Staro 10.12.2013., 13:24   #301
back2quick
Datum registracije: Jan 2012
Lokacija: righthere
Postovi: 441
nemam ni ja, inače bi već pogledao sam
back2quick je offline   Reply With Quote
Staro 10.12.2013., 17:57   #302
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
Upaljeno, ali je problem što mi krenuo recimo sad skidati 500kb/s i onda nakon par minuta brzina drastično padne, tipa 20-60kb/s.
Staro 10.12.2013., 18:13   #303
Prezime
Datum registracije: Aug 2013
Postovi: 4,362
Jel imas sve ovako podeseno u routeru?
Ako imas i ako ti u utorrentu u doljnjem desnom uglu stoji zelena ikona za status veze, onda je to to kaj se portova tice, a onda brzina skidanja ovisi samo do dostupne brzine torrenta.
Staro 10.12.2013., 19:35   #304
monet
Datum registracije: Oct 2013
Postovi: 9
Autor Prezime Pregled postova
SX763 can be used for full package. The only thing that can go wrong is that it will not get all your necessary user data from ACS server, because at present, it is set for your ADB router. In that case, a phone call to their "User Support" will soon get that fixed. You only have to say that you changed your router and that they need to register your SX763 on ACS. After that and rebooting SX763 everything should work, internet, VoIP, and MaxTV.
Btw, I am not sure that ADB will work as a repeater, since you can not get WDS to work...
Hi all
Just in case anyone is interested;
I installed DD-WRT software on the SX763 and set the wireless to Client Bridge (Routed) mode etc. Then I set up a Virtual interface with the wireless as AP. Now I have extended the WiFi of the ADB and the SX763 provides internet on all 4 LAN ports as well as WiFi.
There is info to install DD-WRT on SX763 on this forum and instructions for settings can be found on DD-WRT website.
One word of advice; use a clean install of firefox browser to install software on the SX763 as explorer and chrome browsers might not work properly.
monet je offline   Reply With Quote
Staro 10.12.2013., 20:01   #305
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
Gašenje TR-069
1. logiras se kao administrator
2. odaberes "Advanced Mode"
3. odaberes "Settings"
4. odaberes "Management"
5. odaberes "TR069 Agent"
6. odaberes "Enable TR069: No" i stisnes Apply
može pojašnjenje šta je TR-069?
esc je offline   Reply With Quote
Staro 10.12.2013., 20:07   #306
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
pod external interface imam
ethernet over ATM 0/35 (10.112........)
ethernet over ATM 0/50 (static ipv4 adres not configured)
PPP ethernet over ATM
Staro 10.12.2013., 20:46   #307
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
i dal da u utorrentu upnp i nat-pmp otkacim ili? i sta sa portom? random ili?
Staro 10.12.2013., 20:46   #308
Prezime
Postovi: 4,362
To je sve OK, jer moja slika je skinuta sa routera koji nije spojen na internet, pa ni nema dodijeljene IP adrese...
Bitna je boja one ikonice na dnu utorrenta. Ako je zelena sve ti uredno radi.
Staro 10.12.2013., 20:49   #309
Prezime
Postovi: 4,362
Autor monet Pregled postova
Hi all
Glad that you succeeded
Staro 10.12.2013., 20:54   #310
Prezime
Postovi: 4,362
Autor -POP- Pregled postova
Oznacis (stavis najkicu) na: Enable UPnP port mapping, Enable NAT-PMP port mapping i Add Windows Firewall exception. Ostale opcije u tom dijelu su onda nepotrebne.
Staro 10.12.2013., 20:57   #311
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
šta sa portom? totalni sam njub kad je ovo u pitanje, nakon skoro 10 godina na bnetu i nikakovih problema, nakon selidbe eto problema sa t-comom
Staro 10.12.2013., 21:00   #312
Prezime
Postovi: 4,362
Autor esc Pregled postova
To je (podrska za) protokol pomocu kojeg ti provajder moze automatski konfigurirati postavke tvog routera:
"The integration of TR-069 technologies facilitates the automatic installation and the automatic provisioning of services."
Staro 10.12.2013., 21:03   #313
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
meni lijepo up 10x veći nego down... grrr
Staro 10.12.2013., 21:05   #314
Prezime
Postovi: 4,362
Port ne diras, ne treba ti neki broj; uopce se ne brines o nekom portu. Za to se sad brine UPnP umjesto tebe
Meni od 2005., od prve verzije utorrenta stoji port 64444, ali nikad ga ni jedna verzija utorrenta nije koristila, jer uvjek koristim UPnP.
Staro 10.12.2013., 21:08   #315
Prezime
Postovi: 4,362
Pa daj vec jednom odgovori, koje ti je boje ikona za Network u dnu utorrenta? Mora biti zelena uz natpis Network OK!
Staro 10.12.2013., 21:13   #316
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
je, zelena je
Staro 10.12.2013., 21:17   #317
Prezime
Postovi: 4,362
Onda vise ne cackaj po routeru i utorrentu, jer oni nisu krivci za tvoju nevolju
Staro 10.12.2013., 21:25   #318
esc
Lynnfield
Postovi: 1,023
s obzirom da malo znam/nemam potrebe za nekim konfiguracijama rutera to je onda možda pametno ostavit uključeno? imam jedino isključeno upnp agent u postavkama adb-a,ostalo nisam dirao
jeli taj TR-069 onda vezan za možda novi firmvare?
Staro 10.12.2013., 21:34   #319
Prezime
Postovi: 4,362
Jos nisam cuo da je nekom T-Com mijenja firmware preko ACS-a, pa sam sklon vjerovanju da to ne rade...
TR-069 je prisutan radi postavljanja i brige oko tvojih korisnickih podataka koji su potrebni za rad njihovih servisa. Kad imas TR069 ukljucen, ne trebas brinut o svojim pristupnim podacima za internet, VoIP (IMS), kao ni za postavke bezicne mreze; ako si sve te podatke pohranio na njihovom portalu oni ce u slucaju potrebe uvjek biti automatski ucitani...
Staro 10.12.2013., 21:37   #320
Prezime
Postovi: 4,362
Sad mi je palo ovo na pamet. Jel imas u utorrentnu ogranicen Upload? To vjerojatno nije potrebno na B.Netu, ali na T-Comu je nasusna potreba
Ogranici upload na recimo 20kB/s pa vidi jel ima razlike...
Staro 10.12.2013., 21:40   #321
esc
Lynnfield
Postovi: 1,023
nisam ja ništa pohranio,imao sam sx763 kojeg sam valjda pokvario sa stavljanjem ddwrt-a i onda sam dobio adb
Staro 10.12.2013., 21:45   #322
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
ogranicio upload i skida full brzinom. vidicemo za par minuta
Staro 10.12.2013., 23:00   #323
Prezime
Postovi: 4,362
Ako nisi uopce morao konfigurirat ADB za spajanje na internet, onda je vec SX763 pohranio tvoje podatke. Ako si ADB morao konfigurirat svojim podacima, onda su oni sada pohranjeni (pomocu TR-069) na ACS serveru za buducu upotrebu.
Staro 22.12.2013., 12:23   #324
QS
QS's Avatar
Datum registracije: Mar 2009
Postovi: 284
Jel se meni čini ili je T-Com počeo gurat novi firmweraj na ove svoje ADBove?
Firmware Version:PRGA4202N_HTC_2.1.1.0009 - main <<< nisu mijenjali verziju? možda neke postavke?
Šta je novo? Ništa, osim što sada internet lampica svijetli zeleno kad je modem u bridge modu... Jel netko zna više?
QS je offline   Reply With Quote
Staro 22.12.2013., 15:19   #325
Prezime
Postovi: 4,362
Koliko znam, oni ni ne mijenjaju cijeli firmware, nego samo korisnicke postavke i podesavanja...
Ovo je verzija iz prvih koje su dijelili, pa usporedi:
Firmware Version: PRGA4202N_HTC_2.1.1.0009 - main
Platform Version: 2.1.0.0041
Hardware Version: BCM6362
Staro 30.12.2013., 03:17   #326
baTman
Lokacija: asfsafsa
Postovi: 327
i jeli netko napokon saznao kojom magijom se dava visi net prioritet jednom ethernet portu ili lan adresi?
baTman je offline   Reply With Quote
Staro 04.01.2014., 14:24   #327
Tihomir111
ZeNgE_Tiho_Cro
Tihomir111's Avatar
Lokacija: Virovitica
Postovi: 466
pozz
kako pristupit uređaju na 192.168.1.5, imao sam hrpu rutera, sve radilo bez problema, ovaj ne pušta. Radi se o satelitskom reciveru. Hvala
Tihomir111 je offline   Reply With Quote
Staro 04.01.2014., 15:44   #328
Prezime
Postovi: 4,362
Jel ti prolazi ping do receivera na 192.168.1.5?
Staro 05.01.2014., 14:40   #329
Tihomir111
ZeNgE_Tiho_Cro
Tihomir111's Avatar
Postovi: 466
nisam probao, stvarno nemam vise zivaca za taj uređaj, nit pušta dyndns na sebe nit ovo s recom.
Stavio sam stariji sx763 s open wrt, bio je na optimi pa ga prebacio na anex b.
Milina
Zadnje izmijenjeno od: Nikky. 05.01.2014. u 16:54.
Staro 05.01.2014., 17:21   #330
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,132
Dobih taj router i imam jedan problem.
Do sad sam imao 2x SX763, jedan preko kojeg je išao net/ims i drugi (sa OpenWRT) koji glumi AP.
Problem je u tome kaj SX763 sa OpenWRT-om gubi komunikaciju između sebe i ovog crnog španjolskog smeća. Postavio sam SSID, vrstu šifre, kanal (11) i WiFi radi u radijusu ADB-a.
SX763 sam flashnuo sa novijim OpenWRT buildom, instalirao relayd, blablabla... Uglavnom, spojio se na ADB i proradio je. Nakon nekoliko sati (može biti 2 sata a može i 22 sata) Open763 više ne komunicira sa ADB-om. Reboot ADB-a je jedina stvar koja pomaže.
Što bi mogao biti problem?
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
