Staro 25.09.2008., 17:37   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Nvidia GeForce 178.13 WHQL driveri
Nvidia has now released a new WHQL-certified graphics card driver, the GeForce 178.13. Coming with support for the GeForce 6, 7, 8, 9 and GTX 200 series cards, the 178.13 includes the PhysX v8.09.04 software and features:
- Added support for 2-way and 3-way Nvidia SLI technology with GeForce GTX 200-series GPUs on Intel D5400XS motherboards
- Support for single GPU and Nvidia SLI technology on DirectX 9, DirectX 10, and OpenGL, including 3-way and Quad SLI technology
- CUDA support
- Support for the Folding@home distributing computing application.
- Numerous 3D application compatibility fixes
- Several 3D application performance improvements. For example (improvements measured with 178.13 versus 175.19):
Single GPU increases up to 11% in 3DMark Vantage (performance preset)
Single GPU increases up to 11% in Assassin's Creed DX10
Single GPU increases up to 15% in Bioshock DX10
Single GPU increases up to 15% in Call of Duty 4
Single GPU increases up to 8% in Enemy Territory: Quake Wars
2-way SLI increases up to 7% in Bioshock DX10
2-way SLI increases up to 10% in Company of Heroes: Opposing Fronts DX10
2-way SLI increases up to 12% in Enemy Territory: Quake Wars
2-way SLI increases up to 10% in World in Conflict DX10
http://www.tcmagazine.com/comments.p...=21938&catid=3
Staro 25.09.2008., 19:02   #2
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Aj fala bogu, konačno.
175 sam bio prekrižio i stavio 177.79 betu, uglavnom, nisam zadovoljan. Čak mi se i grafa znala vračati u 2D mod dok bih igrao recimo COD4
To nije bilo dobro, nimalo, zbloka sve, sa 125 FPSa, padne na 6, pa se povisi i u 2D modu vrti mi 40-50-60 FPSa
Restartam komp, sve u redu, radi u 3D-u
Sad će ići friška instalacija windowsa i novi WHQL driveri
blaa
Staro 25.09.2008., 19:37   #3
Apacer ft Bozja
Baja!
Apacer ft Bozja's Avatar
Lokacija: Sisak
Postovi: 761
wtf...jel digital vibrance ne radi sa ovim drajverima ili koji k*..stavim ga na 100% i nista..ko da je na 0..bas mi je ruzno bez toga
zna netko mozda sta bi moglo biti..jednostavno su mi boje mracne i bezveze
EDIT: oni koji imaju XP,sa ovim driverima nece moci omoguciti digital vibrance..eto samo malo upozorenje
ja se vracam na stare dok to ne poprave
Zadnje izmijenjeno od: Apacer ft Bozja. 25.09.2008. u 20:14.
Apacer ft Bozja je offline   Reply With Quote
Staro 25.09.2008., 20:26   #4
Wolverine
Wolverine's Avatar
Postovi: 12,429
yebate jelc pa kaj si i ti ateriral na vugla da u zadnje vrijeme visiš na nevidiji
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 25.09.2008., 20:36   #5
Razer
Razer's Avatar
Postovi: 11,642
Tko bi odolio toj zelenoj boji
Staro 25.09.2008., 20:43   #6
Wolverine
Wolverine's Avatar
Postovi: 12,429
btw
nabiyem nevidiju i sve njihove mr.dr.sc.kripl.ing .... i drivere od 100+MB
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 25.09.2008., 20:55   #7
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
skida se...aj bas pa cemo provjetiti hoce li ista biti bolje
NovA Squadron
kripton je offline   Reply With Quote
Staro 25.09.2008., 22:14   #8
Kobe
Kobe's Avatar
Lokacija: Ispod zvijezda
Postovi: 95
Malo sam testirao drivere na crysisu. ( prvome ne warheadu)
1680 x 1050 igram na very high ( ona šema very high na xp) bez AA i AF.
Čini mi se da su fps malo podigli, kretali su se prije oko 18-20 ali su bili nestabilniji, znali su past na 14 u akciji pa se opet dignuti poslije. Sad je situacija stabilnija, drže se u granicama 17-21.
Kobe je offline   Reply With Quote
Staro 25.09.2008., 22:50   #9
Jelc
Super Moderators
Postovi: 17,485
Veliki je događaj kad Endivia izda WHQL drivere...to se mora kvalitetno popratit
Staro 25.09.2008., 22:53   #10
Razer
Razer's Avatar
Postovi: 11,642
Nesjećam se kako je prije bilo no kako vidim sad, WHQL drivere izdaju dosta često, barem u zadnje vrijeme kako vidim.
Staro 26.09.2008., 00:33   #11
BeroVK
Lokacija: Vinkovci
Postovi: 780
Evo upravo stavljeni, malo isprobano na cod4 i losije ide onako u mojoj konfi ide oko 70fps na max ali cesto zna past fps, kao da lagga.
BeroVK je offline   Reply With Quote
Staro 26.09.2008., 12:31   #12
Apacer ft Bozja
Baja!
Lokacija: Sisak
Postovi: 761
Oprostite ako zbog gluposti bumpam temu,ali mozda nekome pomogne,kao sto je meni
Naime..ako zelite osposobite DV na XP.u,koristite Riva Tuner i tamo ukljucite DV na koliko hocete..eto meni je pomoglo
Staro 27.09.2008., 16:44   #13
Vendetta
Vendetta's Avatar
Postovi: 919
Imam problem kod instalacije na 64 bitnoj Visti,"zaleti" se do pola,stane,instalira mi drivere valjda (pocrni ekran pa se opet vrati slika),onda cekam i cekam i cekam,pa mi izbaci da odaberem jezik za ovaj NVIDIA PhysX,klinem ok na engleski ,i onda krene dalje i izbaci mi ovo :
ima li jos neko sa vistom ovakav problem ?
Vendetta je offline   Reply With Quote
Staro 27.09.2008., 16:56   #14
nexusone
Datum registracije: Apr 2008
Postovi: 139
Autor St-M Pregled postova
Meni se to pojavilo, ali nakon instalacije sam isao u nvidiin kontrol panel provjeriti koja je verzija drivera, pak tamo pise da su instalirani ti driveri, isto tako su i za fiziku...
nexusone je offline   Reply With Quote
Staro 27.09.2008., 16:59   #15
Vendetta
Vendetta's Avatar
Postovi: 919
A pogleda sam i ja,ali koji k... kenjka onda
Vidit cemo kako ce to funkcionirat
Staro 28.09.2008., 23:42   #16
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Meni isti taj "problem" ali sve šljaka normalno...
Staro 29.09.2008., 10:45   #17
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Da to sam primjetio na već neliko revizija ovih novijih drivera (mahom beta pa sam to pripisivao tome), najbolje je maknuti iz fodera Phsyx installer (nakon što se otpakira driver) i stavit negdje drugdje di ga neće nać (npr Desktop) i odvojeno ih instalirati jer onda prolazi 100% bez problema...
Have a nice day...
Staro 08.10.2008., 13:11   #18
Exe
Exe's Avatar
Postovi: 353
Ja imam 169.44 drivere i ako inst. samo Nv PhysX da li če to raditi ili moram staviti nove drivere.
Exe je offline   Reply With Quote
Staro 08.10.2008., 16:02   #19
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
kod mene blu skrin posliije restarta prilikom bootanja... stari driveri prije instalacije pobrisani driver cleanerom... ostajem na 175.19
T0mB1ll je offline   Reply With Quote
Staro 08.10.2008., 23:17   #20
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,540
Da vam ne zapne instalacije deinstalirajte Physx i stare drivere. Novi driveri instaliraju oboje. Tko ima problema sa ovom verzijom neka proba 178.15, čini se da rade bolje. Ovi nemaju Physx, pa ga skinite posebno.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
LAcy je online   Reply With Quote
Staro 09.10.2008., 09:57   #21
Z-man
Z-man's Avatar
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
A jel tko probao Xtreme-G 178.13 ?
Z-man je offline   Reply With Quote
Staro 09.10.2008., 10:23   #22
yedwy
yedwy's Avatar
Postovi: 6,956
Autor LAcy Pregled postova
Nejde, ja sam jučer instalirao na formatirani stroj i opet je zapelo (origigi driveri od nvidie nisu bete) mislim da je problem u njihovom instaleru, inače instalira on driver do kraja ali kad treba preć na Physx installer se jednostavno smrzne...
Kad ga se preko taska ubije i restarta stroj ide bez problema i driver je cjeli gore...
Have a nice day...
Staro 10.10.2008., 16:35   #23
TDK
Datum registracije: Sep 2002
Postovi: 276
instaliram, vratim se u windowse, par sekundi slika, nakon toga nestane, a windowsi se i dalje dizu i normalno rade, al nema slike i monitor je u standby modu
TDK je offline   Reply With Quote
Staro 10.10.2008., 20:32   #24
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
Autor Z-man Pregled postova
ja stavio... nema blu skrina kao kod obične verzije, al nisam još isprobao u igrama..
Staro 10.10.2008., 23:44   #25
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,540
Autor TDK Pregled postova
To je najnoviji fetaure drivera Vjerojatno ti je postavljena rezolucija koju monitor ne podržava, odi u safe mode i tamo promijeni u neku drugu. Ja sam malo bolje prošao. Instalacija 178.15 prošla dobro, nije ništa zapelo, restartam sve ok. Ugasim računalo, drugi dan upalim a ono 1600x1200!? Uopće ni nema moje rezolucije, niti prepoznaje monitor kako treba. Rješenje, napravio sam custom rezoluciju.
MacBook M1 Pro
MacBook Air M2
Moto Edge
