Postovi: 7
Kupnja prvog OWN kompa
Eto kao što kaže naziv teme odlučio sam si kupiti samo svoj komp (dosad je bilo ono.. "obiteljski" a pošto je navršio jedno 7-8 god želim im ga totalno prepustiti ![]() ![]() ![]() SAMSUNG SM T220, 22", Wide format, 1680x1050 (WSXGA+), 300 cd/m2, 20.000:1, 170 °, 160 °, 2 ms, Composite, D-Sub, DVI-D, Boja Crna/crvena, Postolje zakretno u hor. osi, Timer, HDCP - XFX 9800GTX+ GeForce 9800 GTX+ 512Mb 765MHz, DDR3 256 bit, tv-out, Dual DVI, HDTV ready ,Engine Clock : 765 Memory Clock 2200 MHz, PV-T98W-YDQ4 Miš Logitech LX8 cordless, Logitech, bežični RF, PS/2, USB, laserski, 1000 dpi, Tipke 5 + scroll, Boja plavo-crna Gigabyte EP35-DS4, s775, intel P35+ICH9R, FSB 1600 OC/1333/1066/800MHz, 8xSerial ATA II, 1xUDMA133, 2xPCI, 3PCI-E x 1, 2PCI-E x 16, 4DDR II (Dual channel 1200OC/1066/800/677/533 MHz), 8-channel audio, Gb LAN, 2xFW, USB 2.0, HT, ATX,GIGABYTE Dynamic Energy Saver(DES) technology HDD WD 640 GB, 6400AAKS, WD Caviar SE 16, SATA II, 16 MB, 3,5", 7.200 rpm DDR2 2 GB 1066MHz KINGSTON, 2x1024 MB, Napajanje 2,2 V, Latencija CL5, HyperX, KHX8500D2K2/2G Napajanje CORSAIR TX Series, 650 Watt, ATX, EPS12V, PS/2, Modular Power Supply, EU Version CPU Intel Core 2 Duo E8400, Socket 775, Radni takt 3000 MHz, L2 cache 6 MB, BUS 1333 MHz, Jezgra Wolfdale, Hladnjak DVD+/-RW NEC DVD RW AD-7203S-0B, black Kućište SILVERSTONE Precision PS01B Midi Tower, ATX Mainboard Supported, 7 slots, 2xUSB2.0, IEEE-1394, audio, PSU optional, Black Tipkovnica Logitech Internet 350 Black USB OEM CREATIVE LABS SB Audigy SE, bulk D-Link DWL-G510, bežični, PCI, 11/54Mbps,802.11b/g, Vrsta priključaka antenski konektor MA, Broj priključaka 1 p.s uzeo bih 4 GB rama no ako ne bude sad para onda samo dva pa još dva prvom prilikom i zanima me dali mi preporučujete quad ili ovaj proc jer se mislim ponekad i poigrati u sony vegasu recimo (program za profi audio i video obradu) - neznam koliko se osjeti tih 2 MB cache-a razlike hvala svima koji će si dati truda da pročitaju unapred ![]() |
Postovi: 33,972
1. zamijeni NEC pržu sa LG/Samsung/Pioneerom 2. Audigy ti nije potreban jer imaš zvuk na ploči 3. šta će ti taj D-Link? 4. možeš uzeti i slabiji Corsair (VX450 ili HX520) 5. možeš uzeti i slabiji proc (npr. E7200). Razliku ionako nećeš vidjeti osim u novčaniku i 5 sek. bržeg kodiranja. 6. zamijeni 9800 GTX+ sa HD4870 7. 4Gb rama će ti vidjeti samo 64bitni OS kojeg si vjerojatno nećeš stavljati. Dosta ti je i 2Gb (XP) ili 3Gb (Vista). 8. pročitaj neku od tema u ovom podforumu jer imaš brdo odličnih kombinacija sortiranih po cijenama istih
Postovi: 7
1. ok - primio na znaje ![]() 2. znam da ima ali neće li biti bolji sa zvučnom? pošto dosta lsušam muziku i zvuk mi je važan :? 3. Wireless internet imam u kuci pa.. zato, sto ima na ploci ili ja nevidjeh :? 4. ma nije neka razlik u cjeni..a frend tvrdi da struje nikad sdosta, vazno da je valitetno napajanje ![]() 5. ajd reci što misliš o quadu - zbog onog igranja u vegasu kako sma napomenuo a i općenito cijena oko 1200 kn proca moze biti, mozda i malo vise, vidjet cemo kako bude overall cjena (nejdem iznad 10 k) 6.bolan pa to skupo ![]() 7. znam ali dugo necu mjenjati komp pa.. sto fali kasnije da imam dosta rama, ai imat cu 64 bitne windowse kad tad 8. malo sma cituckao sad.. ali malo.. ima toga puno a ja sam pred closing the deal pa trebam brzu pomoc i to specificnu ![]() ![]() a i nisma dugo pratio hardver, pa da se malo informiram na forumu |
#4 | |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Uzmi napajanje HX520 i proc 7200 i za tu razliku u cijeni kupis 4870. To ti je bolja kombinacija od ovoga sto ti planiras uzeti. ![]()
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
Postovi: 7
ma mislim d aće stati u cijenu čak i bez mjenjanja ostalih komponenta uopće! p.s ali niste komentirali zamjenu procesora za quad po takvoj cjeni i cocounat mi nije odogovorio isto :? p.s zašto je bolja kombinacija? HX 520 mi je 120 kn skuplje, što popravdava taj skok u cjeni za manje watta? |
Bill Gates
Lokacija: Vukovar
Postovi: 1,983
Modularno je napajanje tj. ima odvojive kablove ako ti ne trebaju neki. |
Postovi: 7
pa dali da zbog toga plaćam više novaca z manje watta? može netko odgovoriti na druga pitanja? i gdje je coconut :? |
#8 | |
Adrenaline junkie
Postovi: 3,593
Nemas potrebe uzimati Q procesor, jedino ako baš hoćeš da imaš 4 jezgre onda uzmeš Q6600 (cijenom je tu negdje sa E8400), ali mislim da nemas potrebe, bolje bi ti bilo uzeti na primjer gore već navedeni E7200 i ušparati na njemu nešto para, koje kasnije daš u bolju grafičku. Razliku između E7200 i E8400 u igrama nećeš osjetiti kao ni u svakodnevnom radu. Nema ga više, pojeli smo ga maloprije.
Postovi: 7
pa... zbog vegasa mi je vazno imati dobar proc i dobre rame (zato pitam jel neko zna jeli za takve programe bolje imati quad) kanta nije primarno gamerska nego onako.. da bude brza u svemu! i dobra idućih 6 god ![]() p.s stvarno mi je žao zbog coconuta, činio se baš simpa ![]() p.s koja je razlika između VX i TX? |
Postovi: 33,972
Milentije ti je sve rekao u vezi procesora. Što se tiče audio kartice, ako nisi teški audiofil sa ušima osjetiljivim poput šišmiševih, razliku ćeš teško osjetiti. btw, ja nisam jedan od onih što više na forumu 0-24 tako da nema potrebe za paničnim traženjem moje malenkosti.
Postovi: 7
ostavljam onda ovaj proc! ![]() čiju HD4870 da uzmem? Koja je točno razlika između HX, VX i TX?? onda zvučnu neću uzeti @: bez_panike - kako za čije potrebe zadnji komp koji sam platio 10 k kuna me i sad sasvim dobro služi jedino trebam malo veći hard i gigu rama pa 180 kn! za 500 kn je ko zmaj ![]() |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
imho moj savjet je da uzmes bestbuy komponente i smanjis broj rata na 6 vjeruj mi kasnije ces mi biti zahvalan... ako oces tu besbuy konfu pukni mi pm pa ti slozim nesto.
Postovi: 7
Ajd eovako da vas pitam.. čitao malo po forumu i vidim da većinom mrzite ovakve topice no jbg, kad dajes 10 000 kn nije ti svejedno bas ![]() u biti, nesto mi je neki lik srao za maticnu, sto vi kazate na maticnu i koju preporucujtete ako ne ovu za cjenu do 1100 kn ajde molim vas pomozite jos oko ovoga, sve drugo sam pronasao na forumu manje vise! |
Adrenaline junkie
Postovi: 3,593
Samo malo. Vidim da uzimas komp na rate sto znaci da bi sve trebalo biti uzeto u jednoj trgovini. Da li mi je promaklo ili nigdje ne pise koja je to trgovina? Ali eov predloga iz više trgovina za matičnu ploču u rangu od oko 1100kn. Links ASUS P5Q Pro - 1019 kn ASUS P5Q-E - 1199 kn GIGABYTE EP45-DS4 - 1195 kn Ve-Mil GIGABYTE EP45-DS4 - 1111 kn HGspot DFI LAN PARTY JR P45-T2RS - 959 kn DFI LAN PARTY DK P45-T2RS - 949 kn Hardveraj BIOSTAR TPower I45 - 1000 kn GIGABYTE EP45-DS4 - 1050 kn DFI LAN PARTY DK P45-T2RS - 950 kn
#16 |
Postovi: 33,972
Neisplativo je u ploču uložiti 1.100kn bez obzira kakve kerefeke ima, jer će sasvim dobro isti posao odraditi i ona od 600-700kn. A novčanik će osjetiti tu razliku.
#17 |
Lokacija: Zabok
Postovi: 1,189
gle... sad zelis komp za 10 k kn, a isto ce ti trajat ko i ovaj kojeg sam ja slozio : razlika nikakva pretjerana, a ti sretan i zadovoljan... a presao si sa 6 rata... i neces to trebat tak dugo otplacivat... u ovoj konfi samo kuciste fali , a to uzmes po volji.. |
#18 | |
Adrenaline junkie
Postovi: 3,593
![]() Samo umjesto tog ASUS rezača uzeti neki Pioneer, LG,...
#20 |
Lokacija: livno
Postovi: 1,065
mozda grafu gf 260gtx za 1900kn?? |
