#10231 |
Datum registracije: Sep 2019
Lokacija: Mostar
Postovi: 369
Trajnost kondenzatora ovisi o vrsti, kvaliteti i radnim uvjetima, pri čemu elektrolitički kondenzatori obično traju 5-10 godina, dok visokokvalitetni uljni kondenzatori mogu trajati i duže. Ključni faktori koji drastično smanjuju njihov vijek trajanja su visoka temperatura okoline, prekomjerni napon i pogrešan odabir komponente. Warranty Duration: A reliable indicator of lifespan; a 7–10 year warranty suggests high longevity. Capacitor Quality: Japanese capacitors often last longer than cheaper alternatives, usually lasting 8–12 years. Heat and Dust: Excessive dust and heat can degrade internal components, reducing lifespan. Cleaning fans every 1–2 years is recommended. Usage Load: Running a PSU at maximum capacity 24/7 wears it out faster. Fan Failure: The cooling fan is often the first part to fail, often indicating the PSU needs replacement. |
#10232 | ||
White Rabbit
Lokacija: München/Varaždin
Postovi: 5,737
#10233 |
Postovi: 340
Gledam uzeti konfiguraciju za kućni AI, do 2K €. Ima netko ideju što uzeti? Vrtio bih open source modele (Gemma 4). |
