Staro 14.07.2008., 19:10   #1
sinke01
sinke01's Avatar
Lokacija: zgb
Postovi: 55
(riješeno) Ne prepoznaje HDD kod reinstalacije Windowsa
Imam matičnu Winfast/Foxconn 761gxk8mc-RS i HDD Seagate 80GB SATA 2. Komp uredno radi, ali budući da nisam napravio reinstalaciju Windowsa otkad sam ga kupio 2006. odlučio sam to sad napraviti.
Kada sam počeo sa reinstalacijom, javio mi je da ne može nači HDD.
Onda sam pomoću RAID floppy tool-a sa CD-a od matične kreirao sata drajver na disketi. Nakon što počne instalacija, pritisnem F6, ubacim disketu, on iskopira fajlove i opet kaže da ne može naći hard disk.
Skinuo sam sata driver sa sajta http://www.foxconnchannel.com/suppor...D=en-us0000004 i http://driverscollection.com/?file_id=30662, ali oni su preveliki (5MB i 13MB) pa ne stanu na disketu. Kaj da radim???
sinke01 je offline   Reply With Quote
Staro 14.07.2008., 20:22   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Integriras te SATA drajvere u windowse pomocu nlitea..Imas tu sve objasnjeno! http://forum.pcekspert.com/showthread.php?t=36885
IE6
Linux is Not Windows
Staro 14.07.2008., 21:31   #3
thopok
Lokacija: Splity
Postovi: 3,003
Nisu. Nalaze se u System & Chipset Drivers zip-u.
The following details that installation of the drivers while installing new Windows XP/2000. This method don’t be supported for new Windows Me/98SE installation.
  1. Start the installation:
    Boot from the CD-ROM. Press F6 when the message “Press F6 key if you need to install third party SCSI or RAID driver” appears.
  2. When the Windows XP/2000 Setup window is generated, press S key to specify an Additional Device(s).
  3. Insert the driver diskette into drive A: and press Enter.
  4. Choose one of the following items:
    “WinXP SiS Raid/IDE Controller “,
    “Win2000 SiS Raid/IDE Controller”,
    that appears on screen, and then press the Enter key.
  5. Press Enter to continue with installation or if you need to specify any additional devices to be installed, do so at this time. Once all devices are specified, Press Enter to continue with installation.
  6. From the Windows XP/2000 Setup screen, press the Enter key. Setup will now load all device files and then continue the Windows XP/2000 installation.
  7. Please install the driver package again (ex. SiS RAID driver v1.02) while the operation system has been setup.
Zadnje izmijenjeno od: thopok. 14.07.2008. u 21:43.
Staro 14.07.2008., 21:49   #4
sinke01
sinke01's Avatar
Lokacija: zgb
Postovi: 55
@ thopok
U tom zip fajlu od 13MB ima 232 fajla. kak da znam koje da stavim na disketu???
Staro 14.07.2008., 22:31   #5
thopok
Lokacija: Splity
Postovi: 3,003
A pokreni RAID Floppy Tool.exe u ..\ChipDrv\ChipDrv\SISRaid\disk_v1.05
Staro 14.07.2008., 23:38   #6
Joke
N00B
Joke's Avatar
Postovi: 3,886
Autor sinke01 Pregled postova
@ thopok
A ovo iz drugog posta ti ne pomaze? Jesi pogledao tutorial ovaj od domy-a?
IE6
Staro 15.07.2008., 01:07   #7
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Kaj ti nije lakse integrirati te drivere u postojecu windows xp instalaciju pomocu programcica nLite?
Flikoman je offline   Reply With Quote
Staro 15.07.2008., 01:36   #8
sinke01
sinke01's Avatar
Lokacija: zgb
Postovi: 55
pa puno mi je lakše (i brže) putem diskete, budući da nikad to nisam radio... pokušao bih izbjeći tu integraciju ako ikako mogu
Staro 15.07.2008., 11:17   #9
domy_os
domy_os's Avatar
Postovi: 18,847
Da ne skidam sad drivere, pogledaj je li imaš kakav folder u kojem je datoteka TXTSETUP.OEM zajedno s još par drugih datoteka. Naziv foldera bi trebao biti po Windowsima - winxp, xpx86 i slično. Ako imaš tako nešto, sadržaj tog foldera stavi na disketu ili učitaj u nLite.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 15.07.2008., 12:28   #10
sinke01
sinke01's Avatar
Lokacija: zgb
Postovi: 55
kreirao sam disketu. instalacija počne, nakon F6 me traži disketu, ubacim je, on je iskopira pa kaže da i dalje ne prepoznaje HDD. zbilja neznam kaj da radim. iz ovog proizlazi da ni integracija sa nLiteom nebi prošla, jer vjerojatno taj SATA driver od matične ne radi, a neznam koji drugi da stavim. :-(
Staro 15.07.2008., 14:03   #11
sinke01
sinke01's Avatar
Lokacija: zgb
Postovi: 55
sad sam u BIOS-u prebacio iz RAID-a u IDE. Instalacija je počela, bez diskete sa SATA driverom. Ako ću kasnije htjeti vratiti na RAID, hoću li morati naknadno instalirati SATA drivere???
Staro 15.07.2008., 14:27   #12
domy_os
domy_os's Avatar
Postovi: 18,847
Nećeš moći naknadno, trebao bi prilikom instalacije...
Staro 15.07.2008., 15:02   #13
sinke01
sinke01's Avatar
Lokacija: zgb
Postovi: 55
misliš da sam svejedno trebao putem F6 instalirat drivere s diskete?? iako sam stavio na IDE??
Staro 15.07.2008., 15:27   #14
Postovi: 33,942
Razliku između SATA i IDE ionako nećeš primjetiti u svakodnevnom radu pa se ne zamaraj time previše.
Staro 15.07.2008., 15:45   #15
domy_os
domy_os's Avatar
Postovi: 18,847
Za RAID ih moraš integrirati pa onda po potrebi prebaciš na RAID, a za običan IDE (pod uvjetom da nećeš prelaziti na RAID) ti ne trebaju.
Staro 16.07.2008., 12:55   #16
sinke01
sinke01's Avatar
Lokacija: zgb
Postovi: 55
Instalacija je gotova. zasad sve radi kako treba. Jedino mi je CD od matične zadavao probleme, tj. sporo je reagirao, i nisam sa njega uspio instalirat AGP on-board driver, nadam se da ću moći bez njega. Skinuo sam taj driver s neta, al ni on se nije dao instalirat. U prvih sat vremena rada na kompu mi je stand by ikona bila onemogućena, a onda proradila, neznam zašto.
@ Coconut
Imaš pravo, razlika između RAID-a i IDE se ne primječuje, tak da ne planiram to mijenjat.
Hvala svima na pomoći.
