Staro 12.05.2018., 12:36   #1021
Gigi1
Postovi: 2,138
AMD Super-SIMD Patent, coming to a GPU after Navi
A super single instruction, multiple data (SIMD) computing structure and a method of executing instructions in the super-SIMD is disclosed. The super-SIMD structure is capable of executing more than one instruction from a single or multiple thread and includes a plurality of vector general purpose registers (VGPRs), a first arithmetic logic unit (ALU), the first ALU coupled to the plurality of VGPRs, a second ALU, the second ALU coupled to the plurality of VGPRs, and a destination cache (Do$) that is coupled via bypass and forwarding logic to the first ALU, the second ALU and receiving an output of the first ALU and the second ALU. The Do$ holds multiple instructions results to extend an operand by-pass network to save read and write transactions power. A compute unit (CU) and a small CU including a plurality of super-SIMDs are also disclosed.
ako se tko sjeca terscale arch od ati/amd, odnosno vliw...ovo je ajmo rec na tom tragu
edit: evo malo detaljnije
http://www.legitreviews.com/amd-seek...mputing_205227
Zadnje izmijenjeno od: Gigi1. 12.05.2018. u 12:44.
Staro 29.05.2018., 14:46   #1022
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Laptop sa ryzenom 2700, Vegom 56 i 144hz panelom
https://videocardz.com/76295/amd-rad...s-500-notebook
Prvi high end all amd laptop nakon 100 godina, ako ne računamo onoga sa R7 1700 i rx 580 4gb i 60hz panelom kao high end
Staro 29.05.2018., 23:57   #1023
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
NHF ali ne želim znat koliko traje baterija ili koliko je velik power brick
Bez potpisa.
Staro 30.05.2018., 13:29   #1024
Manuel Calavera
Postovi: 14,589
Jedno dvaest minuta
Treba vidjeti kad se pojavi recenzija. Naravno ne vjerujem da troši kao desktop verzija, ova je kao što se spominje u tekstu ili undervoltana klik ili se radi o nekakvim mobilnim verzijama koje je AMD kažu potvrdio
Uglavnom čisto sumnjam da će biti neki isplativ laptop
Staro 31.05.2018., 14:38   #1025
beli14
beli14's Avatar
Datum registracije: Mar 2011
Lokacija: Gotham City
Postovi: 519
Kada možemo očekivati nove AMD kartice, ako se zna? Nasljednici od RX580, RX570?
beli14 je offline   Reply With Quote
Staro 31.05.2018., 14:51   #1026
syss
syss's Avatar
Postovi: 10,805
Autor RaneZ Pregled postova
powerbrick je zapravo 500w napajanje zakeljeno plastikom
Staro 31.05.2018., 15:36   #1027
Manuel Calavera
Postovi: 14,589
Autor beli14 Pregled postova
Ne zna se ništa službeno. Nagodinu im izlaze 7nm gpu, a za ovu godinu se ne zna dali će išta izaći. Ako izađe može biti samo nešto od postojećeg (još jedan polaris rebrand ili vega, samo na 12nm)
Staro 31.05.2018., 19:28   #1028
beli14
beli14's Avatar
Postovi: 519
A ima li išta službeno iz zelenog tabora pošto je gtx 1060 već "stara" podosta?
Staro 31.05.2018., 21:20   #1029
Max_Damage
Max_Damage's Avatar
Lokacija: Krapinske Toplice
Postovi: 959
OT, ali bude nešto oko ljeta ili jeseni
Max_Damage je offline   Reply With Quote
Staro 01.06.2018., 00:25   #1030
Manuel Calavera
Postovi: 14,589
imaš nvidia turing temu već neko vrijeme
Staro 01.06.2018., 20:11   #1031
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,311
Znaci ovo sto se spominje Navi za 8. mjesec je definitivno patka?
Chuby je offline   Reply With Quote
Staro 01.06.2018., 21:08   #1032
Manuel Calavera
Postovi: 14,589
Nigdje nisam vidio da se spominje navi za ovu godinu. To je službeno potvrđen proizvod za 2019 godinu. Do kraja ove godine eventualno na 7nm možda stigne vega 20, ali to nije consumer proizvod, nego "deep learning" gpu
Staro 06.06.2018., 09:10   #1033
Manuel Calavera
Postovi: 14,589
Staro 08.06.2018., 00:14   #1034
Manuel Calavera
Postovi: 14,589
Staro 12.06.2018., 17:37   #1035
Manuel Calavera
Postovi: 14,589
  • Vega 7nm will not be coming to gamers.
  • Navi 10 will be the first Navi part to arrive and will be landing sometime in 2H 2019 or early 2020, depending on a couple of factors. The performance level of this part will be equivalent to Vega and it will be a small GPU based on 7nm.
  • Navi 14 will follow Navi 10 soon after.
  • Navi 20 is going to be the true high-end GPU built on the 7nm node and as things stand right now, you are tentatively looking at it landing sometime around 2021.
  • Navi will also be the first architecture to transition away from GCN (and along with it, the 4096 SP / 64 CU limit that is inherent to the uArch implementation.)
  • ‘Next-Gen’ architecture is the uArch formerly codenamed KUMA internally before AMD decided it didn’t like that name too much (oops) and will be based on the same brand new major architecture that AMD rolls out with Navi.
https://wccftech.com/exclusive-amd-n...dmap-cost-zen/
Staro 12.06.2018., 20:29   #1036
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Mali osvrt na Vegu 64 LC.
Pošteni komad hw-a. Predivna i lijepa.
Driveri? WTF. Ne radi pola toga, neće sejvat postavke, resetiraju se sami od sebe. Probao 3 verzije. Undervolt MUST have osim ako ne želite grijat doma kuću sa 300W toplinskog ispuha.
Igre? A ono. Radi xD Nije glasna ali ima neki zvuk (slično coil whineu) kao mali Krško kad radi. Guta sa undervoltom 230W inaće može potegnut do 400w na turbo postavkama i OC. Perf sigurno bolje od 1070. Nisam raido čmarkove ali sam odigrao par igri i napokon ljepi pubg na 144fpsa.
Mining? IMHO, jedina poštena namjena za istu. Još tiša i još hladnija + melje ko dve 580 (140w)
Ide nazad u rudnik ili na njusku po većoj cijeni nakon ove objave da ih neće bit. Ja se vraćam zelenima.
Bez potpisa.
Staro 13.06.2018., 23:37   #1037
aurellie
aurellie's Avatar
Datum registracije: Nov 2002
Lokacija: i
Postovi: 504
Je li probao tko rudarit sa novim adrenalin 18.6.1 sa Vegama? Strah me napravit remote update (na brodu sam) ali nekako me svrbi
The machine spirit is with me!
aurellie je offline   Reply With Quote
Staro 16.06.2018., 15:43   #1038
Manuel Calavera
Postovi: 14,589
Staro 17.06.2018., 03:12   #1039
Manuel Calavera
Postovi: 14,589
Sa Forbesa
Which brings us to, in my eyes, the more interesting revelation. According to my sources, Navi isn't just inside the Sony PS5; it was created for Sony. The vast majority of AMD and Sony's Navi collaboration took place while Raja Koduri -- Radeon Technologies Group boss and chief architect -- was at AMD.
Koduri joined up with Intel late last year as chief architect for its new Core and Visual Computing Group.
But the collaboration came at the expense of Radeon RX Vega and other in-development projects. Allegedly, Koduri saw up to a massive 2/3 of his engineering team devoted exclusively to Navi against his wishes, which resulted in a final RX Vega product Koduri was displeased with as resources and engineering hours were much lower than anticipated. As I mention in my companion report, the implication is that AMD CEO Dr. Lisa Su wanted to devote more energy into its semi-custom business than its desktop graphics division.
Taken as a solitary piece of news, this may sound borderline ridiculous. But when zooming out to a wider angle -- as I did today analyzing AMD's history of consumer graphics products and its semi-custom business -- it fits like a glove. The same sources who spoke to me about the PS5 had more to say about AMD's business motivations with Apple, Microsoft and Sony in the link below.
Beyond that, RX Vega has failed to find traction in the market. AMD launched its "Frontier Edition" of Vega that was a confusing (if sexy) hybrid between professional graphics and gaming. This was done before its dedicated RX gaming version to satisfy a promise that Vega would reach consumers within the deadline AMD promised.
Pull on that thread and it sheds more light on Vega's troubled development, due to the majority of Koduri's engineering team being swiped away not just to work on Navi, but to work on Navi for Sony.
On a related note, a new rumor emerged recently about Navi for desktop being merely a midrange part and not competing with Nvidia's high-end GeForce cards. That makes perfect sense if it was developed primarily for a console first.
The other interesting aspect to all of this is that my sources never mentioned Microsoft in the Navi conversations. This is pure speculation, but maybe Microsoft's next Xbox devices -- code-named "Scarlett" -- won't use Navi at all. Perhaps it will use a separate semi-custom solution incorporating Vega, or something else entirely that we're not privy to. Either way, the conversations I had referred to Navi in the past tense, as if it was already finished.
Perhaps Sony is closer to a PS5 than Microsoft is to a next-generation Xbox?
Staro 30.06.2018., 02:59   #1040
Manuel Calavera
Postovi: 14,589
Staro 29.08.2018., 01:13   #1041
Manuel Calavera
Postovi: 14,589
Staro 02.09.2018., 21:49   #1042
Manuel Calavera
Postovi: 14,589
Staro 02.09.2018., 22:20   #1043
Gigi1
Postovi: 2,138
brutalne compute brojke ako je istina
Staro 02.09.2018., 23:14   #1044
warlock25
warlock25's Avatar
Postovi: 2,327
Opa
Jel to moguce da cemo vidjet nesto iz crvenog tabora?
Staro 02.09.2018., 23:22   #1045
Manuel Calavera
Postovi: 14,589
Nije to nova vijest (stariji postovi na ovoj stranici), no kad se radi o novim cutting edge nodeovima fino je imati friške potvrde. Novost je ovo o dimenzijama i tflopsima
Inače radi se o AI "deep learning" gpu, a ne gaming gpu
Staro 02.09.2018., 23:30   #1046
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Vjerojatno će izbaciti samo Instinct i Pro verzije, i to po dosta visokoj cijeni, 7nm, 32 GB HBM2 = skupo.
Staro 02.09.2018., 23:35   #1047
Manuel Calavera
Postovi: 14,589
Da, jer su yieldovi za 7nm niski. Par iljadarki dolara možda
Staro 03.09.2018., 00:58   #1048
Oklen info da su TSMC 7nm yieldovi niski?
Sent from Usreo Mobara
Staro 03.09.2018., 01:09   #1049
Manuel Calavera
Postovi: 14,589
Zapravo nema neki konkretan info o postotku, spominjalo se općenito po medijima, no logično je jer je ovo još uvijek malo rano, prvi high performance proizvod, a čip nije baš malen, tako da waffer sigurno nije jeftin u ovoj fazi, yieldovi sigurno nisu (pre)visoki, ali ni gpu neće biti jeftina samim time
Iz istog razloga prvo idu radeon instinct i epyc proizvodi, jer je tu marža visoka, pokrit će više troškove, a ne neki mainstream proizvodi
Čip je zapravo "mid size" ako je anandtech procjena od 336mm2 točna, što je zapravo još gori indikator ako gpu bude preskupa, jer bi onda 500-600mm2 bilo sigurno neisplativo tj. jako slabi yieldovi. Nvidia će morati pričekati možda godinu za svoje high end gpu za mase
Zadnje izmijenjeno od: Manuel Calavera. 03.09.2018. u 01:19.
Staro 03.09.2018., 03:32   #1050
Gigi1
Postovi: 2,138
Prije da ce cijenu dignuti 32gb hbm, a i 20+ tflopsa je puno
