#31 |
(°_°)
Postovi: 3,249
Da se vratimo temi. Prvo, jel postoji na Sljemenu, tj. medvedgradu odasiljac za tu mrezu? Ili je to jos u planu? Drugo, ako se i bi spojio na tu mrezu, kakvom je vezom ta mreza spojena na internet? Jel ako je DSL, a vec sada ima 15tak clanova, onda nakon par mjeseci se fakat vise ne bi isplatilo.... (ako gledamo to sa strane da zelimo 24/7 net po pristojnom bandwith-u... )
Toshiba m200 TabletPC + Samsung 205BW |
#32 |
***2CROwded***
Datum registracije: Mar 2002
Lokacija: Cro
Postovi: 1,610
OVO BI UBO: TEW-303PI 11/22Mbps Wireless PCI Network Adapter TRENDnet’s TEW-303PI 11/22Mbps Wireless LAN PCI Card creates freedom for your desktop PC. This PCI Card plugs right into your PCI Bus Slot providing wire-free access to networked resources from your LAN and Internet or create a network without networking cables. It dynamically shifts between 22, 11, 5.5, 2, and 1 Mbps for maximum availability and reliability. Complying with 2.4 GHz frequency band and IEEE 802.11b standard, TRENDnet’s TEW-303PI ensures great security and performance for your wireless networking environment. Enlarge Image Download Datasheet (PDF) Wire-Free access to networked resources for desktop PC Uses 2.4 GHz frequency band (DSSS), which complies with world wide requirements Delivers data rate up to 22 Mbps Dynamically shifts between 22, 11, 5.5, 2, and 1 Mbps network speed, based on signal strength, for maximum availability and reliability of connection Reversed SMA connector with detachable external Antenna Supports Windows 98 (SE)/ME/2000/XP Ensures great security by providing the 64/128/256-bit Wired Equivalent Privacy (WEP) defined in IEEE 802.11b standard 3-Year Warranty Interface Type: PCI Bus Power Management Specification 1.0, Standards: IEEE 802.11b WLAN Standard, PCI Rev 2.2, ACPI 1.0 Antenna: External 2dbi Antenna (length = 103 mm) with reversed SMA connector Data Rate: 22Mbps, 11Mbps, 5.5Mbps, 2Mbps, and 1Mbps Media Access Protocol: CSMA/CA with ACK Module Technique: Direct Sequence Spread Spectrum (DSSS), CCK, DQPSK, DBPSK Frequency: 2.4 to 2.4835GHz (Industrial Scientific Medical Band) LED Indicator: Power Output Power: 15 dBm (typical) Receiving Sensitivity: 10-5 BER @ -80 dbm (11Mbps) min. Channels: 11 Channels (US & Canada) Power Consumption: 3.3V, 350mA (Max.) Dimensions: 134 x 120 x 23 mm (5.27 x 4.72 x 0.9 inches) without antenna Weight: Appr. 85 grams (3.0 Oz.) with antenna Temperature: Operating: 0° ~ 55°C (32° ~ 131°F) Storage: -20° ~ 65°C (-4° ~ 149°F) Humidity: 95% max. (Non-condensing) Certification: FCC, CE Integration Friendly: Drivers support most popular Network Operating Systems. Economical: Save time, labor, and material for network cable installation. Flexible: Creates wireless peer-to-peer network in Ad-Hoc mode or connects to Ethernet LAN in Infrastructure mode using wireless Access Point. Cost Effective: Supports IEEE 802.11b wireless standard, user can connect to any IEEE 802.11b wireless network. Performance: Connects at a speed up to 22Mbps, wirelessly! |
#33 | |
Lokacija: Poljanice Zagreb, Hrvatska
Postovi: 56
****************************** ABIT KR7A-RAID AMD Athlon XP 1900+ 1x512 MB DDR 266 RAM Samsung ATI Radeon 8500 ****************************** |
#34 | |
(°_°)
Postovi: 3,249
![]() Dakle u blizoj buducnosti nista od zgw-a za mene ![]()
