Staro 23.11.2008., 23:37   #181
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
probao, meni radi ali cini se da to grafa uopce ne detektira kao 3d ili koji vec k jer je vent ostao na defaultu i zagrijala se u 3PM dok si rekao keks.
i da, nije donut niti dlakavo nego ovo
da, gpu mem test mi javlja toliko errora da bi ocekvao da mi graficka uopce ne radi. Nadam se da je rijec o beta problemima jer tesko bi spavao uza sve te errore koje ne mogu reklamirati jer grafa radi potpuno ispravno
Staro 23.11.2008., 23:45   #182
LUXX
Vodenjak :)
LUXX's Avatar
Lokacija: Križevci
Postovi: 667
Zanimljivo.
Na xp-u mi nije radio taj test.
Na visti 64bit radi.
Diglo takt grafi i sve radi kak treba kao da pokrenem furmark
LUXX je offline   Reply With Quote
Staro 24.11.2008., 20:52   #183
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
OCCTPT3.0.0.b06
Changelog :
* GPU temp properly recognized and saved
* 64 bits OS detected automatically : if 32 bits : no 64 bits mode (obviously), if 64 bits : 64 bits Linpack & Power supply test by default
* Computers with more than 2GB of memory are now properly recognized with Linpack and Power supply tests - couldn't test with vista64 though
* Adding/removing temps doesn't reset other lines in the monitoring panel
* Custom Sensor 2 name for Voltages is properly saved/loaded.
* Default res is now 1024x768
Need a Gigabyte latest BIOS?
GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz
G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2)
G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1)
Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD,
Corsair Hydro-H50 (MX-2)
Gigabyte Superb 720W,Windows 7 SP1
stasio je offline   Reply With Quote
Staro 25.11.2008., 02:06   #184
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
OCCT 3.0.0 beta 7
Changelog :
* The power supply test now works with Vista64
Zadnje izmijenjeno od: stasio. 26.11.2008. u 05:18.
Staro 25.11.2008., 09:03   #185
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
Meni zadnja verzija radi sve osim GPU memtesta, ali ljudi moji što ovo zagrijava grafičku LOL
Do sada mi još nije prešla 70°c al na ovom čudu ode na 85°c pa i više, hebesh ti PCS+ i zerotherm, brijem da večeras gore ide dobri stari S1+ 2X120 scythe slipstream.
Doduše zerotherm mi je lockan na nekih 20-30% vrtnje i neželi se brže zavrtit al neda mi se zezat sa servisom, tek sam piknu grafu u komp, prelijen sam opet ostajat bez nje
D-I-A-B-L-O je offline   Reply With Quote
Staro 28.11.2008., 10:03   #186
Tetedeiench
Lokacija: Lille, France
Postovi: 44
Hey guys, long time no see
I came here to warn you about the new beta, but it seems somebody else already did Thanks stasio !
I have to warn you about one thing though (the new version will include a HUGE warning of some sorts) : the power supply test is HARDCORE and could very well mean the death of your power supply.
Tests shows that OCCT Power supply demands 20% to 30% more power than Crysis or 3dmark on dual-cores... and 50% more on quad-cores !
So be warned if you've got a no-name power supply (or "cheap" brands such as LC Power, heden), as OCCT already killed a few of those (they sported a 550W label, they didn't take the test with a dual-core and a HD4850 or such graphic cards). Be warned !
Oh, and there's still something missing with the current version : there're no profile for OCCT GPU at the moment. That means SLI people have to create it manually. Next version should be able to create it automatically for Nvidia, and i have yet to get my hands on an ATI card to get a look into it.
Have fun boys, and thanks for your support !
Tetedeiench je offline   Reply With Quote
Staro 28.11.2008., 16:03   #187
Razer
Razer's Avatar
Postovi: 11,642
Great job Tetedeiench, looking forward to the final version
Staro 29.11.2008., 00:21   #188
Tetedeiench
Postovi: 44
I want to burn stasio once at least
OCCT PT 3.0.0.b08 OUT !
Changelog :
  • The EXACT Linpack formula for Problem Size <-> Memory used has been found - OCCT Exclusive ! (This caused "no CPU Usage" bugs on this test under Vista)
  • OCCT GPU does not force the resolution anymore - It can be run in window, fullscreen mode,...
  • OCCT GPU in "error detection" mode now is now multithreaded - the checking algorithm will exec on several CPUs
  • If your CPUs cannot check that many frames per second, OCCT GPU will now adapt dynamically its speed, instead of "just at the beginning".
  • CPU Usage is now correctly calculated (it was minored in some cases (Linpack mostly)
  • CPU Usage in Power Supply mode is now the sum of the CPU Usage of both tests (Linpack and GPU3D, not just Linpack)
  • The display is only refreshed once per second, instead of once per 1/4s.
  • The Linpack default mode is now Max stress instead of Mid.
Enjoy !
http://www.ocbase.com/download.php?fileext=beta
Staro 29.11.2008., 14:27   #189
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Keep up the good work
Staro 05.12.2008., 17:53   #190
D-I-A-B-L-O
Bannija :D
Lokacija: Sisak
Postovi: 1,098
Nego imam pitanjce.
Pomoću čega ova zadnja verzija occt-a mjeri temp procesora?
Naim NAPOKON sam uspio iskemijat i probit barijeru od 2.9GHz na svom procu, i sad je trenutno bio testiran na 3.0GHz, s tim što me nakon 10 minuta baca van i u logu mi ispiše da je cpu too hot.
Temparatura mi dođe do nekih 56-57 i neide dalje, u occt-u je nariktan shutdown na 80, kako je on doša do te temparature ako ja imam 20 i kusur supnjeva manje??
Komp nije nestabilan, malo sam sad probavao grid i fallout3, sve radi normalno, čak imam i pokoji fps više, ali muči me to.
Temparature pratim sa smartguardianom (inače dfi-jev alat, ali ova ploča je rebrandirani dfi,čak ima i lanparty oznaku na sebi) i pcwizardom i oboje pokazuju identično, u occt-u sam poštelao da mi sa tih istih senzora prikazuje cpu temp.
Probao bih ići dalje sa dizanjem, a neznam šta da radim, neznam jel bi bilo pametno povisit limit u occt-u pa ručno nadgledat temparature preko pcwizarda i guardiana, cooler je zalman cnps 9500, tako da mislim da se nebi smio moći pregirjat obzirom da su voltaže nedirnute.
Testirao sam normalno i linpack modom.
Staro 10.12.2008., 19:36   #191
Vuco
Vuco's Avatar
Postovi: 9,505
OCCT PT 3.0.0.b10 OUT !
Changelog :
* Linpack test has been updated, and is now much harder on core i7s.
* DirectX 9 version is detected and if not recent enough, the tab is disabled and you've got an error message
* Cuda is detected the same way (but incomplete, as it reports OK on GeForce 7s, and yu need GeForce 8 or more to run it).
* OCCT won't enter the crazy mode anymore if you click the on and off buttons ni a loop
* Core number detection improved (but there's still a bug going on there, sometimes OCCT detects only 3 cores out of 4, 1 instead of 2...)
* Graph size option has disappeared (unused)
* A new option has appeared "Generate graphs", checked by default. Guess what it does if unchecked... it won't generate graphs !
* Due to a few power supply deaths, the Power Supply test bears a warning the first time you click on it.
* The GPU test now works in fullscreen mode with ATI crossfire cards, and the window can be moved to another screen without crashing
* The window position is now saved and restored upon startup.
* The aboutbox now has the correct design
* The bottom of the main form now has the right design (shape, size, color).
http://www.ocbase.com/OpenBeta/OCCTPT3.0.0.b10.zip
@ Diablo
Pa trebalo bi mjeriti sa onime što si odabrao.
Staro 12.12.2008., 07:13   #192
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Mozete skinuti samo beta 08.
Ima nekih problema sa beta 09 i 10.
Staro 12.12.2008., 07:39   #193
D-I-A-B-L-O
Bannija :D
Lokacija: Sisak
Postovi: 1,098
Autor Vuco Pregled postova
@ Diablo
Heh,znam i ja da bi trebao, ali iz nekog razloga mi na temp. 20'C nižoj od one koju prikazuje prekida test zbog navodno previsoke temparature proca.
Probat ću danas popodne skinut zadnju verziju pa da vidim hoće li se i na njoj dešavat isto.
Staro 13.12.2008., 17:08   #194
Vuco
Vuco's Avatar
Postovi: 9,505
Beta 12 Download
Changelog :
* Several graphical glitches were fixed
* the Linpack test is now working again
* The OCCT test has been updated - check it out
* the GPU test now correctly works on Crossfire configurations and SLI config too (SLI needs a profile)
* A few warnings were changed (just made more explicit, really)
Staro 15.12.2008., 00:28   #195
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
OCCT 3.0.0.beta 14
* The linpack test now works with 32 bits OS with more than 2GB of Memory
* OCCT's way of remembering window position as been changed for some people for which it didn't worked
Staro 16.12.2008., 15:05   #196
Tetedeiench
Postovi: 44
Happy to see that everything is still posted to this board.
I hope i'll be able to reach stable stage by the end of this year, but due to necessary translation delays, i probably won't
Stay tuned though
Staro 23.12.2008., 05:18   #197
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
OCCT 3.0.0 beta 16
Changelog :
* The linpack test is now working again with XP32 with more than 2GB of memory
* the TAB key now works everywhere, and the order has been fixed
* The Temperature line is drawed in front of the CPU Usage line, in the graphs. This leads to better visibility of the graphs.
Staro 06.01.2009., 07:05   #198
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
OCCT 3.0.0 beta 17
Changelog :
* The OCCT Test is now executed in a separate process (this is done to open the way for the "one core not detected" bugfix).
* The OCCT GUI will now report on which core the error occured in the OCCT Test.
* The files "ThreadX.txt" aren't generated anymore (the previous point removes all need for them).
* The way translations are handled is now brand new and much, much more easy to update for me
* If the Linpack test refuses to start, OCCT will now lower the memory utilisation until a successfull start. You may see a small delay in launching the Linpack test, but it is usually less than a second in the worst case.
* The field showing the test duration is now always updated, depending on the test selected. Try to select "custom" and change the duration, you'll quickly see what i mean.
Staro 07.01.2009., 19:39   #199
hercegm
Lokacija: Metkovic
Postovi: 13
OCCT problem
Bok ekipa, evo testirao sam svoj clockani e8500 na 3,8ghz i kad sam ga testirao na OCCT nakon 45min javlja mi se ova poruka, dali je to vezano za moj komp ili za software.
Molim pomoć
Hvala!
http://www.imagesforme.com/show.php/...0107182906.png
hercegm je offline   Reply With Quote
Staro 08.01.2009., 21:37   #200
n4d44
n4d44's Avatar
Postovi: 259
Testiraj opet. Ali ovaj put ga ostavi malo dulje (nekoliko sati) . Ako se greška ponovi smanji overclock za 100mhz drugo ništa ne diraj i probaj opet.
n4d44 je offline   Reply With Quote
Staro 08.01.2009., 21:46   #201
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Ili nek proba neku stariju verziju...
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 08.01.2009., 22:09   #202
Vuco
Vuco's Avatar
Postovi: 9,505
Ili probaj sa npr. IntelBurnTestom koji isto koristi Linpack za testiranje CPU-a. Ovo ti može biti radi svega, od samog OCCT-a do Windowsa/proca.
Uostalom, n4d44 ti je dobro rekao. Smanji takt pa vidi jel će opet ili ne javiti taj error.
Staro 08.01.2009., 22:42   #203
Uber Gosu
FORD Fix Or Repair Daily
Uber Gosu's Avatar
Postovi: 872
Autor hercegm Pregled postova
Molim pomoć
Hvala!
kolko "smeca" imas instalirano gore nije ni cudo da ne radi.
Uber Gosu je offline   Reply With Quote
Staro 09.01.2009., 19:51   #204
hercegm
Lokacija: Metkovic
Postovi: 13
Hvala, radi sve perfektno, samo sam malo povecao voltazu procesoru.
Pozz
Staro 15.01.2009., 12:19   #205
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
OCCT 3.0.0 beta 22
Changelog :
* The OCCT Test now executes as a separate process
* The bug known as "-1 core detected" is gone
* Monitoring/system info engine updated
* Linpack 32 bits test now works with systems with more than 4GB of memory - max mem considered is 1.44GB (universal value)
* The power supply test now works everywhere as well
* GPU:Memtest has been GREATLY updated : 6 thorough tests have been implemented, and they are EXACTLY the same as Memtest86+. One pass is takes much, much longer though (i'd say about 10 minutes). But the efficiency is now much better. Remember, you need a geforce 8 or later cards.
Staro 30.01.2009., 05:13   #206
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
OCCT 3.0.0 Final
Changelog (Since 2.0.1) :
MAJOR FEATURES
* OCCT's main UI has been completly revamped
* Graphs now shows a 2nd line showing the CPU usage / FPS during the test.
* CPU usage is now instantaneous instead of an average since the start of the test
* OCCT now has 5 different tests. The descriptions are at the end of the changelog
USER INTERFACE
* Entirely revamped - now based on tabs, and completly modular
* Now has a small help module - just move your mouse around OCCT's window, you'll see
MONITORING
* The built-in engine has been updated - lots of new hardware are now supported
* Alot of bugs are fixed, included the famous "3 cores out of 4 detected"
GRAPHS
* Graphs now shows a second line showing the CPU usage/FPS during the test
* A legend explains everything
* The test configuration is now entirely present in the graph's subtitles
TESTS DESCRIPTION
CPU:OCCT
* The original, inherited from previous versions of OCCT
* Now Core i7 compatible
* Optimized
CPU:LINPACK
* The very same as IntelBurnTest, based on a test provided by Intel
* It will make your CPU hotter than never !
* 32 and 64 bits support
GPU:3D
* Home-made test written in Direct3d that will make your GPU really hot - this test is similar to ATITool and Furmark (thanks to Furmark and JegX for his support and for the aborted partnership )
* Will make your graphic card real hot - especially the GPU
* Has an error detection mode similar to ATITool
* SLI and Crossfire support (Just enable Fullscreen mode !)
GPU:Memtest
* Again, Home-made test written in CUDA that'll launch a MemTest86 or MemTest86+ like test on your Graphic card memory and report any error found
* Requires a Nvidia Graphic Card, and a GeForce 8 or Higher !
Power Supply
* Dedicated to power supplies - it'll launch GPU:3D and CPU:LINPACK at the same time to load your power supply. BEWARE, THIS TEST IS REALLY DEMANDING !
* WARNING, DO NOT USE THIS TEST WITH NO-NAME POWER SUPPLY, AS A FEW DEATHS HAVE ALREADY BEEN REPORTED !
* This tests demands 30 to 40% more power than crysis on a quad-core system with an SLI graphic system installed...
Staro 23.02.2009., 15:18   #207
kill
Datum registracije: Jun 2003
Postovi: 533
probam vrtit gpu test sa error control i valjda svaki frame izbaci error, a framerate padne sa 58 na 15ak.
normalno?
kill je offline   Reply With Quote
Staro 23.02.2009., 18:08   #208
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
OCCT 3.0.1
Changelog (Since 3.0.0) :
GPU:MEMTEST
* Now compatible with GeForce cards with more than 512MB under Vista (A Cuda bugs was encountered, but i found a workaround)
* Now 4 times faster (thanks to a switch to Cuda 2.1 which came with bugfixes in the SDK - new prerequisites though)
* The test cannot be run on GeForce 7 or lower anymore
MONITORING
* OCCT now saves monitoring sensor based on sensor names when available, not on position in a list. Thus, when a sensor disappear, OCCT configuration is preserved
* Engine has been updated - new CPU support,...
* the maximpum CPU temp can now be set at a temp higher than 99°C (before, it could be done, but it was reset upon reloading OCCT at 80°C)
TRANSLATION
* Arabic and Romanian support have been added
* Italian have been updated
OCCT REQUIREMENTS
* Up-to-date DirectX9 (Under Vista, DirectX 10 and 9 are updated separatly) for GPU:3D and Power Supply
* Nvidia Drivers 181.22 or later for GPU:MEMTEST (Now based on CUDA 2.1,as several critical bugs have been fixed in this release).
Staro 06.07.2009., 08:02   #209
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Update:
OCCT 3.1.0
Staro 05.11.2011., 00:53   #210
mis
Postovi: 60
Evo nakon duzeg vremana izasla je nova verzija occt
http://www.ocbase.com/perestroika_en/index.php?Download
Zadnje izmijenjeno od: mis. 05.11.2011. u 01:57.
mis je offline   Reply With Quote
