#1382 |
Lokacija: Rijeka / Grobnik
Postovi: 4,523
pogledaj u gpu-z sta ti pise. |
#1384 |
Postovi: 4,523
a onda si nesto limitiran ali opet na GPU OC/UV mozes nesto izvuci. edit: za one koje interesira MSI Radeon RX Vega 56 AIR BOOST 8G OC ima limeni backplate i spojen je na nekoliko mjesta sa komponentama "plastelinom". misljenje, dali mislite da bi poboljsalo malo hladenje uklanjanje backplate-a i stavljanje obicnih jezica na doticna mjesta? gdje to traziti bez da skidaju gace? kako se to fixira? ako ide nekakvo termalno ljepilo onda nista jer time gubim garu. |
#1386 | |
Lokacija: Stuttgart/Rijeka
Postovi: 414
#1387 | |
Postovi: 2,138
Osobno, kada bih vec isao na takav zahvat onda bi bome i hladnjak kompletan promjenio i metnuo gore arctica. Ovsko da ti ostane stock hladnjak, a da se jebeš sa ježicima nema baš smisla i onak samo s njima nebuš niš puno/osjetno dobio
#1388 |
Postovi: 4,523
to sam i mislio. stavljat morpheusa, ali necu jer je preskupo i gubim garu. nema smisla jednostavno zveknut jos 800-1000kn samo na hladenje i dobit mozda nesto malo, a izgubit garu. pustit cu ovak pa za 6mj razmislit dal prodat i uzet nesto drugo. |
#1389 | |
Postovi: 4,523
"Issue encountered by first version of FOCUS Plus was a reboot under load due to the fact that Vega platform, as well as some others high end cards are having huge spikes under load that are outside ATX specifications and lead PSU to shutdown. Based on the description of your issue, it's not related to this and your PSU is from 2019 based on your serial number. We would suggest to check this with your Vega as this GPU Series got also some issues with voltages and power delivery: set vsoc (memory) and vcore on the same voltage via wattman: 975 mV or eventually 1050 mV. On some forums, such issues fixed crashes encountered with Vega (and any PSU in general). If it's not helping fixing your issue, we would suggest to check your PSU in any other computer to see if you can replicate such issue. Also, if any O/C on your CPU or GPU, please remove it to see if it can solve your issue." |
#1390 |
Datum registracije: Mar 2017
Postovi: 403
Zanimljivo, čak su možda i u pravu Ma vega je culprit, sad vidi čega ćeš se riješit. Ako već nisi, undervoltaj pa testiraj, ali ljudima su se gasila i druga napajanja, ne samo focusi. Nekima se, kao i meni, samo rušilo, nikad ugasilo. To prilično svaljuje krivicu na grafe jer ovaj pali zaštitu, a tvoj je i ovogodišnji model.Kod mene je 590 uskočila umjesto 970 i ne moram spominjati power draw, pa ovaj fake focus riotoro od subote nije ugašen, kamo li da bi štucnuo, a dao sam im posla sad za vikend, go figure. Primjerice 970 bi se zrokala u cb15 tamo negdje kad auto izađe na ulicu ili čak malo prije. |
#1391 |
Postovi: 4,523
undervolto jesam, al ne nest pretjerano jer ocu max OC/UV .razmisljam opet da prebacim switch bios-a na onaj power save koji je kao otkljucan i flasham V64 bios pa vidim ako cu dobit sta na VRAM-u. bumo vidli. |
#1392 |
Postovi: 4,523
flash-o uspjesno v64 bios na moju v56. malo razocaran rezultatima. izgleda da nece preko 1050mhz HBM iako ima upumpano vise V. na toj freq i malo visim latencijama (nece na istim onim latencijama kao na default v56 biosu), jedva dotaknem rezultate/FPS-ove iz testova/bencheva od v56 biosa. zadnje stabilno na default v56 biosu: ![]() zadnje stabilno na v64 biosu: ![]() ak imate neki savjet sta jos probat dizat/spustat... za one koji neznaju, sa prckanjem po latencijama u amd tweak memory dobijete jako puno na perf tak da ko nije krenuo ja bi na vasem mjestu ;-). flash biosa v64 totlano nepotreban IMO, bar ak imate losu karticu kao sto je moja ocito. ovim testirate HBM prije jacih testova: https://github.com/kruzer/poclmembench ![]() |
#1393 |
Postovi: 2,138
Nisu ti ovo latencije za v64 samsung hbm, prezategnute su ti kolko sam brzinski vidio, zato i nemres iznad 1050. Sutra ujutro ti pošaljem def.latencije od v64 pa se igraj, ali da - sa mijenjanjem timminga mem. kod amd gcn ere gpu se može dosta izvući )
![]() Zadnje izmijenjeno od: Gigi1. 17.12.2019. u 19:45. |
#1396 |
Postovi: 4,523
@Eliovp "magic trick" is to disable p6 and p7 core state and stay on p5 core , p6 and p7 jump one soc clock step higher on some men frequency up to (1107soc) (example p7 core clock and p3 mem and your frequency is 830 hbm mem so your step is higher then 800soc so 847soc +"1 soc step" so you will get 900soc if you set p5 core you will get 847soc ) -->
- please explain this again , so yo usay on a 56 disable the p6 and p7 states on core then i can set higer memory than the 900 i seem to be capped at ? or you are saying by disabling those two the mem will automatically jump higer ? **edit*** @duck Hellen You are definitely on to something, I disabled the p6 an p7 states for my 4 card Hynix 56 rig and all of a sudden no more crashes or instability, power draw is also good 150 watts from the wall, I’m still at 1100/825mv and 900/825 " edit: i nisam siguran za ovu pricu oko tREF-a koji povecava perf. kao da se snjime visoko HBM pocne pregrijavat, al ja ga push-o vec do 28000 i jos se ne rusi, a temp HBM-a ne prelazi 63C sto mi se cini ok jer vidim da majnerima to zna ic do 90C bez problema. vidim da ga OnnA drzi na 25000, al neznam dali zbog stabilnosti ili temp. sve 5.
pazi, mozda sam nesto previdi, ali stvarno vec tjednima proucavam vega-u po netu i masu toga sam skuzio. imam hrpu biljeski vec. moja izgleda jednostavno nece preko 1050, stagod napravio. nije ni ovo lose, al mi je malo razocaravajuce jer sam ocekivo kad bumpam HBM sa 1,25 na 1,35 da ce mi pustit bar jos 100ak mhz gore, a ono sipak. mozda negdje grijesim. bumo vidli. u svakom slucaju gain u odnosu na default grafu/postavke je ogroman. stvarno je steta da ovakvu karticu salju takvu iz tvornice, toatalno neoptimiziranu. ovo je def gpu za ljude koji vole prckat, a ne za njubove koji zele ubost i igrat. na ovo sam naletil neki dan i nisam siguran jel tu ima nesto, meni se cini da ne, jer nisam primjetio nikakvu promjenu SOC-a kad disable-am p6/p7: " @Eliovp "magic trick" is to disable p6 and p7 core state and stay on p5 core , p6 and p7 jump one soc clock step higher on some men frequency up to (1107soc) (example p7 core clock and p3 mem and your frequency is 830 hbm mem so your step is higher then 800soc so 847soc +"1 soc step" so you will get 900soc if you set p5 core you will get 847soc ) - please explain this again , so yo usay on a 56 disable the p6 and p7 states on core then i can set higer memory than the 900 i seem to be capped at ? or you are saying by disabling those two the mem will automatically jump higer ? **edit*** @duck Hellen You are definitely on to something, I disabled the p6 an p7 states for my 4 card Hynix 56 rig and all of a sudden no more crashes or instability, power draw is also good 150 watts from the wall, I’m still at 1100/825mv and 900/825 " edit: i nisam siguran za ovu pricu oko tREF-a koji povecava perf. kao da se snjime visoko HBM pocne pregrijavat, al ja ga push-o vec do 28000 i jos se ne rusi, a temp HBM-a ne prelazi 63C sto mi se cini ok jer vidim da majnerima to zna ic do 90C bez problema. vidim da ga OnnA drzi na 25000, al neznam dali zbog stabilnosti ili temp. Zadnje izmijenjeno od: geronimo_2. 18.12.2019. u 08:41. |
#1398 |
Postovi: 4,523
dobro vjerovatno drzis fan na nekoj "normalnoj" brzini? ja ga uredno zveknem na 80% sto je ak se ne varam oko 4000rpm, odnosno polijetanje boinga 747 lol. al me to ne hebe kad testiram. u igri se nece toliko cut jer se nece toliko zagrijat jer koristim freesync + chill na 60-90fps. bar u GTA5 koji igram trenutno se ne cuje bas pretjerano odnosno ne smeta me. i to mi je temp u sobi sad po zimi 20-23C. po ljeti se bude vjervfatno previse grijalo jer mi bude 28-30C. |
#1400 |
Lokacija: ZAGREB-DUBRAVA
Postovi: 1,075
VEGA 8 pitanje
uzeo sam laptop LENOVO IdeaPad L340 81LY002RSC ,Ryzen 5 3500U 8GB,ddr4,256GB SSD Radeon RX Vega 8- 17, 3 FHD i u notebookcheck kaže da se mogu igrati igrice od Call of Duty Black Ops 4,Battlefield V ,Call of Duty WWII idr. a ja recimo ne mogu pokrenuti Call of Duty WWII niti na najnižim postavkama pa ako mi netko može pojasniti jer ima šanse da pokrenem te igrice ili ne Zadnje izmijenjeno od: robi64. 26.01.2023. u 16:15. |
#1403 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Skini s www.amd.com najnovije drivere, pa vidi hoce li pomoci. Trebao bi bez problema moci igrati bilo koju Call of Duty igru na tom laptopu, na low postavkama, samo rezoluciju podesi na 1280x720.
#1405 |
dr. sc. tech. dipl. ing.
Lokacija: Rijeka-Opatija
Postovi: 3,183
AMD FineWine ide dalje! Pogledajte kako je Vega56 sretna s Vulkan rendererom. Na kraju pregazila GTX1080 i to za dosta ![]() https://www.overclock3d.net/reviews/...aphics_cards/1
Pouzdan i pošten trgovac! (ima još puno novijih primjera, nisam ni pratio jel me još tko stavljao u temu.. slobodno pretražite novije postove na temi) StarCitizen refferal code: |
#1406 |
Datum registracije: Feb 2016
Postovi: 12
Imam Asus VivoBox 15 sa AMD Ryzen 7 3700U sa RX Vega 10. Mogu li se driveri preuzeti bez onoga AMD control software? |
#1408 |
Postovi: 2,138
Bilo mi dosadno pa sam odlucio vegulju u home pc-u počistit i osvježiti. Dao joj fresh term.pastu(13W/mK) i padove 12W/mK. 3 stupnja niže za gpu, 6 za hbm i 11 za vrm ![]() zavrtio 3dčmark, dobio dugotrajnije boost taktove na grafi u jednom trenu je grafulja otišla na 1700MHz ili ti teritorij vodene vege, zadnje sto se sjecam kad sam vrtio bench - graphics score bio oko 7k, sad je cca 10% viši https://www.3dmark.com/3dm/45992609
![]() Zadnje izmijenjeno od: Gigi1. 21.04.2020. u 09:18. |
#1410 |
Postovi: 4,523
stavil danas adrenalin 20.11.2 jer ocu RDR2 da zaigram. kakav uzas od izgleda control panela. kako godine idu sve gore i gore. fejzbukovski driveri . bitno da blešti i da se sjaji .nego jel vi koristiti anti lag ili je to BS na koji bolje ne gubit vrijeme na proucavanje jer meni ta opcija jos uvjek nije jasna? edit: i jel afektira FPS jer sam vidio negdje da se to spominje? edit: da sam sebi dam zakljucak lol: "works best when gaming in the 60 to 90 FPS range. in some games you will see a performance impact, in others you won’t" Zadnje izmijenjeno od: geronimo_2. 08.12.2020. u 19:05. |
