Staro 19.08.2014., 09:34   #5131
Darude
DJ_Darude kicks ass...
Darude's Avatar
Lokacija: Virovitica
Postovi: 213
evo ja složio jučer novu pilu...
važe 41kg
..:: Vlak je uvijek brži ::..
Darude je offline   Reply With Quote
Staro 19.08.2014., 10:21   #5132
O9g1
Bee-do Bee-do Bee-do, TUP
O9g1's Avatar
Datum registracije: Aug 2009
Postovi: 323
Daj još koju sliju, uvijek je gušt vidjet fino složen bijeli setup... :drull:
Možda samo da još malo obuzdaš ovo kablovinje ispod MBO!? Malčice bode oko, inače đust najs!
CPU: Intel i5 2500k (BX80623I52500K) cooled by Scythe Ninja3 (SCNJ-3000)
MBO: Asus P8Z68-V PRO/GEN3
RAM: 2x4GB Kingston 1600MHz, DDR3, XMP (KHX1600C9D3K2/8G)
GPU: GIGABYTE Radeon R9 290 4GB Windforce 3x (GV-R929OC-4GD)
SSD: Samsung 840 EVO 120GB (MZ-7TE120BW) - System
HDD1: WD Caviar Black 500GB (WD5001AALS) - Storage
HDD2: WD 250GB (WD2500JS-22MHB0 ) - Backup
ODD: Samsung 22/8/8/48/32x (SH-S222AB)
PSU: XFX XXX Edition P1-650X-CAG9 650W
CASE: Fractal Design Arc midi
FAN CONTROL: Scythe KAZE MASTER 5.25″ Bay Fan Controller (KM01-BK)
FAN: 2x Fractal Design Dynamic GP-14, 140 mm intake+2X Scythe S-flex 120mm (SFF21E) exhaust
OS: W10 x64
LCD:MASTER: LG 29UM57-P Ultra širok đubar, jooooj što ga volem... , SLAVE: Dell 17"
KEYBOARD: Logitech UltraX keyboard (Y-BL49)
MOUSE: Logitech G400
SOUND: Creative Sound Blaster X-Fi XtremeMusic
HEADSET: Steelseries Siberia v2
RALLYING GEAR: Logitech G25+homemade cokpit+handbrake (modani Genius MaxFighter F-16U)
IF IN DOUBT, FLAT OUT!!!
Don't touch it! It is mine! It's all miiiiineeee!!!
Lenovo Essential B580
CPU: Intel Celeron Dual Core B820 1.70GHz (2MB cache)
LCD: 15.6" HD LED 1366 x 768
GPU: Intel HD Graphics 3000
RAM: 4GB DDR3 1600MHz
HDD: 320GB SATA
ODD: DVDRW DL
PSU: Up to 4hours (Li-Ion 6 cell)
ETHERNET: Yes (Gb LAN)
COMM: Yes (802.11b/g/n)
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
FINGERPRINT READER: Yes
CAMERA: Yes
OS: Windows 7 Profesional
Lenovo ThinkPad E560
CPU: Intel Core i7-6500U 2.5 GHz
LCD: 15.6 inch 16:9, 1920x1080, IPS-Panel, LED-Backlight, glossy: no
Extern LCD:Lenovo X24a, 24 inch 16:10, 1920x1200, IPS-Panel, LED-Backlight
GPU: AMD Radeon R7 M370 2 GB GDDR5
RAM: 16GB, 2 x 8 GB DDR3L-1600
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
ETHERNET: Gigabit Ethernet
COMM: 802.11ac, Bluetooth, Intel Dual Band Wireless-AC 8260 - M.2 Card
CONNECTIONS: 3 x USB 3.0, HDMI, VGA, OneLink connector, LAN, Headphone/microphone combo jack
CARD READER: 4 in 1 ( SD Card, MultiMediaCard, SDHC Card, SDXC Card )
CAMERA: Yes
OS: Windows 10 64x
Poštena, dobra i odgovorna trgovina +još jedna...
Straight roads are for fast cars, turns are for fast drivers!
O9g1 je offline   Reply With Quote
Staro 19.08.2014., 10:27   #5133
Darude
Darude's Avatar
Postovi: 213
Autor O9g1 Pregled postova
ajde danas još okinem...slagao jučer 6 sati cijeli setup...potrajalo
pa se žurilo stavljat "prozore"...
Staro 21.08.2014., 23:38   #5134
Darude
Darude's Avatar
Postovi: 213
još jedna kad je stavljeno H110 vodeno...
Staro 22.08.2014., 09:19   #5135
alengrosevic
alengrosevic's Avatar
Postovi: 3,799
eventualno da okreneš radijator, pa da crijeva idu prema naprijed. Tako bi se lijepo vidio cooler tj "Corsair znakić" Tako sam napravio na H100i i puno bolje izgleda.
Staro 22.08.2014., 09:27   #5136
Darude
Darude's Avatar
Postovi: 213
a neda mi se sad mjenjat sve
ionak ne gledam tolko u kučište da mi treba taj znakić
inače sve radi ko urica...složeno i hladno
Staro 22.08.2014., 09:36   #5137
ivan77
Autor xulos Pregled postova
Carbide Air 540
OVaj kabl od grafe je kasnije popravljen i zategnut, naruceni su sleeve extensioni u crnoj boji pa cu i to popraviti Inace kejs je bomba, mjesta kolko hoces a odlican za slaganje
Ovo je lijepo, al dal bi stala 3 ili 4 HDD?
Staro 22.08.2014., 14:44   #5138
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Dole imaš dva mjesta za staviti 3.5 diskove, u prostoriji iz mbo traya imaš plastičnjaka za 2.5 diskove. Tu su i dva 5.25 mjesta gdi bi se isto moglo staviti, a obzirom da otraga ima dosta mjesta, moglo bi se dograditi kavez. Mažda Corsair i prodaje, no mogli bi biti skupi.
Staro 25.08.2014., 22:57   #5139
Postovi: 8,259
Ja sam brijo da u onom kompartmentu di je napajanje stane bar 6-7 diskova. Mogli su to ubacit unutra, šteta što nisu.
Al kućište je fora, svakako.
@Xulos
fin kompletić imaš u kućištu
Staro 25.08.2014., 23:10   #5140
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Autor ivan77 Pregled postova
Fala Bi, 2 naprijed i 2 mogu stat iza ako kupis adaptere sa 5.25
Autor Pupo Pregled postova
@Xulos
Danke šn ne stane jeg, iza ima za 5 ssda mjesto i pun k mjesto za DIY kavez uz 2x 5.25. bit ce to bolje kad ubodem AIO opet, nemos bas hladit 4770k sa zrakom
Jedino sto mi se kod kejsa ne svidja je kako su rijesili tj nisu rjesili vibracije diskova. Disk kad se zavrti cijelo kuciste dobije neki tupi i glupi zvuk iako hdd holder ima neke gumene distancere, jako je lose rijeseno. To moram pod hitno rjesavati.
Zadnje izmijenjeno od: JuiceBox. 25.08.2014. u 23:29.
Staro 11.09.2014., 13:40   #5141
karlo10
šekler
karlo10's Avatar
Postovi: 115
Gdje bi mogao kupiti, po mogučnosti u Varaždinu (ako netko zna), ovakve ljepljive gumene(ili kakove već) plohice kakve koriste u ovom videu.
Htio bi dodat na Zalman Z9, da malo ljepše kablovinje izgleda. Za sada su samo sakriveni kablovi iza matične. Mogu i okačiti koju sliku ako treba.
Hvala
karlo10 je offline   Reply With Quote
Staro 11.09.2014., 21:00   #5142
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
crvena elektrana od 750w
esc je offline   Reply With Quote
Staro 11.09.2014., 21:13   #5143
ShanTech
Postovi: 3,784
Super si poskrivao kablove, nijedan se ne vidi.
Staro 11.09.2014., 21:21   #5144
esc
Lynnfield
Postovi: 1,023
Autor ShanTech Pregled postova
pa i jesam ni nemože puno bolje za ovakvo kućište
Staro 12.09.2014., 00:33   #5145
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Može.
Campeonato je offline   Reply With Quote
Staro 12.09.2014., 18:39   #5146
robbie
Monster under your bed
Datum registracije: Jan 2010
Postovi: 70
@esc pa kad si se vec tolko potrudio i pobaco para za ssd mogo si dat i jos kojih 20 kn vise i uzet kompletno crno kuciste. dobro speljani kejblovi...
...always look on the bright side of life...
robbie je offline   Reply With Quote
Staro 12.09.2014., 18:51   #5147
esc
Lynnfield
Postovi: 1,023
Autor robbie Pregled postova
našao sam savršeno crno kućište za taj komp ali to je pitanje kad će bit,nema se cajta
ovo će ić
Staro 13.09.2014., 00:12   #5148
robbie
Postovi: 70
solidno kuciste, ne bi trebalo bit problema s kejblovima... osobno mi se ne svida dizajn, djeluje mi plasticno i jeftino. al o ukusima se ne raspravlja.
Staro 13.09.2014., 00:49   #5149
alengrosevic
Postovi: 3,799
nije lose kuciste, imao sam prilike raditi sa njima. U klasi zalmana. Nije lose ali nije niti odlicno. Neka sredina bih rekao. U biti, koliko para toliko muzike...
Staro 13.09.2014., 15:47   #5150
boy005
boy005's Avatar
Postovi: 598
Trenutni Cubitek...
boy005 je offline   Reply With Quote
Staro 13.09.2014., 16:49   #5151
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,597
Autor boy005 Pregled postova
Trenutni Cubitek...
Picikato
Staro 13.09.2014., 18:23   #5152
2 die 4
2 die 4's Avatar
Postovi: 2,289
Lepo naš kako!
RedGreenBlue
Staro 13.09.2014., 18:47   #5153
Strong
Strong's Avatar
Lokacija: Našice
Postovi: 186
Stvarno jako lijepo složeno... :O
Strong je offline   Reply With Quote
Staro 13.09.2014., 22:08   #5154
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
@boy005 - pa daj jos koju sliku.
Staro 13.09.2014., 23:06   #5155
boy005
boy005's Avatar
Postovi: 598
Evo dvije fotke, prije zimske preinake u zlatno/crno kombinaciju sa referentnom grafom, jer ovakve grafe neodgovaraju kucistu...
Staro 14.09.2014., 22:09   #5156
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Autor 2 die 4 Pregled postova
Lepo naš kako!
Majke mi?pa dooobro..
@boy005
Odlično, turbo mi se sviđa taj mali case ! Trenutno slinim na tako nešto, vidjet ćemo dali ću uspjeti tako malo nesto sloziti za male novce. :/
Staro 14.09.2014., 22:29   #5157
DragonSlayer
DragonSlayer's Avatar
Datum registracije: Nov 2012
Postovi: 724
De samo promjeni taj vent, bode oči
Ostatak toliko dobro da bi ostavio kućište otvoreno.
DragonSlayer je offline   Reply With Quote
Staro 14.09.2014., 22:37   #5158
alengrosevic
Postovi: 3,799
Joj kad vidim te noctua ventilatore, padne mi mrak na oči Da su kablovi za napajanje full crni i da je neki drugi vent osim noctua-e, bilo bi savršeno. Odličan posao!
Staro 14.09.2014., 23:04   #5159
2 die 4
2 die 4's Avatar
Postovi: 2,289
Autor Halos Pregled postova
Ću da izađem na televizor?
Autor DragonSlayer Pregled postova
Obojica ste zabrijanovič. Baš paše taj vent, mislim ovako kad se vrti. Totalno je fora kombinacija boja (nijansi)
Još kad ubaci zlatnu boju, to će biti to!
Nemoj mijenjati vent, super je, a i Noctua je!
RedGreenBlue
Staro 14.09.2014., 23:11   #5160
Dottore
Dottore's Avatar
Postovi: 7,736
Meni sviđa kremasta boja.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
