Suit up!
Postovi: 5,962
Apple MacBook Revolution - revolucija
Novi tablet/netbook iz Applea... idealno? ![]() ![]() Configuration: Enclosure Precision aluminum unibody Processor 1.6GHz Intel Atom Processor with HyperThreading support L2 cache 512KB System bus 533MHz Memory 2GB (one 2GB SO-DIMM) of 667MHz DDR2 SDRAM; supports up to 4GB Hard drive 16GB Flash SSD integrated Graphics Intel X4500HD-A Hardware Accelerated Graphics Video Built-in iSight camera; Mini DisplayPort output port with support for DVI, VGA, and dual-link DVI (requires adapters, sold separately) Display 8.9-inch (diagonal) LED-backlit glossy widescreen display with Multi-Touch support, 1024-by-600 resolution USB Two USB 2.0 ports (up to 480 Mbps) Audio Built-in stereo speakers, built-in omnidirectional microphone, combined optical digital input/analog line in, combined optical digital output/analog line out Networking Built-in 10/100/1000BASE-T (Gigabit) Ethernet Wireless Built-in AirPort Extreme Wi-Fi (based on IEEE 802.11n draft specification)2; built-in Bluetooth 2.1 + EDR (Enhanced Data Rate) module 3G wireless modem support on selected models Hardware accessories 35W MagSafe Power Adapter, AC wall plug, power cord, lithium-polymer battery Weight 1.9 lbs / 0.86 kg |
Postovi: 355
ne sumnjam da ce naci kupci ali kad se bolje zapitam. Zasto ??. Nit je NB nit je PDA . Nekako nisam pobornik tih tableta jer su ni vrit ni mimo.. |
Lokacija: Rijeka (Umag)
Postovi: 1,197
ja stvarno neznam za sta bi mi mogao posluzit taj tablet. jedino mozda za video chat ali to ne koristim pa i to otpada sta stane na 16GB a da moze biti korisno na 9" monitoru jedino da se koristi kao digitalni okvir kojem se mijenjaju slike (neznam kako se tocno zove) ![]() |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
9 inca je way premalo... neka apple nauci nesto od sony-eve Tx serije. 11 inca je minimum minimuma za ista raditi.
Postovi: 11,642
PS FTW ![]() |
8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,138
Ko o cemu, Mar navek na Apple! Daj neki racun otvori za donacije. Pa da uplatimo i da konacno na stol stavis neki Apple. Cak i Codiac primjecuje koliko te tisti pa se pravi da nije PS uradak ![]() |
bycod
Postovi: 6,699
a cuj kad imas 12" sve ostalo ti je premalo sta da kazem ![]()
Suit up!
Postovi: 5,962
Jel ![]() Ma slažem se da ispod 12" za te subnotebookove nema smisla ici. @Visage, je Ajfon je bolji od tvojih Njokija, je da nema offline gps, je da nema tipkovnicu, je da ga za dodatne opcije moraš otključat.... al je tanji... i.... lijepši! ![]() |
Postovi: 483
Stvarno jedna od beskorisnijih stvari. Ali dobro je znati da OSX ide na atoma.
Some say that he's Mac compatible, and that he once punched a horse to the floor. All we know is, he's called The ... |
Does youer dewg byte?
Postovi: 1,936
Može li neki službeni link ? Koliko se sjećam, Apple je nedavno službeno izjavio kako mu područje netbookva i inih uopće nije interesantno i da ne namjeravaju u njega ulaziti.
" Have you tried turning it off and on again ? Are you sure it is plugged in ? " ![]() |
Prečupavi mod
Postovi: 9,104
Da, skupa sa blu ray-om ![]()
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
#14 | |
Övo malo djubre je idealno. O tome dal je premalo. Nije. Ako ti je, uzmi si veci i budi sretan. Nekom je 15 incha premalo. Sve je stvar za sto ti treba. Ovo malo djubre je idealno za sjediti na sastanku, pisati notese preko handwritting recognition softwarea. Mislim da bi ovo moglo biti veoma interesantno. A tko ne kuzi za sto sve tablet moze posluziti, neka ne pokusava shvatiti ovaj tip proizvoda. Ako nije za njega, neka se s njim ne sluzi. Mene samo jaaaako zanimaju 2 komponente. 1. cijena ( jer ako je djubre totalno precijenjeno, onda definitivno otpada) 2. autonomija. --- subjektivno Da je 10 incha bili bi meni idealno. 9 jos moze proci. |
#15 | |
8-bit Gen.
Postovi: 3,138
E moj Mare. Malo po malo, ode ti nama u roblje Stevino ![]() G4 sam imao svega pola mjeseca i nije mi se svidjao estetski idealizam koji je tad vec bolesno nastupio u Apple-u. G3 pismaricu sam imao godinu i bio je jako dobar stroj. Ali zadnji stvarno inovativni model, bejaše 540c. Inace po svim listama, 2-gi najbolji proizvod od Jabucnih prenosnika. Tad se stvarno mogao pohvaliti da je prvi u kojecemu: Prva pila sa trackpadom. Stereo zvucnici od kojih je odzvanjala soba dok je PC cistio sinuse na mono piezozoiku. PCMCIA, pa onboard LAN pa gomila do tada nevidjenih management zezalica za autonomiju baterije i boljeg rada. ![]() ![]() ![]() Aktivna matrica koja je doslovno u depresiju bacala kad si je pokusao usporediti sa svime sto je tada bilo na trzistu. Tesko mi je uopce objektivno naci neku usporedbu danasnjih odnosa, koja bi imala jednaku tezinu usporedbe sa tim ekranom - prema svemu sto je bilo konkuretno ponudom tada. Tad si stvarno bio ponosan na svoj Apple i "budi drugaciji" imao je stvarno pokrice. Neki dan procitah kako je Apple nakon 15 godina, skapirao da mu ideja PowerBook Duo i nije losa za probuditi ponovo. Da se manje glupirao sa rucnim Mar drndalicama, ovo je mogao biti danas proizvod bez premca. ccc ![]() ![]() Ne znam za vas, ali ja prvom prilikom moram odgledati The Net (1995) nakon ove price. Sandra je tada morala u svakom filmu imati neku Apple makinu oko sebe. PowerBook (aktivni) Duo se upravo izreklamirao u borbi protiv dušmana. Nagradno pitanje za Mar-a i ostale : Od kojeg filma/serije (da malo pomognem) je Apple shvatio da ce mu najbolje dici prodaju > sto veci filmski angazman Macova? Od tog trenutka, Apple postaje najzastupljeniji komp na US platnu. E moj Mare... ovo su bila vremena : ![]() A ne danas, kad korisnik sam sebi placa da bi otisao na downgrade i pisao po "lepinja salaveta" tipkovnici ![]() Boze glupih li vremena 8 |
#17 |
Lokacija: NaN
Postovi: 3,438
Novi CS4 na dijelu ![]() Odkud si to pokupio opće? Mislim, meni je ovo totalno nepraktično, kao i cijeli princip ovakvih tableta, služi ko podložak za gablec. Šta će ti ovo kad možeš Makić-Zrakić kupit. ![]() I sigurno ima/bi imalo puno 0 u cijeni. |
#19 |
Lokacija: NaN
Postovi: 3,438
Buahah, patko jedna! ![]() Nećeš mene! ![]() Nisi napisao dimenzije pa mi je i to smrdilo, pogotovo još kad bi bio Gigabitni Ethernet, bio bi poprilično debel, i težak. To je ekran od Aira? Mislim da, i inače, Apple nema potrebe za ovakvim proizvodom. |
#20 |
Postovi: 680
Nije da mu ne treba, ali kako bi se uklopili sa svojom cjenovnom politikom u trend jeftinih netbookova? Ipak, ovakav bi uredjaj bio idealan za surfanje iz fotelje (ustvari ne bi, falile bi mu neke kontrole sa strane, kao na Asusu M2H, da se ne mora olovkom ili masnim prstima napikavati).
#22 |
A steta. Ja se poveselio nekom relativno jeftinom netbooku koji je tablet. npr. http://www.crunchgear.com/2008/11/06...t-impressions/ http://eeepc.net/nec-tablet-netbook/ |
#23 |
Postovi: 33,921
#25 |
Postovi: 33,921
Štima, ali zašto se toliko špiči sa nekim polusoftverima tipa iTunes za najobičniji prijenos podataka na iPod? Nije li c/p sistem, kao kod mnogih drugih, jednostavniji?
#27 |
Datum registracije: Apr 2008
Lokacija: Zagreb, Zapruđe
Postovi: 48
#29 | |
Postovi: 328
Posto imam i pc i mac reci cu ti da ni mrtav nebi koristio pc u poslu koji radim ![]() |
#30 |
Suit up!
Postovi: 5,962
Mislim da nije ni mjesto ni vrijeme za PC vs Mac rasprave ![]() |
