Staro 18.08.2011., 06:27   #481
Postovi: 34,222
Zna li netko neku dobru aplikaciju za otkrivanje WEP-a? Imao sam Penetrate i bila je majka za Thomsone. Nažalost, više je nema na Marketu, a ja sam je izbrisao s mobitela. Router Keygen mi se nije pokazao toliko efikasnim.
Staro 18.08.2011., 10:21   #482
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Pa ima Penetratea po netu koliko hoćeš. Npr.;
http://www.mediafire.com/?md6enm66efjwj97
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 19.08.2011., 20:03   #483
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Dobar Weather replacement
blaa
Staro 19.08.2011., 21:08   #484
Goranbm
Goranbm's Avatar
Postovi: 1,238
Autor hammer_of_thor Pregled postova
Fora, jel dostupno kod nas ili se možda plaća, jer nenalazi mi ga na marketu ?? i jel ima uopće na marketu ??
Goranbm je offline   Reply With Quote
Staro 19.08.2011., 21:17   #485
hammer_of_thor
Postovi: 5,430
Autor Goranbm Pregled postova
Neznam, sad sam na poslu a trenutno nemam data plan na DHD-u pa ne mogu pogledati. Možda se može naći .apk na XDA ili negdje drugdje.
blaa
Staro 22.08.2011., 10:45   #486
simuncan
simuncan's Avatar
Datum registracije: Aug 2011
Postovi: 7
WISEPILOT
...pozdrav!
instalirao sam Wisepilot, i nakon 10 dana mi je javilo , da ako zelim i dalje koristit wisepilot, moram ga kupit
kako zaobic tu kupnju, a da i dalje radi?
e da, mob je x10
hvala
BOLJE BICIKLOM U KURVANJE, NEGO MERCEDESOM NA POSAO
simuncan je offline   Reply With Quote
Staro 22.08.2011., 18:27   #487
Postovi: 34,222
Koliko ja znam, t-mobile je nudio Wisepilot za svoje pretplatnike besplatno, ali samo prve 2g. Vidi malo s njihovom SZK. Ako ne ide, makni ga. Barem za Androida ne fali navigacija.
Staro 22.08.2011., 23:33   #488
Goranbm
Goranbm's Avatar
Postovi: 1,238
Da išao je uz Galaxije isto .....
Staro 23.08.2011., 13:23   #489
danijelch
Datum registracije: May 2009
Postovi: 10
postoji li koja tipkovnica za defy - android kod koje se može razmještat raspored slova po želji. Mislim da bi mi idealan raspored bio da iz qwerty tipkovnice izuzmem slova a,q,w i premjestim ih u novi red iznad. Znači da tipkovnica izgleda otprilike ovako
a q w
e r t y u i o p
s d f g h j k l
z x c v b n m
slova bi mi trebala biti maksimalno razmaknuta
i u gornjem redu poslje w može bit tipka za velika slova i backspace. Nisam nigdje našao ništa slično
danijelch je offline   Reply With Quote
Staro 23.08.2011., 17:05   #490
D.O.M.I.
D.O.M.I.'s Avatar
Datum registracije: Jul 2009
Postovi: 279
kako maknut Wisepilot s HTC Desirea ?
D.O.M.I. je offline   Reply With Quote
Staro 24.08.2011., 00:15   #491
Goranbm
Goranbm's Avatar
Postovi: 1,238
Aplikacije za provjeru stanja računa i sve kaj vam vaš operater nudi Napomena - samo za prepaid korisnike za sad
Bonbon info v1.6 - https://market.android.com/details?id=cro.perger.bonbon
Vip Stanje v1.1 - https://market.android.com/details?id=cro.perger.vip
Moj Tele2 v1.2 - https://market.android.com/details?id=cro.perger.tele
Ako postoji neka tarifa ili opcija a da nije uključena, ponavljam vrijedi samo za prepaid korisnike, slobodno me PM-ajte da popravim
Staro 24.08.2011., 08:07   #492
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,585
Bilo bi dobro kad bi se za uslugu NAZOVI ME (u t2) mogao birati broj iz imenika.. ostatak je supere. Pohvale Gorane
Staro 24.08.2011., 10:33   #493
Goranbm
Goranbm's Avatar
Postovi: 1,238
Hvala ti na pohvalama . A čuj možda bude i jednom moguće Problem je kaj ti ne šalješ na broj iz imenika, nego u poruci taj broj, pa moram malo proučiti kako da se to izvede
Staro 24.08.2011., 10:40   #494
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,696
Iznenađujuće igrivo uz odličnu grafiku i stereo zvuk ako se koriste slušalice.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
LAcy je online   Reply With Quote
Staro 24.08.2011., 21:29   #495
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,257
Goranbm, ajde napravi aplikaciju za Vip Web SMS.. onih 15 poruka sto se dnevno moze poslat..
Uf, to bi mi jako dobro dosli a i smatram da je pizdin dim za napravit
Odgovoran trgovac:1, 2, 3, 4, 5, 6, 7, 8, 9,10
Staro 25.08.2011., 00:50   #496
Goranbm
Goranbm's Avatar
Postovi: 1,238
Trenutno sam u pokušaju izrade web sms-a za bonbon, ukoliko uspijem primjenit ću to i na vip.... Ima dosta posla, a i moje znanje još trenutno možda nije dovoljno, a treba mi i javascript znanje, hehe Kako sam dobio dosta upita za vip i Tele2 aplikaciju za korisnike pretplate, molio bih sve koji su zainteresirani, a korisnici su pretplate na nekoj od tih mreža, da mi pomognu i pošalju na PM, kako se provjerava račun, kako se aktiviraju neki internet ili sms paketi (ukoliko postoje) kako se uključuju/isključuju/mijenjaju opcije i tarife, ukoliko je moguće, pa da sklopim i to u aplikacije za pretplatnike Unaprijed hvala ....
Staro 25.08.2011., 14:49   #497
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Mireo DON'T PANIC
Android update to be released very soon! Expect free, fully- functional trial maps of your country, UI upgrades and bug fixes!
viper je offline   Reply With Quote
Staro 25.08.2011., 15:06   #498
Omerta
Omerta's Avatar
Postovi: 3,257
Staro 25.08.2011., 15:34   #499
viper
super user
viper's Avatar
Postovi: 1,805
Da,dosad nisu ni imali free/trial kartu osim ako se okrljastena mapa sireg centra Zga moze nazvat mapom. Tak da je ovo pozitivna stvar, pogotvo za strance .
P.S. Look forward to friendly pricing of map bundles of West + East Europe and Google Checkout support for In-App buying in DON'T PANIC Android!
Zadnje izmijenjeno od: viper. 26.08.2011. u 16:40.
Staro 27.08.2011., 12:30   #500
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,696
Odlično a besplatno, Elixir 2
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 27.08.2011., 16:47   #501
bozhan
Datum registracije: Jan 2010
Postovi: 28
trebao bi neku aplikaciju koja prati kroz mjesec dana poslane poruke, minute poziva te potroseni internet promet
Prodajem HTC Wildfire - kupujem Omniu 7
bozhan je offline   Reply With Quote
Staro 28.08.2011., 08:30   #502
Postovi: 34,222
Staro 28.08.2011., 10:17   #503
viper
super user
viper's Avatar
Postovi: 1,805
Dal ima kakva aplikacija preko koje se moze promjenit zvuk zvonjave za neke kontakte s tim da svi ostali koji jesu u imeniku i koji nisu ostanu na besumnom/vibraciji?
Staro 28.08.2011., 10:23   #504
Mad_Duke
Ne znam. Nije mi nikad trebalo. Možda da hitiš mp3 sa "snimljenom" tišinom na mob i staviš kao default zvonjavu (iliti vibracija), a posebnim kontaktima odrediš posebnu melodiju?
Staro 28.08.2011., 10:52   #505
viper
super user
viper's Avatar
Postovi: 1,805
Vidis vidis, dobra ideja!! HVALA
Staro 28.08.2011., 16:30   #506
jollyb
4K FTW
jollyb's Avatar
Lokacija: Minken
Postovi: 1,046
Autor bozhan Pregled postova
Droidstats - jedna od meni najdražih i najkorisnijih aplikacija.
jollyb je offline   Reply With Quote
Staro 29.08.2011., 09:54   #507
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 460
zanima me dali postoji app nešto slićno everestu ili aidi64 za komp,tj da vidiš sve komponente moba,temp i tako to?
dart_tom je offline   Reply With Quote
Staro 29.08.2011., 12:12   #508
Omerta
Omerta's Avatar
Postovi: 3,257
Autor dart_tom Pregled postova
Nije bas ni priblizno everestu ali dosta toga pokazuje u detalje, brdo informacija..
Elixir 2
https://market.android.com/details?i...android.elixir
Staro 29.08.2011., 12:19   #509
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 460
Autor Omerta Pregled postova
Elixir 2
evo iskopo sam jedan meni dobar,android system info
Staro 29.08.2011., 12:24   #510
Omerta
Omerta's Avatar
Postovi: 3,257
A pa to je aplikacija koja je obavezna na Androidu.. Nju prvu instaliram kad stavljam sustav, custom rom itd.. Ali nije to baš nešto kao everest, Elixir je puuuuuno detaljniji ali sam ga baš zbog toga i maknuo..
ASI je zakon sto se toga tice..
