Staro 13.01.2004., 13:49   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Driver Cleaner 2.7
Kaj je novo:
Improved:
- Some small code changes
- ATI cleaning file
Added:
- 3Dfx cleaning file beta
- SIS Graphics cleaning file beta
- Polish language file
Read the Readme.
IMPORTANT: uninstall the older version first before you install this version.
For uninstalling nVidia drivers i recommend putting the backup functions on. If something goes wrong you can restore it. Also if you get an error with installing new drivers, please send me the directories in the backup folder, so i can check and locate the problem than. Or mail me if you want to ask more how to send it, but don't use the restore before you sended it.
It is for nVidia, ATI, Creative, Turtle Beach, SIS Graphics and 3Dfx. It will remove anything that is left by the drivers after uninstall.
Skidanje:
http://www.driverheaven.net/cleaner/...C2Setup_27.zip
Staro 13.01.2004., 23:27   #2
miato
(°_°)
miato's Avatar
Postovi: 3,249
nice
Staro 13.01.2004., 23:42   #3
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
kao novi fanATIc slijepo prvo metnul catalyst drivere i nisam mogao klokat katricu zatim sam se sjetil da je jel neke pisal o tome i voala!!!
omega driveri rulaju..
TNX!!!!!!! Jelc!!
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 14.01.2004., 00:12   #4
Jelc
Super Moderators
Postovi: 17,485
TNX!!!!!!! Jelc!!
Sa Omegom imaš najmanje problema-a dobiješ i set korisnih alata.
Šteta kaj je morao izbaciti RadClocker ali ga se može slkinuti sa neta.
Ja sam još na 3.9 Omega
Staro 14.01.2004., 00:43   #5
Bl@de
Bl@de's Avatar
Postovi: 2,004
Ja sam skinul ove Radeon Omega Drivers v2.5.04su ti dobri.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
