#62 | |
Postovi: 7,568
![]() Ma cijeli album je odličan. Kad sam ga nabavil jedno par desetak puta se odvrtel na repeat-u. Samo čekem nekog recenzenta da veli kak je i u ovom nastavku soundtrack podbacil. Joj.... |
#64 | |
Fallen
Postovi: 237
bite ce da su promjenili . a jebga ![]() |
#65 | |
Postovi: 7,568
#67 |
Fallen
Postovi: 237
pise na gamespotu : ARTIST / SONG Avenged Sevenfold / Blinded In Chains Bullet For My Valentine / Hand of Blood Celldweller feat. Styles of Beyond / Shapeshifter Celldweller / One Good Reason Dieselboy + Kaos / Barrier Break Disturbed / Decadence DJ Spooky and Dave Lombardo feat. Chuck D / B-Side Wins Again Evol Intent, Mayhem & Thinktank / Broken Sword Hush / Fired Up Hyper / We Control Ils / Feed The Addiction Jamiroquai / Feels Just Like It Should (Timo Maas Remix) Juvenile / Sets Go Up Lupe Fiasco / Tilted Mastodon / Blood And Thunder Rock / I Am Rock Static-X / Skinnyman Stratus / You Must Follow (Evol Intent VIP) Styles of Beyond / Nine Thou (Superstars Remix) Suni Clay / In A Hood Near You The P$C / Do Ya Thang The Perceptionists / Let’s Move The Prodigy / You’ll Be Under My Wheels The Roots and BT / Tao of The Machine (Scott Humphrey’s Remix) |
#68 |
Postovi: 7,568
Prokleti bili, stvarno su deli samo jednu pjesmu...budale... |
#69 |
Fallen
Postovi: 237
inace . ja jos uvjekl imam problema sa sovojom konfom pa tako i kod ove igre vozi mi u 35 fps a zna i dosta cesto pasti jel zacukava i to u 1024 . procito sam na ofical stranici da prvi put kad se igra instalira , ona sama podesava najbolje detalje za najbolje igranje . e pa meni je smjestio rezu 800X600 i skoro low detalje . svasta neznam sta da radim , nesto me u konfi cjelo vrijeme gusi . neznam sta da vise radim kaze jedan lik na guru3d-u: Ok i take everything back, just played the demo and it looks amazing, it even plays better than NFSU2, i am pulling 40-50fps at 1280x960 with 4X AA and 8X AF !!!!!!! a konfa mu je : Processor: P4 2.4C @ 3.2 5:4 FSB267 Operating System: WinXP PRO SP2 Mobo: ABIT IC7-G | Cooler Master Stacker super tower ![]() RAM: 2x512 Twinmoss UTT PC3200 Video: MSI NX6800 unlocked 16/6 | 400/860 Storage: WD 74gig Raptor + Maxtor 80gig S-ATA Audio: Audigy 2 Platinum & Cambridge Soundworks DTT2500 neznam kud ovo vise vodi. |
#70 |
Postovi: 7,568
Ja još svoj komp slažem (još se kupuju dijelovi), ali kad ga složim mislim da bu igra delala bez problema......ovaj nadam se da bude. ![]() Pa ni vrag da ti na 6800 ne dela kak spada. |
#71 |
Fallen
Postovi: 237
pa nemogu ni ja vjerovat . eto , neznam sta da radim . isti mi je bog i sa q4 i svim igrama nesto nevalja , a neznam sta . trebalo bi sve ic ko po loju, i jos je grafa otkljucana . a jos vise me zabrinjava sto u 3d marku imam ok rezultat (bar mislim ) -4200. inace , probao sam brdo drivera i sa svakim isto |
#73 |
Fallen
Postovi: 237
pa ja neznam onda ko je ovje lud . bit ce da je komp ja igram skoro sve na high, 1024 i iskljucenim vsync-om i ide mi u 35 a zna cukat dosta pa pada i na 25 a dogadja se jos jedna cudna pojava: kad udjem u meni prvi put kad startam igru sve je ok (45fps ) i onda odvozim utrku -dvije i kad se vratim u pocetni meni sve steka (20 fps ) . cudno ![]() a zna nekad kad malo duze vozim framerate samo opat u pola trke drasticno i sve je sporo , pa se opet digne pa opet padne i onda ostane tako stalno |
#75 |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Brijem da si ti od svog tog silnom mjenjanja driajvera i ostalog sje... cijele windowse... ![]() Ako mos, probaj lagani format c: i sve ostalo sto slijedi (reinstall win)
#76 |
Fallen
Postovi: 237
e kunem ti se prijatleju da nije to prije 2 (rijecima : DVA) dana sam formatiro c i instaliro nove , drugacije windowse nego sto sam prije ima i druge drajvere za sve i opet sve po starom . reinstaliro sam win vec par puta i formatiro nije u drajverima 100 % . nesto me od komponenta bas koci . a imam filing da je maticna il nesto .nemogu nijednu igru normlano igrat da mi ne cuka , resetirava se komp , pada fps i događaju se jos gomila cudnih neobjasnjivih stvari od toga svega cu skrenut kako mi se cini a da stvar bude jos gora necu imat dosta vremena ni kune u djepu da kupim mbo . |
#77 |
Postovi: 7,568
Matična bi mogla.......dobar je čipset, ali proizvođač...... |
#79 | |
Datum registracije: Jun 2004
Postovi: 3,996
#84 |
Postovi: 12,613
Na kraju te stranice imas opis u slikama step by step kako flashati evoPcchips A koji bios imas provjeri sa npr. Everestom
#85 |
Fallen
Postovi: 237
hvala rista, neznam kak to nisam zmjetio ![]() evo metnuo sam nove biose al opet ista pjesma po starome . u igri mi zna svako malo hard zarostat na tren pa tako i cukne . a i fps mi je opet mali . ide u 35 fps (osim kad hard zarosta pa padne jako , pa opet vrati) a na zahtjevnijim djelovima 23-25 |
#87 |
Fallen
Postovi: 237
sad sam instaliro full verziju i nemorma ni spominjat da mi jos gore radi ![]() ima neka dobra dusica za posudit 754 plocu dok ne kupim novu ![]() ps. u 800X600 mi igra ide u istom framerateu ko i u 1024 al mi vise ne zastekava (skoro ![]() Zadnje izmijenjeno od: Jaymz. 20.11.2005. u 22:20. |
