Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Staro 15.05.2008., 01:18   #1
jurbAs
jurbAs's Avatar
Postovi: 2,583
Razlika u gamingu sa 4gb u odnosu na 2gb rama
evo nesto sto bi moglo mnogima objasnit situaciju da se NE ISPLATI IMAT 4GB RAMA pogotovo za igre
LINK
Staro 15.05.2008., 01:43   #2
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Normalno da u FPS nema tolke razlike, al u loadanju ima...
Something else that we noted while running the benchmarks is that game loading times were also significantly enhanced by installing 4GB of system memory. While that was not the focus of this article (framerates was) we noted that Crysis v1.21 loaded 54.1% faster (14.28s versus 22.00s) on the initial level load. After the level was loaded and then restarted (as if one died and started over) the load times were within a hundredth of a second. Obviously, having more memory will also help other areas and at the end of the day it helps performance. If you're going to be building a new gaming PC then by all means use 4GB as it does help performance, but don't expect a night and day difference in the gaming benchmarks.
Poanta je: ak se pališ na loadanje, uzmi 4GB ultra super brze jake debelo skupe kekse.
Staro 15.05.2008., 02:27   #3
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor jurbAs Pregled postova
LINK
Uff kad se sjetim FarCrya i 512 vs 1 GB....
Što se mene tiče prelazim na 4FB, jer Vista + procesi i igra dosta deru!
Staro 15.05.2008., 06:19   #4
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Vista + Igranje - IMHO 3GB je već dosta, 2gb i nije baš, gladao sam kod sebe i znam 100% da je tako...
Sad 4GB je stvar ukusa (za sad) ali s obzirom na cjene skoro da je svejdno uzeo neko 3GB ili 4GB pa niti nema razloga da si ne uzme...
Have a nice day...
Staro 15.05.2008., 09:40   #5
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,545
mislim da cu i ja sebi dodati jos 2 GB jer vista stvarno popapa memorije... za klokanje memorije mi ionak nije toliko bitno necu je dizat prek 850 mhz(s tim da je single memorija ,ne radi u dual channelu)
Staro 15.05.2008., 10:06   #6
Matt
Matt's Avatar
Lokacija: Zabok
Postovi: 1,622
Nedavno sam kupio još dva keksića, pa sad ima 4gb. Nisam primjetio znatno poboljšanje u performansama kompa što sam iskreno očekivao. No dobro, C: particija mi je full puna (kad sam instalirao programe na nju ), uglavno oba harda su na nekih 90%, pa vjerojatno i zbog toga nije nešto primjetljiviji pomak. Al kad sam instalirao SP3, stvari su se pomaknule na bolje. Brže bootanje, otvaranje aplikacija i sl.
Svi elektronički uređaji rade na bijeli dim!
Kad dim izađe uređaj više ne radi!!!
Matt je offline   Reply With Quote
Staro 15.05.2008., 10:13   #7
Razer
Razer's Avatar
Postovi: 11,642
Autor Ice Demon Pregled postova
Kao ti, jel
Staro 15.05.2008., 10:16   #8
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
busted
timmy je offline   Reply With Quote
Staro 15.05.2008., 10:16   #9
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor Razer Pregled postova
Kao ti, jel
Kak si znao?
Jel mi zamjeraš iz dna duše što sam jako nestrpljiv dok mi se loada igra?
Staro 15.05.2008., 10:19   #10
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
ohoho, ice demon se pali na loadanje igara,, jbt sta je to RAMseksualac
EDIT:
da ne kazete da moja je moja tvrdnja bez dokaza:
Briga me što je tebi bacanje love u vjetar, kad tu brzinu osjetim. Baci me u ludnicu, gdje god hoćeš i radi mi šta god hoćeš kad je ja u loadanju svih programa (malo teže u programima koliko u igrama) osjetim.
Zadnje izmijenjeno od: timmy. 15.05.2008. u 10:34.
Staro 15.05.2008., 10:22   #11
Razer
Razer's Avatar
Postovi: 11,642
Čini se da je tako
Evo sam za Ice Trola, par golih Ballistix sličica
Pictures Courtesy Of MP950
I da, kako napreduje review
@timmy_75
Zadnje izmijenjeno od: Razer. 15.05.2008. u 10:40.
Staro 15.05.2008., 10:24   #12
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Hvala Razer, ide u posebnu arhivu...
Staro 15.05.2008., 11:21   #13
Roberto
Roberto's Avatar
Postovi: 2,636
Da, razlike u gamingu uglavnom nema, barem ne značajne.
Što se isplativosti tiče, tu je već druga priča, sve ovisi o OS-u i programima koji se koriste jer ih ima koji znaju bolje iskoristiti veću količinu rama.
ja sam uvijek za više meme negoli za bržu memu.
kad moram birati između 2 gige brzog i clockabilnog ballistixa i 4 gige renditiona, ja sam za rendition, pogotovo jer je riječ o otprilike istoj cijeni.
Staro 15.05.2008., 11:40   #14
jurbAs
jurbAs's Avatar
Postovi: 2,583
E da vista shit jedna stvarcica imas 4GB ona se naseli gotovo an 2gb why hehe jer voliii rameee eto
Staro 15.05.2008., 11:47   #15
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
alkohol? nhf salim se, ali post izgleda ko da je pisan pod utjecajem neceg.
Staro 15.05.2008., 11:55   #16
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor timmy75 Pregled postova
Barem je upotrebljavao velka slova...
Staro 15.05.2008., 11:58   #17
yedwy
yedwy's Avatar
Postovi: 6,956
Voli i DX10 za razliku od nekih zastarjelih OSova...
Have a nice day...
Staro 15.05.2008., 12:19   #18
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
hmmm, ice demon...
jedno slovo, dva slova, tri slova....
izgleda da demonko isto upotrebljava nekakve supstanace, jer koliko ja vidim koristio je jedno veliko slovo i to početno, a moj post je bio u šali...
tvoj problem ako ne znaš brojati do 2, ajoj... ...da... sad sam se sjetio, ti znaš brojati samo do 1,45 i onda ne bootaš dalje...sry ice demon
Staro 15.05.2008., 12:20   #19
WeD@
Space Cadet
WeD@'s Avatar
Lokacija: Split<-->Vela Luka
Postovi: 592
neznam jeli ja to krivo kontam, ili stvarno treba citat reviewe na internetu, ali evo odat cu vam tajnu kako provjerit koliko vam treba rama, a to je da pritisnete zajedno ctrl+alt+del, dok igrate neku zahtvjevnu igru ili koristite druge korisne programe zbogh kojih ste kupili c2d i provjerite koliko imate slobodnog rama, ukoliko je zauzeto vise rama nego sto imate , morate kupit jos rama. Nadam se da su vam sad stvari jasnije.
e4300@3.2, 965p-ds3 rev 3.3, (kingmax 667 ddr2 1gb)x2
9600gso 768mb, 1tb wd, 500gb wd, sb live!
fortron 500w
WeD@ je offline   Reply With Quote
Staro 15.05.2008., 12:29   #20
žile
žile's Avatar
Postovi: 3,074
Kladim se da bi famozni Crysis radio daleko bolje sa 4gb.Makar bi se eliminirali dropovi kada odjednom dobiješ 5 fps-a,što povezujem sa učitavanjem novog dijela mape.Neke manje zahtjevne igre vjerujem da nebi profitirale (makar ne u toj mjeri). Probao sam CoD4 igrat sa 1gb,samoubojstvo,komp iz siga nije prelazilo 25fps.
Za vistu definitivno 2gb nije dovoljno.Odmah čim se upali zauzeće je preko 50%,što kada igraš značajno naraste.Sad razliku među 3 ili 4 neznam,ali više je bolje
žile je offline   Reply With Quote
Staro 15.05.2008., 12:37   #21
Bravo
Bravo's Avatar
Postovi: 1,450
Što više rama imaš, sve ždere više tak da 4gb obavezno ak si na visti, a i cijena je danas jako pristupaćna.
Staro 15.05.2008., 12:47   #22
jurbAs
jurbAs's Avatar
Postovi: 2,583
Sorry na gornjem postu zurio se na kavu sa legom hehehehe nije alcohol samo gladna godina
ovaj imao sam 4gb i neke vece razlike u performansama nisam osjetio kod igara po pitanju ucitavanja jedina bitnija razlika je bila kod COH.a drugdje nista posebno a to dok cekam da mi se digne igra nije strasno...
vista mi je popala 2gb u startu dobro imao sam ogroman sidebar i to je trosilo 500mb rama tako da... a sad 4gb se teze oc.a i sve al dobro nije to lose za imat.. ali x64 bitna vista je zajeb... dva program files.a i tak...
Staro 15.05.2008., 12:48   #23
Darude
DJ_Darude kicks ass...
Darude's Avatar
Lokacija: Virovitica
Postovi: 213
kolko danas koštaju keksi... ne vidim razloga ne preći na 4gb
a i bolje radi Vista
..:: Vlak je uvijek brži ::..
Darude je offline   Reply With Quote
Staro 15.05.2008., 13:01   #24
bullseye
Postovi: 122
stavili mi u novu konfu 2*1 GB Kingmax 667 keksa.. Samo jedan je bio Single sided a drugi dual.. Sad idem to zamijenit jer se stalno rusi ... Dal da uzmem mozda 2*2GB 800 kekse? Vista + gaming :-)
bullseye je offline   Reply With Quote
Staro 15.05.2008., 13:03   #25
yedwy
yedwy's Avatar
Postovi: 6,956
Meni je osobno draže imati (pre)dovoljno malko sporijeg rama nego nedovoljno malko bržeg...
Have a nice day...
Staro 15.05.2008., 13:03   #26
Bravo
Bravo's Avatar
Postovi: 1,450
@bullseye
uzmi 2x2gb,ak imaš 64x vistu.
Staro 15.05.2008., 13:12   #27
bullseye
Postovi: 122
Autor Bravo Pregled postova
@bullseye
32 bitna za sada..... znaci da idem na 2*2 gb 899 kingmaxa?
Staro 15.05.2008., 14:42   #28
Rux
Rux's Avatar
Lokacija: Bosnia
Postovi: 358
ja ne znam ali izgleda da sam nekakve lude srece... dobio sam 2x2 kingmax ddr2 800 (Kingmax KLDE88F-B8KB5)) ... i rade bez problema na 948mhz @ 2.05V sa svim mogucim testovima i nije pokazalo ni jedan error niti se resetovao !
probao sam 960 sa 2.1V i radilo je par dana ali mi se samo jednom resetovao dok sam obrađivao jedan video tako da sam ga vratio na 948mhz @ 2.05 CL5 ... a CL4 nece ni da cuje
sto se tice prepoznavanja rama u 32bitnom sistemu, od kako sam instalirao SP1 na vistu, sistem mi prepoznaje okrugla 4GB rama...
XVG Verge
Zadnje izmijenjeno od: Rux. 15.05.2008. u 16:39.
Rux je offline   Reply With Quote
Staro 15.05.2008., 15:36   #29
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor Rux Pregled postova
da ali ne koristi sva 4 GB
link
DeadMan+ je offline   Reply With Quote
Staro 15.05.2008., 16:21   #30
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Autor Ice Demon se prosrao...
Ma kako mi je ovo samo promaklo, LoL.
Autor Ice Demon opet napaljen na keksice :)
Jos kad bi prodavali ES verzije keksica, ha? Jeo bi ih kako Petit Beurre
