Staro 20.11.2008., 23:35   #1
malcom
malcom's Avatar
Postovi: 411
TakeMS Blade i max kapacitet mem.
ovako posto sam dobio na poklon gore navedeni mp4 player koji ima utor za micro sd karticu neznam koliko je maximalni kapacitet memorije 1,2,4,8GB. Ima netko od forumasa taj mp4 da mi pomogne jer mi se stvarno neda ici kupovat karticu od 8 gb za bezveze.
Intel Quad Core 6600@Freezer 7 pro, Nvidia 8800GT, Abit IP35-E, Samsung 320GB, 4x 1GB DDR800, 5-5-5-18, OCZ 500W, @Sharkoon Rebel 9, Logitech G5, Surround 5.1 Logitech X-530
malcom je offline   Reply With Quote
Staro 24.11.2008., 23:15   #2
georgy
georgy's Avatar
Postovi: 408
Product : takeMS 2GB MP3 Blade
Description
Special Features:
including Radio
supports MP3, MP4, WMA, JPG und BMP
rechargeable battery
razor-thin housing
the battery charger is contained in the scope of supply
Technical Features:
MP3 player with Radio function
Supported music formats: MP3, WMA, WMV, ASF, WAV
Dimensions: 90*40.5*10.5 mm, Weight: 52g
Screen: Matrix (160*128) Liquid Crystal
Power Supply: up to 3 hours play mode
Supported Systems: Windows 2000/XP,Vista
Integrated Memory: (variable) 1,2,4 GB
Power: Integrated rechargeable battery charging directly via USB-Port)
A, možda i radi 8gb, imam taj mp4, ali nemam karticu od 8gb.
georgy je offline   Reply With Quote
Staro 24.11.2008., 23:30   #3
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
To je integrirana memorija. Tj. verzije playera s tim kapacitetom, a ne SD karticom.
I ja imam na ploci.
Staro 25.11.2008., 09:00   #4
georgy
georgy's Avatar
Postovi: 408
A, nisam skužio.
