Staro 09.05.2008., 22:50   #1
taip@n
Master of the VCR
taip@n's Avatar
Postovi: 340
Seagate ST3500320SV
Mjesto radnje: hgspot osijek
danas sam namjerio uletiti u jedan 500gb disk i u hgspotu dobijem ST3500320SV za 609,00 kuna, iako na cjeniku piše da ga nema... imali su valjda 4 komada.
ako sam dobro vidio, još nitko nije pisao o tom disku a budući da je malo specifičan, eto ja ću...
Enterprise-class reliability for 24x7 video surveillance applications, with >1 million hours MTBF and <1 percent AFR
Improved data transfer rates (read/write speeds) enabling higher-performance video recording
ATA-7 streaming commands optimize video streaming performance and integrity.
Reduced power consumption and heat generation allow surveillance systems to run cooler and last longer.
Capable of operating under drive case temperatures up to 75˚C
Enhanced caching capability—up to 32 MB—provides superior video recording quality.
Backed by the industry-leading Seagate 5-year limited warranty
i ljink: http://www.seagate.com/ww/v/index.js...&reqPage=Model
eto...
edit: e, da, temperatura je netom nakon formatiranja ...
♦ As i was going up the stair ♦ I met a man who wasn't there ♦ He wasn't there again today! ♦ I wish, I wish he'd stay away.♦
taip@n je offline   Reply With Quote
Staro 09.05.2008., 23:31   #2
Baja 001
Baja 001's Avatar
Postovi: 7,504
OK, disk ima dobro čitanje.
BTW svi spominju neki R1 i kupovanje po nižoj cjeni, može li mi neko objasnit kako to ide?
Staro 09.05.2008., 23:35   #3
taip@n
Master of the VCR
taip@n's Avatar
Postovi: 340
gotovinski račun za firmu, pa onda tražiš povrat pdveja... ako imaš firmu...
btw, zaboravih reći da je novi seagate tiši od wd5000aaks kad na testu krene ono seek roštiljanje, i da je cijelo vrijeme 2-3 stupnja hladniji...
Staro 09.05.2008., 23:38   #4
Buger
Postovi: 4,398
R1 ti je račun kojim kupuje firma. Dakle firma kupi neku komponentu na R1 račun, trgovine u kojoj kupuje isplati punu cijenu i onda na kraju godine dobiva povrat poreza (22% ili 18% ? ).
E sad ako ti želiš kupiti na R1 odeš kod nekoga poznanika koji ima firmu i on kupi na firmu i onda tebi pokloni disk
no ako dođe inspekcija mora pravdati kupljene artikle, npr. ako imaš cvjećarnu, normalno da nemožeš u godini dana naručiti 12 računala, 9800GTX, 19 diskova itd.
Staro 11.05.2008., 12:10   #5
Ivan_1
Lokacija: Duga Resa
Postovi: 823
jbt pa bolje onda to uzet nego disk sa istom oznakom osim sto je AS na kraju, taj je 599kn, ono..razlika u cijeni je strasna... no ipak pitanje je jeli to istina sto pise u specifikacijama..
Ivan_1 je offline   Reply With Quote
Staro 11.05.2008., 13:26   #6
domy_os
domy_os's Avatar
Postovi: 18,929
I ovaj kao i novi 320 GB modeli imaju preveliki RAT, nešto tu jako smrdi... Kad je u pitanju Seagate, zasad mi se najbolja kupnja čini model ST3500320AS, a od ostalih WD 640 GB.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 11.05.2008., 13:58   #7
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Buger Pregled postova
Znači praktički poznanik dam svotu za disk bez poreza, ako se nevaram.
Staro 11.05.2008., 14:02   #8
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,128
Da, a poznanik placa ful cifru sa PDV-om...
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 11.05.2008., 14:20   #9
Ivan_1
Lokacija: Duga Resa
Postovi: 823
Autor domy_os Pregled postova
"domy_os, the right answer."
ali zasto ne SV... why domy why!? bio sam uvjeren da mi je to konacana odluka s obzirom da za 10 kn vise dobim barem po specifikacijama bolji disk
Staro 11.05.2008., 15:42   #10
domy_os
domy_os's Avatar
Postovi: 18,929
Specifikacije kažu čemu zapravo služi taj disk - za video obradu ili sustave za video nadzor i to je to. Puno I/O operacija će ga priklati.
Staro 11.05.2008., 21:37   #11
taip@n
Master of the VCR
taip@n's Avatar
Postovi: 340
sori, al ovo nisam shvatio....
mislim, ono, ak je disk (tako bar piše!) namijenjen mulltiplim video streamovima i ima povećan cache kako bi to uspješno odradio, pa zar to nisu upravo i/o operacije....
OT: da me netko ne bi krivo shvatio, ja nisam od onih koji pate da je njihov komad hw najbolji na svijetu, nego me to jednostavno zanima.... jer sam mislio da je to to...
Staro 11.05.2008., 22:47   #12
Buger
Postovi: 4,398
ne, disk je bolji kod baratanja većim fileovima, a kod manjih glava mora brže šetati i to je ono što ovaj disk ne voli, a i ima veliki RAT...
Staro 11.05.2008., 23:35   #13
taip@n
Master of the VCR
taip@n's Avatar
Postovi: 340
aha... kužim... tnx
a ovo za rat sam primijetio..., da.....
