je offline   Reply With Quote
Staro 30.11.2008., 14:24   #850
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Instalirao igricu sve radi bez problema.
Presao sam je u 4h u komadu i igrica me zapanjila, stvarno je odlicna i rekao bih da je bolja od COD IV.Grafika je odlicna, nesto izmedu krize i cod IV.Jedine primjedbe imam na bugove(morao sam par puta isponova level igrat), AI je nekada stvarno glup, onaj rus koji ti da snajper uopce se necuje tj. nema zvuka dok govori kao i neki drugi likovi, i ponekad me iritira to sto ispucam cijeli šanžer u japanca, a njemu nista???
Moja ocjena 9/10
DraŽ je offline   Reply With Quote
Staro 30.11.2008., 21:42   #851
crocro25
Lokacija: Sisak
Postovi: 589
evo kratki video mene u cod5 na levelu 10
uspio sam najvise sam do levela 12 sto je jako tesko sam postic
no nisam snimao,budem probao veceras srusit rekord
http://www.youtube.com/watch?v=RSlkTjt8LgQ
Prvo i zadnje upozorenje.
crocro25 je offline   Reply With Quote
Staro 01.12.2008., 00:13   #852
hammer_of_thor
Postovi: 5,430
Level 12, single player zombie. Sad nagurao. Sigurno bi došao bar do 14-15 lvla da me nisu opkolili na stepenicama
Ev danas prvi put otvorio onu kutiju sa random oružjem i dobio Rail Gun
Ko neki mali alienski pištolj iz crtića
Loše se vidi, nisam na svjetlo stao, al vidi mu se "red dot sight"
Ubija ko blesavo, i dosta municije ima
blaa
Zadnje izmijenjeno od: hammer_of_thor. 01.12.2008. u 00:49.
Staro 01.12.2008., 00:41   #853
Newmie
Postovi: 1,396
To ti je najjace oruzje. Kad igram sa frendovima uvijek pokusavamo dobiti taj Rail gun, mi ga zovemo "Cvrćak"
Najbolja kombinacija ti je rail gun i ona velika strojnica sa bubnjem sastrane. Nije loša i ona sa malo manjim kalibrom ali je dosta neprecizna.. Najvise smo izdržali do 22 levela, no sad u 12 startamo ponovo pa se nadamo jos boljem
Staro 01.12.2008., 00:52   #854
hammer_of_thor
Postovi: 5,430
Autor Newmie Pregled postova
MG42? Još ga nisam dobio, mada kad sa njim uhvatiš nema dalje reloada, predugo traje, pa bude dlakavo.
A Thompson me bome iznenadio, dobra puškica za zombie
blaa
Staro 01.12.2008., 16:25   #855
bego2
bego2's Avatar
Postovi: 2,724
hmm ja tamo nemam tog active.txt, i ne pomaže hvala svejedno.
Staro 01.12.2008., 16:35   #856
Newmie
Postovi: 1,396
Evo danas smo popravili rekord na 23, a imam jedan screenshot sa 21 levela:
Staro 01.12.2008., 18:41   #857
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Treyarchov tim je došao najviše do 29 levela.......
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO!
1oo1
NOOB - POWER IN NUMBERS!
Good judgment comes from bad experience and a lot of that comes from bad judgment.
MisterM je offline   Reply With Quote
Staro 01.12.2008., 18:44   #858
Ruky
Ruky's Avatar
Postovi: 50
meni je igrica proradila kad sam maknuo kvacicu read only
Staro 02.12.2008., 03:39   #859
bego2
bego2's Avatar
Postovi: 2,724
i to sam napravio ali
edit: sad skužih da kad maknem kvačicu read only i kad kliknem ok i pogledam ponovo jel ima kvačice i ona opet tamo, koliko god puta pokušao maknut ona opet tamo stoji ZAKVAČENA
Zadnje izmijenjeno od: bego2. 03.12.2008. u 04:19.
Staro 05.12.2008., 00:38   #860
hammer_of_thor
Postovi: 5,430
Dali zna netko jeli se može nastaviti od već postignutog levela sa onim cd-keyem koji sam *khm*posudio od prijatelja*khm* kada pređem na svoj vlastiti originalni ključ?
Da ponovo sve ne prelazim.
blaa
Staro 05.12.2008., 00:53   #861
Kimi
Kimi's Avatar
Postovi: 652
Autor hammer_of_thor Pregled postova
Bila je fora s cod4 koja je meni upalila:udes u igru,upises taj novi kljuc,onda ne izlazeci promjenis neku klasu,npr i klasi jedan izabreš drugo oruzje i onda izades iz igre.meni je tako sve ostalo,mada dolaskom pama4 i promoda to postaje nebitno
Kimi je offline   Reply With Quote
Staro 05.12.2008., 01:09   #862
hammer_of_thor
Postovi: 5,430
COD 4 sam i ja nastavio igrati s prelaskom na original.
U igri se samo promjeni ključ, odmah se spoji na neki server i odigra se trenutna mapa do kraja, i sve se spremi pod stari profil sa novim origigi ključem. Ugl, u COD 4 je to lagano napraviti. Pitanje je ovdje u petici ovi online accountovi i to.
blaa
Staro 05.12.2008., 09:36   #863
Spirit
Spirit's Avatar
Postovi: 723
meni je smotano jer nema ni jedan pametan original server kod nas...
Staro 05.12.2008., 09:45   #864
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
... Pitanje je ovdje u petici ovi online accountovi i to.
Mislim da ti neče uspjeti sa "starim" keyjem.... makar online account ti je samo ime ne i config i save-ovi.
Inače samo napraviš backup (za XP) foldera C:\Documents and Settings\username\Local Settings\Application Data\Activision\CoDWaW u kojem ti je profil config igre i pejstaš ga tamo kad instaliraš igru (ili u tvom slučaju promjeniš key).
Ubacujem fajl za jednostavn backup profila i za XP i za Vistu - unutra je read me fajl sa objašnjenjem.
Možda ti pomogne.
1oo1
Staro 05.12.2008., 16:56   #865
hammer_of_thor
Postovi: 5,430
Hvala
Budem probao kad kupim.
Nego, gledao malo Zombie mod na jutubu, lik je solo došao do 22 levela
I gledao neke likove, novi rekord valjd postavili, 37 lvl
blaa
Staro 07.12.2008., 20:12   #866
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Pitanjce : zašto X-vatra još krivo pokazuje da li na serverima ima ili nema igrača?
Ono piše mi 0 (nula) a server pun......
1oo1
Staro 09.12.2008., 00:16   #867
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor MisterM Pregled postova
Kaj svima X-fire radi normalno??
1oo1
Staro 09.12.2008., 00:26   #868
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
Meni isto pokazuje 0 igraca.
I ja imam na ploci.
Staro 09.12.2008., 00:37   #869
vedro91
vedro91's Avatar
Lokacija: Djakovo
Postovi: 263
Meni ne moze naci cod5 kada pokrenem xFire. Igram zombie mod,predobro. Najdalje sam doguro do 9. lvla.
vedro91 je offline   Reply With Quote
Staro 12.12.2008., 18:30   #870
Bravo
Bravo's Avatar
Postovi: 1,450
Ujutro instaliram i sve mi je radilo. Sad više neželi?
prvo mi se pojavio ovo
pa onda ovo
Probao sam instalirat nanovo, ali opet isto..
