Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Nvidia GeForce 178.13 WHQL driveri
Nvidia has now released a new WHQL-certified graphics card driver, the GeForce 178.13. Coming with support for the GeForce 6, 7, 8, 9 and GTX 200 series cards, the 178.13 includes the PhysX v8.09.04 software and features: - Added support for 2-way and 3-way Nvidia SLI technology with GeForce GTX 200-series GPUs on Intel D5400XS motherboards - Support for single GPU and Nvidia SLI technology on DirectX 9, DirectX 10, and OpenGL, including 3-way and Quad SLI technology - CUDA support - Support for the Folding@home distributing computing application. - Numerous 3D application compatibility fixes - Several 3D application performance improvements. For example (improvements measured with 178.13 versus 175.19): Single GPU increases up to 11% in 3DMark Vantage (performance preset) Single GPU increases up to 11% in Assassin's Creed DX10 Single GPU increases up to 15% in Bioshock DX10 Single GPU increases up to 15% in Call of Duty 4 Single GPU increases up to 8% in Enemy Territory: Quake Wars 2-way SLI increases up to 7% in Bioshock DX10 2-way SLI increases up to 10% in Company of Heroes: Opposing Fronts DX10 2-way SLI increases up to 12% in Enemy Territory: Quake Wars 2-way SLI increases up to 10% in World in Conflict DX10 http://www.tcmagazine.com/comments.p...=21938&catid=3
its slightly turbocharged
Postovi: 5,430
Aj fala bogu, konačno. 175 sam bio prekrižio i stavio 177.79 betu, uglavnom, nisam zadovoljan. Čak mi se i grafa znala vračati u 2D mod dok bih igrao recimo COD4 To nije bilo dobro, nimalo, zbloka sve, sa 125 FPSa, padne na 6, pa se povisi i u 2D modu vrti mi 40-50-60 FPSa Restartam komp, sve u redu, radi u 3D-u Sad će ići friška instalacija windowsa i novi WHQL driveri ![]()
blaa |
Baja!
Lokacija: Sisak
Postovi: 761
wtf...jel digital vibrance ne radi sa ovim drajverima ili koji k*..stavim ga na 100% i nista..ko da je na 0..bas mi je ruzno bez toga ![]() zna netko mozda sta bi moglo biti..jednostavno su mi boje mracne i bezveze ![]() EDIT: oni koji imaju XP,sa ovim driverima nece moci omoguciti digital vibrance..eto samo malo upozorenje ![]() ja se vracam na stare dok to ne poprave ![]() Zadnje izmijenjeno od: Apacer ft Bozja. 25.09.2008. u 19:14. |
Postovi: 11,642
Tko bi odolio toj zelenoj boji ![]() |
Lokacija: Ispod zvijezda
Postovi: 94
Malo sam testirao drivere na crysisu. ( prvome ne warheadu) 1680 x 1050 igram na very high ( ona šema very high na xp) bez AA i AF. Čini mi se da su fps malo podigli, kretali su se prije oko 18-20 ali su bili nestabilniji, znali su past na 14 u akciji pa se opet dignuti poslije. Sad je situacija stabilnija, drže se u granicama 17-21. |
Super Moderators
Postovi: 17,485
Postovi: 11,642
Nesjećam se kako je prije bilo no kako vidim sad, WHQL drivere izdaju dosta često, barem u zadnje vrijeme kako vidim. |
Postovi: 919
Imam problem kod instalacije na 64 bitnoj Visti,"zaleti" se do pola,stane,instalira mi drivere valjda (pocrni ekran pa se opet vrati slika),onda cekam i cekam i cekam,pa mi izbaci da odaberem jezik za ovaj NVIDIA PhysX,klinem ok na engleski ,i onda krene dalje i izbaci mi ovo : ima li jos neko sa vistom ovakav problem ? ![]() |
#14 | |
Datum registracije: Apr 2008
Postovi: 139
Meni se to pojavilo, ali nakon instalacije sam isao u nvidiin kontrol panel provjeriti koja je verzija drivera, pak tamo pise da su instalirani ti driveri, isto tako su i za fiziku... |
#16 | |
Lokacija: Home
Postovi: 2,186
#17 |
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
Da to sam primjetio na već neliko revizija ovih novijih drivera (mahom beta pa sam to pripisivao tome), najbolje je maknuti iz fodera Phsyx installer (nakon što se otpakira driver) i stavit negdje drugdje di ga neće nać (npr Desktop) i odvojeno ih instalirati jer onda prolazi 100% bez problema...
-- Have a nice day... |
#20 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,536
Da vam ne zapne instalacije deinstalirajte Physx i stare drivere. Novi driveri instaliraju oboje. Tko ima problema sa ovom verzijom neka proba 178.15, čini se da rade bolje. Ovi nemaju Physx, pa ga skinite posebno.
#22 | |
Postovi: 6,956
Kad ga se preko taska ubije i restarta stroj ide bez problema i driver je cjeli gore...
#25 | |
Pink Floyd fan
Postovi: 5,536
