#601 | |
Postovi: 152
kad ih jednom osvojis slijedi neprijateljska odmazda i onda moras koristiti strojnice, bazuke ili protuavionske topove kako bi unistio tenkove i kamione koji idu na tebe veliki je naglasak na upotrebi dimnih bombi (naravno da mozes i bez njih, ali je teze - igram na veteran tezini.) po meni je to doslovno ista igra kao i COD2 isti tip misija, isti dizajn levela |
#602 |
Postovi: 9,067
Patch 1.1 is out ![]() Notes: Mods are now enabled in Co-op, Single Player, and Multiplayer. Players will now be notified when a new patch is available. Improvements for SLI support. G_Spawn: no free entities crash has been fixed. Server no longer runs out of script variables. License key is no longer required to run a Dedicated Server. A Dedicated Server can now be started from the Command Line via Remote Desktop Connection. Various fixes in Server Browser. Players will no longer see multiple friend invites from the same friends. When a player calls in a recon plane in a Hardcore match, the HUD will properly appear. Clan Tags will now display in game where appropriate. Map holes fixed Spawn improvements and weapon balancing Download: Worthplaying.com - http://www.worthplaying.com/article.php?sid=57405 AusGamers Files - http://www.ausgamers.com/files/details/html/40158 http://www.callofduty.com/intel/173
___________ Just atha x |
#603 |
Hejter
Postovi: 6,521
Igra je genijalna , tocno takav FPS volim i zelim igrati , bez previse opterecivanja mozga , daj mi pusku i da pucam . Cak i moja kanta ( athlon x2 na 2.8 , 2gb rama i 9600gso ) tera igru da leti i izgleda genijalno za moj pojam . Ovo cu proci barem 20 puta . |
#604 |
Bill Gates
Lokacija: Vukovar
Postovi: 1,983
Eto, napokon su sredili. Jos samo da netko proba i kaze kako je sad. |
#606 | |
P.E.B.K.A.C.
Postovi: 2,304
Evo ja jucer proveo jedno vrijeme online kako bi isprobao full verziju na svim mapama, neke su stvarno veeeelike ![]() E sad da nastavim raspravu sa drugoga topica (da ne spamamo bezveze onaj topic) o copetitiv nacinu igranja: Sto se tice mapa, vecina mi se svida zbog no da budem iskren mozda 3-4 mape valjaju sto se tice S&D i tu je i bio u pravu Robert7 (one manje mape, bome sam se i ja dobro nasmijao kad sam vidio na onoj velikoj da su plentovi sa samo jedne strane dok 60% mape prazno ![]() ![]() No opet sagledavsi stvar iz druge persperktive (recimo CTF kojeg najvise igram od svih modova) recimo novih modova poput War koji funkcioniraju na temelju toga da cim osvojis jednu tocku moras se grupirati na drugu i tako zauzeti sto je vise pointova da su mape malo manje bilo bi katastrofalno pogotovo ako se radi o serveru sa 24 pa navise slotova... sad je to opet dilema public vs. competitiv publike.... Daleko od toga da nevolim S&D ali istina je da svodi samo na 3 mozda 4 mape... ha mozemo se nadati da ce izaci u buducnosti custom mape... Sto se tice oruzja istina je to sto je Robert7 napisao (djelomicno) da gewer i slicna oruzja (semi-automatic) osim garanda, prakticki nemaju recoil dok recimo druga poput Bar-a (osobno meni najdraze oruzje) i Mp40 imaju i to mozda veci nego u CoD-2 nastavku... to popraviti zajedno sa puskama i mislim da nebi trebalo biti problema ili bar smanjti damage koje te puske nanose (ili sam ja igra HC pa mi se cinilo da brze umiru ![]() ![]() PPSh nisam jos isprobao imam jos igranja dok ga neotkljucam ![]() No sve u svemu igra je daleko od sranja, govna, smeca kako ga neki argumentirano opisuju bar je to moje skromno misljenje public heroja ![]() Naravno da ja Treyarch smjesan develop. team naspram IW ali mislim da opet iz druge perspektive koliko je u povjesti igara tj. develop. teamova pokupovalo tude engine i ucinilo 10x goru stvar nego sto je Treyarch napravio sa cod4 enginom... ukratko.. Citiraj:
![]() Nadam se da su patchu ispravili vecinu gresaka... Jel itko isprobao??
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/ Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Zadnje izmijenjeno od: Gjurovski. 11.11.2008. u 12:54. |
#609 | |
Postovi: 257
Za drugi: nu liste servera http://www.gametracker.com/search/co...Zn8XgKl468Jyrw Jedino što xfire ne registrira COD5 pa ukucavam u console. Zna li netko kako da mijenjam ime u online profileu? |
#611 | |
Strichek Moderator
Postovi: 9,344
žmnpp |
#616 |
Lokacija: Chernobyl NPP
Postovi: 4,777
kaj od ovoga treba maknuti, koliko vidim koristim ovaj treći, a za što su mi ova prva dva?? da li se to može poslije nazad dodati, i net dalje normalno radi (nisam baš expert za takve stvari ![]() ![]() |
#618 |
Postovi: 4,777
a ti imaš original?? hvala, hvala...removal sam prva dva modema i igra je proradila, ali sad imam drugi problem, kad je pokrenem ponudi mi neke profile za birati, ne mogu ih izbristai ni napraviti novog, kak da to riješim... hebem ti ja taj release, jedan problem riješim drugi nastane ![]() Zadnje izmijenjeno od: xGAME. 11.11.2008. u 18:20. |
#620 |
Postovi: 206
uf, imam original... da... ![]() napravi nesto, nisam ni ja uspio odma, jer pita i online i offline profil... napravi i offline i online i onda za online stavi da nece ili tak nest... nece ni sa patchom, ni sa safe disc hiderom bze c***ka... |
#621 |
Postovi: 4,777
prešel sam prve 3 misije, sad sam negdje na sredini 4....nije da serem po igri ali CoD4 je barem meni bolji, i kao šro skoro svi vele zvuk je sranje... za profile sam išel u save game i obrisal jednog... @fps_gamer i @Filip7 hvala vam još jednom ![]() ![]() |
#623 |
Datum registracije: Mar 2008
Postovi: 167
opet kažem što dalje to bolje.ali je igra bugovita i to u rangu sa stalkerom.dodjem do misije po nekim tunelima.pobijem sve kamikaze i na kraju su neki topovi što gledaju na ocean.tu se trebam regroup s ekipom ali je problem što je pola ekipe pozapinjalo po zidovima.neki ostali na početku levela i šta sad.trebo bi misiju iz početka.haha.nevjerujem .to je samo jedan u nizu bagova.igra nijue smeće kao što su mi bili prvi dojmovi ali bugovi su prevladali.već sam jedamoput zbog baga išo misiju iz početka ali ovu nene.blaženi add remove |
#624 |
Postovi: 1,710
Public Fixed server
http://eu.prepsafe.com Zadnje izmijenjeno od: robert7. 11.11.2008. u 22:53. |
#625 |
P.E.B.K.A.C.
Postovi: 2,304
Yep popravili su puske.... ![]() ![]() ![]() Ali nisu dirali semi-automatic puske... :-/ I dalje no recoil ![]() Server: 80.101.210.85:28980 HQ
#627 |
Postovi: 1,389
Igrate li Zombi mod? Meni je to definitivio jedna od najzabavnijih stvari koje sam igrao u zadnje vrijeme.. nas 4 u lanu i opleti.. ![]() Izdržali smo do sada najvise do 17-og napada... |
#628 |
Bill Gates
Lokacija: Vukovar
Postovi: 1,983
Poslije patcha je stvarno uzitak igrati. Oruzja kako treba, nema onih g_spawn errora, spawnovi su na mjestima na kojima i trebaju biti. Stvarno je dobar MP. |
#629 | |
gejmer
Lokacija: Virgin Islands
Postovi: 452
#630 |
Datum registracije: Aug 2008
Lokacija: mamuti
Postovi: 310
