Staro 07.08.2008., 00:26   #1
asdf123
asdf123's Avatar
Lokacija: Zg ilili
Postovi: 253
Windows XP Professional x64 how to hibernate???
Dakle doticni win i u postavkama napajanja nemogu nac ni postavit da si komp stavim u Hibernaciju....
Moze li se to nekako u regisrima ukljucit ili ta mogucnost ne postoji?
inace win je Verzija 5.2.3790
Hvala na pomoci...!
asdf123 je offline   Reply With Quote
Staro 07.08.2008., 00:31   #2
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Odeš u Control panel -> Power Options i tamo upališ i tabu hibernate enable hibernation?
Have a nice day...
Staro 07.08.2008., 00:31   #3
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,107
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 07.08.2008., 00:39   #4
asdf123
asdf123's Avatar
Lokacija: Zg ilili
Postovi: 253
procitao sam razlog...
Imam 4GB rama.
Pitanje dal ce mi to radit?
Ako moze radit dal ce se brze aktivirat iz hibernacije nego da se klasicno pali?
Staro 07.08.2008., 00:42   #5
asdf123
asdf123's Avatar
Lokacija: Zg ilili
Postovi: 253
Autor yedwy Pregled postova
tabu hibernate nemam ne pise....................
Mozel i se to u reg. ukljucit? to sam od pocetka pitao???????
Staro 07.08.2008., 01:32   #6
^SuperUnknown^
Prečupavi mod
Postovi: 9,107
Osim ako nemas neke konkretne razloge protiv, razmisli o Suspend to RAM varijanti. Dizanje i bacanje u "sleep" ti traje doslovno nekoliko sekundi...
S3 Power mode
The S3 mode, also called suspend or standby mode, is ideal for media PCs as it can turn on and off the PC within seconds. This is achieved by not shutting down the operating system but by "freezing" it into the RAM. Modern ATX supply units guarantees that the PC is absolutely quiet in suspend mode, just as if the PC was turned off normally. All fans, harddisks or other stuff inside the PC are turned off! Often you have to configure the S3 mode in the bios of the PC first, so that it really turns off these devices and does not only go into S1 mode.
If you worry about the power consumption: Our measurements have shown that the power consumption in S3 mode is almost exactly the same as if the PC is shut down normally. In worst case the consumption was at 1.8 Watts compared to 1.1 Watts when the PC was shut down. In most cases the consumption was below the treshhold which could be measured by us at all. Standalone devices like CD players, TVs or amplifiers usually need much more power in standby mode. So the S3 mode offers best conditions to be used in media PCs! It is supported by Windows® OS since Win 98b.
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 07.08.2008., 01:48   #7
asdf123
asdf123's Avatar
Lokacija: Zg ilili
Postovi: 253
super samo mene zanima dal je S3 po defoultu postavljen i ako nije di i kakko ga postavit....
A sto se hibernacije tice znam da je malo zeznuto ali ipak dal se to da enablati u registrima bas me zanima.
Jedna stvar? Kod hibernacije dal smeta nestanak napajanja, kos s3 cinimi se da smeta jer je sve pohranjeno u memoriju ?????
Staro 07.08.2008., 02:02   #8
^SuperUnknown^
Prečupavi mod
Postovi: 9,107
S3 postavljas u BIOS-u, obicno se opcija zove "Suspend type", postavljas je na "S3" ili "Suspend to RAM". Komp bacas u sleep pomocu Start->Shutdown ili Turn of your Computer->Stand By. Kaj se tice hibernacije, mislim da je ovaj link na M$-u i vise nego jasan. Kod hibernacije ti ostaje sve, makar iskljucio komp iz zida godinama, a kod Suspend to RAM-a gubis sesiju prilikom nestanka struje (duzeg od 1-2 sekunde, koliko bi mozda elektroliti izdrzali napajati plocu i RAM).
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 07.08.2008., 02:13   #9
asdf123
asdf123's Avatar
Lokacija: Zg ilili
Postovi: 253
Puno ti hvala sto si mi to tako lijepo pojasnio
ali opet lijepo bi bilo kad bi se dalo stavit u hibernaciju ipak bilo bi na disku ....
sta je tu je
Staro 07.08.2008., 18:15   #10
thopok
Lokacija: Splity
Postovi: 3,003
Jesi pokuša ono:
In this scenario, you must add the /MAXMEM=4096 switch to the Boot.ini file to reduce the highest physical memory to 4 GB.
Staro 08.08.2008., 01:31   #11
asdf123
asdf123's Avatar
Lokacija: Zg ilili
Postovi: 253
Autor thopok Pregled postova
Jesi pokuša ono:
nisam
a ni necu jer ako sam ja dobro shvatio necu dobit nista s hibernacijom....
a neznam dal je to tocno ali cini mi se da virtualna memorija sluzi za pospremanje podataka za obradu (vecih podataaka)a u ram da se prispremaju adrese i tak to....
nebitno uglavnomdosta mi je i s3
Staro 14.08.2008., 20:54   #12
asdf123
asdf123's Avatar
Lokacija: Zg ilili
Postovi: 253
pise mi sljedece:
^Jibernation failed with the following error: The request is not supported.
The following items are preventing hibernation on this system.
the system is running in PAE mode, and hibernation is nt allowed in PAE mode.^
Dakle kakav je to PAE mod .i dal se to da nekako iskljuciti/prebaciti u drugi mod?
Zadnje izmijenjeno od: asdf123. 15.08.2008. u 21:11.
Staro 15.08.2008., 14:45   #13
Punio4
Punio4's Avatar
Lokacija: Zagreb, Maksimir
Postovi: 437
Jao kako volim kad ljudi "Speakaju" engleski u naslovu topica, te ne koriste hrvatske dijakritičke znakove ^^
Punio4 je offline   Reply With Quote
