Staro 17.01.2009., 14:26   #1
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
Exclamation Router problem
Tu je stranica i guide kako da podesim ruter i radi se o tamo navedenom routeru ( http://www-uk.linksys.com/servlet/Sa...#versiondetail ), ali kada upisem u browser 192.168.0.1/advanced ili samo 192.168.0.1, on mi nista ne pronade ? Kako znaci da udem u router i namjestim postavke??
kiwwy je offline   Reply With Quote
Staro 17.01.2009., 14:38   #2
thopok
Lokacija: Splity
Postovi: 3,003
I am not able to access the Phone Adapter’s Web-based Utility Setup page.
User Guide
Staro 17.01.2009., 16:14   #3
zmikic
zmikic's Avatar
Postovi: 206
run --> cmd pa izvrsi ipconfig. sto ti pise pod default gateway?
odi na start --> run --> cmd pa izvrsi ipconfig. sto ti pise pod default gateway?
walk the talk
zmikic je offline   Reply With Quote
Staro 18.01.2009., 11:55   #4
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
U tom i je problem pise mi 0.0.0.0 a nemogu promjenit zato jer mi u properties od mreze pa pod Iv4 nema toga di bi trebo gateway upisat i onaj subnet mask i to?
Zadnje izmijenjeno od: kiwwy. 18.01.2009. u 15:34.
Staro 18.01.2009., 13:10   #5
zmikic
zmikic's Avatar
Postovi: 206
daj posalji sve sto ti ispise naredba ipconfig /all
walk the talk
Staro 18.01.2009., 15:29   #6
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Bruno>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Bruno-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
PPP adapter Broadband Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadband Connection
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 213.147.102.52(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
DNS Servers . . . . . . . . . . . : 213.147.96.3
213.147.96.4
NetBIOS over Tcpip. . . . . . . . : Disabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Intel(R) PRO/1000 PL Network Connection
Physical Address. . . . . . . . . : 00-19-D1-E1-3B-5F
DHCP Enabled. . . . . . . . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::f9d9:7aee:7a88:37e2%10(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.55.226(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 17:
Description . . . . . . . . . . . : isatap.{6001FF96-FEF8-4EC6-BE05-FF879F6AF
444}
Tunnel adapter Local Area Connection* 18:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter Local Area Connection* 19:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #3
IPv6 Address. . . . . . . . . . . : 2002:d593:6634::d593:6634(Preferred)
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
213.147.96.4
C:\Users\Bruno>
Staro 18.01.2009., 15:54   #7
Postovi: 23,547
Opet Vista sme * e, probaj isključit TCP/IP v6 i onda manualno podesit TCP/IP v4
Staro 18.01.2009., 16:05   #8
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
Problem je zato jer iako ja ukljucim ili iskljucim IPv6 opet pod IPv4 nemogu manualno namjestit gateway i ostalo evo slika:
Staro 18.01.2009., 16:14   #9
Cor
Cor's Avatar
Lokacija: HRVATSKA, Slavonski Brod
Postovi: 35
Uhh , pa moras postaviti rucno IP adresu svoje mrezne kartice preko koje se mislis zakaciti na router. Jer ocito ti je na router-u iskljucen DHCP. IP adresa tvog racunala recimo moze biti 192.168.0.10, jer ti racunalo mora biti u istom range-u IP adresa koju koristi router po default-u dakle u ranngu 192.168.0.2-254, 1 ti je vec zauzet za sam router. Kod postavki Primary DNS-a i Default Gataway-a upisujes 192.168.0.1
Nisam za EU. Globalizacija je navece zlo koje je do sada snaslo nas planet ! Na forumu sam da ako nekome mogu pomoci, a ne voditi sulude beskonacne rasprave tipa ciji je veci i tko je bolji tehnicar!
Cor je offline   Reply With Quote
Staro 18.01.2009., 17:22   #10
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
Autor Cor Pregled postova
Gdje da to postavim?? I kad stavim ip adresu 192.168.0.10 nece mi se uopce spojit na net kaze error !
Staro 18.01.2009., 21:49   #11
Cor
Cor's Avatar
Postovi: 35
Ocito koristis koliko vidim po ipconfig/all ispisu PPPoE konekciju kreiranu na racunalu. U tom slucaju kada postavis static IP LAN konekcije da bi pristupio routeru nemas vezu s internetom, dok ne vratis na prijasnje postavke. Najme dok koristis PPPoE konekciju na racunalu tvoj router ustvari ne radi kao router vec kao DSL modem, dokle god u routeru ne kreiras DSL vezu i prebacis da radi u router modu, sto znaci da ce se tvoj router vezati na internet a sva racunala prikljucenena bilo LAN ili WLAN vezom na njega ce automatski sva biti vezana istovremeno na internet bez bilo kakvog uspostavljana posebne veze na racunalima (za mene apsolutno puno bolja varijanta nego primitivno uspostavljanje veze preko PPPoE konekcije na samom racunalu, jer u tom slucaju imas router koji ustvari nista od svojih mogucnosti ne cini osim sto koristi DSL modem)
Dakle prvi korak ako mislis ista na routeru mjenjati da posavis svoju LAN vezu da mu mozes pristupiti preko web browser-a.
Evo ovdje naputka kako ces promjeniti svoj IP na static IP i ostale postavke mreze tu ces vidjeti i gdje mjenjas DNS i Gateway.
Osobno ne koristim Vistu i nemam ju na niti jedom svom racunalu instaliranu pa ti nazalost video clip s tocnim postupkom korak po korak ne mogu snimiti kako inace na poslu to profesionalno odradjujem kod supportiranja.
To configure a DNS client for static IP address
  1. Click Start, click Control Panel, and then click Classic View.
  2. Double-click Network and Sharing Center.
  3. In the Network and Sharing Center window, click Manage network connections.
  4. In the Network Connections window, right-click the connection that you want to manage, and then click Properties.
  5. Do one of the following:
    • To configure IP version 4 (IPv4) for the connection, perform the following steps:
      1. Click Internet Protocol Version 4 (TCP/IPv4), and then click Properties.
      2. Click Use the following IP address, and then type the connection’s IP address, subnet mask, and default gateway that are assigned by your network administrator in the respective boxes.
      3. In Preferred DNS server and Alternate DNS server, type the IP addresses of the DNS servers that are assigned by your network administrator.
    • To configure IP version 6 (IPv6) for the connection, perform the following steps:
      2. Click Use the following IPv6 address, and then type the connection’s IPv6 address, subnet prefix length, and default gateway that are assigned by your network administrator in the respective boxes.
  6. Click OK, and then click Close.
Staro 18.01.2009., 21:55   #12
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
      1. Click Use the following IP address, and then type the connection’s IP address, subnet mask, and default gateway that are assigned by your network administrator in the respective boxes.
I sad kod ovog djela meni ne pise
Subnet mask
Defaul getaway
to se vidi na slici iznad znaci problem je to kaj ja to nemogu upisat da mogu vec bi sredio !
Jel zna tko?
Staro 19.01.2009., 01:24   #13
zmikic
zmikic's Avatar
Postovi: 206
Za pocetak...vidim da si isao desnom tipkom misa na Broadband Connection. Tu neces naci Subnet Mask i Default Gateway.
Trebas ici na Local Area Network! Tu ces naci za upisati Subnet Mask i Default Gateway.
E sad mi reci...
Koji uredaj ti imas?? Prema ovome sto si postao
imas Phone Adaptor With Router, Model no SPA2102. Da li je to tocno?
Ako imas taj uredaj reci mi da li imas kabel spojen izmedu zutog porta od rutera i LAN porta od kompjutera?
Imas li sto spojeno na crveni port? Sto? Kamo ide drugi kraj kabla?
walk the talk
Staro 19.01.2009., 02:09   #14
darQ
I'm nightrider
darQ's Avatar
Lokacija: Bjelovar
Postovi: 718
Autor kiwwy Pregled postova
Subnet mask
Defaul getaway
Jel zna tko?
ajd čitaj malo što ti je čovjek napisao
vjerovatno si zato i kupio drugi router, zato što tipkaš ip adrese u konekciju s kojom se spajaš na net a ne u local area connection, i naravno da ti tak ne radi net
uglavnom, nemaš subnet i gateway jer ih cijelo vrijeme tražiš na krivom mjestu...
hjoooj, na poslu se svakodnevno susrećem s ovakvim "problemima"
dakle, pogle šta ti čoek napiso
start, control panel, network and internet, network and sharing centre, manage network connections (to ti je u izborniku s lijeve strane)...
i sad, ono bitno, ono što cijelo vrijeme radiš pogrešno, desni klik na
LOCAL AREA CONNECTION....
dakle, ne na onaj broadband pppoe, nego na...
ev još jednom, da slučajno ne kažeš da nisi dobro vidio
i još jednom
sad tu dvoklik na internet protocol ipv4 (ali pazi da ne makneš kvačicu, dakle, kvačica ostaje)
i upišeš one brojeve koje ti čovjek spomenuo...
i ak slučajno napišeš da opet nema gejtveja i sabnet maske...
ostavi se tog, zovi nekog lokalnog pc guru-a koji će ti to poklikat i spojit te na net prije neg ti stigneš popušit pljugu....
sorry...al morao sam
plug & pray
Lenovo L440
Intel iCore i7 4702MQ
16GB DDR3
Intel HD 4600 GPU
14-inch LED-backlit fHD IPS (1920 x 1080, 300 nit) matte display
Intel Wireless-N 7260, BlueTooth
Samsung 850PRO 1TB
Logitech M705
6cell baterija
Windows 10 Pro 64bit
Pošteni trgovci: 1, 2, 3, 4
darQ je offline   Reply With Quote
Staro 19.01.2009., 17:27   #15
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
Nista, zapravo hvala ti darQ jel inace nebih nikad shvatio , ali to opet ne radi mislim ja upisem to napokon tamo di treba i stisnem OK i onda izadem iz Local area connection propertisa i onda mi se ona kao restarta ali ovaj Broadbend connection ostane connectan i vise nemogu ni na net ni na msn ni na nista. Onda samo disconnect - connect napravim na Broadbend i onda sve ponovo radi ali kada napisem ipconfig/all sve je na starom Gateway je na 0.0.0.0 Subnet mask je na 255.255.255.0 kako sam ga postavio a ip je opet neki random. I ponovo kao i na pocetku nemogu uc u svoj router preko 192.168.1.1 kako bi morao. U cem je sad problem?
I da nisam kupio drugi router ovaj sam dobio s metronetom!!
Autor zmikic Pregled postova
U novom stanu sam i onda imam sve zice iz svih soba kroz zid. One sve vode u jednu rupu iznad vrata. Tamo su sve ukopcane u neki Konig adapter i onda zica od tog cjelog adaptera ide u taj linksys u Ethernet utor. Ako to sto pomaze da znate.
Staro 19.01.2009., 17:38   #16
zmikic
zmikic's Avatar
Postovi: 206
Odgovori mi na pitanja koja sam ti postavio
walk the talk
Staro 19.01.2009., 17:47   #17
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
Model je SPA2102
Ovo sve kaj sam reko je ukopcano u Ethernet!
U kompu mi je samo ukopcan onaj kabel od neta ?
Staro 19.01.2009., 18:04   #18
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
I jel pomaze to sta ?
Kad sam stavio sliku nisam mogao tekst napisat pa sam anknadno dopiso!
Staro 19.01.2009., 18:14   #19
zmikic
zmikic's Avatar
Postovi: 206
Daj spoji kabel u LAN port od svog racunala i u ethernet port od linksysa. pa probaj 192.168.0.1 u browseru.
EDIT:
Zasto je ovo pitanje? Kamo uopce ide drugi kraj kabela koji ti je spojen u komp?
walk the talk
Staro 19.01.2009., 18:21   #20
hylem
Postovi: 279
Probaj ovako ... upiši u Local Area Connection potrebne adrese i dns-eve. Broadbend konekciju nemoj koristiti, odnosno budi disconnected dok radiš cijeli ovaj postupak koji čitaš. Nakon upisanih brojeva u Localu, dupli klik na mozillu ili sto vec koristiš, pa unesi adresu routera i malo pričekaj da uđeš u konfigurator. Nakon postavljanja postavki u routeru i reboota istog trebao bi biti spojen i tek onda ce se ipconfig promjenjeniti.
hylem je offline   Reply With Quote
Staro 19.01.2009., 18:22   #21
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
Kabel koji mi je spojen u komp u jedini utor gdje stane ( valjda je LAN ) ide znaci prvo u taj adapter Konig koji omogucuje spajanje svi kompjutera u router, a poslje njega ( kroz njega ) u Ethernet utor na linksysu neznam kako da bolje objasnim!
EDIT: Evo slike ipconfiga s zgasenim broadbend connection i upisanim 192... u mozzili
Staro 19.01.2009., 18:39   #22
zmikic
zmikic's Avatar
Postovi: 206
Probaj u Internet Exploreru.
walk the talk
Staro 19.01.2009., 18:43   #23
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
Opet nista tata mi radi nes na kompu pa kad zavrsi cu probat ukopcat u LAN pa onda 192... kad probam javim.
Staro 19.01.2009., 18:46   #24
hylem
Postovi: 279
Neznam do čega je, zovi službu za korisnike i žali se da nemožeš konfigurirati router, pa nek te vode korak po korak.
Staro 19.01.2009., 19:41   #25
Cele303
Cele303's Avatar
Postovi: 337
Prvo se sam sa sobom dogovori da li je router 192.168.0.1 ili 192.168.1.1? Pišeš jedno na početku a drugo pri kraju ovog topica...
Ako je router 192.168.0.1 onda ip adresa mora biti minimalno 192.168.0.2, a ako je router 192.168.1.1 onda je ip adresa 192.168.1.2
Ti si stavio 33 na ss-u, znači 192.168.0.33 bi trebalo raditi u kombinaciji sa 192.168.0.1 za gateway i dns (dns-u možeš ostavit i ove vanjske ip adrese od metroneta)
Kad promjeniš postavke otvori cmd i upiši ping 192.168.0.1, ako ima reply otvori firefox i upiši 192.168.0.1 i dalje se logiraš pa što već želiš promijeniti...
Zadnje izmijenjeno od: Cele303. 20.01.2009. u 02:08. Razlog: tipfeler
Cele303 je offline   Reply With Quote
Staro 19.01.2009., 20:00   #26
zmikic
zmikic's Avatar
Postovi: 206
PA u ovoj zadnjoj slici se vidi da je ruter 192.168.1.1.
Vjerovatno kad sa PPoE netko pristupi ruteru on ne moze u browseru ucitati 192.168.1.1
EDIT: brijes da je on sam upisao gateway...a moze bit
walk the talk
Staro 19.01.2009., 20:00   #27
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
Evo ipak bi trebalo ici 192.168.0.1 ali kada to stavim isto na radi
Kada sad upisem dok sam connectan na broadbnd connection ping 192.168.0.33 dobim ovo
Pinging 192.168.0.33 with 32 bytes of data:
Reply from 192.168.0.33: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.0.33:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Pod ipconfig/all pod local area connection pise sve kak sam stavio ali pod broadbend opet pise gateway 0.0.0.0 i neki drugi ip.
Mislim da se nece nis promjenit ako ukopcam u lan ali probat cu poslje kad cu moc ( u user guidu pise da se connecta u ethernet )
Staro 19.01.2009., 20:13   #28
zmikic
zmikic's Avatar
Postovi: 206
A zasto uopce zelis pristupiti ruteru? sto bi mjenjao?...ovako kako si poceo, nest ces jos shebat.
walk the talk
Staro 19.01.2009., 20:21   #29
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
Htio sam postavit static ip.
Staro 19.01.2009., 20:39   #30
zmikic
zmikic's Avatar
Postovi: 206
hmhm...zelis imati static ip kad si na internetu? zasto?
walk the talk
