Staro 22.10.2018., 08:41   #31
gearvita
gearvita's Avatar
Datum registracije: Sep 2018
Lokacija: China
Postovi: 241
Macaw RT-20 Earbuds with Cool Metal Appearance, Looks More Trendy
Macaw RT-20 earbuds features ergonomic design rests well on your ears without irritating ear-canal which will give us classic comfort. It has super sound quality because of 8mm dynamic driver for high fidelity playback. With the stylish design and high-end sound quality, compatible with the latest generations of iPod, iPhone, and iPad.
Product Features:
● Ergonomic design rests well on your ears without irritating ear-canal.
● The body adopts tempered glass logo and austenitic 316 metal shell one-time molding process, which enhances the texture and duration.
● The body is more streamlined, better wearing comfort, the auditory is softer and more outstanding bass performance.
● Use carbon fiber composite nano-technology in the diaphragm moving coil unit, mixing wonderful material to make low dive deeper, more explosive transient performance.
● 8mm dynamic driver ensures the high fidelity playback.
● 3.5mm universal plug, gold-plated antioxidant lossless transmission plug. Fine workmanship, reduce signal transmission loss, detail fidelity reduction for all types of portable audio devices.
● Low-frequency elasticity and high-frequency brightness, medium-frequency fullness, wide sound may you enjoy a hearing feast.
● With the stylish design and high-end sound quality, it is compatible with the latest generations of iPod, iPhone, and iPad. They work with all Androids, tablets, mp3 players, and related devices with a standard 3.5 mm jack.
Silver and black two classic colors are availble at GearVita, brushed metal process creates stronger metal feel, makes the earbuds look more stylish and trendy: https://gearvita.com/macaw-rt-20-in-ear-earbuds.html
Related products:
xiaomi lyej05lm mini
qcy q26 pro mini wireless bluetooth music headset
Best Brand Consumer Electronics Provider GearVita
gearvita je offline   Reply With Quote
Staro 22.10.2018., 10:15   #32
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Wear NO.1 F5 GPS Outdoor Smartwatch, Start A Scientific Running
The NO.1 F5 smartwatch is a low cost GPS, coupled with good appealing. It looks sporty and so far one of the best looking smartwatchs. The smartwatch has a 0.95' inch screen with 96 x 64 pixel resolution. The body is zinc alloy and can be operated via touch button key and physical buttons. It has a removable two tone silicon strap with stainless steel buckle, and is IP67 life waterproof.
Product Features:
● Using 0.95 inch 96 × 64 OLED color display round screen with Sapphire crystal glass mirror surface, which further exaggerate it's quality and beauty.
● With built-in GPS module, it can independently record GPS. It supports Google map, when connected to internet, you can use the GPS to find the right route.
● Heart rate monitor measures your heart rate, record your sports data and monitor your health condition.
● Real-time temperature and altitude measure function makes it great for outdoor sports, so that you can respond to sudden weather changes.
● Multiple sports modes record, including walking, running, climbing, swimming, and cycling.
● After connected with Bluetooth, you can experience those functions: see messages, contacts and notification reminders.
● The screen isn't always on the normally state, you can lift your hand or turn over your hand to brighten the screen.
● Support Alarm, Sleep Monitor, Sedentary Reminder, Pedometer, Finding Phone, Calls and Messages Reminder, etc.
● 380mAh battery is also convenient for your using, that last for 30 day standby time, daily use for 3 weeks, GPS use for 12 hours.
● Marked as IP67 water resistant, splash water and rain resistant, inapplicable in swimming, bathing or sauna.
The smartwatch is available in gray, green and red colors on GearVita, you can choose according to your preference. And the strap can be replaced two-color 20mm strap, really a thoughtful design: https://gearvita.com/no-1-f5-smart-watch.html
Related products:
xiaomi huami amazfit bip smartwatch
lenovo watch 9
Staro 23.10.2018., 09:02   #33
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Chuwi Hi8 SE Tablet, One Hand Can Grip
The Chuwi Hi8 SE tablet comes with full HD IPS screen with 1920 x 1200 resolution and a 16:10 aspect ratio boasts wide viewing angles and miravision wireless display technology for stunning vision and impressive color. Inside the metal uni-body a 64-bit MT8735 quad-core chipset, coupled with a Mali-T720 graphics unit are powering the sleek tablet. It runs on Android 8.1 Oreo operation system, equipped with 2GB of memory and 32GB of internal storage, plus support for up to 128GB expandable storage let you achieve multitasking with less effort and enjoy more entertainment while on the go.
In the camera department, the Hi8 SE has a 5.0MP camera sensor on the rear and a 2.0MP selfie camera sensor to offer. It has a built-in high-density polymer lithium battery with a capacity of 4000mAh, ensuring a long battery life. Other features and connectivity include dual-band Wi-Fi 802.11 a/b/g/n, Bluetooth V4.0, and intelligent split screen.
Main Parameters:
CPU: Mediatek MT8735 quad core 1.3GHz
GPU: ARM Mali-T720
System: Android 8.1
Screen: 8.0 inch IPS capacitive screen with 1920 * 1200 resolution
RAM: DDR3 2GB
ROM: 32GB EMMC
TF Card Extended Storage: Up to 128GB
Camera: 2.0MP front camera + 5.0MP rear caera
WiFi: 802.11 a/b/g/n/ac ( support 2.4GHz and 5.0 GHz )
Battery: 4000mAh
Product Features:
● Meets the OGS Technology
The IPS screen on Hi8 SE utilizes OGS craftsmanship, which makes the tablet more transparent and beautiful. Seamless visual effect brings better contrast and more accurate color rendition.
● Enjoy Stunning Vision
IPS screen with 1920 * 1200 HD resolution,16:10 aspect ratio boasts wide viewing angles and MiraVision™ enhancement solution provides impressive color and stunning vision.
● Sleeker Than Ever
Metal uni-body with 7.8mm thickness and 340g weight, lighter, sleeker and more comfortable to hold. Smaller body and more convenient one-handed operation.
● 64-bit Quad-core Processor
Featuring 64-bit MT8735 quad-core SoC, the Hi8 SE improves 20% in performance and reduces 10% in power consumption. Better video decoding capability will be good for TV streaming.
● More Expandable Storage
2GB + 32GB of internal storage, plus support for up to 128GB expandable storage. Now you can achieve multitasking with less effort and enjoy more entertainment while on the go.
● Android 8.1, GMS Certification
Get started on your favorite tasks more quickly with 2x the boot speed when powering up. Android Oreo helps minimize background activity in the apps you use least.
● Intelligently Split Your Screen
Hi8 SE enables you to split your screen monitor into two or more so that you can view two or more applications side-by-side, watching movies while chatting with your friends at the same time.
● 2.4G/5G Wi-Fi, Fast Connectivity
Top speed 2.4G/5G dual-band WiFi supports 802.11 a/b/g/n/ac protocol. Instant switching between WiFi and 4G offer you better web surfing experience.
● All-day Battery Life
High-density polymer lithium battery plus excellent power optimization of CPU ensures long battery life. Enjoy hours of reading, watching TV shows, browsing the web and more.
● Miracast Wireless Display Technology
Project to a larger display with Miracast technology and you can wirelessly share content on one screen to another screen, such as presentations, videos, apps and photos.
What Chuwi Hi8 SE really attractIve is its low price, only $104.99 you can buy it from GearVita with the coupon code "CWHi8SE" when checkout: https://gearvita.com/chuwi-hi8-se-ta...-32gb-rom.html
Related products:
Chuwi Hi9 Pro
Chuwi Hi10 Plus
Staro 23.10.2018., 11:52   #34
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Macaw TX-90 Headset, Light As A Feather, Make It Easy for You To Run
The hanging neck design of Macaw TX-90 earbuds provides the ideal wearing comfort and safety, plus the ultra-light head weight, so you can enjoy it in sports. It also adopts unit inverted technology, in the same cavity space, the auditory feels comfort and softness. The bass performance is outstanding, the potential is good, and the depth is, deep.The head is set with a logo shape LED breathing lamp, the light leaped evenly and was full ofmotion, it's easy to be cool at the same time you look for it in the dark. The shape of earbuds is inspired by nature macaws, which is very stylish, personalized and passionate.
Product Features:
● Support Apt X lossless audio decoding with CSR8645 Bluetooth chip, indulge in the original sound, more true and pure.
● Excellent sound effect collection, superior sound isolation, efficiently reduces external noises, provides HD stereo sound.
● 5UM graphene composite diaphragm, graphene has carbon atoms and its hardness is 100 times that of steel. Graphene diaphragm can better restore current signal and produce smooth and high-definition sound quality.
● Voice line control, switch songs, call, operate conveniently bring you an user-friendly experience.
● Pair with your smartphone in seconds, connect with your phone steadily without worrying about dropping off.
● Support multi-point connection, DFU upgrade.
● Medical level liquid silicone along with a memory metal inside, lightweight and fordable, could easily be kept in storage and carry with.
● Equipped with 150mAh large capacity battery, 350 hours long standby time, 12 hours of continuous play time, let you enjoy this data comes from the Macaw Lab.
● More advanced IPX7 grade nanometer waterproof rating for better daily protection, let you be more fearless and enjoyable in the sweat and rain.
The headset is compatible for 99 percent Bluetooth-enabled devices and perfect for sports running, gym, exercise, casual, office and other activities. Purchase it from GearVita, let it become your sports companion: https://gearvita.com/macaw-tx-90-bluetooth-earbuds.html
Related products:
buy xiaomi lyej05lm
qcy q26 pro mini
Staro 23.10.2018., 13:17   #35
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Samsung EVO Plus Micro SD Card, Simply The Right Card
Keep high-resolution files protected and easily accessible with this Samsung EVO Plus micro SD card. It provides robust storage for up to 256GB of data from your action camera, tablet or smartphone thanks to its resistance to shock, seawater and extreme environments. This micro SD card reads data at speeds of 100MB/s for smooth 4K UHD media playback and writes data at up to 90MB/s, making it ideal for HD cameras and other demanding gadgets.
Product Features:
● Fulfill Your Need for Speed
Record and play 4K UHD video without glitches. With superfast read and write speeds up to 100 MB/s and 90 MB/s respectively, the 256GB EVO Plus lets you transfer a 3GB video to your notebook in just 38 seconds. Shoot flawless high quality photos and videos, and share them all in an instant.
● Capacity to Live Large
Never worry about space again. A massive 256GB memory, its maximum capacity, is enough for 12 hours of 4K UHD video, 33 hours of Full HD video, or 55200 photos. So go ahead and savor all of what life has to offer, and keep it all too.
● Extended Compatibility
Compatible with a wide range of devices for both SD and micro SD, you can even capture detailed 4K UHD video. This memory card works perfectly with even the most advanced devices to protect your memories for life.
● 4-Proof Protection
Your experiences are irreplaceable, and now unforgettable. Backed by 4-proof protection, the EVO Plus can withstand up to 72 hours in seawater, extreme temperatures from -25° to 85° Celsius, airport X-ray machines and magnetic fields of up to 15,000 gauss — the equivalent to an MRI scanner.
More space and higher speed. Free up your devices with the largest capacity and highest read/write speeds in its class, perfect for 4K UHD video. With astonishing performance and reliability, EVO Plus lets you save and treasure the richness of life.
With the coupon code "SSEVOP256" when you checkout on GearVita, you can get this 256GB Micro SD card of only $58, this discount price ends on the 27th. There are also other three storage capacity options for you to choose from, 32GB, 64GB and 128GB: https://gearvita.com/samsung-evo-plu...o-sd-card.html
Related products:
kingston sd card class 10
netac p500 micro sd card
Staro 28.10.2018., 05:18   #36
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi 70mai Dash Cam Pro GPS Protects Your Car, Guarantees Your Safety
Xiaomi 70mai Dash Cam Pro GPS, comes with Sony IMX335 image sensor, provides superb quality recording experience. It has the distinctive functions of WiFi connection, G-sensor, and loop-cycle recording offer you a comfortable, safe and worry-free driving environment. Meanwhile, it's H.264 photography compression technology and 1080P full HD lens, giving you a satisfied recording experience.
Product Features:
● 130 degrees FOV, cover wide vision range.
● 1920 × 1080P HD resolution, clear FHD recording.
● 5-mega-pixel, 1944P resolution with WDR that adjusts the exposure balance captures in greater detail both in darkness and strong light and produces a more clear and vibrant image.
● 1/2.9 inch light-sensitive components, capture clear images during nights.
● Sony IMX335 image sensor provides you better performance.
● With time-lapse function and motion detection supported by G-sensor, 70mai Pro can keep recording during parking mode.
● WiFi connection allows you to real-time to watch the recording and share the videos or images on the popular social media.
● Advanced H.264 photography compression technology keeps high-quality videos and plays a part in saving storage as well.
● Real-time alert warns you when veering off the lane and when about to hit another vehicle ahead.
● High-temperature resistant adhesive, can avoid the problem of falling under high-temperature conditions, provide strong adhesive force, but also more beautiful and do not damage the car glass.
● DeFog algorithm reduces distortion or degradation of images and reproduce a clear vision while driving in snow, smoke and haze environment.
● Coupled with car charger and micro USB power cable for power supply, convenient for users to adapt themselves according to their needs in the car.
● The video can be monitored on the APP "70mai Dash Cam" of your phones, you can download APP from Google Play or Apple Store.
● Rotatable holder meets various recording demands.
With simple and exquisite appearance, Xiaomi 70mai Dash Cam Pro with GPS will be a decoration in your car and its versatile and affordable price will definitely make you fall in love with it. Applying the coupon code "XIAOMIDC" when checkout on GearVita, you can purchase it of only $89.99, limited to 30 pieces, take the opportunity: https://gearvita.com/xiaomi-70mai-da...ps-module.html
Related products:
xiaomi 70mai dash cam pro
yi mini dash cam
Staro 28.10.2018., 08:48   #37
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
$252.99 for Global Version Xiaomi Mi 8 Lite 64GB, $297.99 for 128GB
Xiaomi Mi 8 Lite 64GB styles a superb display 6.26 inch with a screen resolution of 1080 × 2280 pixels and a sharp pixel density of 403ppi that can render a clear viewing experience. The display type is IPS LCD and the aspect ratio offered is 19:9 which enhances the view. It sports a dual rear camera of 12.0MP + 5.0MP with a lot of great functions that enable it to shoot pictures and videos. The front camera is a 24.0MP giant that clicks selfies like no other in this price range.
Mi 8 Lite 64GB runs on a 3350mAh Li-ion battery for long-lasting backups along with quick charging and it holds two SIM cards that support 4G networks along with VoLTE services. The internal storage is 64GB and the external storage is expandable up to 256GB. The Xiaomi Mi 8 Youth runs on a 64-bit two quad-core processor (2.2GHz Kryo 260 + 1.8GHz Kryo 260) and a 4GB RAM. This powerful combination sits upon a Qualcomm Snapdragon 660 MSM8956 chipset and an Adreno 512 graphics card. This offers the user a great configuration capable of running all high-end games and doing all multimedia jobs with smoothness.
Basic Parameters:
Display: 6.26 inch, 2280 × 1080 pixel FHD+ capacitive screen, 403PPi
CPU: Qualcomm Snapdragon 660 AIE, Octa core, 2.2GHz
GPU: Adreno 512
Operating System: MIUI 9 (Base on Android 8.1 OS)
RAM + ROM: 4GB RAM + 64GB ROM
Extended Storage: 256GB
Camera: 12.0MP + 5.0MP rear camera and 24.0MP front camera
SIM Card: Nano SIM card + Nano SIM card / Nano SIM card + Micro SD card
Bluetooth: 5.0
Battery Capacity: Built-in 3350mAh(typ)/3250mAh(min)
Product Features:
● 6.26 inch "notch" full screen, the width of "Notch" is reduced by 45%, taking pictures and unlocking is more convenient.
● The unique dream blue, the twilight gold two gradient colors, like a dream of youth, full of endless imagination.
● Front selfies camera with 24 million ultra-high resolution, 1.8μm large pixels, and AI scene camera and AI screen ntelligent fill light, day and night to shoot, every photo is stunning.
● The new AI nude makeup beauty, accurate recognition of facial features, intelligent analysis of hair, eyebrows, eyelashes and other colors, light natural nude makeup. More support for video beauty, dynamic real-time beauty.
● Rear AI dual-camera with 1.4μm large pixels, from the SLR 2PD dual-core focusing technology, not only bright and delicate during the day, but also can quickly capture the beauty under the dark light.
● The first Snapdragon 660 mobile phone fully upgrades the GPU and CPU in the game, performance and efficiency. The high frame rate picture is always smooth, and the power is not dropped when it is turned on for 5 hours.
Before November 1st, you can pre-order this Xiaomi Mi 8 Lite 64GB Global Version of $252.99 on GearVita with the coupon code "XMMi8L64": https://gearvita.com/xiaomi-mi-8-lit...l-version.html
Also the coupon code "XMMi8L128" can be used for pre-order of Xiaomi Mi 8 Lite 128GB Global Version, the discount price is $297.99.
Related products:
xiaomi redmi note 6 pro
xiaomi mi a2 lite smartphone
Zadnje izmijenjeno od: gearvita. 28.10.2018. u 09:08.
Staro 28.10.2018., 11:43   #38
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Bluedio T-Talking Bluetooth 5.0 Earbud with Smart Voice Control Cloud Service
Bluedio T-Talking Earbud is optimized by combining with the chip circuits of bluetooth 5.0. It has many advantages such as better connection, not easy break off the wire, undisturbed as well as clearer data and better sustainability with lower power sonsumption. You can ask questions, play music, pick up the phone, provide information, news as well as whether and so on. All of these come true by voice control cloud service. It combines with the advantages of small shape, easy to carry and operate. Turbine earphone, just like the turbine on airplane, can bring us strong and dynamic music.
Product Features:
● Combined with Bluetooth 5.0 chip circuit optimization, better connectivity, less disconnection, interference, and clearer data transmission.
● In order to eliminate safety risks of battery, its socket is built-in self-healing fuse resistor PTC.
● Reduce power consumption, lower energy consumption and better endurance.
● Asking questions, playing music, picking up the phonem providing information, news as well as whether and so on. All of these come true by voice control cloud service. You can also voice control home appliances and the range of transmission is up to 10 meters which lead an amazing convenient life.
● Compact and easy to carry, very small size, easy to carry, easy to understand, good for sports and driving.
Differ from headsets and neckband earphones, the design of T-Talking is more accord with human mechanics, which means that it can be widely used in sports, driving as well as ordinary use. Get it home from GearVita, you will actually feel that: https://gearvita.com/bluedio-t-talking-mini-earbud.html
Related products:
cheap xiaomi lyej05lm
cheap qcy q26 pro mini wireless bluetooth headset
Staro 29.10.2018., 04:56   #39
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Mi Box S Brings You to Experience Clarity And Smoothness Like Never Before
Connect to a world of content and entertainment at home with Xiaomi Mi Box S Global Version. Running on the latest Android TV 8.1 is easy to use, supports voice controls and your favorite apps such as Netflix, VUDU, YouTube, SlingTV and more! Experience stunning 4K HDR visuals and Dolby DTS for an immersive experience. Catch your favorite TV shows, play games, watch the news or listen to the radio. Mi Box also recommends videos based on your personal YouTube and Google Play preferences.
Main Parameters:
CPU: Cortex-A53 Quad-core 64bit
GPU: Mali-450
RAM: 2GB DDR3
Storage: 8GB eMMC
Operating System: Android 8.1
Ethernet: 1000M LAN
WiFi: 802.11a/b/g/n/ac 2.4GHz/5GHz
Bluetooth: 4.2
Support Language: Global
Product Features:
● Powered by Android 8.1 for Superior Functionality
Mi Box S is powered by Android 8.1, easy to use and supports voice search and Chromecast as well as delivering a world of content the whole family can enjoy.
● Access Tons of Content
Compatible with thousands of apps, giving you access to tons of premium video services and a constant stream of fresh new content.
● SmartCast
Built-In Chromecast, cast photos, videos, movies from your phone onto your TV wirelessly from your devices.
● Google Assistant
With the Google Assistant, you can quickly access entertainment, get answers and control devices around your home. Just press the mic button on your remote to get started.
● High Clarity 4K HDR
Features the latest 4K HDR technology and high-speed 4K processing for up to 60fps playback, supports 4K Ultra HD resolution and High Dynamic Range (HDR). Enjoy an ultra high-definition, lifelike viewing experience.
● Premium Audio Puts You in The Action
Supports both Dolby audio and DTS-HD audio encoding, Dolby and DTS deliver crisper, three-dimensional surround sound.
● Voice Control that Does It All
Built-In Google Assistant and in Apps voice search. Search for photos, check the weather, set an alarm. Life should be simple.
● High Performance Storage Capacity
Powerful Quad-core CPU, 3+2-core GPU, provides fast and stable rendering to enjoy a high quality video experience.
● DDR3 2GB RAM, eMMC 8GB ROM
Configured with DDR3 2GB RAM, and eMMC 8GB ROM, thus it can provide enough room and freedom to install Apps without worrying about running out of space.
● Wired and Wireless Connections
Supports Wi-Fi, Bluetooth, and USB connections, delivering super fast transfer speeds.
With the coupon code "MiBoxSA", only $54.7 needed, you can get this Mi box S from GearVita. Limited to 50 pieces, don't miss this opportunity: https://gearvita.com/xiaomi-mi-box-s...l-version.html
Related products:
xiaomi mi box 3s
mi 4k tv box global version
Staro 29.10.2018., 10:14   #40
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
OVEVO Q62 Pro - Designed by Germany Reddot And iF Design Award Winner Team
OVEVO Q62 Pro earbuds have the Germany Reddot award and iF design award winner team design. The trick to the earbuds is that they are absolutely wireless! There are no wires between the left and right earbuds and no wires to charge them, because the unique conductive portable charging system is adopted to avoid running out of batteries. The new enhanced battery in the wireless earbuds allows up to 2.5 hours for music and calls, and the 800mAh rotatable charging box can supply power for the double headsets for 4 times, providing additional 10 hours of music/talk time on the go. They also have features of pair with one press, hi-fi sound quality and smart noise reduction etc.
Product Features:
● Paired with One Press
Q62 Pro add the physical pairing button in the charging box creatively. Press the button before use and the earbuds, they will automatically pair. Paired with one press function makes the Hi-Fi dual wireless earbuds better to use.
● Automatic Pairing
The automatic pairing button is added in the Q62 Pro. It only need to be paired with the cell phone once, then it will and no longer have the problem that can not be paired or one earbud connected only.
● Real HiFi Dual Wireless
CD level original sound reproduction, comparison for good voice, checking by the blind listening video.
● Imported Biocomposite Diaphragm
The customized sound cavity unit supplied by Harman karton for many years and imported special biocomposite diaphragm make better stereo sound performance.
● Independent IC Amplifier
Q62 Pro with independent IC amplifier to make the sound field larger. lt has more than four times the driving performance of majority of Bluetooth earphones in the market, and it is better in driving the custom unit.
● BOSE Tuner Tuned Up
Golden ear and professional audio tuning technology, improve Q62 Pro's audio performance from the source of research and development.
● High Quality CD Level AAC
Support for the general AAC high-quality audio compression transmission technology, to experience the sound details 2 times of normal Bluetooth earphones.
● Eighth Generation CVC Noise Reduction Technology
CVC smart noise reduction technology filter out the interference and noise of audio signals directly. Meanwhile, through DSP master control optimization, it improves the perfermance of call noise reduction.
● Comfortable to Wear
4.5g weight only and invisible wearing. The composite ergonomic designed product outline can be accurately adapted to most user's ears, and it will not fall off in fierce movement.
● 10h Battery Life
Built-in big capacity lithium battery. If using one earbud with the charging box, battery life can last for more than 20 hours.
● Wide Compatibility
Fully compatible with all operating systems and devices, all that is needed is that they support the Bluetooth wireless standard.
The earbuds come with English and Chinese voice prompt, take different area people into consideration, expedient for operation. Get them from GearVita, feeling the unparalleled sound quality they bring you: https://gearvita.com/ovevo-q62-pro-b...ancelling.html
Related products:
best xiaomi lyej05lm
best qcy q26 pro mini wireless bluetooth headset
Staro 29.10.2018., 12:08   #41
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
DM2018 4G Smartwatch Phone, Everything You Want Is Here
The DM2018 smartwatch is a remarkable 4G touch screen SIM smartwatch phone is that uses an Android OS 6.0 to take your watch phone experience to the next level. You will also be able to browse the web and take calls without needing your phone on you. In fact, it accomplish almost everything your phone can do, so its a great replacement for it on a night out.
Main Parameters:
Display: 1.54inch IPS Full View
Resolution: 320 * 320 pixels
Touch Type: Capacitive Touch Screen
OS: Android 6.0
CPU: MT6737M(4*CA53 1.1GHZ)
RAM + ROM: 1GB RAM + 16GB ROM
Bluetooth: V4.0
Battery: 900mAh Lithium Battery
SIM Card Slot: Single SIM(Nano SIM slot)
Connection Type: GPS/WiFi/Bluetooth
Camera: 2.0MP
WiFi: 802.11b/g/n
Frequency:
- 2G network: GSM 900/1800/1900MHz
- 3G network: WCDMA 900/1900/2100MHz
- 4G network: FDD-LTE B1/B3/B7/B8/B20
Product Features:
● 1.45 inches IPS Curved Screen
With exquisite color IPS touch screen,every touch are interpretation of your wrist on the distinctive , showing a unqie temperament.
● Built-in GPS
DM2018 can receive GPS satellite signal, All the data will be reflected on your App to creat exclusive pace rate analyse and speed analyse.
● Different Styles of Watch Dials Available
Popular themes and colorful dial to manifest your personality and charm,change the style waht you like,each one comes with a corresponding display version.
● 4G Supported and Independent Phone Calling
You can insert single Nano SIM card that supports,you can call making,answering,texting,email checking and so on ,all on the wrist,making your life much easier.
● Incoming Call Remind and Messages Notification
While Bluetooth connecting, if there is an incoming call, it would show the caller ID. Almost notification of APPs could be synchronized to the watch.
● Bluetooth 4.0
By using the smartwatches BT 4.0 support it can easily be connected to your Mobile Phone. This gives you SIM free usage options as it can partner with your phone and transfer all the important updated and data to your wrist.
● Android 6.0 and APP Download
The latest system with more excellent interface,it has excellent power management and the added security of this Android.
● Heart Rate Monitor
It can accurately monitor pulses and active and resting heart rate changes to generate a professional heart rate report.
● Remote Capture
Built-in 2.0MP camera, you can take photos or video talk through the camera in the smartwatch phone.
● 1GB RAM and 16GB ROM
Powered by a Quad-Core processor and 1GB of RAM, there is 16GB of internal memory for storing photos and your music library and apps so it can meet all the main processing needs.
● 2G/3G/4G Network
Supports 2G 3G and 4G, so it can work as an independent smartphone. With its cellular connectivity, it brings messages, social media updates and calls directly to your wrist.
DM2018 also includes a pedometer, sleep monitor, and sedentary reminder let you take charge of your fitness giving you the power to track and measure the intensity of your workout sessions and track your fitness progress. Get this smartwatch from GearVita, it will help you to keep your fitness pledges on track: https://gearvita.com/dm2018-4g-smart...-16gb-rom.html
Related products:
xiaomi mijia quartz waterproof smartwatch
Staro 30.10.2018., 04:51   #42
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi Amazfit Verge Smartwatch - Small Watch, Big Intelligence
The aesthetics of Xiaomi Amazfit Verge smartwatch emphasizes a 1.3 inch AMOLED screen cemented on a body of polycarbonate and ceramic zirconia, being covered by corning gorilla glass 3. In this way, we can enjoy a full-color navigation. Being able visualize our messages once we synchronize our phone with the smartwatch through the Bluetooth 4.0 connection that it integrates. How could it be less, we can answer incoming calls from our wrist. As for sports options, the commitment to include a high precision optical heart rate sensor results in an analysis efficiency of 98%, achieving constant measurements throughout the day. The heart rate monitor is also capable of detecting abrupt changes in our consensuses, alerting us in case of detecting any variation that must be medically revised. And although the watch is not intended for swimming, its IP68 certification is water resistant up to 2 meters deep in a maximum of 30 minutes.
The device is practically independent from the mobile, since it makes use of GPS and Glonass positioning to detect our actions optimally. We will have at our disposal 12 sports modalities to obtain exhaustive records: running, indoor running, hiking, walking, elliptical, mountaineering, tennis, skiing, soccer, bicycle, indoor bicycle.
Product Features:
● 1.3 Inch AMOLED Color Screen
1.3 Inch AMOLED high-resolution display, makes the displayed content more vivid and beautiful. Bigger screen, fit the width of the wrist, bring a pleasant feeling of wearing. The big screen displays a comprehensive and rich information, raise the wrist, efficiency is obvious.
● Built-in Multifunction NFC
Built-in multifunction NFC, can simulate your bus card and makes travel more convenient. Simply lift your wrist and place the smartwatch in the sensing area to implement the bus card function.
● Mi Home Smart Home Control
This smart watch can be connected to a variety of smart home devices in the Xiaomi eco-chain, including sweeping robots, air conditioners, rice cookers, electric fans and more. Just click on the Mi Home App or Xiaoai classmates to achieve remote control.
● Built-in Intelligent Voice Assistant - Xiaomi Ai
This smart watch has a built-in smart voice assistant that makes the watch more than just an accessory and can be a personal assistant to help you solve problems.
● 11 Sports Modes and GPS + GLONASS Dual Satellite Positioning System
Built-in11 sports modes, including running, indoor running, trail running, walking, elliptical, mountain climbing, tennis, skiing, football, outdoor riding, indoor riding. At the same time, the GPS+GLONASS binary positioning system has been added to accurately record your movement trajectory and tell you the calories burned.
● Optical Sensor, 24-hour Heart Rate monitor
Uses a new generation of high-precision optical sensors and algorithms for more accurate monitoring and lower power consumption. The all-day heart rate recording function allows you to see your heart rate changes throughout the day, discover abnormalities in time.
● Long Standby Time
It's not easy to increase the length of life on a smart watch with a rich feature set and AMOLED colorful display. But Amazfit Verge smart watch with ensures about 5 days ultra-long standby time for a full charging.
● A Variety of Well-designed Custom Dials
Each dial built into the Amazfit smart watch has been carefully designed. It has a classic traditional watch style to show your calmness and stability, as well as a dynamic sports fan, to promote your youth and vitality. A variety of custom dials make it easy to respond to every scene and easily express every mood.
● More Functions
Huami Amazfit Verge smartwatche also has the function of answering and making calls, Alipay offline payment, reading WeChat and SMS message, pedometer, sleep monitoring.
Buy Xiaomi Amazfit Verge at the best price at GearVita, always look a new style with its interchangeable digital interface designs, easily control the environment of your home: https://gearvita.com/xiaomi-amazfit-...martwatch.html
Related products:
xiaomi huami amazfit stratos smartwatch 2
Staro 30.10.2018., 09:50   #43
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
NuForce BE Free8 - Truly Wireless Earbuds with NFMI Technology Unlike Others
The NuForce BE Free8 earbuds are engineered to deliver the best truly wireless sound experience. Unlike most of the truly wireless earphones available today, the BE Free8 use bluetooth to connect to the left earphones, then NFMI technology to sync the left and right earphones for a stable connection, low latency and a good sound quality experience. Free8 are IPX5 rated for sweat and water resistance. They feature both AAC for a high quality bluetooth connection with IOS devices and apt-x for a near lossless connection with most other devices, brings you superior Hi-Fi sound and robust reliability.
The BE Free8 are very light weight and include 5 pair of different sized Spinfit eartips, which helps provide a secure fit. 2 pair are shallow and 3 pair fit deeper in the ear - try them all and use the one that fits most securely. Free8 have a surprisingly stable and secure fit. Battery life is rated up to 4 hours, with the included compact case providing 3 full charges, for a total away from the wall playback time of 16 hours. There is a physical button on each earbud, making it easy to use. You can activiate Siri and Google Assistant with the built-in microphone.
Product Features:
● True Wireless Freedom
Free yourself from cables with advanced Bluetooth® and NFMI (Near-Field Magnetic Induction) technology to maintain a reliable connection between your device and both earpieces.
● Superior Sound Quality
Compatible with both AAC and aptX® LL technologies to provide high fidelity audio to any device including iPhone®, Android™ and Windows® phones, as well as PCs and Macs. Feature dynamic drivers with NuForce proprietary sonic coating (a razor thin and strong coating of several refractory metals for close-to-perfect piston movement) ensures lightning-fast transient response and ultra-low distortion.
● Non-stop Music and Calls
Enjoy up to 16 hours of listening, ideal for audio and phone calls on the move. Four hours of continuous uninterrupted audio with three additional full charges using the portable charging case.
● Full Headphone Functionality
These multi-functional truly wireless earbuds have a built-in cVc™ noise-cancelling microphone for calls, and a button on top of the earpiece to to play, pause and skip songs as well as activate Siri and Google Assistant.
● Lightweight, Portable Design
Crafted from polycarbonate, these true wireless in-ear headphones are tough and lightweight making them suitable for any workout at the gym and daily commute.
● Maximum Comfort and Perfect Fit
With stylish and robust enclosures, these ergonomically designed earbuds with SpinFit® ear tips provide a secure and comfortable fit. Each pair comes with two different shapes and multiple sizes to ensure a great fit.
● SpinFit® Ear Tips
The newly patented ear tips are developed from high quality silicone. They are uniquely designed to rotate 360 degrees at the centre to allow the earbuds to sit comfortably in your ear.
● IPX5 Water-resistant
With a rating of IPX5, these true wireless in-ear headphones are weather resistant, ensuring protection from rain and sweat – making them ideal for any active lifestyle.
Go to GearVita and buy it, free yourself and go truly wireless from today: https://gearvita.com/nuforce-be-free...earphones.html
Related products:
buy xiaomi lyej05lm
buy qcy q26 pro mini wireless bluetooth headset
Staro 30.10.2018., 12:05   #44
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Beelink Z85 Mini PC Supports HDMI + VGA Double Screens Display
The Beelink Z85 Mini PC sports the new high cost-effective chip, Intel Atom Z8350 processor with a quad-core CPU and Intel HD Graphics 400 GPU. This hardware is supported by 2GB of RAM and 32GB/64GB of internal storage which can be expanded using an SD card to about 64GB. The implication of this hardware combination is that users will experience high performance and the video/image quality is ten times better than an average mini PC. In addition, this SoC is a low power consuming chip which delivers a seamless operation. This device can offer a fantastic daily performance, you can either watch movies at high speed or download applications you want to use, and you don’t have to worry about its RAM size, it is more than enough.
Main Parameters:
CPU: Intel Atom Z8350
Core: Quad Core
GPU: Intel HD Graphics 400
RAM: 2GB
RAM: 32GB/64GB
Max. Extended Capacity: SD card up to 64GB
5G WiFi: Yes
Bluetooth: 4.0
RJ45 Port Speed: 1000Mbps
Product Features:
● Intel Atom X5-Z8350 processor offers stunning visual and low power consumption.
● Performance upgrade comparision - better heat dissipation and one more USB 2.0 port added.
● HDMI + VGA double screens display, you can connect monitors simultaneously with two video interface, up to 4K × 2K 30Hz.
● Powerful storage of 2GB RAM and 32GB / 64GB ROM, free expansion.
● Support voice operation, play music, and broadcast news.
● 4K HD lets every details shine, display quality is more exquisite and vivid, more clear.
● Batter heat dissipation, more vents and dustproof net inside to bring a better experience.
● More stable network signal, faster network speed.
● Well-mounted design, simple, convenient and practical, easy to place with the mounting bracket and two HDMI cables.
Applying the coupon code "Z85MP32" on GearVita, you can get this mini pc 32GB with the price of $89.99. Applying the coupon code "Z85MP64", you can get the 64GB with the price of $95.99.
Beelink Z85 is a very convenient device for people who have light work and less space. It has a superior connectivity system and superfast network transfer speed, which is very much suitable for offices as they require less space and efficient working performance: https://gearvita.com/beelink-z85-min...-64gb-rom.html
Related products:
xiaomi mi box s global version
beelink s2 mini pc
Staro 31.10.2018., 07:54   #45
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi Mijia 1S Walkie Talkie Accompanies You to Chat Along the Way
The Xiaomi Mijia 1S Walkie Talkie is packed with some powerful features – a huge 10km range, 8 days of standby time and up to 17 hours of talk time, GPS positioning and even an FM radio function. It has a detachable antenna for easy storage and has a micro-USB port for charging that can also be powered with a power bank. It supports the Very High Frequency (VHF) range spanning from 136MHz to 174MHz, also comes with support for the Ultra High Frequency (UHF), i.e. the frequency range between 403MHz and 470MHz. Xiaomi walkie talkie can be used almost anywhere, including metropolitan areas with a high degree of radio interference. On top of that, the device comes with support for FM Radio, allowing you to tune in to your favorite radio stations, also capable of location sharing.
Product Features:
● 41% thinner than last generation, 43% lighter, built-in back clip, one hand handling.
● Not only support 3.5mm earphone port, but support Bluetooth headset with dual mode Bluetooth chip.
● Micro USB charging port, no need to worry about loss of charger, convenient and practical.
● Quick to form a team, once one starts a team, the others can click to join the team without putting complicated frequency.
● Location share function, in the range of calls, it can check the location of teammates by the screen or App even there is no Internet.
● 2190mAh big capacity battery, micro-USB charging design.
● Long time to use, 8 days stand-by time,17 hours for normal use.
● Auto detection function during charging, prevent the risk of overcharge, over discharge, over voltage and other issues.
● FM radio function, it can search channel in 87 - 108MHz, providing entertainment apart from communication, but the talking between walkie talkie have priority when listening to radio.
● Digital filtration, good talking effect even in various complicated environment.
● In order to achieve clearer and louder call sound, the speaker has a speaker volume that is 65% larger than the effective radiation area of the previous generation. The maximum volume is increased by 162%, and in a noisy environment, good call performance can still be maintained.
● Sending voice without pressing talking button when your volume is reached to a certain level,free your hands.
● Suitable for two-way communication from different locations.
● A maximum power of 3W and a call distance of 1-5 kilometers in order to meet the call needs in a variety of scenarious.
● Comes with UHF frequency range of 403-470MHz, and VHF frequency range of 136-174MHz., give it the ability to be used in a densely populated area as well as in the wild where there is little or no obstruction to the radio waves.
● Comes in black and white colors with along with handy display and some buttons on the surface for controlling the device.
Applying the coupon code "MIJIA1S" when checkout on GearVita, you can get this Mijia 1S walkie talkie with the price of $41.9: https://gearvita.com/xiaomi-mijia-1s...ie-talkie.html
Related products:
xiaomi smart walkie talkie
xiaomi mijia d301 walkie talkie
Staro 31.10.2018., 10:39   #46
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Enjoy The Silent Private Space with Huawei AM185 Active Noise Cancelling Earphones
Huawei AM185 earphones feature built-in exclusive noise cancelling circuit, high sensitivity MEMS silicone microphone and professional noise cancelling chip, it can receive and analyze the spectrum of outside noise, and then product the opposite signal to cancels out the noise so that blocking outside noise getting to your ear and lead to undisturbed silent private space.
Product Features:
● A full-bodied bass output with a silky mid range and crisp high end, reproducing natural sounds for an immersive and high-fidelity listening experience.
● Special sound chamber design and high-end speakers (two dynamic drivers and two NdFeB D13.0 balanced armature drivers) with composite diaphragms and ultra-high purity (99.995%) oxygen-free copper cable keep sound distortion to a minimum and enhance audio definition and fidelity.
● Housed in a precisely cut aluminum shell with low-key gunmetal finish, giving them a smart and modern look.
● Can be directly charged through the headphone jack of your device when used in combination with the Huawei Honor 8 or other phones supporting earphone direct charging technology.
● Active Noise Cancelling gets rid of the noise distractions around you, let you have a good rest or just immerse yourself in thinking in your spare time.
● Fit for multiple digital devices, no matter what devices you are used, just turn on the cancel switch, the noise canceling will come true.
● Adopts the moving-coil and balanced armature hybrid dual drivers design, deliver more wide voice register and more detailed sound.
● U design earhook design let the earphones stay securely in your ears, comfortable to wear. Meanwhile, three pair of earbuds in different sizes are available.
● With low power consumption design, it can works 8 hours for noise cancelling.
● Supports charging the earphones directly with Huawei phones, for Huawei Mate 8 / Mate S / Mate 7 / Honor 7 / Honor 6 Plus, P9/P9 Plus.
● L shaped plug and metal braided tangle-free cable for easy holding.
If you are looking for a headset under $100, which includes additional functions such as noise cancellation, good sound, and also an eye catching and elegant design, come to GearVita, Huawei AM185 is an excellent value for money: https://gearvita.com/huawei-am185-ea...ancelling.html
Related products:
xiaomi lyxqej01jy earphones
huawei anc 3 earphones
Staro 01.11.2018., 05:13   #47
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
OnePlus 6T - In-Display Fingerprint, Smaller Notch, Larger Battery
The OnePlus 6T aims to improve on the already excellent OnePlus 6. It utilizes a larger 6.41 inch AMOLED display with a smaller notch design that’s known as a teardrop. Another big change of the display is an embedded fingerprint scanner. The rear fingerprint scanner has been removed and the new in-display scanner lets OnePlus 6T return to putting fingerprint readers on the front of the phone. It has also improved the brightness on its displays for better viewing outdoors.
The headphone jack is gone so that can increase the size of the resonance chamber on its internal speakers, as well as make room for a few other components without having to increase the phone size much. The OnePlus 6T runs the same Qualcomm Snapdragon 845 chipset as the OnePlus 6 and depending on the model has 6GB or 8GB of RAM and 128GB or 256GB of internal storage. Batteries was also overdue an upgrade here, it packs a 3700mAh battery that should easily make it through a day or more.
Main Parameters:
Display: 6.41 inches
Resolution: 2340 x 1080 pixels 402 ppi
Aspect Ratio: 19.5:9
Type: Optic AMOLED (Support sRGB, DCI-P3)
Cover Glass: 2.5D Corning® Gorilla® Glass 6
Operating System: OxygenOS based on Android™ Pie
CPU: Qualcomm® Snapdragon™ 845 (Octa-core, 10nm, up to 2.8 GHz), within AIE
GPU: Adreno 630
RAM: 6GB/8GB LPDDR4X
Storage: 128 GB/256 GB UFS 2.1 2-LANE
Camera: 16.0 + 20.0 rear camera and 16.0 front camera
Battery: 3700mAh, fast charging (5V 4A)
Unlock Options: In-display fingerprint sensor, face unlock
Bluetooth: 5.0, support aptX and aptX HD
NFC: Enabled
Product Features:
● Screen Unlock
Unlock your OnePlus 6T with the fastest in-display fingerprint sensor on any smartphone, setting a new industry standard with cutting-edge screen unlock technology.
● Display Design
Featuring our largest display ever and a resilient glass back, the OnePlus 6T was crafted with care and purpose. Experience a 6.41 inch Optic AMOLED display for true immersion through an 86% screen-to-body ratio, beautifully slim cut-out, and more.
● 16.0 + 20.0MP Dual Camera
Nail every detail night or day with Optical Image Stabilization (OIS) and our new Nightscape feature. Photos look more dramatic thanks to new Studio Lighting and an industry-leading camera sensor for better pictures.
● Fast and Smooth
Do more with up to 6GB/8GB of RAM, the Qualcomm® Snapdragon™ 845 Mobile Platform, and up to 128GB/256GB of storage. Hardware and software work together for an experience that is consistently fast and smooth.
● Large Power
With a 3700mAh battery, the OnePlus 6T puts more power into your hands than ever, while our Fast Charge technology gets you up and running in just half an hour.
● Oxygen OS
The operating system is all about ensuring your phone works for you, not the other way around. Powered by Android Pie, the OnePlus 6T offers more features than ever on the fastest and smoothest version of Oxygen OS yet.
● Type-C Bullets
Whether you’re listening to music, watching a video, or enjoying your favorite podcast, the Type-C bullets offer superior sound quality and convenience.
The body is glass on both the front and back of the device, and you’ve got the choice of two colors on GearVita: midnight black or mirror black. That’s right: you can have any color you like as long as it’s black, the reflective choice does look quite different to the matte version. If you want bigger display with smaller notch, terrific power and cutting-edge features like the in-screen fingerprint scanner, the OnePlus 6T is made for you: https://gearvita.com/oneplus-6t-4g-s...128gb-rom.html
Related products:
oneplus 6t 8gb 256gb
oneplus 6t 6gb 128gb
Zadnje izmijenjeno od: gearvita. 01.11.2018. u 05:24.
Staro 01.11.2018., 10:11   #48
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Huawei ANC 3 Earphones with Multi-Scenario Noise Cancelling
Equipped with the advanced Active Noice Cancellation (ANC) technology and Hi-Res sound quality this Huawei ANC 3 delivers exceptional audio. Deep bass with rich mid-range, and crisp high end, bringing an excellent listening experience.
Huawei ANC 3 is equipped with a dedicated noise reduction circuit, including custom high-sensitivity silicon wheat and professional noise reduction chips, and it receives and analyzes the external noise spectrum and inverts it. The phase of the signal to offset it, so as to achieve the purpose of shielding external noise.
It is designed with in-ear earbuds and is very compact and is lighter than previous generation 2 noise reduction headphones. The earphone housing maintains a very good metallic color. Due to the concentric circular design, the earphone housing looks three-dimensional and quite tall. It is the perfect combination of business style and fashion classic.
Product Features:
● Adjustable active noise cancelling function.
● 3 noise cancelling modes for different purposes.
● In-ear design in combination with ANC reduce ambient noises and improve the music playback.
● 13mm moving-coil driver brings good sound quality, and it has been certificated by Hi-Res Audio.
● The conductor is made from oxygen-free copper that improves audio detail resolution and achieves minimum sound distortion.
● Type-C port charging design, you can charge it by your type-c smartphones.
● MEMS silicone microphone with anti-wind design ensures clear phone calls.
● Three-button on-cord control, convenient to use.
● Integrate the ANC button into the side of in-line control for one-press ANC on/off.
● Aviation aluminum alloy cavity with elegant design, fashion appearance.
● Ergonomic in-ear design and food-grade silicone eartips in multiple sizes for ultimate comfort.
Overall, the exterior design is the perfect combination of business style and fashion technology, the new flagship P20 with Huawei can be said to be a perfect match. Whether you are a music lover or not, come to GearVita, Huawei Active Noise Cancelling earphones 3 is definitely the best choice: https://gearvita.com/huawei-anc-3-ea...ancelling.html
Related products:
huawei am185 earphones
xiaomi lyej05lm earphones
Staro 01.11.2018., 11:39   #49
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
LEMFO LEM8 4G Smartwatch, Capture Your Heart
Simply beautiful, this is the design approach of the new LEMFO LEM8. It has a minimalistic design of a titanium alloy body, a 1.39'' inch AMOLED touch screen with 400 × 400 pixel resolution, and a skin friendly silicon strap with stainless steel buckle. The smartwatch overall has an IP67 waterproof and dustproof rating able to withstand splashes of water. It is powered by an MTK6739 processor, making it fast and smooth in processing apps and notifications. 2GB RAM and 16GB ROM will surely satisfy your craving for more apps. It is also loaded with Nano SIM supporting 4G connectivity, you can make smooth independent calls. With the 580mAh lithium polymer battery, it has a standby time of about 2 days.
Product Features:
● High-level Configuration
Equipped with more stable Android 7.1.1 OS and 2G + 16G huge memory, brings the best using experience.
● High-definition Full Color Display
Selection of high quality AMOLED HD 1.39 inch screen, 400 * 400 resolution. Equipped with aero titanium alloys watch case, which is slim and more wear-resisting. Equipped with 2MP HD camera, enable you to video chat and take pictures freely.
● IP67 Level Waterproof and Dustproof
Enough to resist water and dust from daily life. Not suitable for taking shower, swimming and diving.
● Barometric Height Monitoring
Accurate movement algorithm, barometric height monitoring in real time, your trust health guardian.
● Heart Rate Monitoring All Day
Turn on heart rate monitor to check real-time feedback measurements.
● Smooth Independent Call with 4G Connection
4G independent phone call with Nano sim card, won't miss any message and calling.
● Customized Your Own Watch Faces
Click the settings icon on the preview dial interface, take a photo or select a photo in the photo album to customize the dial you like.
● Do Sports without Your Mobile Phone
Recording and collecting steps, calorie and all sports data in real time, to have a scientific sports and live a healthy life.
● Various Commonly Used Functions, Make Life Easier
App download, misic, Bluetooth, search voice, weather report, calendar, etc., various common functions, to replace your mobile phone.
● Comfortable Watch Strap
TPU soft material strap, fashionable and skin-friendly. Wicking and anti-microbial, perfect fit with your wrist.
Get LEMFO LEM8 from GearVita and start your smart sports life: https://gearvita.com/lemfo-lem8-4g-smartwatch.html
Related products:
lemfo lem x
lemfo lem7
Staro 02.11.2018., 04:31   #50
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Sunvell T9 TV Box Opens Your New Horizon
Sunvell T9 TV Box is a small and smart media player. The latest Android 8.1 gives you the ability to run virtually any Android APP on your TV. The powerful Amlogic RK3328 CPU with Mali-450MP2 GPU provides stellar performance for high definition video playback. You can freely enjoy all your movies, food shows and entertainment programs. It will bring you much fun and convenience.
Product Features:
● Android 8.1 OS
The latest Android 8.1 operating system version can be perfectly compatible with majority of software, games and application programs, it also has many convenient and user-friendly operation options and functions which can give a better user experience.
● High Performance
T9 TV box comes with the latest RK3328 Quad-Core Cortex-A53 CPU with Mali-450 MP2 GPU, which make sure the box running stable and smooth to load movies, pictures and games without buffer, no need to wait for wonderful moment.
● 4GB RAM and 32GB ROM
With 4GB RAM 32GB ROM high storage ensures speed and stability of the operation system, you can better run apps without any lagging or freezingprovide, play games and watch movies more smoothly, extendable storage capacity provide more space to download your favorite Apps.
● 3D + 4K + H.265
T9 TV box supports 4K and 3D function. H.265 Hardware decoding can saves 50% of bandwidth resources, you can watch movies fluently. The 4K 1080p resolution is 4 times more than full HD, so you can see every detail of the screen is glossy.
● Massive Applications
Google Play Store supports many Android apps, just connect it to an HDTV and start streaming in minutes.
● 2.4G WiFi and Bluetooth 4.1
T9 Android TV box supports 2.4G WiFi, if you like using WiFi, it exactly match your needs with stable, fast and high quality WiFi signal. And the Bluetooth 4.1 allows you use mini keyboard and headset to enjoy the box.
● More Convenient Operate
T9 TV box are connected through a HDMI cable. Two USB port, connect with your mouse and keyboard to help you operate more convenient. Infrared remote control let you enjoy your wonderful life which the wireless brings to you.
T9 Android TV Box brings you an absolutely unusual audio-visual experience with its different and attractive appearance, user-friendly customized build, very easy setting and usage, as well as the mighty fast and strong processor. With the coupon code "SVT9Box" of GearVita, you can get this powerful TV box with the price of $39. Limited to 50 pieces, hurry to grab it: https://gearvita.com/sunvell-t9-tv-b...-32gb-rom.html
Related products:
sunvell t9 tv box 64gb
Staro 02.11.2018., 10:14   #51
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
KZ ZSN Second Generation Hybrid Earphones Show More Sound Details
KZ ZSN earphones are new generation of professional hybrid technology mix drive headphones. In the name of science and technology, redefine sound quality. It has the shocking low frequency of the dynamic unit, and also has the powerful high-frequency analysis of the balanced armature unit, which has the high-frequency performance ability that the dynamic unit can never reach and is more rich and delicate.
Product Features:
● Precision metal craftsmanship combined with the bright colors of resin, together with the bright color of each fashion sense, make the overall appearance fashion.
● The second generation of hybrid drive scheme to enhance voice detail.
● The self-developed titanium film moving coil unit greatly improves the high frequency ductility.
● Intelligent noise-canceling gives you a high-definition enjoyment.
● Improved 0.75mm gold-plated, 2PIN plug-in structure.
● Solid ergonomic design for your wearing comforts.
● The custom MIC is designed with dual capacitors to support the standard (US standard) interface standard mobile phone high-definition call.
● The self designed silicone ear muff is more comfortable to fit into the human ear.
● Professional wire rod, tensile resistance, anti-bending and corrosion resistant.
● Improved detachable connection, the groove protection design protects the earbuds' pins from distortion and prolongs the lifetime.
● 3.5mm audio jack, compatible with most of the phones, computers, and portable media devices.
There are three colors - black, purple and cyan as well as with mic and without mic options on GearVita for you to choose from: https://gearvita.com/kz-zsn-hifi-hyb...ancelling.html
Related products:
kz ba10 earphones
kz zs10 earphones
Staro 02.11.2018., 11:51   #52
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
GearVita 11.11 Big Sale - Deals from $1.11
On the occasion of the 11.11 coming, GearVita has launched a 11.11 promotion, lasting until November 12. The lowest price of this deal starts from $1.11, and the discount is super big! More daily flash sale and cool add-ons are waiting for you to take participate in.
Flash sale products will be replaced every two days, and some are even sold at a loss, in limited quantities, on a first come, first served basis. Missed this time, there will not be such a preferential price. Come to GearVita every day to see if there is any product you like, and grab the time to buy it. Any order over $50 will obtain a $9.9 redemption opportunity for an add-on, each order is limited to one chance and is really cost-effective.
There are also many hot-selling Xiaomi smartphones, including the newest Mi 8 Lite global version, which are given back to you at a price you will never expect. For example, the original price of Mi 8 Lite 128GB blobal version was $379.99 but the current price is $289.99. The original price of Mi 8 Lite 64GB global version was $329.99 but the current price is $259.99. The original price of Mi Max 3 64GB global version is $309.99 but the current price is $249.99.
The smart watches, audio products, tablets and accessories, smart homes of all major brands are also presented at prices that cannot be rejected. With so many categories of goods, there is always one item you like.
For more details please click here to learn: https://gearvita.com/11.11-sales
Zadnje izmijenjeno od: gearvita. 02.11.2018. u 13:46.
Staro 03.11.2018., 05:59   #53
gearvita
gearvita's Avatar
Datum registracije: Sep 2018
Lokacija: China
Postovi: 241
Lanniu A6 Colorful LED Speaker, Also A Power Bank Supports Wireless Charging
The elegance of Lanniu A6 speaker could create a powerful atmosphere at home, and its interesting lighting features can make music vibrant. Easy to carry,making it to be an ideal travel companion.
Product Features:
6 modes colorful lighting effect.
360 degree omnidirectional function will bring beautiful light show, the lightshow will flash as the music plays.
5500mAh battery capacity, can be used as a power bank.
The top area support wireless charging, supports all smartphones that are compatible with Qi wireless charging.
8 hours of playtime.
Equipped with Bluetooth 4.2, supports call function, you can answer the phone anywhere.
There are two colors available on GearVita, black and white. Open it at night, you can enjoy the beautiful light show while listening to the wonderful music, add luster to your nightlife, really enjoyable: https://gearvita.com/lanniu-a6-porta...inbow-led.html
Related products:
xiaomi bluetooth speaker 2
bluedio ts-5 speaker
Staro 03.11.2018., 10:27   #54
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
You Will Shine Out with No.1 G12 Smartwatch
The No.1 G12 smartwatch has a beautiful rectangular design with its stainless steel body with IP67 waterproof rating. The wearable has a removable strap, you can buy 22mm watch bands on your own, even to customize your own band. The display is also amazing with its 1.3'' inch 3D HD touch screen protected by a Corning Gorilla glass display.
It is a sporty, classy looking smartwatch that logs your daily activities including steps, calories, and distance, it can also measure your heart rate with the built-in high-quality sensor. It is lightweight and comfortable to wear with its ergonomic design.
Product Features:
● Stainless Steel Bezel, Superb Craftmanship
316L stainless steel, vacuum coating, 45 procedures, 113 process to make it.
● Colorful HD Screen
1.3 inch colorful 3D HD touch screen by Corning Gorilla Glass 3. Multifunctional design, durable, light, anti allergy and comfortable.
● Various Watch Faces To Go with Your Mood
Stylish and practical watch faces mix and match your occasions and outfits.
● Face The Challenge of Rain Or Shine
IP67 waterproof and durable quality, you can still use the watch when you wash your hands or on rainy days. Stay with you along the way, rain or shine.
● Exercise Monitor and Scientific Training
Your personal training coach, it helps you focus on your training without worry about plans, track your daily activities, when you switch to another sport, it offers you a detailed BMI report.
You can simply place one finger to check your heart rate and get to know your health condition with all day monitoring. When the new watch spots your heart rate is too high, too slow, you will get a notification.
● Sleep Monitor, Scientific Managemant
Get a good sleep and be in a good state, it monitors and analyzes your heart rate and sleep time, helps you know your sleep condition, it equips with auto wake up function and wakes you up in a gentle mode every morning.
● Movement Patterns
8 movement patterns: running, walking, swimming, cycling, football, basketball, hiking and badmoniton.
● Don't Miss Out Your Important Things
Not with your cell phone? No pressure, you can get notification from your smart watch when you receive a message or phone call, you will get a nitification with vibration. In the meanwhile, the screen shows the notification content.
● Sedentary Reminder
Add warm sedentary reminder function for your busy life, you will get a notification to remind you get up and stretch your body after sedentary. It helps you better your life and monitor your health.
● Multifunctional App
You can custom your personal training according to your physical health.
If you see it as it really is, you will think it is a business watch because of its appearance. If you happen to be someone who likes this style, don't miss it. Get it from GearVita and enjoy fitness from now: https://gearvita.com/no-1-g12-smartwatch.html
Related products:
xiaomi huami amazfit bip
no.1 g8
Best Brand Consumer Electronics Provider GearVita
gearvita je offline   Reply With Quote
Staro 05.11.2018., 04:43   #55
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Dacom K8 Earbud - Invisible Body, Cozy Wear
Dacom K8 earbud, with an invisible tiny body, the lightweight and minimal shape create a perfect fit, so light and discreet you will hardly notice you're wearing it, ensures no burden on your ear. 8mm driver units it conducive for bass, added the noise cancelling technology, delivers pure and powerful bass for you. Equipped with a mic so you can answer phone calls easily.
Effortlessly pair your favourite wireless device such as a smartphone or tablet with the mini wireless earbuds. With zero wires on the Dacom K8, you’re able to avoid the struggles of tangled cords. The Dacom K8 high performing chip enables the earbud to have a low power consumption while still providing you with a high performance.
Product Features:
● Smallest Invisible Earbud
Only 4.3g, lighter than a one-dollar coin, impossibly small, it virtually disappears in your ear.
● Wireless Experience
Totally hands free, put tangled wires behind you, enjoy music in your office, during driving, everywhere.
● Multi-points Connection
Advanced Bluetooth V4.1 enables easy and fast connecting with smartphones, tablets and other Bluetooth enabled devices and it can connect with two Bluetooth devices at the same time.
● One-button Operation
Featuring a single multi-function button, answer, hang up, pause or play music with just a tap.
● Built-in HD and Sensitivity Microphone
Acoustic echo cancellation guarantees high-quality sound and enables you to call clearly at any place, seamlessly switches between incoming voice calls and music.
● Long Battery Life
40mAh rechargeable battery, up to 2.5 hours continuous talk time or 2 hours music time.
Dacom K8 is offering tested and proven best quality sound and comfort for office and driving. With the price of only $9.99 after applying the coupon code "DacomK8" on GearVita, you will absolutely love it: https://gearvita.com/dacom-k8-wireless-earbud.html
Related products:
syllable d9
qcy q26 pro
Staro 05.11.2018., 10:35   #56
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
ZGPAX S222 Wearable Action Camera Records The Bits And Pieces of Life
ZGPAX S222 action camera takes videos in 2K (Full HD) and 720P (HD), the refresh rate is 30 frames-per-second. The built-in 8-megapixel image sensor comes from "General plus", whose sensors are mainly used in inexpensive dash cams. The recordings made in AVI format can be saved on a microSD memory card. For a particularly wide field of view provides a 153-degree wide-angle lens. Matching the video, the sound is recorded via an integrated microphone.
Product Features:
● The depth of waterproofing is 30 meters, convenient for you to shoot wonderful water sports anytime and anywhere.
● Low light ( luminous mode ) shooting function makes evening video more exciting.
● 8 mega pixels, support HD 1080P shooting at 30fps.
● HDR high dynamic range imaging technology for more details.
● High-capacity battery of 900mAh.
● With WiFi function, you can more easily view, control and share on the mobile phone by APP.
● 6 layer A+ glasses lens and F1.8 aperture, video is more clearer.
● Tri-proof: waterproof, drop-resistant, dust-proof
● Multipurpose sports camera: wearable, magnetic suction, etc..
● Supports up to 32G memory cards.
● Strong magnetic suction, multiple uses of the camera.
● Multiple-format recording: MOV/1080P/720P, video shooting is more comfortable.
● Ultra small appearance, easy to use.
This is a wearable, magnetic, waterproof, drop-resistant, dust-proof sports camera that sells for $69.99 on GearVita. Compact body is easy to carry, with hand-wearable and magnetic function, you can record wonderful moment anytime and anywhere: https://gearvita.com/zgpax-s222-wear...on-camera.html
Hot sale products:
buy xiaomi mi a2 lite smartphone
buy xiaomi mi max 3 4g smartphone
Staro 06.11.2018., 05:13   #57
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Share Happiness with Your Lover by Awei T3 Earbuds
The Awei T3 earbuds is durable, sturdy, and packed with great sound for your entertainment, leisure, sports, and other activities. Designed with your lifestyle in mind, pair in a few seconds with your smartphone, tablet, or music player, and let your favorite music and podcasts drive you forward. With 3.5 hours of music playing time and sweat-proof design, you can take it for a good work out, knowing the headset will remain stable as you sweat it out.
Product Features:
● The stylish portable charging compartment with 480mAh battery capacity, provides full charge for the earplugs 6 times, not afraid no electricity outdoors.
● Truly wirelss, cable-free, it is more convenient to wear.
● Ultra small, only 5g weight, no pressure in your ears.
● Bluetooth V5.0 makes transmission is more stable and lower power consumption.
● Compatible with most Bluetooth-enabled devices, it will connect automatically with a phone paired previously.
● Built-in A2DP / AVRC audio processing system, with a very good CVC6.0 noise reduction, perfect for stealth listening or watching at work.
● With IPX4 waterproof / anti-sweat function, it is suitable in gym, outdoor running.
● Ergonomic design, comfortable fitting wear, firmly do not fall.
● True binaural wireless, you can also choose to use monaural or binaural mode.
● Optimized circuit design, product has over-current protection, short-circuit protection, does not hurt the equipment.
● Support microphone hands-free call function, safe and convenient.
Get this headset from GearVita, happiness will become very simple since then. Wireless bondage is more free and can be shared with your friends, family members and lovers: https://gearvita.com/awei-t3-bluetooth-earbuds.html
Hot sale products:
buy xiaomi lyej05lm
buy xiaomi mi pad 4 plus 4g
Staro 06.11.2018., 10:26   #58
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
KingWear KW18 Smartwatch Phone - The Beauty of Round Screen Keeps Abreast of The Time
The KingWear KW18 smartwatch has been designed with a captivating 1.3 inch HD touchscreen display that features a anti-scratch material for a durable finish. Made from anodized aluminum, the watch case is clear, robust and wear-resisting ensuring it is durable for all outside activities while also looking fashionable. The smartwatch phone features many practical functions, includes heart rate, pedometer, sedentary, sleep analysis, recorder, and phone call, Bluetooth.
Product Products:
● 1.3 inch HD Touch Screen
By using Sharp brand 1.3 inch AMPLED round screen with non-air-gap, KW18 has an awesome display as well as the hypersensitive touch, which can supply you the clear display even in the glare.
● Sapphire Crystal Glass Mirror
KW18 is prolonged wear-resisting because of its sapphire crystal glass mirror surface for its screen, which is similar to the screen surface of classic Swiss wristwatches.
● Metalli-feeling with Outstanding Workmanship
Made from anodized aluminum, the watch case is clear, robust and wear-resisting.
● Side Two-in-one Card Slot
Patent design for card slot, TF card and SIM card are two-in-one, communication anytime anywhere.
● Information Synchronization
With independent SIM card slot to achieve phone functions, notifications of your smartphone can be displayed on KW18 simultaneously, such as the incoming calls, SMS, Facebook, WhatsApp, emails and more.
● Sleep Monitor
Can effectively monitor your sleep quality, including your sleep times and sleeping depth, which helps you to develop a healthy lifestyle.
● Pedometer
The smartwatch can record your steps, distance and calorie consumption to get enough exercise at the same time to avoid overexertion.
Prolonged sitting is a common problem for office worker groups. Wearing this smartwatch, it can be set a period time to remind you to take a break for relaxing your body.
● Anti-lost
After connecting KW18 and your smartphone via Bluetooth, once the distance between KW18 and your smartphone exceeds 10 meters, both KW18 and your smartphone will be alerting. Meanwhile, they can find each other easier anytime.
● Waterproof for Daily Life
Waterproof and dustproof design, easily satisfy all your requests of waterproof in daily life (no for swimming, bath and soaking).
● Compatible with Both IOS and Android OS
Carrying ultra-high performance CPU MTK2502C, KW18 has a fluent reaction spped under both IOS and Android OS.
If you are a person who likes a round screen watch, you may like it because of the elegant colors and fantastic user interfaces, creating a cool fashion. There are three colors on GearVita - black, white and gold, each color has its own unique beauty: https://gearvita.com/kingwear-kw18-s...tch-phone.html
Hot sale products:
buy xiaomi mijia quartz waterproof smartwatch
buy xiaomi mi 8 lite 64gb
Staro 07.11.2018., 09:27   #59
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
QKZ CK8 Earphone - Dual Units and Four Speakers
Let mono-driver headphones be a thing of the past and step up your audio experience with QKZ CK8 earphone. QKZ CK8 dual driver headphone, creates an audio experience unlike anything you've ever heard before. Equipped with two drivers and seamless ergonomic fit, the sonic expression of your songs comes alive with exquisite detail and emotional power, by separating the high-end frequencies from the mids and the bass. Sit down, slip them in, and become the music. It's your music, you deserve it.
Product Features:
● Quality optimization of exclusive patent, metal composite vibrating membrane.
● Ear and tail pipe connection with 45° oblique angle in-ear design for ergonomics.
● Light-weight in-ear headphones with 3 sizes of nipple grade silicone earcaps ensures a long time comfortable wearing.
● HI-RES certification, good sound that can be seen.
● 8mm and 10mm dual moving coil unit make the middle and high frequency more natural and bass stronger.
● Built-in microphone enables hands-free calls, with in-line control, easy to control music and calls.
● Two vocal units are arranged in the same unit to suppress the distortion of the driving unit, so that the sound can be equalized to radiate, and the low frequency, which can be replayed freely and has a sense of weight, is played freely.
● Specially designed small high-energy magnet, which is close to the magnetic flux of 1 tels make sound powerful and driven energy, dynamic performance.
● Using the fine electronic frequency division technology, the unit energy is carefully adjusted to ensure the smooth transition of high, middle and low three-frequency and complements each other.
● Universal 3.5mm gold-plated plug, compatible with smart phone, Tablet PC, MP3 and other 3.5mm audio devices.
With extreme night black/snow mountain white/platinum silver/streamer gold on GearVita, there is always one that suits you: https://gearvita.com/qkz-ck8-in-ear-...-with-mic.html
You may like:
xiaomi lyej05lm review
qcy q26 pro mini wireless bluetooth headset review
Staro 08.11.2018., 08:18   #60
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Doing Sports with Dacom Armor G06 Earphones, No Need Worry Too Much
Dacom Armor G06, true wireless stereo headset, in-ear with headband design, closely fits with your ear canal, reduce pressure on your ears and not worry it will drop or fall while doing sports. IPX5 professional waterproof technology, not afraid of drizzle or heavy sweat for exercise any longer.
Product Features:
● IPX5 Waterproof
Protecting from splashing water and rain, protecting from the corrosion of haze and sweat.
● Lower Failure Rate
Dacom sport Bluetooth earphone can be reduce 65% failure rate than general brand.
● CSR Bluetooth 4.1 Chipset
Faster transmission speed, lower consumption, strong stability.
● CVC Noise Reduction with High-definition Mic
More effective shielding background noise, speaker more clearly, HD sound quality.
● Long Time Standby
With 150mAh lithium-polymer battery, the talk time is up to 8 hours, playing time up to 8 hours and standby time up to 180 hours.
● Other Features
Hands-free call, English voice prompt and multi-point connection.
With three colors on GearVita for option, Dacom Armor G06 earphones is a perfect sports partner for you to enjoy running, climbing or driving: https://gearvita.com/dacom-armor-g06...earphones.html
Hot sale products:
xiaomi lyej05lm
