Postovi: 310
ATI RADEON HD 3870 - Links - Akcija - 799kn!
ZAGREB 26.06.2008. u 16:37 sati SUBOTNJA AKCIJA - 28.06 .2008. Sliku u thumbs AKCIJA: VGA PCI-E GECUBE ATI RADEON HD 3870, 512MB DDR3, DVI, HDTV Cijena za gotovinu/maestro/visa electron 799,00 kn * Design based on ATI Radeon HD3870 series. (RV670XT) * On-board with 512MB GDDR3 high speed memory. * Unified Superscalar Shader Architecture built-in 320 stream processing units. * Built-in HDMI support for HD video with multi-channel (5.1) AC3 support, enabling a plug-and-play cable-less audio solution. * Hardware processing UVD (unviversal Video Decoder) delivers sharp images and vibrant color fidelity with 1080p playback of Blu-ray and HD DVDs. * Dual DVI display port supports resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI, HDCP). * ATI CrossFireX™ multi-GPU technology support (A complete ATI CrossFireX system includes ATI Radeon Graphics, an AMD 790FX or AMD 790X Chipset, ATI CrossFireX Certified memory and an ATI CrossFireX Certified power supply.) * High-Speed 128 bit HDR (High Dynamic Range) rendering * ATI Avivo HD technology includes fully integrated HD audio capabilities and supports playback of multi-channel (5.1) audio streams. * Windows Vista with comprehensive DirectX® 10.1 support. * Shader Model 4.1 Evo... Pa ako netko misli o novoj jefitnijoj grafi, mislim da je ovo OK izbor... ![]() |
64VT klon
Lokacija: ZGž
Postovi: 464
Zna li netko iz iskustva( ne nagađati) kakve su moguće razlike između krosfajra DDR4+DDR3 i 2xDDR4 ? Baš bi ljepo nasjela još jedna 3870 a aovo je jeftino a novo, samo me brine taj ddr3 |
Lokacija: Zagreb,Dubrava
Postovi: 2,281
http://www.xtremesystems.org/forums/...d.php?t=180386 Prema ovom nebi trebalo biti nikakvih problema ipak imaju isti gpu. |
Flajing super šiiiip
Lokacija: Zd -- Zg
Postovi: 1,709
Razlike u performansama nisu neke znacajne, ddr4 je po taktu brzi ali ima losije latencije tako da nije to nesto oko cega treba razbijati glavu ![]()
5.1.4 setup: Zvučnici - 2x Arendal 1723 S monitors, 1x 1723 S center, 4x 1961 height, 2x 1961 surround, XTZ 12.17 EDGE Amps - Marantz Cinema 40 + ROTEL RMB-1585 |
Can You Hear Me? 142.8 dB
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
pa zar nije oduvijek bilo bolje prodati staru i nadoplatiti pa kupit jednu novu? u usporedbi sa kupovinom još jedne stare. (a često je i jeftinije) u ovom slučaju: 800+800 = 1600kn = 2x 3870 a jedna nova 4870 je oko? (ako su novcate 4850 oko 1200kn) SLI i Crossfire mi više miriše na to da iz dve nove grafe izvučeš maksimum maksimuma i budeš 'glavni', a ne iz starijih, pošto obično 1 nova grafa troše manje struje od dvije stare, i daje bolje performanse.. možda brijem krivo, ali tako mi se čini da sam viđao tu na forumu rezultate.... a i netko je napisao na forumu kada spoji crossfire, ne može koristiti 2 monitora, kao što možeš normalno sa 1 karticom pa je i to jedna prednost 'single card' setupa(uz one gore navedene) potražit ću pa paste-am ako iskopam
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() |
#7 | |
Postovi: 616
Crossfire 2x hd3870 definitivno bolje gura igre na vecim rezolucijama od hd4850 - doduse driveri su tu ogranicavajuci faktor obicno. Mogu mozda drugacije govoriti prvi "reportovi" s neta, ali pri takvim rezolucijama (1920x1200 i vishe) 2 kartice bolje guraju od jedne, a hd4850 nije neka revolucija naspram starije serije, vec super omjer ulozeno/dobiveno. Tako da ako ide mjenjati postojecu 3870 za 4850 umjesto josh jedne da doda u crossfire (ako vec ima takvu plocu, nisam gledao), nedobiva skorom nista. a razlika izmedju ddr3 i ddr4 u crossfire je samo u teoriji - naime u praksi u performansama razlike nema, a jedino je prisutna u tome da ddr4-tki mozes vishe overclockirat memu, na vishe taktove ali to se ne izrazi valjda ni u jednom fps-u. I za kraj bih htio reci da bi se hd3870 rabljene trebale uskoro prodavat i po 600 kn, pa go for it. |
64VT klon
Lokacija: ZGž
Postovi: 464
E pa zato sam i mislio, jer za ovu grafiku dobim max 750kn, a 3870 ću uzet kad krenu po 600kn, fala. A za monitor ni problem, jer jedini monitor u koji gledam je ovih 42" ![]() |
